Visitor Agreement.
is your truck xcab 4x4? The first time I had the
clank in the drive train the dealer installed
what they called an anticlunk seal (spacers in the
rearend) this did not help. I am going to see how
long the noise going over bumps stops with the
new leaf springs. Not much faith in my service dept. Have your dealer look at the springs in yours, mine is 2nd set the dealer has changed, the
first was on a 2wd. Then have them look at your
gear backlash and torque converter, Hope this helps.
with a 2wd Xcab and he gets the windshield noise
and several dash squeaks. He has not mentioned
any drivetrain noises or vibrations yet but I
have seen 2wd complaints here. Alot of new model
bugs in these, havn't heard from anyone local with
a 2000 to compare, all my buddies have 99's
1) "clanking" in rear end: Overload spring hitting on other springs. See a solution described above.
2) "Slapping" or "vibrating" noise in windshield:
Is actually caused by the two thin rubber "strips"
that cover the hood hinges. They are designed to be lose, and are generally quiet on trucks without bug deflectors. The bug deflector causes turbulence, which causes the rubber strips to flap back and forth at highway speeds. If this is your problem, you can actually see them flapping back and forth if you look closely while driving. Haven't come up with a good fix yet, and neither has GM as far as I know.
3) "Buzzing" vibration from under the cab, usually present when accelerating at slow speeds: Exhaust heat shield under passenger seat vibrates. Service tech gave it a slight "bend", which totally resolved the problem on mine this far.
4) Cab "bounce"; cab bounces up and down at highway speeds, especially on rough roads (gets really irritating after 100 miles or so): Tech. re-torqued rubber mount bolts, which really helped. The bounce I'm talking about is really obvious when you put a topper on; you can see the cab bouncing up and down when looking out the rear window at the topper. Need to keep these tight.
Love my Sierra; fourth new GM truck now, won't be the last! Hope this helps someone. . .
but have determined that it is the mouldings on
the sides of the glass. I had my rear springs
changed and the "clank" seems to have vanished. I
don't know if it is me or not but the driveline
clunk has become more frequent/louder after the
spring change. Will have dealer try the Reflash on
the converter to see if that helps. Lifter chatter
has also vanished with recent oil change. My truck
has 9000 miles on it. This is not my first new GM
vehicle with new model problems. Had a 94 S10 4x4,
95 Monte, 98 Blazer and now this. They all had the
first year bugs but none as frustrating as this.
Although I blame alot of my problems with my
service department. Not much faith in them only adds to it. Will keep you advised on the drive-
line noises.
the driveline was acting up again. Told him about
the converter reflash...had no clue what that was.
Said he has changed the springs in 4 trucks, 2 have cured the noise and 2 have not. He said that
he has seen 99 customers trade for the 2000's al-
ready. Was more concerned about his grade on the
GM survey for the service work. I printed up info
from the GM site and will be taking it to him. I'll let then try once more to fix the driveline noises then I think I'm gonna see about a new vechicle. Should be interesting, I have alot of
add-on stuff on my truck.
bought the truck, I heard a noise in the driveline
upon accelerating and when it up/downshifts at low
speeds. Dealer first installed anti-clunk seal
which is really a spacer for the rearend. This
helped for awhile, then I developed a "clank" that
came from the rearend when I drove over small
bumps at any speed. This my dealer called "spring
slap" and just recently replaced my rear springs.
This has cured the noise going over bumps but has
increased the driveline noise. They have replaced
four sets of springs so far in 2wd and 4wd trucks.
I have heard on here that the driveline noise is either the torque convertor or gear backlash.
Either way it sounds like hell and I don't think
a $30,000 truck ought make these kind of noises.
I am going in tommorrow to talk to dealer about
the drive line noises and see what he says. Will
keep you posted.
off from a stop. It has to be in the drive train
somewhere, either a loose gear or yoke or some-
thing. I went to my dealer today and told him the
noise when I drive over bumps is gone but that the
drivetrain noise is worse. Gave him info that I
downloaded from GM site. He will check with his
rep or so he says.
Also spoke with my saleaman, he said Chevy just
bought back a 2wd truck from a customer. He is willing to work a deal with me if they can't fix
my truck. He said I could trade for a 2000 P/up
or car. This will be interesting as I don't think I'll take another truck. Will see what happens when I try for a car of lesser value/price.
But I first have to let them mess with my truck again to see if they can fix it (again)
mike
If you are running Goodyears on your truck and have a vibration problem have them check the tires. This is specially true if your truck was manufactured after about the first of April. According to the dealer, trucks made after the first of 1999 should have the correct hubs (B9's) and after the first of April the correct rear shackles.
troubles here, glad I waited. Had one squeak,
fixed in myself, the grounding cables under the
cab needed some lube.
My suggestion: at the FIRST sign of vibration, brake fade, etc. take that baby back and demand service...not lip service.
That's gotta be the best one yet!
- Tim
times for rear end noises. 1st time they put in
an "anti-clunk" seal, then they lubed the splines
everytime I complained. It went from spare-tire
carrier, to tailgate to replacing the rear springs
Last week it was new u-joints (after waiting 3
weeks for them to come in) As soon as I log off
I will be calling in to report the noise has returned. Still waiting for 3rd door window to
come in. I have called Chevy and obtained a file
number only to be told that the problem/noise is
on all trucks and they are supposed to make that noise. I told them I suppose thats' what Ford told
all the Pinto Owners too. I think what they are
doing is stalling til the mileage racks up. That
means less money for them. I'da kept my Blazer if
I would have known it would be this bad. I've had
several 1st year models and never had this much of
a problem.
I'm still not totally disgusted, just really, really annoyed at the time it is taking for replacement parts and a solution. Not to mention the 5K they wanted to swap for 1 year for the SAME truck. The longer they keep the bad ones with the owner that originally bought them your right it reduces their liability and flooding the market with a bunch of bad 1999's that would drive down future sales of new ones.
I did drive a Tundra the other day and must say I was impressed.
Problem is it's always in the shop. Told my service advisor about the noise returning, he said
that they will look at it when the window comes in, more miles driven. Did not get to talk with Chevy today, but my salesman has told me they will
reinburse me for what I paid for the truck minus
.25 a mile. He also told me they will "Buy Back"
my add-ons if I leave them on the truck and pro-
duce receipts. I have heard others say they will
not. Since I probably will not purchase another truck I hope they will, as I have invested about
a grand. I would like to get a new style Tahoe but I haven't heard much about them. We'll see.
On the new Tahoe and Yukon, I believe I'd wait a year on those models as well. They have a totally new link and coil rear suspension on them this year and I'd be nervous of another new design with GM's track record on the Silverado.
Hey... don't give up and if you like trucks I'd say try a Tundra Limited out. It's a little smaller and not as comfortable, but the one I test drove showed me a lot, it was rock solid and the motor was real smooth.
I hope my next report to everyone will be the problem is fixed.....
Hope this helps you, it made mine feel like a new truck again.
I have read about the clunks but I am interested to find out if anyone has had the horrible squeaking problem. A person can't even get in or out of the truck without the squeak.
There are many things that I really like about this
truck but, I have experienced a number of problems
with it. Vibrations, Steering Wheel Clunk, Sticky
Throttle Cable, Leaky Cab, Wind Noise, Bad Tires,
etc...I have perused all of the postings in the
topic list that relate to this particular vehicle
and there are a number of extremely common threads
that are very widespread. I think we all know what
they are by now. The Vibration one is a really
serious one that GM has started buying back trucks
that simply cannot be fixed to the owners
satisfaction. Has anyone entertained the idea of a
class-action suit? It appears that it would be
well warranted. The issue that concerns me is
resale or trade-in values. As all of these issues
leak to the forefront who do you think y'all are
going to get someone to pay fair market value for
what is likely to become a lemon model year??? I
think that as exposure widens it is likely that the
public may regard this entire '99' year of GMC
trucks as something to shy away from. Who do you
think is going to personally take the hit for
several thousand dollars when that happens???
Looks to me if these problems are as serious as
they appear to be we should all stick together
rather that fight our own personal wars with our
individual service departments and GM. Don't get
me wrong, I think this truck is a winner in most
respects but these issues are no laughing matter.
Do you really think this isn't going to make a
difference? Somewhere along the line it looks like
we are all in for a beating. Any class-action
takers?
Acknowledging that they have my complaint. My truck has been at the dealers for as total of 32 days.
Today I saw a piece of tape and a black rubber
block in the dash grill. Tried to get it out but
it fell in the duct. Now I know what that strange
buzzing was that has been driving me nuts for the
Past 2 weeks. Did I go to the dealer for this
latest noise. Hell no, my blood pressure can't
handle it. Every day something new crops up.
Class action, yes yes yes. GM is a fraud selling
defective junk. Like a rock, you bet. My truck
rides like a rock falling down the side of mountain.
A u-haul rides like a limo compared to this pile
of rattling shaking bouncy bucket. I rent u-hauls
at least twice a year and this year drove 3 other
pick ups ( FORD DODGE CHEVY (old body style),over 1200 miles. But what did I buy.....JUNK. Almost got killed in it the first day I drove it. The vibration on the highway was so bad I almost lost control on the 1-10.
SIGN ME UP...............NOW!!!
Count me in. Just got a letter from LA AG office acknowleding that they have my complaint. My truck has been at the dealers for as total of 32 days. Today I saw a piece of tape and a black rubber block in the dash grill. Tried to get it out but it fell in the duct. Now I know what that strange buzzing was that has been driving me nuts for the past 2 weeks. Did I go to the dealer for this latest noise. Hell no, my blood pressure can't handle it. Every day something new crops up.
Class action, yes yes yes. GM is a fraud selling defective junk. Like a rock, you bet. My truck rides like rock falling down the side of mountain. A u-haul rides like a limo compared to this pile of rattling shaking bouncy bucket. I rent u-hauls a least twice a year and this year drove 3 other pick ups over 1200 miles. l rnte.
put in, splines lubed,springs replaced, and the
latest, new u-joints. Still waiting on 3rd door
window. At the urging of my salesman, I started
a file at Chevy in an attempt to have them buy the
truck back as they have not been able to fix the noise in three tries. Spoke with them Wed, dealer
told them all truck make this noise, just some louder than others. Will not buy back. They said
to keep letting the dealership try and fix. This
after they left the oil fill cap off on first oil
change. Said I could appeal to Chevy but best bet
was to trade/sell truck or live with it. I know
that trucks are not as quiet as a car, but when it sounds like the rearend is going to fall out when you accelerate from a stop or drive over a
speed bump, it gets pretty embarrassing. This
thing stickered at 31k. I have never had so many
problems with a first year model. Tap on your
dash, it sounds hollow, I can't wait for it to start rattleing. Will be going to dealer today to
appeal to them, then I guess I'll try my Lemon Law
Good Luck, seems we are on our own.
Bought March 99
Current Miles 23000
Problems
1) 3000 miles--Front end aligned twice--problem corrected
2) 4000 miles--Clunking in rear end of truck at take off and going over bumps--Have taken truck in four different times with this problem; greased splines, greased yoke,6000miles--replaced springs,8000--greased springs, 11000 miles-- replaced yoke 14000 miles--changed to a so-called new transmission fluid which Chevy now says has been causing the yoke not to slide properly therefore making the clunking noise. I have almost lost count of the specific times I have taken the truck in for some of these same problems and others including, bad sylenoid switch around the EFI system which caused a clicking noise which would start about 30 seconds after i cranked the truck--problem cured. It is currently in the shop for the clunking noise again, lifters clicking when I crank the truck, and the steering column rattling when the truck is turned slightly to the left.
At one time , I felt like I had bought the only 99 Z71 lemon but I now know that I am not alone.
I'm glad I found this site and I appreciate all of the input from everyone.
I'm currently debating what to do about this truck. I've started the process of a possible buyback from Chevy and also talked to an attorney about the lemon law. I've also considered selling the truck but I don't want someone else to go through the same ordeal I have. I have always liked the Chevy and Toyota trucks. After driving a Toyota Tundra this morning, I was extremely impressed. Toyota has built another excellent truck. I have to say I had my doubts about Toyota competing with the big three but not any more. It may take some time for people to get used to the Tundra but it will happen . This is a well designed vehicle and I have to believe it can't be any worse than the truck I'm driving now.
