A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Liberty has been out long enough that most bugs should be well worked out. I wouldn't be too concerned with the diesel option since it's been out awhile too, just not here. Who knows what our crappy diesel will do to the thing though.
In the chart that is omitted from the online version of article it may be seen that diesel option is less cost, nearly same or slightly higher cost than comparable gasoline version when sold in Europe. In the USA you pay $4000 or more for diesel in pickup trucks and SUT's. This higher cost is due to greed and not actual cost of manufacture IMHO.
If diesel is to sell in North America in volume it will have to be at parity or minimal increase in cost, same as in Europe. Charging $4000 extra for a Liberty or passenger car diesel option will spell doom for diesel.
An example of successful diesel marketing is VW TDI where the diesel is more expensive than 2.0L gas and less expensive than 1.8T. It sells well at that level.
That may be (simple demand) but it seems there are a lot of folks that walk away from a diesel pickup just from the cost. Even if you really don't lose much in depreciation, they still see it as an excessive cash outlay. I am more of the opinion that these engines cost that much because they're built for extreme conditions. The Cummins is not much short of an OTR engine, and the Duramax/Powerstroke are also designed for long-term heavy use. The engineering, component strength, and severe service items alone have to add up to a big cost. My TDI will likely last a long time, but I'd bet if I pulled a even light-duty trailer/load constantly it would wear out much quicker simply because it's not designed for that.
I believe that when the Liberty Diesel will be available to you, the curtain will fall over the fears expressed in this forum.
These figures seem to be the norm with everyone. P.S. our altitude in Johannesburg is 1800Mt. ASL.. so the turbo looses less power, consequently has the advantage... I hope this helps..
Somebody claims they get 24mpg out of a gasser liberty (which is 3mpg MORE than the epa highway and I believe possible for long trip legs, but not day-in and day-out). Another person claims (from a different country) that they get 24mpg average highway mileage from a diesel Liberty. Then another person (from another country) claims they get 24mpg overall average from a diesel liberty in heavy city use. How can this be used to prove much of anything beyond different people and driving condition result in widely differnt mpg ratings??
The diesel liberty should get about 30% better fuel economy as the gasser. That's only fairly compared to the same driver over the same conditions.
Well, it's the same for us. The only scientific approach here is the total mileage covered in the different parts of the world; miles could be understood as 'N' entries. I've been checking my mileage since I bought the truck, and it comes to 10.3 L/100KM (+/- 0.2) over 17000 KM. For a scientist, this means around 38 refills with a possible distribution error of 0.3 liters every 50 liters.
In addition there are likely differences between what one person calls highway, urban, city, etc. as well. When I state my highway mileage, that's usually 100% for the highway. In other words, I get on the highway, set the cruise to a certain speed and drive until I need fuel (or a bathroom if driving the TDI
Then there is the driver personality which can have a great effect on economy. My wife can get upwards of 3-4mpg better with my diesel Jetta around town because she's not as aggresive as I am.
It's just totally unscientific data for the most part, great for chatting but nothing to get mad and make a decision on. Now if EVERYONE came on here and said "I can't get more than 16mpg out of my Liberty no matter what I do" than that sounds like a vehicle issue.
The Liberty is a truck that is built to endure harsh off-road conditions as well as navigate city streets and interstate highways. It sits high and is boxy and has a beefed-up frame, suspension, and drivetrain. It was not built for fuel economy whether you're burning gas or diesel. The MPG matches the vehicle so unless you do an extreme makeover to the fuel technology system, the numbers are not going to make most people smile--gas or diesel.
If you want something with high MPG then look elswhere. Meanwhile, enjoy it for what it is and make friends with your local fuel station pump.
This way you filter out driving habits.
There are plenty of cars to pick from that get decent mpg, but anyone that needs/wants 4x4 and trailer towing ability are stuck buying gas guzzlers. Nothing in this category that gets good mpg can tow or off-road
I'm not sure the Dakota would be worth much better mpg. I can squeeze 20-21mpg out of my 5.3L 4x4 Tahoe out on the highway and it doesn't seem to matter if I've got two passengers or six passengers plus luggage. Weight doesn't seem to effect the mpg, more so the aerodynamics. Not sure the Dakota is going to slice through the air much better than a Ram. Maybe worse as tall as the 4x4 Dodges sit.
In our organization there are 12 Liberty diesels and 15 Liberty 3.7 liters... we all have a petrol card and fill up the vehicles each time...each month we get a report with consumption, cost per km etc. The company is now refusing to buy the petrol 3.7 Liberty because of the unacceptable consumption. By the way at 80Km/h the liberty gets 8,4 l/100 km. Air-conditioning on or off makes no difference to the consumption ! The turbo lag @ 1000 RPM - 1900 rpm is atrocious and unacceptable at high altitudes. (at sea level the truck is more smooth). I have erratic access to this site (on the road most time), so I post replies when I get opportunity to log on .
So to save cost, a std vane was fitted... with the consequence that this has a higher inertia & therefore turbo lag...
They told me they had no complaint sofar, and dissapeared. Typically this rattling sound appears between 100-110 KM/H on flat grounds.
It's the only thing I would like to be fixed by DC. I just can't imagine a whole day of travelling at 110 KM/H with that noise. People will just become more and more aggressive, and Jeep will make a flop with the diesel market: no torque at the low end and a whistling kettle at the other! But for driving faster than the speed limit, it becomes quiet again until you hear the siren of the highway patrol.
{No Torque Whistler}
The whistling is a punishment reserved to those who like diesels. I stongly believe that people who don't mind the high accoustics don't hear it after a few years. Right now I'm forced to adapt my driving below or above 2100-2200 RPM.
But I'm sure this can be improved. It's just the matter of choosing the proper engine and transmission mounts, and tuning the turbo properly. This is already well done on the diesel sedans!
NO.
Does anybody make a naturally aspirated diesel???
Perhaps.. but a diesel and a turbocharger work soooo Verrry well together that most designers would not consider it. The early VW diesels were NA (Naturally Asperated) engines. Some Diesel motorcycles and lawnmowers may not be turbocharged.
Lets not forget that a diesel engine (unlike a gasoline engine)is "throttled" by adjusting the FUEL FLOW into it. There is no butterfly valve in the intake system so a diesel engine is ALWAYS breathing as much air as it possibly can. (This is part of its efficency because a gasoline engine is always "working" to suck in air past the throttlevalve which is pinching off the intake.)
So, the first thing a diesel engine wants is LOTS of air getting into it. The action of a turbocharger "recycles" wasted exhaust energy by forcing more air into the engine. On any engine, (gas included) a turbocharger acts to "recycle" otherwise wasted exhaust energy that would go out the tailpipe.
A turbocharger allows an engine to produce 20%-50% more power than it would if it were NA. Essentually FREE power that is usually wasted out the exhaust pipe as heat and noise.
I sure wish I COULD hear the turbocharger on my VW Jetta. All I can hear is a slight whistle at idle. Any RPM above idle sends the turbocharger into the stratosphere wayyy beyond my upper range of hearing.
I have a perfect commuter car: VW Golf GLS TDI. I get 46 mpg during heavy commutes and I can get up to 51 mpg on long highway trips. I cannot tow a ski-boat with my Golf, so I need a mid-size truck or SUV to do this. I love diesel - it makes crusing and passing in the Rocky mountains effortless. But there are no options for diesel mid-size trucks or SUVs. I have to buy a full-size domestic truck or Excursion to get diesel power. And I don't have $70K for a VW Touareg V10 TDI. My dream is that after 2006 (once we get cleaner diesel fuel) - I can get a diesel 4Runner or something similar.
2FastDre.
2FastDre.
jeepmagazineletters@bbdodetroit.com
It is EXTREEMLY unfortunate that the CARB folks have not kept "up to speed" on diesel technology. If they really wanted to make some changes, they could measure in "emmissions per mile" instead of what they currently do. Since a diesel uses over 20% less fuel per mile, many of the emmissinons factors are less by definition.
Another problem that us "boarder states" have is that our legeslation has forced the CARB rules upon us... but the accompining specia FUEL that California has is NOT AVAILABLE in our states.
It is a sad thing that politicians feel compelled to "regulate" what they know little about.
All I can say is that I am glad that I got my diesel VW Jetta in 2003 before Vermont shut down the availability of diesels. 52MPG and over 600 Miles/tank puts a smile on face every time 8-)
I was able to get as low as 9.17 L/100Km. Considering this is an automatic and what the competitors are really giving their customers, there is nothing to be ashamed of. True (only) city mileage alone is 11.7 L/100Km.
Commuting 50% city 50% @110KM/H is 10.3L/100Km. This is almost arithmetical and excellent for the 'bulldozer'.
282.481 UK's magic number
so:
235.215/9.17=25.6US mpg [@55~70mph]
235.215/10.3=22.8US mpg [50%city @35mph+ 50%@75mph]
235.215/11.7=20.1US mpg [city traffic ~20%queuing]
As a comparison:
Driving a Cadillac STS Northstar in Montreal traffic gave me 16L/100Km [14.7mpg], and I got the same from a Lincoln Towncar. I love to play with the big cars we can't afford because of taxes over here! The cost of renting a compact in Europe will get you a luxury full size in North America. That's life...
Steady highway 55-65 mph = 21-22 mpg
50/50 city-highway = 17-19mpg
city = 15-16
It seems that any driving that deviates from pure highway cruising is devastating on mpg averages. I'm hoping that the RainX windshield treatment that I recently applied will improve wind resistance to increase mpg enough to justify the 75 cent cost of the product used.[smiley face]
Your figures for the diesel are close to a 25% improvement.
Driving 10,000 miles yields about a $ 140 savings if fuel averages $1.70 per gallon. Now we need to know how much more Jeep is going to charge for the diesel option to determine the break even point.
Driving the land yachts like Cadillac and Lincoln sure make the Liberty feel like a log truck. I have a Chrysler Concorde with all the options and it is one sweet ride for considerably less money. The Liberty seems fine as long as I stay away from the Concorde for a week
or so. I like the contrast-- it makes life a little more interesting. The Concorde with a 3.5 liter V-6 will average 24-25 mpg highway and 18-20 mpg city.
Part of the problem also comes from the sales tax issue - California wants their cut of a vehicle purchased by a California resident, no matter where it was purchased (I once thought about buying a car in Nevada because I could have gotten a better deal, but the paperwork seemed to be too much of a bother for what little I would save).
As to whether you could get away with it - that's up to you. Personally, I wouldn't try - too much of a chance of someone hitting you or getting a parking ticket or lots of other possibilities. And I have no idea what the fines are if they catch you with an improperly registered vehicle.
Final question to be answered - is Nevada one of the border states? I vaguely thought it was for some reason, but don't recall why. So will it even be available in Nevada?
Considering the behaviour of the diesel engine in off-road conditions, I must admit it makes it easier to keep the driver's attention on the track and forget about the eventual stalling of the engine. You could compare with driving a farm tractor. It has it's charms.
For commuting, it's like being fit and carrying a heavy ruck-sack everyday. You burn more calories...
This brings the diesel to 4.00 USD/Gal, and gas to 5.75 USD/Gal. This also makes our break even point more evident...
The truck sells for 33000 Euros (41250 USD)
The insurance is ~1000 Euros (1250 USD)
Normal services each 12000 miles are ~150 Euros. I will have to pay for my first service soon.
The biggest cost for owning a vehicle here in the States is depreciation---not fuel costs. Is it that way in Europe?
The only thing that makes sense financially is to buy used and get lucky or keep a new car for 2-3 hundred thousand miles. Even with possible major repairs and rebuilds, you still come out better over the long haul. The problem is that it's not much fun. Buying what you want goes to the heart of most consumers. I plead guilty as charged.
Your thoughts on the charm of driving a vehicle that is a bit less refined is right on. It's exactly why I bought a
liberty instead of a Honda CR-V. I'm happy to say that I'm still enjoying myself behind the wheel.
Over $40,000 for a Liberty--ouch!! Hopefully, your taxes cover all your medical care and prescriptions to help balance the budget.
2FastDre.
Those are some big numbers for a car that cost around $18,000 new. Puts me at 54% of new value, the 1.8T at 47%, and the 2.0L at 49%. 5%-7% variance is very large for four year old vehicles.
I like the efficiency of a diesel and not having to fill up as often.
I like the higher resale of a diesel, don't like the higher initial cost.
I like the fact that diesel fuel is less expensive nearly all year in the area I live in.
I like the fact that diesel is a renewable fuel that may be refined from vegetable oils, animal fats and waste veg/animal oils.
