Visitor Agreement.
Now, as for the Sprinter, a MB diesel is in a class that is all together different. We need to compare oranges to oranges, these engine are not the same.
NOW PLEASE, GIVE US OUR FREEDOM OF THE POST
Farout
You have it!
Now let's all move on.
Farout
Farout
Relax. When USLD is mandated and used, most of your emission related problems will go away. This is the main reason small diesels are not sold here. You are experiencing first hand why other manufactures won't offer a diesel powered product in the US market. The Crappy fuel clogges everything up. This is the only thing which I will give Clinton credit for. The mandating of USLD. It was not mandated for the tree huggers. The soot produced by our crappy fuel causes engine component failure and increased operating costs.
Sorry for venting!!!!!!
That's GOT to be a record or close to one!
Why is it that only the 545 RFE is announced and described everywhere and people don't look at their stickers? Now I understand better why soda-pops are sold in a different area than dish washing solutions.
My first oil change was at 3000 miles, then I skipped the 6000 and changed it at 12,000. My 3rd change was at 24,000, 4th at 42,000. In the future it will be entering winter for many years I hope...
http://www.shell-lubricants.com/products/product_details.php?code=50044 for diesels is what I have in the engine now.
I never had to add any oil between changes, and my dipstick is closer to the engine head than yours is. This could explain the uncertainty of the Max-Min marks some posters refer to: we have the same stick but your guiding tube is longer.
Our diesel fuel varies between 1.10 and 1.25 Euro per liter making a pretty sum of 5.5 to 6.25 USD per gallon.
I have a question for you: could you look at one of your ball joints and tell me if you have the heat spreading fin installed?
To answer the ball joint question, yes there is a heat shield/fin in place on my CRD. Some time ago you posted a picture and I have the same shield/fin in place.
Why is the Amsoil synthetic 15W-40 too heavy? It specs out closely to the Mobil 1 products.
The oil pump in the CRD engine is a vane type pump. In a few diagrams I have seen of them, there are no bearings that I can see. Could you please enlighten me and others?
This is my first question. Has anyone used a Fabric guard sucessfully (non-staining on light color seats) on the Liberty? I have light gray interior, and I'm afraid to sneeze in the vehicle!! :surprise:
I'm also trying to find a suitable set of floor mats, that will do a better job covering the wear areas. My trucks all have vinyl, and I just hate carpet on the floors, even though I know it helps with sound deading. Thanks
Tailgate
For mats, I bought weathertec. I get them via mail order. They are full rubber and hold alot of liquid, which can be important here in winter. They last a long time and I have used them on many vehicles.
I stopped at Auto zone and found a reasonable set of mats for the front.
Or Constant Rebuilding Disenchants ?
Ok, this is too easy.... goodnight all.
If you have trouble fallin asleep...count your gas pumps
[IMG]http://pic20.picturetrail.com/VOL1211/5578087/11123017/160659791.jpg[/IMG]
I'm not the fastest on the road but we get there! It pulls in OD very well at 60mpg there is a very little sway but I think its the tires (Goodyear ST). We have had it Southeast Ohio and it didn't have any problems, other that dropping down a gear and going slower, 50mph on the hills. I don't push it either as I try to keep the RPM under 2600. Didn't notice any wind loads like I did when I pulled a 8600lb 5th wheel.
Gear oil pumps, on the other hand, have a built in clearance and generally do not wear much at all. But, as the oils get hot and thin, the oil pressure drops – sometimes dramatically because oil slips by the pump and more easily through oil clearances in the engine. Hot oil still slips past engine clearances more with a vane pump but it does not slip additionally past the pump itself.
Power steering pumps are an example of vane pumps that we take for granted because they almost never fail and when they do it is usually the oil seal on the shaft. On very rare occasions the vanes develop a whine but the pump still works until you cannot stand the noise and change it out (shedding material into the power steering oil no doubt).
Additionally, vane pumps are better at self priming and flow fluids very quickly compared to a gear pump. Under certain conditions where there is difficulty drawing the fluid and a vacuum is produced cavitations can occur causing erosion of metal. Can this condition occur in the CRD when drawing thicker 15W40 oil? I doubt it, but I don’t know for sure.
I have always heard that diesels do not tolerate low oil pressure and I was concerned about the thin oil. Apparently, thin oil is not a problem with a vane pump. Does anyone with a shop manual know what the oil pressure is in the 2.8 engine?
Thanks for your input. Learned something new today from your post and that is appreciated.
Your concern about 15W-40 oil, especially Amsoil Synthetic, does not bother me. I researched Mobil 1, Shell, Chevron, Red Line, Royal Purple, etc. and found that some of the 15W-40 synthetics have properties very similar to the 5W-40 oils. Amsoil and Red Line values fall right in between those for Mobil 1 0W-40 and their 5W-40 synthetics.
I have written to V.M. Motori about Amsoil's 15W-40 Synthetic oil. As soon as I hear from them, I will share the information with everyone on this forum.
Or you could add what I saw on the cowl of a very tough-looking Class 8 semi in Nebraska: a circular badge that says "Kitten Power" complete with a leaping fuzzy kitten. I'm guessing it had a CAT engine, who knows?
I have a cummins in my 1 ton, but I dont want to rob it! :P
Check em out! LK
go to: "Exterior appointments" and then
"similar products"
You could even put the Mercedes flying star emblem on your jeep while your at it, right?
I like diesels.
"Turbo
Diesel"
Red or Silver color choices. I typed in "turbo diesel badges" for the search
I saw this tonight while looking for sources of popping and rattling too.
Does everyone have a 1/8 hole, drilled close to the bottom seam, facing towards the catalict converter?
Thought maybe either the dealer done it to over come a problem, or its there from the factory as a drain. The dealer passed it in an inspection, I need to know if its legal, otherwise I will have to put a new muffler on next inspection.
On top the guard plate, that is just below the front differetial is another plastic plate, wider than the metal guard plate itself. It hangs over, covering the both ends of the axle diffential (it has the sound damping material on top of it). It isnt secured tightly, but it is captive by the guard plate, and you and move it around. I think it vibrates during the right conditions, ruining what would be a otherwise "magic carpet ride". The vibration feeling I feel reminds me what you would feel when a wheel bearing is going out, but this vibration is intermittant. I also found some rocks ontop the plastic damper pan too. Anyone have andy comments?
Brief Description:
I have a Jeep Liberty CRD. I thought DC was devoted to diesel
technology but now I hear that this model will no longer be available
with this engine. DC had to know that the new SO2 rules were coming. Why
deceive people and bring out this model with this engine for only two
years? I am concerned that a model with only 10,000 versions made will
not have good maintenance support by dealers and the spare parts costs
will skyrocket. How will Liberty CRD owners be protected?
Thanks for contacting Dr.Z. Your message has been forwarded to us for
response.
6/13/2006 - A new 3.0-liter turbo Common Rail Diesel (CRD) will debut in
the 2007.5 Jeep® Grand Cherokee.
With more torque than most eight-cylinder engines, equal acceleration
and the fuel economy of a small six-cylinder gasoline engine, the
Mercedes built 3.0-liter CRD is one of the most advanced powerplants
available in the marketplace today. It is designed to be an efficient,
smooth-running engine that gives customers up to 30 percent improved
fuel economy without sacrificing performance.
For more information see our brand websites which provide a wealth of
information, including vehicle information, specifications, towing
capabilities, comparisons, pricing, incentives, Dealer Locators,
brochures and more.
Visit them at:
http://www.chrysler.com
http://www.jeep.com
http://www.dodge.com
If you would rather speak to someone on the phone, the numbers are as
follows:
1-800-CHRYSLER (247-9753)
1-800-4ADODGE (423-6343)
1-800-925-JEEP (925-5337)
Any suggestions?
Oh...after having the CRD for 10 1/2 months I finally got 27 mpg on a trip. Yeah!
Maybe someone who knows will chime in here
Hi Modelaford,
Implicit in your statement is that you prefer or value a vehicle that complies with 2006 emission standards rather than 2007 emission standards and I agree. Unless you need to tow a house .......
I use "Resolve Triple Action Carpet Cleaner" in the hand-pump spray bottle. Found at many local grocery stores. Works perfect on my light khaki interior.
Just spray it on and scrub it immediately and real hard with a clean white cloth. It will appear to leave a mark, but it just needs to dry. Once dry - it's all good.
Thanks for the chime in. What I was wondering, since the cloth fabric seems to stain simply with only water, I was wondering perhaps just the application of a Stain prohibitor would also stain the seats. One has to apply to enough to the seats that they are then wet.
However, if its a even application, then any "spots" wouldnt be appearant, and maybe it would simply cause the complete seat to darking evenly, which I would certainly perfer anyway.
Tailgate
The Ram and CRD are in completely different categories. I love the Ram, but it's awfully big for a daily driver. Whenever I drive it I love it for the first 10-15 minutes and then gradually feel more neutral. Then I get in the CRD and am amazed at how quiet it is and how smooth it rides.
The Cummins will be available in the 2007 Ram but will be revised and probably cost more. If it's the same as the Cummins in the Chassis Cab version for 2007, it will offer reduced hp (305 instead of 325), same torque, and significantly greater displacement. Not sure if these changes will increase or decrease its mpg.
My ideal personal vehicle would be roughly Durango sized with a diesel I-6 in the 200-250hp range. The Jeep is a little small and the Ram is very big. I'm intrigued by the upcoming Grand Cherokee diesel except that the GC seems hardly any bigger than the Liberty.
Thanks. That is exactly what I was looking for. I had a 1500 RAM with the Hemi that I traded in for the CRD - again, looking for a smarter commuter, which the CRD surely is. But I do sorely miss the comfort of that truck. Personally, I'd love to see a smaller engine (like maybe that MB 3.0L V6) in the 1500. The ride of the 1500 with a more efficient engine would be great. That Hemi never got anything better then 12.5. I've driven the 2500 QC 4x4, and the difference in height between it and my 4x2 1500 makes the thing feel three times the size. Well, I guess I'll just sit tight and wait to see what DCX has in store for us in the smaller trucks.
Thanks again,
Paul
An upholstery shop could help too; they might be able to dye the seats if you want to go that far. The Resolve suggestion would be a lot cheaper to test on your fabric though.
