Volkswagen Passat Maintenance and Repair
j0eb0b1
Member Posts: 6
For all the glowing press the VW Passat has gotten since introduction, I have been less then pleased with a number of aspects of the car, and particuarily with the parent company, VW America.
Mine is a 1999 GLS V6 5 speed.
Item 1: The interior carpet mats wore out within the first two years of ownership. Not a big deal, but doesn't compare well with Japanese (Honda) durability.
Item 2: The Passat has great brakes. Trouble is that the brake rotors wear out at the same rate as the brake linings. Be prepared to spend more than $1,000 dollars to put new pads on your car each time you need brakes. (VW America considers this "Normal"). I've never owned car with rotors that can not be turned, even once.
Item 3: The head liner in my car delaminated from the rubber door molding and fell in my lap. $187 to replace. VW Americas response is due the the age and mileage of the car (3.5 years and 51,000 miles) this is a "Normal" occurence.
The Passat is a great car to drive and I really like mine. But don't be fooled. For $25,000 dollars you are getting the same type of build quality they you will in a comparable domestic car. VW will call you once a week during the warranty period to ask if everything is all right but they do not stand behind their product once it is over. You are not paying for a BMW or Mercedes and you are not getting one.
Joe
Joe
I hope you are right that the problems I have highlighted are not across the board with the Passat model. As I said, I really like the car and maybe it is just my particular unit. I will be curious to see whether there are coments, particularly on the brakes. It is my belief that the brake problem with thin rotors that need to be replaced with each set of pads is across the board among all VW products. To me, replacing the brake rotors at 45,000 miles is a premature failure.
VW may have made many changes in the current Passat model and I hope those who bought them are satisfied. It is my experience, however, that VW America does not stand behind their product after the warranty has expired even in cases of obvious manufacturing defects. Let the buyer beware!
but on the warranty issue, what companies routinely stand by their product by paying for repairs after the warranty expired? i've heard anecdotal stories of where a person here and a person there had something repaired post-warranty free of charge and that includes a couple of VW stories, but if it's out of warranty the manufacturer doesn't have to pay. In the case of "obvious manufacturing defects" that's what the warranty is for.
For pre-2002 passats I would say the things buyers should beware of is that the 10yr power train warranty is non-transferable. That to me is more a show of their inability to stand by their product, but they have corrected that policy.
On the question of what manufacturer would provide out of warranty support, in my experience Honda has. Its all about the corporate comittment to quality.
To VW's credit, they covered the cost of repairs for three years, till the last one (where they split the difference due to the "age" of the vehicle). I don't know if many other manufacturers would have done that - certainly not any American brands.
Outside of that, the Jetta only had the common O2 sensor failure, and an alternator go out at 3 years. It has been a good, reliable car for my and my wife (except for the @#(*%&@^&! windows).
VW has finally adressed some of the window issues with a redesigned part, but I continue to hear horror stories with the current generation of Bettle/Golf/Jetta lines - from electrical to other knick-knacks.
Only the Passat is considered the most dependable of the VW lineup, and that's mostly due to the 2001.5 tweaks.
I'm not sure if VW can afford to have the same reliability as American & Chrysler cars (not American), but at least they have demonstrated to me their desire to stand behind their product - and I have to give them kudos on that one.
As for your troubles, I can tell you that quite a number of cars will not allow the rotors to be turned IF they become warped or damaged. Mercedes for instance. This you can blame mostly on litigation practices in the US.
As for overall VW build quality, I agree, it is pretty 'average'.
I'm wondering though why you'd have to pay $1,000 for rotor and pad replacement. This seems outrageous. VW rotors are pretty cheap to buy new, that's the whole idea. I get my Benz rotors for $29 apiece and they are good ones, too.
I don't know where you get your brake rotors but it is not from a VW dealer (or a Benz dealer either, I suspect).
My dealer, Springfield VW in Springfield, Virginia, charges $125.96 for each Passat rotor. Brake pads are another $98.50 a set. Front replacement costs $490. Back replacement has been estimated (not yet performed) at $550. I suspect the cost difference on the rear is for the shoes associated with the emergency brake.
You are very right that most Passat owners seem happy and as I stated, I really like the car. Its just that I've never owned a car that needed $1,000 in routine brake work before 50,000 miles and if not a design flaw, it is certainly not a feature of the Passat product.
you can always check vwvortex or clubb5 for independent shop recommendations.
Or buy from the internet.
For OEM parts for example (http://www.vwparts.com):
Front pads: $58.14
Front rotors: $45.59 (each)
Rear pads: $41.16
Rear rotors: $44.00 (each)
DIY or go to a independent shop.
So that it doesn't look like I'm going solely on rumors, JD Power initial quality for VW is not all that great. Whazzzup?
Finally in May I pulled the trigger and got a Passat wagon. 6700 miles later I have no compliants--nothing electrical, no windows falling out, etc. Will I be writing a post 11 years from now talking about my 02 Passat that just won't die? Who knows, but it's been so much fun to drive I may give it more benefit of the doubt than my Camry (which has with the current model *IMHO* became "cosmetically challenged", while the Passat has become beautiful with the '98 style changes).
Guess it boils down to how important the driving experience is to you. If it's a high priority, you may decide as I did that it's worth the risk.
You also get longer roadside assistance.
I have a 2001.5 Passat GLS w/Tip which I have owned for around 16 months now and I don't have a single complaint. I drives great and I have had no rattles or squeaks (at least not from the car, the kids in the back seat make a fair amount of noise though).
And while I am mentioning problems, the rubber/cloth band around the door opening came unglued in my car too. Bought some epoxy and fixed it much cheaper than the dealer.
1) Two oil pans replaced (NYC potholes/construction)
2) Rear window failed three times (fixed after 3)
3) Replaced engine mounts number of times
4) Replaced boot?? whatever that thing is by the tire twice
5) Catalytic Converter died at 78,000 miles (just made the 80,000 warranty on the emissions system)
And #6 I currently have the car at the dealer -- Life Quality in Brooklyn (great service) -- with it's #6 symptom. Car won't start. SO far the techs been looking at it for two days, have eliminated the starter and the battery, so we'll see.
For a car that's three years old (Nov. 17) and the high mileage (all highway -- Toronto, Cali, Chicago, Orlando, Portland, Main and points in between) it's been a pleasure to drive, and I still get looks -- BUT I'm beginning to get worried, especially about this latest problem.
Any high mileage owners going for the long haul out there -- can give me some encouragement
BTW car's never missed a scheduled maintainance. I also lost the rear cup holder (9 year old nephew)
I am also in NYC (Queens) and am looking to get away from going to the dealer for service.
great car but service sucks. list of issues to date:
1. front seat frame needed replacement.
2. at 25000 miles transmission replaced. unable to fix, it was clunking going into reverse.(Note: these transmissions are $10,000)
3. rotors replaced at 35000 miles.
What was wrong with your front seat frame? Mine seems to be acting up
I had a 02 passat wagon (totaled in rear ender at 17,000k) had the rear window lock button replaced/drl bulbs replaced all free on warrenty.....no rattles , squeaks, etc. fit and finshish were excellent.....no complaints about dealer service.(ONE DEALER ON MAUI, lots of opportunity to gouge) but they don't........
I looked at the alternatives and ordered another passat wagon 03.........was I lucky or was I part of the other thousands that don't come here to complain or praise.....good question, I guess it's in the numbers
The seat would make a rattle noise going over bumps, also if you shake the top of the seat back and forth you can hear it. To fix it, VW had to replace the seat frame.
The bad part is my ext. warranty company (allstate - sucks) won't cover it because I can't prove that the brake fluid has been flushed since I've owned the car. Actually, they're willing to give me a consideration and pay for the instrument cluster ($550). whoopee.
Anyway, anyone had/heard of this?
thx
http://www.batauto.com/articles/brkfld.shtml
Noisy...mine smears, though the manual says to clean the blades with windsheild washer fluid.
I'm getting the TripleEdge blades after winter...
Item #ZVW347003
In Stock
Model Years: 1990-2001
Love the car and the way it drives. However I would only recommend it to those who enjoy driving and dont look at vehicles as just a means to get from point A to point B. Those folks can buy the Hondas and Toyotas.
As far as the charge, if it is a problem with the car (because it happens again too soon), I think they should take care of it. If it is just the bulb, then it is like tires and other things that just wear out and are not covered by warranty.
Any folks out there with a high mileage Passat that can advise me about good preventative maint? I am doing the scheduled stuff and changing my oil every 3,000 miles. I have a '99 1.8T with automatic trans. Thanks.
They located one, on the ship to the states and marked it sold. Whether doing this pushed it through all the checkpoints, we'll never know. But after picking it up for a test drive, 6 times it made a strange grinding noise. Mainly when switching from reverse to drive. It happens after that first initial acceleration and can be felt under the accelerator pedal. It sounds like a pop can being crushed or chains rattling.
The dealer initially told me they couldn't hear anything but called last night and they definatly did. They said something about it being the ABS and possibly having to get the ok from VW to fix it. Has anyone else experienced this? I'm not sure I believe its the ABS since I was never stepping on the brakes when this noise occured. They said if they can't fix it, they are sending it back. Would that really happen??
Thanks for any info you can provide. I told the dealer I'd check with other owners to see what insight they can provide.
Do I need to have my new cars oil change sooner
than the recommended time frame of 5,000 miles.
I am thinking it should be done earlier.
David
I run into this all the time on these boards - My GTI has been perfect - no regrets whatsoever.
I appreciate the problems he or she had, which would make me mad enough to post all over the place too, but please!
Also, however, I should point out it is really easy to forget to update your profile when you change cars. Also, only one of my cars shows on my profile, but I have two.
But since you brought up issues about your GTI then I will too. I have a 1991 GTI with 220,000 miles on it and would you believe that I actually had to replace the alternator at 206,000 miles and new cv joints at 215,000 miles? Jeez what's going to happen next? Thank goodness nothing else has gone wrong but we all agree that a car should be problem-free at least for the first 500,000 miles? I hope my words heavily laced with sarcasm were detected by a few smart people out there. BTW the clutch is the original one that came with the car also the only things that went wrong were the alternator and cv joints (206K and 215K miles. I Have had my Passat wagon for a year now and nothing negative to report. GTI is still my commute car...Electra, which Japanese car company do you work for? Subaru? Hmmm???
Did you ever solve your "Check Engine Light" question?
Have a '99 (a bit over 42K, V6, 5 spd), and mine has lit up twice: once upon return from body shop (better half had been struck from rear while stopped at light....) and second time after jockeying around in the driveway one afternoon.
First instance was just a nuisance, probably caused by a bunch of Really Short Trips around / within the body shop - fools the computer. Light turned itself off after a couple of days (as predicted by dealership).
Second time was more of a bother: car refused to start. Turns out there is a tech note on this (something like "Engine fails to start" - actually found a copy for Audi on the web): ultimate solution in tech bulletin was to simply keep the starter going until engine DID start: that worked, once again light took a day or two to turn itself off, and have not have a problem since (But am more careful about short / frequent start[on] / stop[off] / start[on] cycles!)
Interesting thing is that dealership did not report either instance at next service: had expected the glitch to show up when they checked the 'memory' of the computer (? a correct expectation anyone?)
In any event, am enjoying the car even more then when it was new: don't worry quite so much about door dings due to age (although only blemishes thus far are a BUNCH of stone chips, esp on hood, + a new rear bumper....), and handling/fun factor has been improved by addition of 16" wheels & decent tires.
Can't say whether I would buy another - there are lot of new choices since 1999 - but nothing that seems So Fantastic (for the price!) that I would willingly Trade this one in yet....
Drive Safely!
Reid / SE MI
you can email me dirrectly if you would like @ yorgie@hotmail.com.
