1.Leather seats seem flimsy.
2. Platinum colored surface material on steeering wheel has worn off to reveal balck plastic where my thumb makes contact with it. (really bugs me).
3. Hatch for tools at back keeps falling off.
4. Sometimes can't hear turnsignal click - I leave them on like an octogenarian.
5. No easy way to retrive item that falls between driver's seat and console.
6. Telephone holder does not stay in the angled position - falls to near horizontal position.
7. No wheelcovers available for winter wheels (steel rims and snow tires).
8. Position of interior light switch low on dash near driver's door results in it being bumpted by knee sometimes. It should be higher or recessed.
In addition to wanting to see these annoying items fixed I would welcome;
9. Curtain airbags
10. Turn signal lights on side mirrors
11. Standard fog lights
12. Bigger cup holders
13. Easier headrest arrangement for 3rd row seat
12. Ceiling receptacle for a second pair of sunglasses.
I'm glad you are happy with your choice. You've also reinforced my satisfaction with my own. Happy driving!
well, in any case, we actually almost bought the Trailblazer EXT (the Yukon/Suburban is WAY larger and not in the same class as the Pilot). But then we happened upon and test drove the Pilot. The difference was just so astounding that there was no doubt in our minds that the Pilot was the vehicle for us.
glad you are happy with your vehicle and stopped by a Pilot board to share the news!
One reason I posted my comments, rather than trying to make anyone feel bad or start a war, was that a similar comment in one of these forums led me to check out the 8-passenger Sienna which we also almost bought.
There are many solutions out there and many different needs. Maybe someone else searching herein will consider another option that just might also turn out better for them, due to a seemingly out of place posting.
As always, enjoy your choice and peace to all. :-)
Haha.
I'm in the process of creating DVD+R's from my camcorder and would like assurance that they can be played when finished.
What troubles me is the service dept. seems unaware or not truthful with problems related to the leather. Are there any TSB out there that address these two issues to assist the dealer in correcting the problems.
Thanks for your help
I have seen many complaints about this and I keep checking our pillar and I see no nicks. All I can assume is that it has to do with how different folks remove their seatbelts. Apparently, both my wife and I remove it in a fashion that prevents nicks.
EDIT - oh, wait, ya know, I just remembered a particular post I read. The owner stated that, upon inspecting the inserted part of the seatbelt buckle, he found that the molded joint actually had a sharp edge to it. So he took an exacto knife and shaved it down smoothe. This has helped his particular situation. So you might want to take a look at that.
Maybe A/C system? or a faulty speaker? has anyone else heard this?
Granted, they could no make that pillar material a bit tougher but if it were my Pilot I would just not allow them to snap back into position just like I do now on my cars.
as far as whether you should get it or not is personal preference. I want to get it for ours mainly due to the transmission problems in the past with the accords and oddyseys. This supposedly has been fixed, but I don't want to take any chances. Plus, as far as I know, AWD is a fairly new thing for HOnda, so I don't want to be a guiney pig for that, either. Maybe I'm wrong, but, like I said, its all personal preference. I'd rather spend the $9xx now for peace of mind.
coating applications are crap. you can buy a can of scotch guard and a good waxing product for $20 or so and get the same results (cause that is all that they do as far as I know).
I need advice. please HELP
I have been a lurker in the past and received so much information from this board that I wanted to return the favor
Sue
P.S. Now I have to go out and check my seatbeat pillar.
So you claim you had a leak at the transmission "bolt". Is that the drain or fill plug or some other miscellaneous bolt?
Then you claim another dealer has replaced your transmission 2x for the same leak? That means you have had three Pilot transmissions with the same exact leak!
Sounds like a pretty outrageous claim on your part.
Can you offer a better description than "bolt".
My wifes Pilot is about 7 months old with 15k miles of her and the kids use (abuse?). The leather seats are perfect. I hit them once every other month or so with Lexol which so far has them looking perfect.
The nicks in the plastic by the seat belt openings is outrageous. That plastic must be way too soft for that applciation. My wife does not abuse it, but it is spring loaded (the seat belt) and she has a ton of nicks in the plastic.
Clearly, IMO, Honda cut corners to get this in at $30k. If you want perfection spend $8k more for the Acura.... I wish I could have, but the Pilot made perfect sense.
Despite it's few imperfections, for the dollars spent, a Pilot is hard to beat!
Could not resist!
I will take sagging leather and an early morning "clunk" backing down the driveway over a behemoth 14 MPG, sagging headliner, rear drum brake until 2001, Urban Assault Vehicle - ANY DAY.
FWIW, an associate of mine had a Blazer, Suburban and now a Escalade all in the same period that I had an Isuzu Trooper! We pegged twice the miles on the Trooper and it was waaaaay better off when we traded it on the Pilot than when he returned the Suburban off its lease....
#470 of 496 pilotpilot by dako_tian Jan 23, 2004 (4:07 pm)
Instead of the Pilot we were considering, we bought an 8-passenger GMC Yukon XL SLE. We got a leftover 2003 last November and only had to pay a little under $31,000 for it. It is true that my gas mileage is probably worse than yours (14.9 mpg mixed driving). Though I did not want and did not get leather seating surfaces we have none of your complaints. In addition, we got cargo room for the luggage that the 8 seats will generate when occupied on vacation, standard fog lights, bigger cup holders, a Bose stereo (with 3 distinct variations of volume self adjustment to compensate for speed), and a much quieter interior noise level than our former 1999 F-150 Supercab.
Just got the '04 Pilot yesterday.
When I first looked at one, I tried a homemade movie that was a DVDR-, and it played fine.
didn't think to try a CD-R or plus version DVD.
got home and tried and neither works.
It makes a buzzing noise and reads ERR on the display.
Does any know about this?
The same CD-R plays fine in the CD player.
Any body else with similar experience?
Of course, drive very carefully (with 4-way-flashers on, if those work) to the dealer since your brake lights are not working.
Other than thaqt i have only had some very minor nits. i.e. the driver side windsheild washer nozzle sometimes leaks without using them.
I have driven my car in Death Valley and on the dirt roads around Southern Calfironia. Works great to me.
One thing though is I take my Pilot to Acura for the major services since Honda dealers around here seem to nickel and dime you for certain things that are supposed to be done. Acura does everything for one price with no extras....
Eric the Desert Rat
Every time I come down from a hillside, the breaks will make this humming noise and then a vibration noise at the very end of the break when I'm driving on flat road. The noise will go away when I stop, turn the engine off, then restart and then the break will behave normal again. I took it to the dealer and they found no problem with the breaks. Somebody please help me with this problem.
I was a little too upset about the situation and forgot where my head was. Sorry about the SP error. I still hope somebody can enlighten me if they have had a similar problem.
If the readers on this board can go out and test their Pilots and let me know, I would appreciate it.
Another driver rear-ended my 04 Pilot on Highway today. There is damage to hatch door and bumper I would have to get fixed. Luckily we did not have injuries.
Let me know. Thank you
I just purchased my 2004 Pilot 3 days ago. I have not had a chance to look at the door pillar plastic for chips, but did notice that after having an adult enter and exit for seating in the third row that the door sill plate is severly scratched. This bothered me, as it should be a tough enought material to endure use since it is on the door sill. Oh well, I guess it is not a new car anymore.
