Jeep Liberty Diesel
1155156158160161224
  • synlubessynlubes Member Posts: 184
    my crd is going into third for no reason will not come back out till i shut off the engine and restart then the engine lite stays on anybody had this problem
  • guestguest Member Posts: 770
    Anyone reached 50,000 miles or more? What problems so far?
  • goodcrdgoodcrd Member Posts: 253
    Take it back to the dealer. When this trans experiences a problem it will stay in the gear in which the problem occurred. It may be a bad soleniod in the trans. You are re setting the system when you turn the vehicle off. Take it back to the dealer before it needs to be towed!
    Check the Alternator and Battery before going any farther with repairs. Have it checked on a battery/charging system testing machine. Anything electronically controlled is voltage sensitive. A bad diode in your alternator can also effect your electronics. These red top Optima gel cells are turning out to be junk and causing some electrical related problems. The yellow top Optima gel cells are much better for this application. Jeep is replacing the Optima with an Orbital battery. Go figure.
  • justmecwjustmecw Member Posts: 20
    No. Just disided to look for it. And after a quick look could not find it.
    Has anyone considered that the throttle body is causing the egr problems? The only reason the crd has a throttle body is to make the egr work. I think it could be causing the long turbo lag that some people are having.
  • siberiasiberia Member Posts: 520
    link title
    Check out this link CW. There are pictures of the valvola EGR elettrica (EGR valve) and the EGR cooler. If you look at some of the engine pictures you can find where the EGR valve is located on the left rear of the engine. Also, there is a good picture of the valvola a farfalla (intake throttle valve) including the cheesy little plastic gears that run the thing.
  • caribou1caribou1 Member Posts: 1,354
    I have more than 50,000 miles and have had only a mechanical fan clutch problem since day 1. It had too much play. I expect to keep my brakes another 20,000 miles and change the timing belt at the same time. I never had loose turbo hoses or any kind of spill besides the oil I put on all hinges.
  • lightnin3lightnin3 Member Posts: 153
    Yes going on 65,000Km's.Here in Canada.
    Had The egr Cleaned out once but no problems since.
    It didn't really affect engine performance,just an irritating yellow indicator on the dash.
    I have been using B.P. Premium Diesel when I can,and Shell Ultra diesel.
    I think it helps keep things cleaner,and better mileage also.Plus "lots of power !"
    This is an amazing product .I hope DCX comes out with more.
    I believe with the advent of "clean Fuels"....
    We'll be seeing more Diesel engines on the market,like this one.
    Now I am looking forward to some preventitive maintenance.
    I feel she is ready for a fuel filter change ,and switch over to my "Sport King AT" winter tires.Great for the hyway use..
    Now I'll ne ready for my annual Ski trips in the mountains...
    Later..
    Lightnin..
    Hi lightnin3,
    You may have to wait another 10 years if you want to push this rig to the end ;)
    By then we will all be using B/W video conference on this board :shades:
  • faroutfarout Member Posts: 1,609
    justmecw: The answer to thhe cause of the EGR failure is the PCM. Those dealers who replace the PCM with ERG don't see any more EGR problems. But, then again what would the dealer who sells the most Jeeps, and including the Liberty CRD, know about fixing the EGR problem? The TEC has been to V M Motori, in Italy, and helped with problems in the factory. But unless we insist on having the PCM changed at the same time, the dealers will have a back order on these EGR's, as they do now.
    There is nothing you can do to completly stop turbo lag.
    The reality is the turbo can't speed up until the exhaust gets to it.
    Farout
  • hellodieselhellodiesel Member Posts: 10
    Hi Farout,
    You may remember I had my EGR replaced some time ago, and I don't believe they replaced the PCM at that time. I don't see any paper documentation of it being replaced. Do you know what the part #/brand of the revised part is? I'd like to check mine to see what I have installed now. Looks like I may be due now for a new EGR flow control valve, and I would like to have my ducks in a row concerning the PCM at that time. Any information or direction is greatly appreciated!
    Hellodiesel
    hellodiesel:Part # for the PCM is 56044562CC Hope this helps.
    Farout
    Im not disagreeing Im just giving food for thought. But maybe they are trying to fix the wrong problem. By doing the flashes to fix the EGR does not seem to fix the problem. Posably what they should be fixing is the throttle body programming and by them changing your PCM the new one may have the right programming. If this is correct just changing the PCM will not guaranty that you will get a PCM with the right programming. Maybe the fix for everyone is a simple flash of the throttle body programming.
    As for the turbo lag. On my crd the turbo lag does not feel like the normal turbo lag. If I floor it from a stop it starts with about 10% power and when the power hit it will be a quick jump straight to 100% power. On every other turbo I have driven I could feel a quick rise in power not one quick jump. I is almost like the boost have built up and something quickly releases it.
    Just food for thought.
    Thank you. It was a big help. If I am correct the crome pipe going around the back of the motor is connected to it?
  • nescosmonescosmo Member Posts: 453
    CW.... I wish that mine do what yours do I love the lag it is like been in a jet power plane. Ever since they flash my computer the lag is gone, the rise is smooth like a gas car, not bad but i will love to have the lag.
    nescosmo
    If I am correct the chrome pipe going around the back of the motor is connected to it?
    Yes, that is the pipe to the EGR. But, I don't recall the pipe on my engine being chrome. The engine in the picture may be dressed up a bit for show. Not sure.
    nescosmo Can you tell me TSB the flash was for.
  • frostyyfrostyy Member Posts: 52
    Rumour has it that the 2008 Liberty may have an engine option for a diesel (late availability)....anybody interested???....most likely it will be the Mercedes diesel...
    CW....On 4-21-06 check engine light came on, took it to the dealer and they found bad EGR and #3 glow plug open. to tell you the truth at the time the CRD to me was working perfect. well this is what they did from the ticket:
    M 5142577AA glow new.
    M 5166555AB EGR Valve new.
    M 4669020 Flash new.
    M 4275086AB Flash new.
    Those are the flash that they did; ever since that time the CRD is just like a gas car. (all of those flash were made to the PCM) no more EGR Problems since. Hope it help.
    the 2007 grand cherokee gets the crd i posted it last week3.ol 376 pounds of tork i am looking at a picture of it now the jeep book came with my crd i get it every month with all the new products
  • mgrinkermgrinker Member Posts: 1
    We needed a new ECM at 10K - we were down for 5 weeks!! Our dealer paid the extra rental fees, but when we filed with Chrysler to go through the Lemon Law, Chrysler tried to make us pay the $1238 rental fees! Has anyone else had programing problems? The ECM arrived in about 2 1/2 weeks, but our dealer could not get it to program. Took 2 visits by Chrysler techs to get it done.
    The web site is Mikes totally free Jeep news. There is just as likley a chance it may come from Cumings. The huge if is, will the diesel be for the USA or Europe? That we know about 99% for sure Europe will get a diesel, but the USA us a different story.
    Farout
    siberia: Where or how did you find this information? The pictures are the very best I have seen of our CRD! You deserve a huge "thanks a lot!"
    Farout
    justmecw: There is NO way not to have some turbo lag. I drove one CRD that took almost 5 seconds to get the message to get it moving! 5 seconds seems like a lifetime when you find a 18 wheeler headed right at you, because you forgot to look at what was in the lane to your left, as your making a left turn! It is at moments like this that 5 seconds seems like 30 seconds. I have tryed to time the lag, I can't. but it's less than 2 seconds. I have spun all 4 wheels in 4x4 from a dead stop.
    The reflashes is what caused my problem. You can't go back to a flash that worked so well before. Once the flash is done that's it. Flashes are just a chance you take, if you and the Tec thinks you CRD will do better if done. My PCM was replaced because our fuel milage dropped to 17 right after the two flashes he did. There was a speed control that just would not stay in place on even a little hill, and it poped out. We also were getting a lot a jerky , like back and forth type on jerkyness, and the PCM stopped that as well.
    We have heard from some in this forum that has had as many as 6EGR's replaced. Not one has the PCM replaced at the same time. Yark has NOT had a returm EGR after they started replacing the PCM when EGR was replaced. Think there might be a connection there?
    Farout
    This week I have been driving our 06 3.7 Liberty. I have made a huge discovery! The light I thought was the Glowplug light is actually the Security sensor light! The glowplug lighy goes off so fast I never have seen it. Here all this time (one year) I have waited for the Security sensor light to go out before I started the engine. We did this because the salesman told us that was what the light was for.
    Has anyone else had this happen as well? No wonder the few times we didn't remember to waite for the light to go out, the engine has started just fine, even in the coldest temp.
    Also the ULSD sticker that is to be posted on the diesel pump, can not be put on until the ULSD in the tanks is 85% ULSD. There are some being posted here now. I see no difference in the way the CRD runs. However I am going to start using PS Booster asap.
    Farout
    Farout
    Farout.... I am sorry but maybe my CRD is from mars, but i do not have any lag ever since they reflash my PCM; From stop no lag go in to the freeway, no lag it just run like a gas car. I do not know what that tech did but but since april it run just like that. sorry but that is the truth. Your are welcome to check it out.
    one in Illinois had about 22k miles and one in Texas had about 30k miles.
    Would like to hear the stories about why they were traded in.
  • zachinmizachinmi Member Posts: 228
    My CRD has had less than 1 second of turbo lag since it was new. One full second would only be if I go from idle to floored. In routine driving I would say there's 1/2 second or less for cruising to major acceleration, and no significant lag for mild acceleration. I have had the update that came out in March (April?) but not the most recent update. My CRD is a 2005.
    I have driven a few turbo cars, mostly SAABs and Volvos. The 1980's SAAB 900 turbo had horrendous lag - you'd floor the gas, wait literally 2-3 seconds while nothing happened, and then you'd get an enormous blast of acceleration. The joke name for SAABs used to be "Suddenly, An Amazing Burst!".
    The early 2000's SAAB 9-3 and Volvo S40 (turbo) both had very mild lag; you'd push it and acceleration would quickly, fairly smoothly ramp up. I believe the S40 had a "dual scroll" turbo that was supposed to reduce lag. The Volvo S60 T5 had a bit more lag, but was tuned for maximum power rather than driveability. However, our CRD has a variable nozzle turbo that is pretty much state of the art for reducing lag. At least it was until BMW came out with a turbo engine this summer.
    MY 2005 CRD HAS NO TURBO LAG BUT I HAVE A AREO TURBINE MUFFLER CREATES SUCTION INSTEAD OF BACK PRESSER TURBO SPINES UP A LOT FASTER
    Farout,
    The serial number of the original software figures is on the label of the controller. If your tech had the proper training and equipment he could save you a copy of the original version or of the one you preffered after a few trials.
    The original software can be re-written into memory any time as long as DC provides it to your service technician. Any software version or patch can be considered like a picture in the memory of a digital camera.
    Racing cars get different 'patches' for different tracks ;)
    Formula one cars are said to be remotely flashed during the race. They can't do this during pit stops because 4 new wheels, gasoline refill and oil level in 8 seconds is a bit too tight. I wonder if the pilot takes a nap during service :confuse:
    Farout, either someone posted the link a long time back and I saved it or I found it on the VM Motori site. I don't remember.
    Hi Farout ..
    Any change in performance with using ULSD ?
    I have found a big difference in power and mileage while using the "Shell"Diesel Ultra 50 Cetane fuels or B.P supreme Diesel. instead of the regular fuel.
    It's not ULSD but the next best thing.
    But I also suppliment it with power service.
    The power service ,
    I'll pour a half bottle in the tank on a fill up,and I find this gives a big boost for trips and towing.
    Speaking of boosting power..
    I also have a supplier close by for "Stanadyne performance formula".Have you heard of it??
    Which I find is a more potent suppliment.possibly more concentrated.
    Plus I get more boost with a minimal dosage,and I can buy a years worth and save $$$'s.
    The only time I get turbo lag is when I fill up with the cheap regular fuel,but then at that time I'll use Lucas formula and it seems to help performance.
    Also why I think my EGR problems went away...
    What are your thoughts??
    Speak Soon
    Lightnin...
    A little more food for thaught. Does anyone know if the crd has a variable vain turbo. variable vain turbo's have vain's that can speed up the exhaust going into the tirbine by reducing the area the exhaust has to pas thru. I these vains are not moving correctly it can cause a long turbo lag and not giving enough boost at light throttle reducing fuel economy (less compression and air) and maybe cause egr problems because the fuel is not burning completly.
    Can anyone agree or disagree with this.
    have one on order now transmission locked in third gear
  • zoomy2zoomy2 Member Posts: 50
    (to the host: I'm not going to start a new thread so I'll say what I have to say here.)
    I have been using ULSD from a all new station in town and I can tell the difference my average mileage went up by 2.1 mpg and much better power and little to no smoke even at starting in this cooler weather we are getting around here. I haven't used power service since last winter I might try it again this winter but we'll see.
    Farout a friend of mine knows you friend Dan at Yark's, my friend use to work at Yark' Jeep in Toledo.
    Fourwheeler magazine (Dec. '06) tested their loaner 2005 CRD with homemade B100 and they stated" the engine ran poorly and even stalled on occasion" and went on to say " no richer blend than B10"...
    Fourwheeler also tested a device in the 2005 CRD called a "Fitch Fuel Catalyst" (also one by Walker) and got an average of 1.2 mpg better, they said it was a "fuel polisher" what ever that is?? :confuse: Has anyone here ever heard of it or tried it?
    enjoy reading all on the topic but don't have much to say. :D
    Hey does anyone have a whining noise that it sounds like a coming up through the gear shift selector..and also when i put it into 4wd i have bad vibrations..does anyone have any idea i have just turned over 18k on the speedometor
    Yes, the CRD has a variable nozzle turbo. There are several kinds of VNTs but the most common, and the one in the CRD, uses variable vanes like you describe. These are prone to failure with age, but I haven't heard of any VNT failures on the CRD.
    zoomy2, a few words about the "fuel polisher":
    It can be a set of 2 magnet holders that you place around the fuel line. The magnets come together when nothing sits between them.
    I've tried something similar in the past with no result. For sure, if this would work we would already have it built in the filter housing or casted in the common rail itself...
    When used for softening water this system is supposed to help forming smaller 'CaCO3' (calcium carbonate) crystals. For household use the magnets are often replaced by two coils you wrap along a pipe. There is a variable frequency generator that powers the coils and replaces the permanent field of the magnets. I have friends who use this since 25 years and still don't know if it really makes a difference :confuse:
    I heard that if there is a 'change' in a liquid, it should only remain 'changed' for a very short period of time. This means the accessory should be placed close to the point of process:
    - the diesel pump,
    - the nozzle of the oil burner of a furnace,
    - the inlet of a water heater.
  • anomiousanomious Member Posts: 170
    http://www.aempower.com/ViewProduct.aspx?ProductID=1151
    This might be the answer to the air box problem.
    Let me know what your opinion is. Thanks! LK :)
    Please go to the group top level and create a discussion that fits your comments/questions or post in an existing discussion.
    Jeep Liberty and Jeep Liberty Diesel
    Enjoy!
    Something must change:
    DC broadly uses Bosch components as we all know.
    A colleague drives the Mercedes-Benz ML 400 CDI;
    even using (U)LSD his EGR components had to be replaced twice under warranty in 18 months! :sick:
    Is it that bad with the Liberty diesel?
    LK :)
    Hey Tideseter, way to go! I am a happy camper once again! I think you opening this forum proves that you do listen to peoples suggestions, and I admire you for doing this.
    Please don't get all teary eyed, I just thought you needed some GOOD feed back!
    Farout
    The first indication of a problem hit on Sunday evening, the malfunction light came on and has stayed on. When I restarted the engine the exhaust smells like an old greyhound bus with a million miles on it with never having any work dome on it! Now every time I start the engine the diesel smells like diesel. I have tried to get a code to show up by switching on and off the ignition switch 5 times. Is this the way an EGR shows up? I sure hope not.
    Called several dealers, getting any one to look at it before Thursday is very hard to do.
    I am on the edge of wondering if I am joining those who have serious problems. This just happened when I started using SP Cetane booster two tanks ago, is there any the PS booster caused this?
    Any ideas would be helpful.
    Farout
  • semperfi06semperfi06 Member Posts: 20
    Farout: I hope you can get this resolved easily and quickly. I have been using PS booster since August in our Liberty...over 10k miles now. The summer formula until a few weeks ago, now the winter one...both from WalMart. As I have said before, I also run S15 with 5% Bio from the pump. At least you are under warranty with the maximum care service contract, so at least you can get a rental. What I am mainly worried about is what happens after the warranty runs out if Chrysler doesn't resolve what these problems are. Don't think anything I've said will help, but I'm very interested in your outcome, and like other CRD owners, I probably have a stake in it.
    SemperFi06
    Farout,
    Can you describe the smell? Is it the same smell you have while re fueling at the filling station or is it a 'dry and suffocating' sensation like an absence of fresh air?
    - In the first case the catalyzer would no longer be working and un burnt fuel would give you this smell. You then have grayish fumes when the engine is cold.
    - In the second the EGR valve stays open. If you disconnect the cable going to the actuator of the EGR valve (not the flap) and knock on the valve body a few times there is a chance it comes back to it's closed position.
    I have the impression a simple relay inserted between the controller and the EGR actuator would help. On my truck I only have a little vacuum actuator instead of the EGR solenoid connected directly to the controller, and mine draws very little current compared to what you have. It should be worth a thought because we use the same controllers and pulsed switching of an inductance with a solid state relay can sometimes be tricky and could explain why there is a need to replace the controller :blush:
    caribou1: It has been a good length of time that I last heard from you! You would never believe what this turned out to be.............Yep............EGR VALVE!!!
    I thought for sure I would would not get that dreaded bite of the EGR SNAKE! My Jeep dealer said on the phone it just could not be the EGR valve, or a code would have been seen on the dash speedometer. So.....seeing as the Jeep dealer was so sure it could not be the EGR valve, I took it to the Dodge dealer that works on loads of Dodge diesels about 55 miles away. They had the results in less than 20 minuets. They ordered the EGR valve, and I take the CRD back Thursday to have the new EGR put on. By the way the Dodge dealer found no back loge, in fact St. Louis, MO had 17 in stock! Which brings to mind that several have said they had to wait for to two weeks to get an EGR valve! And that they had to leave their CRD at the shop until it was fixed. Wonder why others have such a hard time?
    I did ask how much the EGR and installation was going to cost DCX, they said a little over $500.00 US.
    The EGR valve is in the open position, and it has not near as good a pick up and go as before. The cause they said was some open circuit, and I have no idea what circuit.
    SO.........I am now part of the CRD-EGR gang. I really thought I was going to miss the EGR failure. By the way my CRD was built June 17, 2005, which is a late build date for the 05 CRD. But even with the EGR out we are getting 23mpg.
    After talking to Yark Jeep Tec, about this he said DCX is now saying that using PS Cetane booster, or the other PS product may be the reason for early failure of the EGR, and that the Mobile 1 0-40w is what DCX is attempting to say keeps the Turbo, and other parts better lubercated. I am seriously considering going back as the Shell Rotella T oil is being discontinued and going to change to a mineral base. Has anyone heard of this?
    I intend to watch this replacement so I know more about this EGR. I sure am glad this forum went back to the way it was.
    Farout
