Mazda6 Accessories and Modifications
I'm trying to sort out whether I need to get the Bose/Moonroof package on a new iTouring. I don't need a moonroof. I would like somewhat better sound than the stock speakers, which buzzed a bit on my test drive.
If I want to get an improvement (I'm not a big time audiophile), can I just purchase 4 new speakers and installation at Best Buy? I don't know enough about speakers to figure out what level would be "better".
What is a decent improvement and what's the total cost typically? Do I need to buy an amp too?
"Thank you for contacting Mazda.
At this time there are no updated navigation discs that have been issued. If updated discs become available in the future, part numbers and ordering information will be made available to authorized Mazda dealerships Parts departments. We regret any dissatisfaction with this situation."
Anyone else having the same problem? My phone is among those listed on the mazdahandsfree.com website as being supported for Bluetooth headset and Bt Audio. All other phone functions work flawlessly.
On the same site I found buried in the FAQs (THIS SHOULD BE LISTED IN THE MANUAL that comes with the car) that the phone book must not contain more than 1,000 contacts. So I deleted a ton of contacts that I am not likely to call anyways and got the list down to around 500 contacts. But the import phonebook hangs (well I lost my patience after about 3 minutes).
I even unpaired and re-paired but it continues to show the same behavior.
I can't believe they charge $2,000 for this nav and still don't get this to work right.
Any suggestions? Please email me.
However, I've still rarely used the address book. Primarily because I hate receiving calls in my car since my iPhone likes to randomly drop the bluetooth connection and I'm forced to switch to speaker which is a PITA.
If you don't mind losing all your saved stations, you might want to try a hard reset via removing a battery cable to clear out all data, and first thing, start the copy over process. If that doesn't work, I don't know what else you can do.
BTW with my HTC Mogul the Bt connection is rock-solid.
