Visitor Agreement.
I have a 1999 S-10 Ext.cab 4x4 and it's been nothing but a nightmare. The biggest problem is this engine noise it's had since day one. Kind of sounds like a loose rocker arm on the older small blocks. First GM said it was normal, due to the new design of the engine; NOT. They then replaced the lifters, which only fixed the problem for two weeks. After several phone calls and some research, I found this is not an isolated problem, in fact GM is aware of it, but they do not have a fix at this time. My vehicle was in the shop for a week this last time and I was told all they could do was soak the top end in engine cleaner, that is was a carbon build-up problem. So if any of you believe that, you'll need to bring your trucks in every 10000 miles for it's quarterly cleaning. Oh yea, engine still has the problem. I'm trying another dealer this week. Just thought this info might be helpfull to some.
hope this helps.
I have the stock 4 speed auto. and the stock 3.42 gear ratio. (I thought about getting the kit that allows the F-body rearend to bolt up to handle the extra power that I will be adding.)
fuel injectors?
Also, does anyone have any idea how to find out if a vehicle was involved in any natural disasters? (aka The floods that happened in northwestern Minnesota/eastern North and South Dakota?
I take care of my vehicles and they last. GM has been good to my family. Maybe you have the "lemon" every manufacturer lets loose....I dont know. Why dont you trade that thing in? If you try to do that and they say something needs to be fixed its still under warranty isnt it?
http://www.s10xtreme.com/
=======>-----------------o) Joe
what the redline is for this particular engine?
also, what are the torque and horsepower numbers for this truck? i cannot find the numbers anywhere. by the way, i love my chevy and i am getting 27 mpg on the highway with it!!!
Make sure you use pellets from GM in your cooling system to keep your intake manifold gaskets from going bad.
the letter reads:
"This letter is intended to make you aware that some 1998 and 1999 model year S10 trucks, equipped with a 2.2L 4-cylinder engine, may experience illumination of the "Service Engine Soon" light, engine misfire, rough idle and hesitation. These conditions may be due to spark plug wire failure. The cause of this condition may be improperly seated and loose spark plug wire terminals. If this condition occurs on your vehicle with 7 years or 70,000 miles the condition will be repaired for you at no charge."
Well, that just about sums it up, hope it was of help to some of you. I only hope you catch this problem before I did, I ended up broken down on the way to work and it took three attempts by Chevy to fix the problem (one of the many reasons I no longer own a chevy)
I've got an old 1985 2.8L V6 Ranger, I get about 15-16 MPG around town and 19MPG highway (5sp 4x4). It has proven reliable, but I'm thinking of trading it in for a mid-90s Ranger or S10. But I'd definitely like better MPG in my next truck.
Thanks in advance for any info.
Install a pair of edelbrock headers also 450.00 and the performance is definatly noticable. Sounds a lot better and it's also quicker. Edelbrock claims up to a full second faster 0-60.(But I think that is for a fullsize truck.)
Either way they are both an excellent upgrade. But if you get the headers make sure you have and aftermarket exaust.
also, i am still wanting any comments about the 2.8 chevy engine and if anyone out there has torque or hp numbers or redline, send em my way, please.
I bought my '95 S-10 new in 1994. It's a 4.3L auto that currently has 53k miles. It rides great, has a ton of power, and has spent very little time in the service dept. Only problem was a fuel pump replacement (under warranty) at 25k miles.
Only time it was ever towed was when I left the dome light on overnight and ran out the battery. I turned off the light and played dumb like I didn't know what was wrong. GM Roadside Assistance towed it in to the dealer and they replaced the battery under warranty.
It's paid for, it looks good, and I plan to keep it for at least another 5 years. Knowing how badly many GM cars/trucks are built, I consider myself lucky.
This is a second gear start. Of course the truck will act better in the snow with weight in the back, but this is just an additive that a lot of people don't know about.
I think I'll get the new K&N intake (think its called gen III, anyway its a snorkel) or something similiar, I've heard the stock airbox is very restrictive, and I'll be able to put it back to stock because the chances are very good that I'll order a '01 S10 with the options I have now.
Keep us informed on your truck and the mods you made.
I think he's right, this engine likes to run.
I lit em up for longer than 15 feet! The traffic wasnt moving, and I was first at the light. It turned green ...........heavy right foot, 3.42 posi... I was sideways for half a block, never did that before!
I've got an old 2.8L Ranger and I get about 15mpg around town and 19mpg highway as well. I might trade in for a new 4cyl Ranger (there's a new OHC 2.3L 4cyl coming this fall) or save a few bucks and pick up a mid-90s S10 or Ranger. Sounds like the Chevy 2.8L isn't a bad engine; 26MPG on the highway isn't bad at all.
Hope that helps.
'91 S10 Blazer 4.3 The '87 was very reliable, best trouble free vehicle I have ever owned. I only performed minor tune-ups, plugs, disc pads...
It was a great off roader, BUT THE 2.8L IS VERY VERY GUTLESS ON LONG STEEP GRADES like the infamous GRAPEVINE hill in So. California. The
proper engine replacement would be a GM 3.4 V6
from Chev Lumnina. It is a shoe in. The '91 S10
Blazer was a horrific LEMON, full of defects and
problems. I got rid of it after 80,000 mi. Have
a '00 S10 Xtreme with vortec engine. Bought it
in Jan and currently have 12,000 trouble free miles. Hope Chevy has finally got their act together.
I was told that this was to help keep the trucks straight during hard acceleration, but I still fishtail. Keep on truckin bud. Chevy for life..
1. Every 35k change transmissions fluid. The standard is pretty easy to do yourself
2. Every 35k change fuel filer. This is a [non-permissible content removed].
The secret is to spray wd40 all over it to remove the old one from the bracket.
3. Constantly grease the front suspension. Clutch too.
4. Do not forget the air filter that sucks up everything up front.
The key to a good long lasting s10 is maintenance and upkeep.
Good luck!!!
Fuel problems with 93 W motor are in the injectors. The injector w/6 arms/nozzles (all 1 unit) was $400 at Napa took me 1hr to remove and replace my self. Solved the extended crank at start up, and get much better performance. Never touched the fuel pump.
