Visitor Agreement.
It is interesting that my EGR "failed" after using 3 or 4 tanks of fuel with Cetane number improver. Coincidence? Maybe. The valve did not look dirty enough to blame the failure on either soot or fuel additive. I believe there is a story going one here that we have not heard yet. The EGR valve will turn out to be quite the little money maker for DC after all our warranties run out. Conspiracy theory? Nah, just good planning.
Could you please ask the people who replace your EGR valve to hand it over to you so that you have a chance to obtain a decent diagnostic from another person?
It would really be nice to understand what really goes wrong such as:
- a stuck stem,
- a corrosion problem,
- a short circuit,
- a broken solenoid lead,
- a melted connector,
- a loose contact,
- a defective power outlet on the controller itself in the case nothing is wrong with the valve and it's matching connector.
This would certainly help the community appreciate the little diesel engine to it's real value and not threaten our savings.
I don't think DC is ready to face a coalition of knowledgeable owners :P
Farout
Did you get your problem taken care of?
Farout
I doubt I will use the additives again, and I am going back to the Mobile 1 0-40w soon. Dan said the 0-40w is one way that DCX and Motori have to keep the emissions problems to the least number possible. I do not know how to agree or disagree with that, so I will think about it and just see.
Farout
They al were supprised at the turbo and said it was a good one. Now seeing as I know zip about most of this engine, everything I learn is not going to waste.
I am interested to see what an EGR looks like, and how big it is. I can tell you There does not seem to be much if any difference in the way it drives, just smells like diesel fuel, no smoke just a smell like someone spilled some diesel fuel. That's how I smell it.
Has diesel fuel gone up or down in price in France? Here it's $2.50 a gallon, and been this price for 3 weks now.
Hey, I did see the Dodge Niotro yesterday. A nice 4x4 with a 3.7 equiped simular to my Jeep was $22,390.. So cheaper than the Jeep Liberty now. More back seat leg room, and more storage room in the back, but the windows have a smaller hight. Sort of looks like the Chevy HHR.
Farout
Has anyone else had similar problems?? Thanks
SemperFi
SemperFi
Nescosmo
I had the PCM replaced about 6 to 8 thousand miles ago, and there was no need to replace it or reflash anything.
The difference I noticed after the EGR was changed is the idle was smoother, and the not as rough sounding, pick up seemed better as well. I have gone 185 miles on 1/4 of a tank which is much better than before.
Hope this helps. I hope this one lasts forever.
Farout
Farout
http://www.xtremediesel.com/index.asp
They offer several choices of power modules. I have yet to buy one as more and more keep coming to the market for our CRD. If you do purchase one, make sure its is an upgrade able model as updates can be downloaded from the manufactures website. Ebay has a few as well, go to Ebay Motors and in the parts section Type JEEP CRD and you should see a few by SP Diesel that offer an extra 100lb ft of torque. The only thing stopping me is the fact that I'm still under warranty. But as soon at that's over, so long muffler, hello bigger turbo and 2.5" lift. Good luck, please report back to us with your choice of module and results.
Here are two pictures I "borrowed" on the web.
This is the flow metering valve (that looks like a carb):
This one is the EGR valve that collects exhaust gas, has the cooling circuit and the solenoid:
Is it the first object that was changed on your truck?
The air flow control valve is looking towards the intercooler (front of the truck).
Does this help you identify the component that was replaced?
Nescosmo.
I saw your post about the "late shifting transmission." Is this the TCM reprogram recall that came out for the 2006 CRD? Our 2006 CRD has been running great with no problems (knock on wood) and it has a little over 6K miles. I too am reluctant to take it in fearing it may come back with a problem.
RangerRod
"Rangers Lead the Way"
Clue me in, what is all these pictures about?
Farout
The 06 gas Liberty we got for our daughter, has now 4,900 miles on it, I put Mobil 1 5-30w in it, and it seems a little quietiter. I will change oil in it every 6,000 miles. It is nice to compare the two liberties, and I can see real quick what the differences are. One thing that I notice is how little it takes to make the 3.7 to move. The 2.8 is easier to have more control in slow speeds. I believe the 2.8 would prove to be faster in a short race, and maybe the 2.8 has a longer range for the passing gear to get into. That might also be because of the 545 RFE transmission. I wonder why the 545 RFE is not with the 3.7? The Commander 3.7 has the 545 RFE in it. Never drove one, so I don't know how it drives.
Farout
Farout
This CRD seems to be a tough engine, but,..... this is DCX's first totally computer controlled power, transmission, and emissions, and what ever you can imagine.
Even the speed control is computer controlled, rather than servo controlled. (which I like the servo type much better)
I hope this helps a little bit, and welcome to the forum.
Farout
Do not buy a diesel!
I think we are getting a better view of the symptom now.
This fresh air valve allowing the mixture with exhaust gasses seems to be the common issue on both continents. All manufacturers using this equipment face the same risk.
The valve could get mechanically stuck or delayed in it's response to the controller by the viscous compound of oil fumes and soot that can harden with time and perhaps vary with temperature.
- Oil leaking from the turbo bearing is common when considered individually.
- EGR valves on diesels are also common and reliable when operating individually and not controlled systematically by an emission limitating system. They work in a harsh environment and are designed for the purpose.
The new configuration where oil plus soot plus an intolerant controller can easily trigger the engine malfunction light. The variable viscosity of the compound could also explain why it's so difficult to get a clean cut incident that anyone can diagnose.
Now concerning oil, I can not say one make is better than another as long as they are comply to the specs (MB229.3). Going back roughly 40 years ago this was a completely different story:
White Rose, Shell and other lubricants from major refiners were of one kind; oil sold by discount stores seemed to come from another world. :sick: :sick:
The more I think about this mixing valve, the more I get the impression a few people should try to clean it with gasoline and a brush, then report if any success. This component is the only difference there is between my truck and yours. I don't have this flap :shades:
http://cgi.ebay.com/ebaymotors/NEW-SP-DIESEL-05-06-JEEP-LIBERTY-90-HP-MODULE_W0Q- QitemZ120055029980QQihZ002QQcategoryZ33597QQrdZ1QQcmdZViewItem
Claims 90hp and 150 lb ft of torque increase. Is this the one you have?
-the stainless steel pipe you can observe (fixed with a spherical collar) connects to the intake manifold from the bottom and goes to the EGR valve located on the other side of the engine.
You can see that it was already done like this on the model year 2003 :shades:
When you get too much fresh air, you are in a leaner mixture condition. Nothing to worry about for the engine but you are breaking the law :sick:
I have not yet taken time to look at the 2.7 CDI. I would like to understand how to profit from today's CRD just in case someone runs into me and I need a replacement
SemperFi
This looks like a good one, Check it out too.
LK
Digi CR -about $539.00
Predetor about $499.00
Optima about $15.00
Race Accelerator about $59.00
Power Box about $199.00
Ts Performance MP-8(dr-2030) about $379.00
and there are some others that I can't remember.
The best are Digi CR, Predetor and TS Performance.
Nescosmo...
Nescosmo
What I have done is disconnect the actual EGR valve, as the CRD is very doggy off the line & blows lots of smoke. I think the EGR is on full trying to get the desired flow.
It now drives like a car off the line, with the turbo kick.
My last tank was 27+ using ULSD. The only annoyance is the MIL on all the time.
