Honda Odyssey Transmission Problems
11112131416
    Well, Steve...
    We are about the same age, it would seem. Back in 1968, I had to have the Powerglide overhauled in my 1962 Impala SS. I remember the car had around 60,000 miles on it at the time so it was pretty normal.
    I wasn't happy about having to spend a whopping 200.00 at the time but I sure wasn't upset either.
    Shortly afterwards, it needed a valve job...remember those? Again, to be expected.
    I'm not sure exactly what they did but you can be assured the last thing they need or want is anymore bad press.
  • grandtotalgrandtotal Member Posts: 1,207
    Unfortunately I don't think we have heard the end of transmission problems on Odysseys. They may have fixed the 2nd gear lubrication but that is only one of several failure mechanisms that occur repeatedly, at least on these and other forums. I will concede that the failure rate is low but I doubt they have done anything to reduce it.
  • robevtsrobevts Member Posts: 22
    Based on my prior good experience with Honda reliability, my expectation when we got our 2003 Ody, is that is that nothing major should go wrong with the drivetrain, providing of course they are well maintained, for close to 200k. This is not unreasonable when you consider that the main reason most of choose Japanese designed vehicles, over USA made is for their reputation for making reliable vehicles. Getting a bad reliability rep for Honda will be disatrous for them, so it will be interesting to see what transpires over the next couple of years. Again, I have to wonder after reading these posts, complaining about their trannys, if they are representative of a the supposed 2% failure rate, or is there really a more broad problem. I wish someone could share something imperical in the way of data. No dings yet from Consumer Reports I am aware of, my friends with Odys and Pilots are not reporting any problems AT ALL, mine has 15k with none, but I don't want to have to cross my fingers any tighter than I have too!
  • just4fun2just4fun2 Member Posts: 461
    I also believe that the "Modern" transmission should be able to achieve 150k without much more than the recommended fluid/filter change. The vehicles of today are computer designed and built and the engine/transmission combination should be matched with the vehicle that it is being used in.
    Now, for the Powerglide...it was a "two" speed transmission, low and hi gear and nothing else. I can remember Chevy's "409" engine could be had with a Powerglide, remember the 60's muscle car days? Rust was the enemy of my cars back then, not the transmission.
    So, in the 1960's a transmissions life was considered normal at 60k, now "zoom" forward 50 years and look at what the Ody transmission is doing. According to some here, 60k on their Ody would be the norm.
    Question? If the Ody is 4300lbs, does it come with a transmission cooler as standard equipment?
  • anonymouspostsanonymousposts Member Posts: 3,802
    Some people don't want to give Honda ANY credit even though they have extended the warranty on affected transmissions and in some cases even repair then trannys outside of that extended warranty period. If you do a google search lots of pages regarding Chrysler transmission problems will pop-up yet I am unaware of Chrysler ever extending their warranty because of tranny failures.
    I don't think the Ody has a standard transmission cooler. I know when we leased ours back in May the dealer and the Ody brochure both stated that to reach maximum tow capacity you were required to buy the transmission oil cooler or your warranty would be voided if you towed anything with the Odyssey.
  • imidazol97imidazol97 Member Posts: 27,734
    All extending the warranty does it insure that soon after 100K you will be replacing the transmission Honda should have built right in the first place. Even the replacements aren't long life units.
    The lifetime of the car warranty would get my attention that they were serious about quality.
    Why would you doubt they have fixed things?
    As far as I'm concerned, a 2% failure rate is too high but I guess on other makes it may be acceptable. People have come to expect a lot from their Hondas and that's a good thing.
    No manufacturer will give you a lifetime warranty on the transmission. Toyota Camry owners who are having their transmissions replaced are not receiving a lifetime warranty on the transmission so why would Odyssey owners? As the mileage gets higher maintenance becomes less and less of a priority. Personally I think it would be murder for ANY manufacturer to give a lifetime transmission warranty. The cost would far outweight the benefit I am sure.
    Most people trade the van before 150K. So a lifetime warranty would insure the resale value for those trading at, oh say 99K. Would you buy a product after hearing people here talk about their 3rd transmission (or was it 4th) before 100k. Think that transmission replacement unit was fixed compared to the original???
    I wouldn't buy a used Ody with 90K on it. Too likely to have a failure.
    Perhaps warranty up to 150K would be more practical. That's on cars that people perceive as 200K-200K automobiles before real problems need attention. Or has that tenet gone the wayside.
    Never knew anyone who had to have a Powerglide replaced in my youth, other than one neighbor who thought you could Reverse-Forward your way out of being stuck in a snowdrift and tore it up with quick shifting...
    Don't remember trans fluid changes being a requirement then either. Now I change mine ever 36K or 2 years.
    I agree that 150K is an expected mileage before a failure for transmissions with some fluid/filter maintenance on a modern car. No maintenance done; expect earlier failure.
    I don't doubt that they have fixed the 2nd gear lubrication issue. However this particular issue had affected only a few tens of vehicles (Honda's own figures) so far even though it has the potential to affect many more if left un-repaired. What I was referring to is the many more reported failures of 2002+ transmissions in ways that are not related to this 2nd gear lubrication problem. Believe me, I like Honda products, I own an Odyssey, but I do not believe that they have addressed the transmission issues, or at least if they have they are keeping quiet so that they are not obliged to recall vehicles for transmission replacement on a massive scale for problems which will likely only affect a small percentage of owners.
    Warrantuy costs and customer unhappiness isn't something they want!
    This 2% transmission failure figure, is that figure from Honda? Does Honda open up their warranty records for public inspection? Who is keeping count of the transmissions that have been replaced?
    Honda opened up this can of worms by admitting there could be a problem with their transmissions lack of lube, so they extended the warrenty. Now, if you go 150k and your transmission fails because of this lack of 2nd gear lube, the customer is going to feel that they have been cheated. If Honda didn't have this problem and the customer transmission failed at the same 150k, the customer will probably look at this situation differently.
    Warranty the transmission for life of the vehicle if the failure is caused by a Honda design flaw.
    It is nice of Honda to extend the warranty to 100k, but the vehicle should never ever need a second transmission within the 100k warranty and that is what some people have reported here.
    Simple!
    My point is that other companies that also have customers experiencing transmission failures before the 100,000 mile mark are not extending their warranty nor, in most cases, will they help with the bill once the car is outside the base warranty period.
  • lil302000lil302000 Member Posts: 149
    I have to agree with you once the warranty is over you are on your own SOL so to speak. The only reason I don't buy Honda is because I don't care for the sheet metal, ride or the looks of most interiors. These are all personal reasons but still my reasons. I do feel they turn out a good product as far as reliability I just don't care for the looks and feel. We must remember that these machines are complicated and we run the risk of problems with all of them. But with competition they will all improve and we will all benefit.
  • gregoryc1gregoryc1 Member Posts: 764
    With proper documented maintenance, I think that an automatic transmission should last at least 100,000 miles. I had an automatic trans. in a 1977 Ford Granada that lasted 90,000 miles. I had it rebuilt by a Ford dealer, and it failed again at 180,000 miles. (Same problem, no reverse). The 302 V8 was still running.
    for all the failures, what is the distribution of the root cause(s)? certainly, they are not all 2nd gear lube related, are they?
    my expectation is that the transmission should last as long as the engine when it is regularly maintained like the engine is maintained.
    100K? No. 150K? No. 200 to 250K? Yes.
    and my expectation is that replacements or wear items related to the transmission should be serviceable and of a cost which doesn't approach anywhere near 1/4-1/5th the total cost of the vehicle (i'm talking about an LX for those that care). For those of you buying LUX trims, your ratio will vary. ;)
    We would have liked to have purchased an LX ODY with a manual transmission! We thought the transmissions issues were a thing of the past when they went to the 5-speed A/T.
    Normal Service Life is probably whatever a manufacturer would warranty it for, or whatever an insurance company would back it up for on extended warranty.
    I'm not aware of any factory warranty or extended warranty past 100K, so I would accept the expert opinion of the factory engineers and the statistical wizards of insurance companies and say that 100K is indeed a normal service life.
    "Normal" after all, implies the bulk of the results...you'll have some quitting sooner and some going longer.
    Put it this way: Would you pay any serious money for a USED automatic transmission with over 100K on it? I sure wouldn't.
    Under most circumstances 100k is probably a reasonable warranty benchmark, particularly considering the manufacturer has no control over driving habits, etc.. Again however, based on my personal experience and perception about Honda reliablility, I have the expectation that nothing major should go wrong with a well maintained drivetrain on any Honda vehicle for 200k. I don't have the stats to prove it, but would wager that overall auto trans failures for all Honda vehicles are well above 100k. If Honda can not maintain this standard for all of their vehicles then they will drive loyal customers like me away. Additionally, if the current transmission failures are attributable to a design flaw, then it would be prudent and wise for Honda to go beyond 100k.
  • mayofamily1mayofamily1 Member Posts: 3
    I had the same problem. I had 118,000 miles on our Odyssey. I took it around to several other places to get estimates before I took it to Honda Dealership.
    I called Honda North american to complain that transmission problems occuring at 118,000 is entirely too early... expecially for a Honda. Come on.. I thought they were supposed to last. Honda North american did acknowledged that they had a recall on defective transmission on 99 - 2004 Odysseys. Here's where it got interesting.
    1)They told me the recall was about delayed shifting .. and not just with the Torque Converter.
    2) Howver, they told me if I was under 100K they would still fix it.
    3) since i was over 100k, they said that I could apply for assistance and they would pay a percentage or all of it .. perhaps.
    4) I just took it to a dealership and they are going to:
    a) charge me the warrantee price to put in a new transmission 2200 bucks, but Honda would pay 25% of cost.
    5) We plan on getting it fixed and retaining our paperwork and doing further research and possibly getting an attorney to have them reinburse us for our portion.
    6) I talked to an attorney and he said defects in cars have no statute of limitation, so Honda should fix transmission regardless of milage as long as we can prove that the defective part is whats on the recall list.
    www.honda.com
    u want to call honda north american in calf
    What kind of symptoms where u having? Gear slippage etc. i have a 99 and the check engine lite came on at 118K. I need a new transmission and honda said they would give me a new one at a cost of 1600 (labor and parts).
  • marks3marks3 Member Posts: 6
    Hi Lisa,
    You seem to have already gone through a situation that I feel I'm entering now. Just turned 50K miles on my 2000 LX and I've noticed a definite shifting problem ( slow or delayed shift ) from 1st to 2nd gear. I've also been to the local Honda dealer twice. The first trip ended in a $85 diagnostic charge with a "NPF" outcome. A short time later, another trip to the dealer and a test drive with the lead Technician and Service Manager resulted in a "that's normal" answer, as the transmission stayed in 1st gear until 3500rpm's, shifted up with a lurch, under very gentle acceleration. They even let me drive one of their Courtesy Shuttles to compare the two and it did the same thing!
    I don't understand why Honda, who has already acknowledged problems exist, is doing very litle to correct it.
    If I call American Honda, they'll more than likely tell me to take it up with the local dealer, which, at this point, seems to be a loosing battle ...
  • pepsicopepsico Member Posts: 5
    Replaced transmission 2 weeks ago, and have been back to service department twice to try and stop fluid leak. No luck as of yet. Anyone having transmission fluid leak after replacement.
    I happen to have a 2000LX that just turned 50K but I'm sure the transmission is the same. When you say "went out", could you be a little more specific? What were some of the events leading up to the problem and replacement ? Did you get a flashing "D4" indicator on your dash, or did you notice any change in shifting patterns, leaks, noises ... etc ?
    I've started noticing a delayed shift from 1st to 2nd gear. All the time ... not just when cold as the owners manual indicates.
    Tks
    Having already owned a 1997 Grand Caravan, I'm afraid to say you may have very well gone from the "frying pan into the fire" with the GC. I had one for 3 years before I purchased the Odyssey in 2000. Except for the delayed 1 - 2 shift that I'm dealing with right now, the Odyssey has been "bulletproof"...
    Good Luck with your GC ...
  • masterpaul1masterpaul1 Member Posts: 421
    Speak for yourself. We own a 2001 GC and it has been very reliable. We have a little over 50K on it. We bought it used in September 2003 with 37K. We have had no transmission problems. The only problems that we have had was both front power window regulators needed to be replaced shortly after purchase (which was covered under warranty), needed a new battery and new gas cap. Total spent was about $300. I will tell you this though, I would not buy a GC or TC before 2001 for those year vechicles I don't feel are reliable.
    That may very well be. But, as I indicated, my experience was with a 1997 GC, which, for the 3 years I owned it, before I purchased the Ody in 2000, pretty much lived at the dealership having work done on it ! I have no doubt that Chrysler quality control has improved since then.
  • macakavamacakava Member Posts: 775
    I bought a new 2004 Ody EX in August and was concerned about the transmission problems discussed on this chat room. Great price and value at $3000 off MSRP!
    I called Honda USA about my concern and was told that my vehicle had newer transmission with the fix already in place. I was told that all 2004 Odys built in 2004 had the newer tranny with the fix in place. However any 2004 Odys built in 2003 need to have the fix added to the tranny.
    Since my 2004 Ody was built in June or July of 2004, I am feeing more confident in the long term durability of it.
    Previously I owned a 1996 Windstar and it had so many problems(including transmission and finally a knocking engine) that I was glad to get rid of it for the Ody. This new Ody drives like a great handling car and I can see why Car & Driver chose it to be the winner over the new 2004 Sienna design, the Quest, with the Grand Caravan and Freestar an embarrassing last place.
  • aspesisteveaspesisteve Member Posts: 833
    I know this is the 'complain about your tranny thread', and there are some really bad stories out there, but for some to conclude a tranny should be warranteed for the life of the car??
    Thankfully I am not a car salesman, because I would walk you out the door and laugh out loud.
    Please tell me a car, household appliance, bicycle, lawn mower, airplane....that says they will give you a lifetime warranty and I will show you a company that is out of business before you can call them for your free service.
    I would agree with that. With proper maintenance and care, I believe any transmission can be good for 150K+ miles. Constant stop and go driving, towing, environment, neutral drops, etc., will more than likely cause transmission problems to surface earlier than highway driving. Although this isn't always the case.
    When did Sears go out of business? Craftsman tools (lifetime warranty) comes to mind!
    I get it! Sears might go out of business replacing all of the Craftsman tools that the Honda Ody mechanics wear out replacing the transmissions.
  • stickguystickguy Member Posts: 53,882
    It basically just proves how unlikely it is for an item made of steel with no moving parts to wear out. Not to mention cheap to replace.
    The real scary thing is how expensive a tranny is these days. How can it cost 5K for a reman tranny, when you can buy a brand new LX for 25K MSRP?
    As a former manager for Sears and after spending many years in the tool business I can tell you there is NO COMPARISION between a wrench and a complex automatic transmission!
    Your analogy is so far off base it's hilarous.
    If you read post 813 the person wants someone to show him/her a company that give a "lifetime" warranty on their product. Now, I believe the poster mentions "household" appliance as an example of a company. Was he talking about a toaster or a dishwasher, there is a difference? I gave the example of a lifetime warranty, ask A. J. Foyt.
    Now, I was not comparing the Honda Ody to the Craftsman tools, one has a proven track record of making "Quality" products for its customers and is willing to stand behind their products.
    Show us Honda's service records that state what you are saying about the 2% transmission failure rate. I have yet to see Honda's repair records, have you? Will they share them with the people at Edmunds?
    Again, I am not "anti" Honda, I just don't like to see people lead astray by comments like....Relax, it won't happen to you!
    For the people that paid MSRP or more this is little comfort.
    I'll end our interchange. You seem bent on stirring the pot and tryint to cause readers here undue fear and concern.
    I'm not the one who stated the 2% number. I've read that number several times in these forums.
    I won't argue with combative people.
    Sorry if your pride got hurt, it was not my goal to make someone unhappy. I am not stiring any pot, I believe it is at full boil enough with the people that are having trouble with their Honda's. What good would this forum be if people didn't have different views?
    And you didn't make me "unhappy".
    You just don't seem to be able to discuss things from a open, rational standpoint and that's where you lost me.
    It must have been the tone in the wording of your msg. that I didn't understand. That is sometimes the problem when you can not hear the words being said and feel the real meaning of the person in question.
    Hope this finds you well.
  • hansiennahansienna Member Posts: 2,312
    VERY Funny post about Sears going out of business because they are replacing all the Craftsman tools used by Ody mechanics replacing all the transmissions.
         A little humor is always good....and YES, if I were to buy a new minivan, the 2005 Ody LX or EX would be my first choice.
    It was written with humor and not ment to make people unhappy. Glad you could enjoy it, some people just can't take a joke.
    Maybe the 2005 Ody will have a better track record when it comes to the transmission issue.
    You won't find many professional mechanics using Craftsman tools!
  • steelengsteeleng Member Posts: 71
    That has more to do with the fact that Craftsman tools are not sold off the back of a truck that makes regular visits to the mechanic's shop. That and Craftsman tools don't come with a calendar full of scantily clad women;)
    I laughed at the humor about Odyssey transmission replacements BUT the reported Ody transmission failures don't scare me any more than the old wives tales (originating in CR ?) about Chrysler minivan transmission problems scared me.
         Chrysler minivan transmissions have been VERY reliable since 2001 and I am quite confident that Honda has fixed the Odyssey transmission problems.
  • johnnyrfjohnnyrf Member Posts: 65
    I had my 2nd tranny replaced on a 99 Ody at 80K miles. At 82K miles, tranny fluid was leaking. It turned out to be leaking from a pressure switch on the top of the tranny housing.
    Well, my Ody is back in the shop again today. I t isleaking fluid again. I will let you know what the diagnosis is when I get it. I will be calling Amercian Honda and I will be demanding a high trade value for this vehicle as I am sick and tired of bringing it in for service.
    Has Consumer Reports editors ever read postings in Edmund's Town Hall or do they cling to old wives tales about Honda vehicles having NO problems and Chrysler vehicle transmissions going out all the time?
         Based on reading Edmund's Town Hall for some time and many years of reading CR, I find the credibility of data found in Edmunds to be much higher than the biased information contained in CR.
         I have more confidence in the reliability of my 2002 Chrysler T&C LX transmission than I would have with a 2002 Honda Odyssey transmission.
  • badgerfanbadgerfan Member Posts: 1,565
    Why, after having such transmission issues you want to trade it in to Honda and get another Honda doesn't make sense to me. I would be headed to Dodge, Chrysler, or Toyota for my next minivan. I don't understand the loyalty.
    Maybe he realizes there is no such things as a perfect van and all manufacturers have had their fair share of problems with the competing cars in this class.
  • aab4aab4 Member Posts: 39
    Odyssey is the platform for all three vehicles, and their is widespread failure across the MDX, Pilot, and Odyssey.
    Most of my research reveals around 100K miles, which led to recalls for all three brands.
    Transmissions are a very costly item, and they should last more than 100K miles.
    Funny how this wasn't widely reported and at first denied by Honda???
    And now people are paying above MSRP for new Odyssey. Come on stop drinking the "Honda Kool Aid"
