Chrysler Pacifica: Problems & Solutions
I'm having a problem that sounds like NHTSA #250938 vibration/shake at highway speeds(in my case over 90km/hr)The dealer said there is no such listing and never heard of it.
I am waiting for the 5* to contact me with their final conclusions(maybe today) which are based on testing and that Chrysler says mirrors not going to saved positions is *normal*. Of course there will be more updates as this situation progresses.
I have been getting an "Error" message when trying to play a CD in the DVD player? Sometimes it happens when I play the 1st CD then another day it was the 3rd slot. I have no problem playing a CD in the CD player, just the DVD player where I keep all 6 slots filled.
I tried using a CD cleaner disk today and still get the Error message. I have tried different CDs in the same 1st slot, it accepts the CD, then it starts clicking and making lite grinding noises then in about ten seconds the display shows "Error". I could not find in the manual what the "Error " message signifies as a possible problem. Any one have any suggestions/ideas before I take it in?
Shouldn't the battery been stronger than that in only six months? Has anyone else noticed this?
This morning (Monday) when I started the car it started a little better, but seemed to require some effort. After it started, I put it in Drive as normal. I felt the transmission slowly go into gear. By that I mean it seemed like it was slipping slightly as it engaged. Has anyone else experienced this?
Thanks...
no slow cranking or anything...
just put snow tires on it... should really grip with Pirelli Snow Tires. got them cause the tire dealer had them in stock from a canceled special order and let them go for his cost :-)
Clueless: Let's see how your Pirellis handle the snow compared to my Dunlop Snow Sport M2s! I'm pleased so far, but have noticed that the acceleration traction is better than the braking & steering traction.
braking and steering ok.. the nice thing about these newer snow tires are they are H-RATED !!! and ride quiet for a snowtire. they are only marginally louder then the all seasons. plus handle on dry pavement nicely up to 70 mphs.. at 75 it just barely starts to feel lose... nothing major just notice its not as firmly handling
the only other downside is it is more likely to pick up small rocks in the wide tread when driving on drive pavement.
not sure about the tread wear. on tirerack see the Pirelli's arent rated high on tread ware but they also have them down as TR rated when they are now H rated. I got them for $20 over Tirerack prices when you factor in the higher cost of mounting and ballancing if I bought at tirerack.
front end rumble ... still have the rumble sound as well from the front suspension. anyone else have this problem beside myself and the other posted earlier? its like he said, a low rumble in the suspension, i find over multiple bumps like the suspension wont settle down. single bumps sound ok but multiple ones sound like something is lose. have to check the mudflap theory still. forgot that when I last brought it in (too many other things on the list)
The 5* verified the mirrors do not return to saved positions. Tested voltages per Chrysler and voltages were normal. Chrysler states to 5* the mirrors are working properly and there is nothing wrong. 5* can't beleive they took this route but thinks a TSB might surface on this issue. I understand the dealer has no control over fixing the problem when the manufacturer does not know how to fix it so I am not upset with them (dealer), but rather Chrysler. I would like Chrysler to handle it better then they (Chrysler) are and I will be contacting them tomorrow.
Keep you posted
Site
I told him 3000 miles had be about right. He does short trips 1 mile and less, with occasion 10-15mile trips. This is in SW Ohio weather.
Are there any lube fittings on the suspension that need to be greased on the Pacifica?
My 98 LeSabre has 8, ball joints and tie rods.
I wish my 03 had them. I know they're greased and haven't gone bad, because I grease them. I had an earlier Ford and replaced the plug with fittings to grease them. The LeSabre doesn't have a replaceable plug for fittings. You just wait until the joint wears out and fails.
That being said, I am fumbling my way though all of the settings, and trying to be true to my manual by reading before doing. I can't figure out a couple of things tho. When I am in the EVIC - I don't see to have access to the mini-trip functions, the amount of gas remaining, and mileage functions. My model is fully loaded EXCEPT for the navigation system - Is this a part of the nav system?
Also, the EVIC default display is the number of kilometres left to the next service - can I turn this off??
Many thanks....
Alisa
But I don't know where I can find the gas info in the EVIC - I toggle thru the choices, and the only one that takes me to "sub menu" is *Use factory Defaults - no* and that takes me to a a bunch of choices, like driver's seat, lights etc... but NOTHING on gas mileage and the like...
There IS "distance to empty" and "average fuel mileage". These are accessed via the "step" button.
I will go outside shortly in the subarctic and try it. Many thanks in advance for when it works!!
Alisa
I agree - the section on the EVIC could be much clearer - It wasn't even that clear on how to access the controls by selcting NO to "Factory Settings - Default". Perhaps the quick guide has that as well, but I haven't looked at it....
This is truly a great place for all things Pacifica. It was thanks to the posters here that I ordered my extra 2 headphones through Ebay and saved a few hundred dollars.
Thanks again to all of you. :-)
HAS ANYONE NOTICED THIS?
The other side where the odometer and gear information is located is still working as is everything else on the dash.
Has anyone else seen this? What's the remedy?
We bought a FWD Pacific at the end of December and really like the car. Unfortunately, we soon discovered nickel sized motor oil leaks on our garage floor and took the car back to the 5* dealer. They said the oil pan gasket needed to replaced and did so.
The very next day after bringing it home, the car started leaking oil again--this time in little puddles :-( We immediately returned it to the dealer, who said that the part that was installed turned out to be defective and they would order a replacement. We're supposed to have the vehicle back on Tuesday, but were just curious if anyone else has had problems with oil leaks...we sure hope this doesn't turn out to be a continuing problem.
Can anyone with this system shed some light on this process - i.e. what sequence of buttons I should be pressing once I put a DVD in and I turn the headphones on?
As always, many thanks for the answer I am *sure* I will find here...
Alisa
The short answer is NO. If a company wants to promote a new product and it's reliability then it should be willing to back up their claims by standing by the product.
I am self employed and can not afford numerous trips to the dealer to fix problems on a new car that should not be there. If any dealers are reading this post go ahead and reply. I would love to know your position.
See the link below:
http://www.autointell-news.com/News-2003/June-2003/June-2003-3/Ju- ne-18-03-p3.htm
Further, the contract is not just to provide a loaner if the car has to be held overnight. My paperwork specifically states that a 'First Day Rental Allowance' provides a rental for any same-day mechanical or maintenance service. The only time its not covered is for repairs necessitated by collision.
I have the coverage for 3yrs/36k miles at no charge, and did not purchase any type of extended warranty to get this.
- James
Let the dealer work on it immediately and get paperwork each time, in case you have tire problems after the car is out of warranty.
"Purchase or lease a Chrysler Pacifica or Chrysler Crossfire, and you automatically receive the Chrysler Premium Care Plan, including a NO CHARGE complimentary loaner vehicle anytime your vehicle requires service during the first three years or 36,000 miles."
I used it when I had my first complimentary oil change done and also had my hitch installed at the same time. The only downside is it is usually a rental car. On my Infiniti, my loaner is usally a Infiniti right from their lot (but I certainly did not pay Infiniti prices for my Pacifica). All in all, it's a great program that no other domestic manufacturer offers.
I e-mailed Chrysler directly to understand why they offer a program that the dealer is not aware of (and of course acknowledges).
One of the largest problems Chrysler is going to have trying to move upmarket with their product is the weak link in the chain, the dealers!!
I heard on the radio yesterday that the Chrysler dealer network will be spending about $1,000,000,000.00 (2 to 3 times what they have been spending) over the next couple of years to upgrade the dealerships. Chrysler will continue to try to move upmarket with their product by introducing a record 25 new models in the next 2 years. If only they could buy competent sales, service, and dealer management!
I am in sales so for me being off of the road is just taking money out of my own pocket. Having a free loaner is an additional incentive that was an important component of my buying decision on both my Infiniti AND on my Pacifica
The point for me is the convenience of the loaner for both my Infiniti & my Pacifica
