Visitor Agreement.
I took tons of digital pictures of these trucks, including the frame stickers that show the build date. The 2001 showed a 6/21 date. I saw many 2000s in the 6/8..6/9 range but no braces. I even have several pictures of a brand new complete 4wd frame leaning against the body shop wall it had no braces..was built in Canada on 6/6. It did have the complete Trans Xmember attached. I would like to see that shop ticket. Could it be vibration related???? Anyway I will be back in town tomorrow night and will upload the pictures to my web site if you are interested.... Oh BTW there are no new rear door handles.
Clay
<<A HREF="http://gm_lemon@bigfoot.com">gm_lemon@bigfoot.com>
<<A HREF="http://drive.to/agmlemon">http://drive.to/agmlemon>
gm just repurchased my vibrating 00, reg cab sportside, it had the 40 mph/1000 rpm vibration.
if your truck has the 40 mph vibration THERE IS NO FIX NOW AND THERE WILL BE NO FIX!!!.gm will tell you everything but the truth about this problem. the vibration is caused by premature torque converter lockup.i have talked to other owners with 99 models that have been told that gm is working on a fix, they have been waiting over a year.if you have this problem file a complaint with the bbb and start a proceding with bbb for a buyback. if you ask gm for buyback they will stall forever and refuse. buyback thru bbb takes about 2 months.
good luck
That is the funniest thing I have ever heard. The dealership told you that the problems were because of the hollow drive shaft. You have got to be kidding. I am laughing out loud as I type this. You better find another dealer, drive shafts have been hollow forever. Atleast since I was born anyway.
1. Engine knock on cold start up
2. Vibration/shutter when you hit a bump at any speed over 50
3. Air leak from the left rear window
4. A/C sometimes blows at 45 degrees and sometimes at 77 degrees
5. Lumbar inflates by itself
I would appreciate any feedback on these types of problems as I am ready to drive it through the dealership showroom and park it in the general managers office.
1. Engine knock on cold start- This is caused by excessive clearance in the rod bearings. Currently no fix and has been corrected for the '01 model.
2. Vibration/shutter when going over bumps over 50. I had my rear springs replaced. Does your truck sit level with no load? If so, the rear springs need replacing. Also there is a technical service bulletin to replace the rack and pinion on 2wd trucks which exhibit vibrations at high speed due to an oversensitive rack and pinion. The question is...your truck 2wd?
3. Air leak from rear left window. GM has updated windows and a TSB issued to fix this problem. I would have them change both rear windows. A test for this is with the latch in the closed position, press the window with your thumb and see if a gap is created between the window and the frame. If so, have them replaced.
4. A/C varies temperature. Have them check your climate control sensor.
5. Lumbar inflates itself. Several people have posted of this happening. No fix as of this date. However, dealer could always replace seat.
What has the dealer done about these problems? BTW, do you have a relative named Don nickname "the Snake"?
Check out the Silverado topic and the Silverado vibration topic for more help.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
