It was a real considerate offer to make to someone you don't know and I want to thank you very much for it!
Scott.
Tami
My problem is how to fix the lights. They will turn on if I hit the top of the shifter cover 5 or 6 times, but they do not stay on when I shut the car off and back on again. The back of the shifter dust cover is broken off and I can feel down inside with 2 fingers the light wire under the light assembly, but it feels tight. I cannot figure out how to get the shifter cover off to see if the connector I cannot reach is tight or not.
Dave
i have the same problem with my auto sorento. what was the out come with yours
I managed to get it out by going into reverse and Driving back and forth a few times.
Luckily it worked or i would have missed my holiday.
Good Luck.
Adrian
as for belts, I asked specifically what was wrong with them frayed,etc they told me they are just cheap parts and they are going to squeal (bought at advanced auto but kia put them on). Just doesnt sound right but I dont know enough about cars. All I know is ever since they were put on they squealled. thanks for suggestion for rockauto.com!!
god knows I put enough money into this vehicle already.
thanks again
as far as wiper arms....so the blade itself doesnt make contact with the windshield.....uuuuummm should be some sort of adjustment...not sure......will have to look at mine.....unless the motor was installed incorrectly ....or the arm is simply bend....there shouldnt be a problem...
engine hesitants under heavy acceleration....comes from the drives side of the engine..almost like a misfire...but its a loud thump instead.....once the sorie is up to speed, it doesnt thump.....again....but when going from a complete stop...or when trying to pass...the engine hesitates........coil...bad plug, valve issue??? any suggestions......I have no check engine light either....
None of these warnings have been about anything, "important." That is to say, no hose, nor belt nor anything other than bothersome DEQ equipment failure which leads to hours of diagnosis by the shop. All of this has been handled under the warranty, but no transportation has been provided for me except when the shop forgot to reinstall my oil dipstick, after an oil and filter change, and they delivered it to my address. I would not purchase another Sorento and wished I'd gotten a Honda or Subaru in the first place.
Anyone else having "check engine light fever?"
DEN
Headlights keep going out
Taillight go out
Shifter light is off and on
Driving lights at least three times
Now the car is trying to start itself with no key in it, just starts cranking over all by itself in the driveway
When I changed the Audio fuse (labeled as needing a 30 amp) I noticed it had a 25 amp in it. I hoped that was the problem. Two weeks to the day went by and the new 30 amp fuse I put in blew again. I replaced it this morning. Jammed out on the ride to work.
When I came outside at 5-o-clock to go home, my keyless entry wouldn't work. It had blown again, ALREADY!
Anyone know of something that could be causing this particular fuse to keep blowing repeatedly?! I really dread taking a whole day off work to go and sit in the dealership 2.5 hours away while they trace back thru the entire electrical system. And then they can't guarantee they won't need the car overnight.
Can you turn off the dome light in the LX? If so, I'll try turning that & the radio off, replacing the fuse again and see how long it lasts. I read on here people were having bulb problems. Does that include interior lights? Think shutting the door is jarring a wire somewhere and causing a blowout?
I'd just like to try everything before taking it back to the dealer. Lastly, can I take it to a different dealership than the one I bought it at? There is one a little closer (a little over an hour).
Thanks for all the help. For the most part, I love the car! Just want it to work right!
Did you find the schematic on the fuse box lid? It should tell you if the right size fuse is being used. It almost sounds like you might want to try a 35 or 40.
I've had my 2005 since new & not too many problems. It saved mine & my friends' lives when a guy hit us at 35 MPH with a new Grand Caravan. Only the wheel, bumper & quarter panel on the exterior were damaged. My boyfriend has one too & I won't let him sell it to get something with better mileage after going through that.
Good Luck to you.
the scheduled maintenance and KIA and Hyundia is outrageous IMHO and is a reason I will never buy another......deviate just a little or fail to document all the maintenance properly, be prepared for warranty claim denial.......just the transmission and differential fluid change intervals alone are ridiculous......not to mention the timing belt and spark plug change outs.....and this engine isnt the most mechanic friendly to work with either....also be careful as to how the dealership defines you maintenance schedule as to whether its severe or normal....most like to define it as severe..since the scheduled maintenance required is much more frequent
my other vehicles are GM and dont require any major maintenance until the 100K mark......happy with all three of them....04 wiht 138K, 06 with 37K and 09 with 10K on it.....my 03 Sorento has 116k on it
My 04 KIA Sorento has been great until now. Has been in to dealership 6 times in 2 months for same problem. Mileage now over 100 000K but they have kindly extended the warranty for this issue. Problem started 2 months ago where around 60km it felt like the transmission would slip/RPMs ran high for a couple seconds before changing gears. This has been intermittent, happens couple times a week, otherwise ran great. Now it will completely stall and cut power, again at random, last time the engine light stayed on for 4 days, then turned off on its own. Dealership says they can not find anything wrong. Very scary feeling driving home on the highways with 3 little kids in the back to have car lose power and die on you in the fark and scared someone is going to run into you.
Please only serious responses, I only have a month extended warranty with the dealership to resolve this problem and I do not have very much money right now to start taking it to other mechanics for second and third opinions. Thanks.
Also, I am the second owner, does the warranty carry over to me?
I don't think any warranty covers that much mileage but I'm pretty sure you put an extra 0 onto that!
A defective MAF sensor would produce the symptoms you described.
SUVs and Smart Shopper
Yeah I'm going to take it to a shop today to get it checked out, hopefully it just got disconnected or something...i'll updated later, thanks!
Anyway, hope this helps. I know it wasn't a Kia, but the problem was so similar I had to respond.
Good luck!
Kevin.
I also filled out report with National Highway Transportation Safety Administration - Office of Defects Investigation in case other people were having the same problem.
though you bought the same size tires....they were apparently different in tread remaining....thus the difference in diameter of the tires..leading to the dif failure...the warranty isnt voided....they simply arent honoring it due to the failure being caused by dif tire diameters.....you may in for a battle to convince them otherwise....goodluck!!!
Hope this is of some help.
Adrian.
