Vibration / Noise GMC truck 1999
HI
I just bought a new 99 GMC full size pick up 4x4.
When driving about 40 mph I hear and feel a slight
vibration. It reminds me of when you drive over
those groves in the road to help drainage. Or
those wake up ridges in the road that are there to
wake you up and let you know a stop sign is ahead.
It is very slight but I wonder what it could be.
Someone said it could be a locking toqure
converter.
md
converter.
md
I have '99 Silverado, and have noticed what you describe. It is indeed very slight, almost not noticeable, and not all the time in any case. On the C/K's I have heard some people say there is a vibration under the floor from the catalytic converter heat shield. But this is definitely not a rattle. I haven't worried about it, but have noticed it occasionally, probably at about 40 mph, and mostly when I step on it a bit, let off, step on it again. Perhaps it is the lock-up torque converter dithering around the lock-up point???
I have a new GMC that has the same thing but mine is getting worse it does it between 35 and 50 mph now. It was at just 40 mph like yours when I first noticed it. I have 3300 miles now, the dealer talk to gm at 2000 miles when i took it in for the vibration. Gm said that they know about the the vibration and are working on it. My dealer said it could be a while before the have a fix. Gm says it is a exhaust vibration but I think it is the torque converter but I'm not a mech. just my opinion. Let me know if you get a fix so I can tell my dealer.
You obviously have nothing constructive to add to this Thread. I would personally take my new Sierra to the dealer every day for repairs before I would consider any of the dodge trucks. We all play the odds with new cars, no company makes 100% perfection but you stick with the people who make the best product for your needs and can fix whats broken (if it occurs). If that is a dodge for you, then fine. Posts like yours (whether pro chevy or other) uncover ones own insecurity about the truck they chose
Dodge would be my third choice.
Are you sure you are not one of the original
Beach Boys since you have nothing to add except
'good vibrations'?
I simply got under the truck, and tried tightening on the cab-to-frame mounting pad bolts. The one that squeaked when I torqued on it with the socket wrench, was under the passenger side cab towards the rear, just behind the door.
I told the dealer which one, and he replaced the pad and bolt, no more squeak. Since there are only about 4 of these for the cab, I doubt it will be hard to find the one causing your squeak.
Let us know how you come out on the windshield molding and driveline growl.
In auto 4x4 mode, you are hearing the front driveshaft rotating under your feet.
In 4x4 high, you're hearing that but also growl whenever the front wheels are not turning exactly the same speed.
I think 45-60 mph sounds too fast for most 4x4 driving, although I am not telling you how to drive. I find I seldom need 4x4 or even Autotrack except under very slippery or unusual circumstances.
When I do engage 4x4, there are some pretty loud engagement clunks/clangs or noises as it switches in or out.
Beyond those observations, it seems to work well.
And if you are driving in 4x4 or Auto because of icy roads, you are also probably getting quite a bit of road noise to accompany the noises the driveline makes. Or if you are in 4x4 or auto and driving over dry pavement, you could expect some noises since it is designed to be a part-time system.
Better lucky than good.
The dealer tried retorqueing the body mounting hardware and lubricating them. They were quiet for about 24 hours and then began to squeak again. The dealer said to give him a couple of weeks to see whether he could learn anything new about the squeaky mounts. I will call him in two weeks because I doubt he will call me first.
Thought you might want to hear this update.
Remember what your mother told you...the squeaky wheel gets the grease. Same for mounting pads/bolts. Good luck, and don't let them off the hook too easily.
If you have General tires on your truck, quite a few people ((myself included) have tires that have lateral run-outs and shake like crazy at 65-70 mph. Supposedly General is going to replace all of the bad tires. We'll see.
It could also be the hubs. Check out the postings to get all of the details. The last 40 or so postings is where the real info. begins.
Good Luck!
Thx
experienced the windshield noise ( I have a Lund
bugshield ) I also have had wind noise from the
3rd door 1/4 window, dealer replaced the latch
but still have noise. Currently trying to solve
"clunk" from rearend when traveling over small
bumps. Dealer said was spare tire,the tailgate,
now replacing rear springs. Anyone else have this?
Annoying as hell after spending that much money.
Dealor has also installed "anti clunk" seal.
and enter your VIN Number. Be
patient, it sometimes takes a while for the site to
respond. You will get the details on all the flash
upgrades from the past. Each upgrade includes all
the preceeding changes. As you will see, there are
several issues addressed in addition to the one you
mentioned. Print the resulting page and take it to
the dealer.
Good Luck, it worked for me.
even when "coasting" so I don't think it is the
converter. It is a metal to metal sound under
the rear end area. Almost sounds like a loose
caliper but I have applied the brakes and it still
occurs. I will suggest the two sided tape for
the windshield to my dealer, is there any adjust-
ment on the 1/4 window? Not much faith in my
dealer service dept. Site still will not open
will keep trying....thanks for info, obearden.
gl3--when you say coasting, do you mean you just hear the sound when you are coasting along before you re-accelerate?
not matter if I am in the gas or letting off.It
can be just a small pothole or speedbump.Dealer
says it is the springs slapping together. they
said they tied a creeper to the bumper and pulled
a tech around he lot. Who knows? And I have noticed that the AC settings affect the noise.
Just seems like a pain ya know? Thanks
... so I wonder what sounds the creeper made when it went over the bump?
the oil changed they left the fill cap off, and
whoever works on it must not know how to wash his
hands as it is a black truck and always comes back
with greasy handprints on it. So I am not real
confident in their abilities. It goes in Wed for
the new rear springs, cross your fingers.
And by the way. I don't buy the creeper story for a second, they were pulling your leg if they told you that.
to my suprise...no noise...so far. Keep your
fingers crossed. And it looks like they actually
replaced the springs. My service invoice this time
stated that they "hooked ears up to rear of truck
to find noise" I don't believe the creeper story
either but they actually wrote that on the last
work order. If this indeed does fix this, I think
I can live with the 1/4 window and W/S noise. I
think they might need to work on the T/Converter
though as the other day in the rain it was clunk-
ing like hell in between shifts. I also heard
something this morning for the first time...lifter
chatter when I first started it..anyone else have
that? It is the 5.3 Does it ever end? Thanks
Also, sometimes when I am stopped and shift from D to R I hear a loud clank in the drive train, like bad U joints.
