BMW 3-Series 2006
Jaron
I do not think every phone will work just fine. I currently have Verizon and wanted to move to Sprint. So I went to the dealership with a PM-325 from LG which has bluetooth but is not in the list and tried to connect to a 5 series with a dealer technician. The I-drive was able to identify the phone but was not able to handle calls. The technician explained to me that BMW may have some encoding that is not compatible with all phones. So I decided to stay with Verizon and buy the Motorola E-815 which is in the recommended list. Anyway, I agree with your last recommendation of trying the phone first.
Best regards,
dom1
There are definitely some phones that either don't work or some features don't work. A search here or other BMW forums will yield many stories of bluetooth phones with limited capabilities when used with BMW cars... There might be the occasional phone (like yours) that happens to work even though it's not on the "approved" list, but that is an exception, not the rule.
Here's the 0.1%..... There are, in fact, features of bluetooth that have been disabled by certain carriers on certain phones. Lawsuits have even been filed over such things. Take a look at these pages:
http://www.eweek.com/article2/0,1759,1751567,00.asp
http://www.engadget.com/entry/1234000983029058/
My Honda has 120k miles & I'm thinking about jumping to my first BMW from a history of Honda's, Acura's, Lexus etc. Honestly I'm a bit nervous about long term reliability of BMW. I was thinking about getting the exented maintenance/warranty package for piece of mind.
Do you think it is better to ask/negotiate for the extend warranty up front or to try to grind it out after you've settled in on the car price?
I'm in the same boat. I priced-out 17'" Dunlop M3 winter run-flats on a set of basic Borbet alloys from TireRack.com for @ $1300. The same tire model (16" not 17") on 16" BMW wheels runs $1850+ from the dealer. My question is whether there's any real reason I need BMW wheels ... any thoughts from anyone out there on this?
BTW - this week my car is in the service center again for hopefully final adjustments (car alarm; vehcile service alert settings, and a couple of other things). I suppose I should be happy it didn't take 3 months to prep the car properly; just 2!
I have to say the service center in Port Chester is gorgeous. The service agent I've been dealing with has been excellent, too -- am I allowed to give his name?
I think naming dealership personnel is verboten.
Ah, well, YES! I think so You should see it in Electric Red...
Traditionally "x" rode higher than RWD (about 1").
E46 are nice, but IMO E30 was when BMW had everything right.
Best Regards,
Shipo
I'm still on the fence about a winter package. It's costly and inconvenient, and with all-season tires I'm not in a circumstance (like you are) where I absolutely have to do it. I assume that RWD + all-season tires will be pretty bad combination in the snow, but my wife and I are able to minimize our snow driving. She's a teacher and she can usually just stay home. But there are those days where it starts to snow, school dismisses early, and then she's stuck driving home in some snow (but before it gets too bad).
You can go with non-BMW wheels. I plan to go that way, if I get a winter package.
_____________
Good question, I think we should keep inquiring about this. Obviously they did this with the E46, but are they making everyone purchase the alarm in order for that nose to blink this time around. Anybody know? Is it in those Sept. updates? thanks for the reply on the chirp Chopsky
There is no height difference between non-SP and SP Xi's siblings.
Do they carry TUV approval?
What about unsprung mass?
I'm sure you made adjustments in the front/rear wheel alignment, so what caster, camber, and toe settings did you use?
Describe the difference in steering response before and after the 20" wheels were fitted. Was the slip angle increased or decreased by the larger wheels?
How was transient response affected?
What is the highest lateral acceleration experienced?
Any increase in NVH?
They look sick on the 3 series
Sick, indeed!
Do the 20" wheels feature run-flat tires, or do you have to carry a spare in the trunk?
How do you cope with the much greater likelihood that a pothole will damage a 20" wheel as opposed to a 16-18" wheel?
Why are you taking a $2000 bath to sell them so soon after buying them?
Food for thought.
I should probably modify a phrase I use regularly (unfortunately).
"This is what happens when one seeks logic where none exists," or some such.
Food for thought, indeed.
Were it that that was so. Unfortunately it ain't. Consider the following:
330xi Sport Package wheels and tires:
Front: 17 x 8.0 and 225/45 R17 All-Season Run-Flats
Rear: 17 x 8.0 and 225/45 R17 All-Season Run-Flats
330i Sport Package wheels and tires:
Front: 18 x 8.0 and 225/40 R18 Performance Run-Flats
Rear: 18 x 8.5 and 255/35 R18 Performance Run-Flats
The suspension on the 330i is also lowered and stiffened, and combined with the higher performance rubber, the 330i SP will be able to run away and hide from a 330xi SP on dry or even wet pavement. The drawback? You will NEED to buy a set of winter rubber for the 330i while doing that for the 330xi would strictly be optional.
Best Regards,
Shipo
david22 is correct. I ordered my 330xi with SP and 18" wheels. For an extra $600 MSRP you can get the 18" wheels that the 330i SP has. In this particular case, you would have to get winter rubber for the 330xi as well.
Best regards,
dom1
Best Regards,
Shipo
I have the following questions:
1. Can I and should I rotate the OEM tires, and if so, at what mileage interval? I remember hearing that you shouldn't rotate tires on BMWs. But I suspect that applies to only BMW models having different size tires on the front and back. Since my tires are all the same size, I see no reason why I shouldn't rotate the tires to balance the wear and extend their life. On my previous cars, I had a dealer or an inpendent shop rotate the tires every 7,500 miles.
2. If I do get a winter package (4 same size winter runflat tires), can I and should I rotate the winter tires? Maybe it makes sense to alternate every winter, fronts in odd years become backs in even years and vice versa?
3. Are tire rotations included in BMW's free maintenance program? I think not, but thought I'd ask.
4. If I do get a winter package (for the first time), I suppose that it may be prudent to do some bookkeeping. Doesn't it make sense to keep track of (a) the mileage on each set of tires as well as (b) the positioning each tire/rim had on the car at the time it was removed?
Vivre l'U.S.A.!
Will.
On my 530i SP (same size tires all around) my intent was to not rotate them either, however, after about 12,000 miles the tires got so damned noisy that it was either rotate them or throw them in the trash. I rotated them. Problem solved.
With that success, I then decided to simply rotate my winter and summer tires, front to back, each time I mounted them. Given that I habitually drive a similar number of miles during each season, I figured that instead of keeping track of my miles on each set, this method would prove to be 98% as effective. This method would also eliminate the potential of say mounting a set of tires one month only to hit some preset rotation mileage figure the next month and then having to take them off and switch them around.
Best Regards,
Shipo
