Does anybody know if the "Trail Rating" done with the standard non-skid plate model when tested on the Rubicon Trail? or with the $150 option.
When I bought my Jeep in February, the salesman told me not to use addititives. In fact he absolutely scowled when I asked him about them. He told me that it is best to get fuel from a place that sells a lot of it such as a truck stop. He said that he has seen some situations where the fuel can go bad because it sits in the underground tank without being sold. I've pretty well followed his advise, have added no additives and have noted no strange performance.
The skid plate that goes from the front suspension to the transfer case skid is part number 82210003 $??? it is just being released by Jeep today, the system does not have a cost (listed under REF. 56). This one should cover the oil filter and the transmission oil pan based on the description.
From the description, it sounds like this plate will need to be removed every time one goes to change the oil. Although I'd like the extra protection, it sure sounds like a nuisance. I also wonder how heavy it would be. I can see myself beneath the truck removing it to change oil and having it bonk me in the head as it is being removed. Is this typical with skid plates?
I've just received my Provent and I will probably install it between the air filter and transmission controller. The air conditionning filter (can) mounted on the firewall has two long threads that can allow for fixation of a second bracket without any modification. I'm just curious to know how much oil can be trapped because my engine does not need refill between every 12,000 miles service. As I wrote in a post some time ago, I open the hood to refill the windshield washer liquid, and nothing else.
Now if oil vapours go into the admission system, this engine will just burn them.
Previous (Renault) turbodiesels mounted on the european Cherokee suffered from severe oil leaks that led to destruction of the engines. A friend of mine was towing his boat through a tunnel when his turbo began to leak oil and he waited till he came out of the tunnel to try to stop his engine. In 4th gear applying the brakes the thing didn't want to stop. He put it in neutral was lucky enough to pull aside and let the engine destroy itself. I think this is one of the historical reasons why you have the choke flap on the newer models. The choke flap can block the oil mist out!
You will never have a steady oil flow come out from the top of the crankcase but if the Provent accumulates oil because it is not well flushed or not installed vertically then the engine may surge for a few seconds. I will install a check valve on the oil return connection to let the eventual oil flow in a can.
I use Power Service Diesel Kleen (silver bottle) in the summer and the white bottle in the winter.
The reduction in risk of fuel problems is well worth the minimal cost of an additive IMO. Especially with the high pressure fuel systems in the common rail and unit injector diesels.
I have been happy with the car, but maybe this is a general example of what others have been saying about the "cheapining" of the brand by DC, I don't know.
With regard to its potential value as a lubricant and solvent, can anyone chime in regarding these benefits? And the relative benefits of bio compared to other types of additives?
Biodiesel Myths and Facts
The general page is National Biodiesel Board
I use B20 as often as I can in my CRD, and I have had absolutely zero problems to date.
One-ounce of lubricity additive can treat a tank of fuel at 25 cents cost, if bought in bulk. That makes $ sense.
The whining could be from the electric cooling fan, I have noticed a whining type noise from it when it is on. I am 12k miles and loving the diesel. One problem so far, early on, with a bad EGR. It was replaced and the computer reprogramed, that was about 6k ago. I have used B20 and noticed a smoother engine idle, no change in fuel economy.
Will
My jeep seems to run good but I only average around 21-22 mpg on my commute which is 50/50 city / hwy.
Daniel
I apologize for not responding to your post any sooner. I've had a lot going on and haven't been checking the posts as much. The oil that will eventually be trapped I plan to drain it. I really haven't figured out how I will eventually run the collected oil back into the sump. I did a test but you will need two people for this. I took the cover off the Provent while the engine was running as you will see the crankcase oil vapors rising. As the engine RPM's increase you will be able the see the vapors being sucked through filter in a cyclone fashion. If you have any ideas on the check valve for the oil drain, please let me know. I had to take my Provent back off before I took it to the dealer for them to replace my EGR.
My check engine light had come on and I checked the codes. P 0299 and P 0410 came on. I took it to the dealer and had a TSB done to it. The dealer re flashed my computer and I got my jeep later that day. It fixed my shudder and jerking problems. The next day the check engine light came back on again and right back to the dealer it goes. They advised me that they needed to replace my EGR valve assembly. When I got my jeep back I noticed a huge difference in my engine response, mileage, and drives smoother.
It's really sad you have to face so many problems with your engine. Mine really works like a jewel. I still have to wait until sept 16th before I put my hands in there. The dealerships here force you to have everything done by themselves if you want warranty coverage.
The Provent can be drained automatically if you use a check valve that gets sucked (closed) by the engine vacuum. Once the engine is turned off, then the valve relaxes and lets the eventual collected oil come out of the hose/tube.
There is one thing I fear with your installation, it's the hardening of the pvc hoses. They are not the best around an engine. I'm thinking of moulding a silicon reduction-adaptor for the hoses to get to the standard engine diameter. In case of a leak the non filtered air would get into the turbo without passing through the filter. Perhaps with heat and vibrations one should be precautious here.
I would'nt bother with recuperating the oil by sending it back into the sump. I doubt it's worth the investment of a banjo adaptor on the drain plug with the risk of ripping the hose off by vegetation or any other object.
Check out their web site at: http://www.stanadyne.com/new/index.asp
Additives
Can I trust that they do process the fuel in an appropriate manner so that I don't have top add extra chemicals? The Jeep seems to run fine without extra stuff of unknown chemical makeup gurgled into the tank.
Thank you for your input. I will be making some changes before I install the Provent back into its rightful place. I did notice a little hardening in the clear pvc stranded hose.
Larry
What is the cetane of the diesel fuel you are buying? What is the lubricity? What is the sulfur content? What is the thermal stability? What is the low temperature operability? The info. is not on the pump. Buying diesel is like playing roulette. Too much left to chance. IF, low sulfur, high cetane fuel is available in your area at least you eliminate some of the variability.
The Jeeps CRD engine was designed to run on low sulfur, high cetane diesel of EU and modified to run on our low quality, low cetane, high sulfur diesel of the USA and Canada.
I know what the additive will do. It is the same quality every time.
You can trust the diesel fuel that you buy if you want to, I'll take the precaution of adding the "extra stuff" and know that cetane, lubricity, low temperature performance are improved.
Once again THANK YOU for any help you might provide.
Sincerly
CCapes
Do you have a central heating system that burns oil where you live?
Well, this same heating oil provider has the proper 'taxed' diesel fuel for the truck.
The different diesel fuels described in your link cover from marine to automobile usage. I doubt all of these can be found within 200 miles because they are too different, and would cost a fortune to store for retail.
All 4x4 raiders going from europe to other continents add a second water strainer on the fuel line of the common rail diesels, but they use what they can buy and sometimes what can burn...
I think DC added a lot of electronics, perhaps too much for you folks to enjoy.
I remember reading an article saying that if the north americans would not buy the CRD, the europeans would. Does DC really want to sell?
I would say a "fix" is in the works.These were intendedto be put on the market as a more environmentally friendly vehicle.
They only put about 5000 in the North American market this year, to see if they would sell.They weren't too sure that Americans were ready for diesels yet .So they decided to test the waters .
But of course people would buy them.As gas prices jump steadily up ,more people are looking for a replacement SUV.
Most are not ready to go back to an "econo - box" yet,because of a life style change,plus the fact that most hybreds and small cars aren't good for towing long distances,but these puppies were built for more than one purpose,including longevity,and styling.
Speak soon
Lightnin3
Here's a cute place where the unique access road climbs so much you can only see the road in the windshield, you have to look through the side window to watch the sky:
http://www.lesjoyeuxrandonneurs.ch/tanay.html
I'm retired too and feel that I would have fared better with the Jetta wagon.
Good luck! LK
Thanks - I guess I will. If I've got an engine that can run on cooking oil with some thinning agents, I'm not going to lie awake worrying about what my local gas station is selling me. I'll just make sure I frequent a station with a lot of business.
However, I will do some other things for longevity of the beast.
I will let the motor idle for 15 to 30 seconds after a hard run. I do worry about the life of the turbo.
I will use the expensive grade of oil the manufacturer recommends.
I plan on using my block heater during the anticipated cold Winter weather with timed heating for about an hour prior to departure. I may also add a battery heater.
Anyone hear about the changes in the Jeep diesel Liberty for 2006? Maybe we'll all be flabbergasted and see a diesel hybrid.......
The main reasons I chose the Liberty are: 1) towing capacity of 5000 lbs; 2) better fuel economy than the V8 Cherokee or the V6 Gas Liberty; 3) it is rather short and will fit in the garage (along with bikes, motorcycles, etc) much more easily than the new Cherokee which is now 5 inches longer than the 04; 4) a true 4x4 compared to AWD vehicles (Honda)--- which may or may not get me through some deep snow in the winter; 5) I just like to buy North American and I have had 5 previous Jeeps so I guess you could say I am brand loyal...
http://www.vmmotori.it/en/01/01/dettAutoOggi.jsp?autoId=53
On behalf of all DC employees, we want to thank all Jeep owners for your loyalty .
Buying our products in the grand scheme of things is like investing in your own job.
just basic economics.
I hope you have as much luck and fun as I had with mine as you will with yours.
Like you ,I am a Jeep man/person myself.
After many reliable years of owning my Gr.Cherrokee ,was ready for another one and was so elated to finally see a diesel option,that offered double the mileage and more power ,from what I realised.
Driving diesel is a whole different attitude.
If you want to save on fuel costs ,
1/Do regular maintenance as stated in the book.
using the sythetic mobile 1 oil.
2/Take your time getting to where you want to go,so lay off the peddle.
The idea is to not engage the turbo unless you need to.
You will find 20% better mileage if:
When on the Hwy don't go over 100 Km's in speed .I actually found out through the Chrysler engineering that our vehicles get maximum fuel mileage at 55Mph/90 Km's.
3/ Don't forget to order your class 3 hitch ,
They can mount it on , at that time it comes in.
Make sure you order the 7 pin connector ,instead of the 4 pin.
Just in case you have to tow a trailer with electric brakes.
4/Also try to make a deal on the tires .The standard ones are only good for summer driving.You can go to a tire store and get them changed and get a rebate on the stock ones.
I suggest B.F. Goodrich All terrain T/A's or Michelin LTX M/S.
I have been getting 4 years 80K's of these types ,and they are a good all around tire as well. The Michelins have been around for awhile and they have come down alot in price, the past 2 years.
But I have found the B.F Goodrich to be a grippier tire,and the Michelin a quieter one.
You might want to consider getting winter Chrome rims and keep the aluminum ones for summer use. although aluminum is sweet looking,they have a down side.
As salt off the roads has a tendency to make them leak after a couple of years.
Steel seems to hold up a little better.
I am eyeing a set of AP's rims .They have quite an assortment of styles and seem to be of good quality.
I am sure you will be happy with your new purchase.
I have been getting 700-800 Km's out of a tank of fuel,and paying lately 97 cents/litre.
I suggest buying from shell as they have 2 grades of fuel.I use the diesel ultra for when I go on long trips and towing power.
Have fun and good luck .
Speak Soon ...
Lightnin3
Just curious as to your total range per tank on average. I usually get between 430 - 520 depending on city or highway.
Will
A question for anyone , what's the most you've ever put in your tank ? I filled up once and got 20.61 gallons in it
The one speed where the thing can't be driven... Wake up! DC
- Get to 60 and then gently slow down without releasing the throttle pedal until you reach 1800 rpm, then put the cruise control. This works on mine but one needs to pay attention. Mileage has to be good in this boundary condition...
It can't drive 55MPH! The transmission will shift constantly along with the TC locking & unlocking. Cruise control or not, it just can't find the combination to keep the software happy. It will stay in OD and locked at 58MPH running 1700RPM. My best tank was 28.3MPG, worst tank 15.6 pulling a trailer,I have 2400 miles on mine. It sounds like DC engineering was sold a bill of goods on the software.
Caribou1 has the trick that I do as well.
Bring it up to speed ,then engage the cruise .
You will be at 65 mph,in 5 th gear .
Then using the "Decel Button" ,
Bring your speed slowly down to 55 mph,watch you rpm's drop.
Now you should be at cruising speed ,and where you''ll find maximum
fuel economy.
Oh Happy Day !
Speak Soon
Lightnin3
_____________________
Advantages to driving 55 :
20% Fuel savings..
Less chance of getting a ticket.
Can sip your coffee on your way to work .
Can relax and listen to your favorite tunes.
Can wave at the gas guzzelling speeders ,as they pass.
