Mazda3 Hatchback
where does the radio antenna go (on the windshield?)?
and what is this thing on the right side of the shifter that looks like a remote control?
Bruno
This method is approved by the SAE (Societiy of Automotive Engineers).
The main issue is that by looking at the windows, you lose precious reaction time (especially true on highways).
I see everything without having to rotate my head more than to look at the mirrors.
WARNING: This method takes some time to get used to it and you SHOULD keep looking through the side windows until you feel totally confident with this new way.
It is really special as you wont see the car behind you in the side mirrors (it was duplicate info from the rear mirror).
I invite you to read this document: http://www.sts.sae.org/membersonly/blindzone/index.htm
1. I don't know if we are talking the same thing but for me the problem of looking at the back window on the highway is NOT reaction time, but rather one have to leave the eyes momentally on what happens in the direction where the car is moving.
2. I usually do not need to look through the back window while driving, because: first, I usually know constantly what is going on all around my car, second: I have my side mirrors adjusting very outward (100% out on my P5) thus I only need to check through the front windows a fraction of second to cover the blind spot. That the way I'm doing for years and years...
Now back to the lack of visibility
1. have you ever tried to backpark into a tight spot with the car like the Open Astra?
2. Sometime the only way to eliminate the blind zone is looking through the back window. For example when entering into a highway from the ramp: the directions of our car and that of the on-going traffic are converging and our side mirrors can't possibly cover another car coming closer from a side.
3. Car design that has a bad visibility will no double compromise the safety, regardless the style of driving. I would reject the car if I don't feel totally comfortable of driving it. Lack of visibility certainly could make me very uncomfortable.
Bruno
There's no external keyhole for the hatch. The MX Sportif is a concept car. The door handles are also conceptual and don't have a exterior keyhole either (production door handles will be like the Mazda6).
"where does the radio antenna go (on the windshield?)?"
Again, concept car, so they kept it clean for showcar purposes. Production antenna will be like the current Protege5.
"and what is this thing on the right side of the shifter that looks like a remote control?"
As mazdafun says, it's the remote control for the NAV.
VW, BMW, & Toyota make quiet small cars. Are you gonna do it this time, Mazda?
Close-ratio 5-sp? 2.3L is big enough to handle this little car. Offer a wide ratio! Or I'll have to increase tire diameter again this time like what I did w/ my '90 Protege LX-- still suffering from the noise today since day 1.
Dinu
Bruno
I doubt if our seats come as colorful, though. Tough to sell a bunch of leather that looks too "tuned." We will probably get a similar wheel option that the 6 has--16 std with option for 17s with some add'l trim package. 18s are too expensive to maintain for a production--at least an economy car. I hope it stays reasonable!
Nice looking car, though. Personally, I like the look of the back end. I don't think the C-pillar is TOO huge, it tapers near the top, so it probably wouldn't block the view too badly once you got used to it.
http://europe.autonews.com/article.cms?articleId=52421
Mazda3 is their best effort (by utilizing Europe's best fwd chassis!) to make a comeback! You expect Mazda to eat dust (& trail behind Corolla & Focus)?
So if you say you have a 160HP car, and someone has a 200+ HP car, your 160HP car is though less of, even though it could be the more fun to drive...
Instead of getting 200HP, I'd like standard SAB/SAC and ABS (ok we get the ABS standard here in Canada, but I still don't see why Mazda USA is charging more for ABS).
Dinu
I'm willing to pay for it - hell, the interior on the Sportif looks better than that on my Passat....
http://www.cars.com/carsapp/autoshowny/?srv=parser&act=displa- y&tf=/features/autoshow2003/coverage/ny/posted/coverage_04_09- _01.tmpl
I can't wait till this car is introduced.
Dinu
They're hard to see into and reflect glare.
http://www.autoexpress.co.uk/?video_gallery/video_gallery_story.p- hp?id=34211
Dinu
http://www.topgear.com/content/features/stories/geneva_2003/06/
"Maximum output is estimated at 150 hp at 6000 rpm and maximum torque is estimated at 140 lb-ft at 4500 rpm. In terms of environmental performance, the MZR engine in the MX Sportif aims to meet the PZEV (partial zero emission vehicle) standard in the United States. The engine in mated to a close-ratio, short-throw five-speed manual transmission"
"The MX Sportif features the latest evolution of the Mazda Advanced Impact Distribution and Absorption System body, dual stage opening Supplemental Restraint System (SRS) front airbags, as well as SRS side curtains and seat mounted front side airbags. This level of passive safety equipment - matched to the active safety that is inherent in any vehicle with exceptional driving dynamics - gives MX Sportif a reassuring level of safety that is expected in all automobiles. Active safety is pushed to the highest levels with the inclusion of Mazda's sophisticated anti-lock brake system and Dynamic Stability Control (DSC), boosting the MX Sportif's overall handling stability and braking performance beyond their basic potential"
MX Sportif Specifications
Dimensions Overall Length 171.3 in. (4350mm) Overall Width 62.3 in. (1760mm)
Overall Height 57.1 in. (1450mm) Wheelbase 103.9 in. (2640mm) Tread, front/rear 60.4/60.2 in. (1535/1530mm)
Seating capacity 5 persons
Engine Type MZR 2.0L inline four-cylinder
Output (SAE net) 150 hp @ 6000 rpm (estimated)
Torque (SAE net) 140 lb-ft @ 4500 rpm (estimated)
Transmission Type Five-speed manual
Suspension Suspension system, front/rear MacPherson strut/multi-link
Brakes front/rear Ventilated disc/disc Tires 225/45R-18
http://www.autointell-news.com/News-2003/April-2003/April-2003-4/- April-23-03-p8.htm
Dinu
(mutcth)
"I want stability (control, that is)!...I'm willing to pay for it - hell, the interior on the Sportif looks better than that on my Passat...."
Mazda wouldn't dare to charge more than that would they? I wonder how much they're charging it in the Japanese-made 6 in other markets.
"OK, I hope they lose the chromed rings around the IP...I hate those things."
I hate them, too. It also makes the car old fashion. & while the 330i got it, the 325i doesn't, along w/ exterior grill & side-window surrounds.
Electronic Stabilization Program has been a $280 option on all the compact (Golf platform) Volkswagens right now since the start of the 03 model year. Even the cheapest US VW, the Golf GL 2.0 2-door, has power everything, ABS, 4-wheel discs, side airbags, and side curtains. With ESP added, it's still only $16,150.
I must admit, when I consider cars other than a TDI VW, such as a Mazda6 or 3, I feel cheated at the thought of having to pay extra for those kinds of safety features that are standard in a German car. As long as they're available in the Mazda, it really makes no difference, of course, it's just a mental thing. Everybody likes more standard equipment, right?
Mike
Some cars, e.g., Subaru Legacy, almost stop the car on every minor skid. You might as well turn it off & risk.
I'm not sure if our Focus's AdvanceTrak is tuned the same as the Euro Focus's ESP, which is excellent at allowing some skidding fun before the stability control steps in, since this platform is already very safe w/o the intervention anyway.
It's a good thing that the Mazda engineers for the "Focus(II)-platform" 3 is being educated under Euro Ford's guideline in the dynamic area! I read this somewhere. So we're likely getting the fun stability program for the 3, if it's available at all.
http://elmundomotor.elmundo.es/elmundomotor/2003/03/05/coches/104- 6887216.html#
Dinu
Dinu
I fail to see how it is overdone. I think this car needs to be more progressive than a Civic or Corolla. Those cars have the sensible crowd all wrapped up. Mazda knows it needs to appeal to a more emotional side. You have to have a reason to not want the standard fare, and a conservative ordinally styled car won't give any reason.
The 6 is well done. So is the Audi TT. So is the Miata. So is the RX-8. None of these have extraneous lines. A tautly stretched skin with flowing lines works great for me. To me, the Motif (from the rear) looks like some Pontiac or Toyota designer (or Chris Bangle) snuck into their studio and added several extraneous lines. The front is actually kind of blah. At least they have fairly well-defined fender flares. I like those v. the smoothly-blended fender flares on most Hondas and Toyotas.
I'll have to see one in person. After all, I thought the Lexus SC430 (???) looked great in print. I thought the rear looked really ugly in person.
On the rear quarter, I didn't like the way light was reflecting off it in the short and grainy video, but I'm reserving final judgement until I see it in person.
I hope I like the Mazda3 as much as the current Protege/P5. I think they're great vehicles (I have a sedan, my wife has a P5). I also hope it doesn't inherit the body roll inherent in the Focus chassis (that, along with other concerns/issues, kept me away from the Focus). The Focus just feels tippy to me, though it's better at soaking up big bumps. I'd rather take a stiffer ride than give up the flat and composed handling.
You meant the American non-SVT Focus. You haven't driven the SVT yet have you? Neither have I. It's only equivalent to Europe's mid-level sport model - ST170.
Guess what, I have test driven an even rarer model - the Street Edition. It's the Euro-suspension limited edition, & only came w/ blue/red/yellow sedan or wagon w/ charcoal interior & falsely listed as available w/ stability.
My impression was that the regular Focus is too-softly tuned that it can easily use up the suspension travel on deep bumps when not slowing down. The Street Edition is obviously firmer w/o being lowered, although not likely as firm as the SVT, very much like a 3-series w/ the lowered sport suspension, which is already not absorbent enough for me.
So the Euro suspension may not be that comfortable, but might still be better than Protege's ride, & for sure it's not tippy.
I hope they go for the firmer settings on the 3. It'll be an interesting year for Mazda with the 6, RX-8 and 3 coming out.
The SVT was the best of course. I imagine you would have to really throw it into a corner to feel the lean that the magazines talk about. Minor issue IMO.
The ones w/o the Zetec engine has one fewer sway bar. Only the sedan doesn't have this engine std. & that's probably almost all rental-car Focuses are!
In case any one of you is concern about what to do to modify the firmness of suspension by changing shocks, I posted my "4-shock comparison test" under post #3.
ANT14 "Focus Owners: Future Models" May 7, 2003 8:18pm!make=Ford&model=Focus&ed_makeindex=.ef0979b
Recently, I talked to someone who compared 3 other sets. They are '94 Protege DX OEM vs. KYB vs. Tokico high performance(high-pressure mono-tube?), which he picked for his lowered suspension.
Obviously, very firm shocks are needed to prevent a lowered suspension from using up its limited travel too soon.
Thank you for contacting Mazda North American Operations. I appreciate
the opportunity to respond to you.
We will not have a 2004 Mazda Protegé5. It will be replaced with
another vehicle in the same segment. It should be available this
Fall/Winter. An announcement will be made within the next few months
about the vehicles name and specifications. Additionally, the MAZDA6
wagon and hatchback are slated to begin production for the U.S. during
the first quarter of 2004.
I hope this information is useful. Please let me know if I can be of
any further assistance.
Again, thank you for contacting Mazda. It has been my pleasure to
assist you. If for any reason this response has not completely
satisfied you, please feel free to reply to this message. You may also
contact our Customer Assistance Center toll-free at 1-800-222-5500.
Please take a moment of your time to give us your opinion about our
e-mail service. Click the link below to complete a brief, online
survey.
Sincerely,
Staci Brock
Specialist, Customer Assistance E-Business
Dinu
-fowler3
Not sure I follow the logic, Fowler. Toyota service to maintain a small SUV is more expensive then Mazda service to maintain a small wagon. Therefore, you switched from owning Honda's to owning a Mazda's.
Also, which competitors of the Mazda3 have worse reliabilty ratings. Certainly Honda and Toyota rate higher reliabilty at JD Powers and Consumer Report?
-LT
I just read Brit's Auto Express special issue that the Volvo version - C50 - either 2 or 3 door will be competing w/ the new BMW 3-series & get a 200hp turbo 5-cyl and AWD w/ active damping system similar to their own high-performance AWD S60! A convertible & a 300hp version are also planned. Other Volvo "Focus"s include an SUV to compete w/ the BMW X3.
