Dodge Dakota - II
This topic is a continuation of....
Topic 19 Dodge Dakota.
We have split the topic for performance purposes.
The original topic will be frozen and eventually
archived. Please continue here.
Front Porch Philosopher
SUV, Pickup, & Aftermarket and Accessories Host
Well, Jim, I hope I haven't pissed you off more, but I have been a die hard Mopar fan since the mid sixty's, and I think there is not a better truck on the road today..period..
BTW -- The Ranger has been an execellent and reliable truck. I was going to get another one -- but 4.0L Rangers cost more than V6 Dakotas, and the Dakota just made a much larger impression.
I picked up a 98 Dakota Reg cab Sport with the 4 cylinder engine. Great fit and finish, great looks, and great handling. The engine?...That's another story.
What kind of idiot gets a truck with a 4 cylinder engine? Big mistake. My thinking was I drive 30 miles each way to and from work and don't haul a trailer of any kind. Why would I need anything bigger that a 4? Also it would help with the gas mileage.
Well, I not sure if the problem is a small engine or just a crappy one. About 5K miles after I bought my truck, I started noticing a clicking sound coming from the engine compartment throughout the rpm range, but especially at high rpm. Sounds like valve clatter to me, but I'm not the expert.
I now have 29,500 miles on it and the warranty is about to expire!
I've taken it to three different Dodge dealers to fix the problem. The first two said they didn't hear anything. The last dealer told me the same and even said he took it on a test drive and didn't notice anything.
However, I checked the odometer before I brought it in to the last dealer. When I picked it up I noticed that the odometer had only turned 1 block. So much for a test drive!
When I confronted the technician after sweating a little, he told me that I must be maxing out the engine because a four cylinder maxes out at 65mph in that truck? So, am I to believe that I'm not supposed to even get up to the speed limit on the interstate in this truck?!
I'm not the only one who has heard this noise. Everyone who has ridden in it has commented on it.
If I could get the dealer to admit that there is a problem, then I could use the Lemon law.
By the way, I also have uneven wear on my tires, and after having the dealer align it once, it still pulls fairly hard to the right.
Any suggestions would be greatly appreciated.
You should have determined if you could live with the small engine before you bought it. Anyway, it should not hurt the engine to run it hard. Your engine clicking is probably not a mechnical problem. It could be the fuel injection system -- they almost always make an audible clicking sound.
If you believe there is a problem, get the service manager to take a test-ride with you. They should at least be able to tell you what is causing it.
Have never seen one of these trucks with a 4-cyl. Don't think they sell very many. Chrysler should drop it, it's just too small for a truck this size.
Love my V6 Dakota!
If the noise is from the fuel injection system, will it have a rhythm to it or will it be random. The noise I hear is a random one. (It could be something like a series of fast clicks followed by a few slow clicks, then a couple more fast clicks, then nothing for awhile, etc.)
You're right, this truck is closer to a full size than a compact, and Dodge should stop offering the 4 cylinder with this truck (even with the manual transmission)...future owners take heed.
Enjoy your V6 and thanks again.
Owned it since it had 27K on it....it now has
160K.
I have never owned a more reliable vehicle.
Fun to drive? Not really, but that's not
why I bought it. I bought it to haul, which
is does without a whimper.
Besides the normal tires/brakes/battery/oil
stuff, only things I have replaced have been
the cat converter (at about 100K), power steering
pump and water pump (at about 150K).
The V6 is only adequate...would love to have the
V8. I think the newer V6s are more powerful,
though, so that may eliminate the need for a V8.
I sell most vehicles when they reach 150K, but
I think I'll keep this one and see just how
long it'll last!
All you other truck buyers: keep buying Dakotas.
That way, Dodge will still be making them next
time I need a new truck!
However, it is definitely worse when going up a grade and/or getting on the gas. I have tried using premium gas and this did in fact seem to clear up the problem...until I filled up again with regualr unleaded.
Pre-ignition huh? Although I'm really fed up with those guys, I'll mention that to the dealer and see if that gets me anywhere. What else can you tell me about pre-igition?
Thanks alot jf!
Fuel injection and valve clatter should be steady, not random. Defenitely sounds like pre-ingintion/spark knock. Perhaps the timing is off.
The V6 is easily adaquate for a 2000 lb trailer, especially with the 2.55 axle. This motor has good low end torque.
It will start with the V-6, then go to the new aluminum 4.7L V-8, followed by the 5.9L that should be optional in the CrewCab. If they make the R/T again, I'm sure it too will have the 5.9L as well.
I think it's a mistake to drop the 5.2 from the Chrysler Corp. Lineup...it's been around a long time and runs great. The new 4.7 is supposed to pump out about 10hp more than the 5.2 and get better mileage, but I just can't bring myself to put an aluminum block in a truck as big as the Dakota.
The 5.2?, well I guess that's progress. 10 more horses, 5 lb/ft less torque, not major I guess and the towing figures don't seem any different.
Aluminum block for a truck like dakota - well I can understand E3MP6's concern, but the engine seems to have done OK in the Grand Cherokee. I understand that the 5.9 is on the way out too, to be replaced by something around 5.4l either in 2000 or 2001.
Better gas mileage - OK now here I have a problem. Gas is cheap - why do so many people get hung up on an extra mile or two per gallon when they quite happily pay $25k+ for their truck. Still I guess it matters to some people.
Apparently Dodge offered to buy the truck back but only 64 people took them up. Now some owners are claiming that they weren't offered a buy back option and today a case was filed in California for breach of contract.
I guess I'll be going back to the Dodge dealership for another round!
2000 Dakotas. Mine just came in and the invoice pricing of options was mostly the same as last year. I think most everybody has seen the base price for the 4x4 Club Cab (18,040 with 520 destination), but I have yet to see a list of option prices on the Web. Anyway, the only increase in the option pricing was $63 for the 4 wheel anti-lock ($361 versus $298 in 1999).
That leads me to a general question: Standard brakes are antilock on one end and disc on the other (I cant remember which end). Now, as I understand it, braking technique is completely different for anti-lock (hit the brakes and stay on them) vs. disc (pump them). How does it work to have both kinds on the same vehicle?
Unless the roads are very wet or icy you should have some control over steering without having to pump the brakes with 2 wheel ABS. See the other topic for more info.
a: It locks the tailgate
b: It's watertight
c: It requires holes to be drilled in my bed
d: If it looks as good as some of the other flush covers
My dealer doesn't have an example of this cover, and I don't want to order it if I won't suit me.
I also looked at the Mopar fiberglass cover, but the ones from A.R.E. and Snugtop looked better in my opinion.
Darrell
Please don't buy Mopar. The quality is the same as elsewhere (usually) and the prices are higher. In most cases Mopar accessories are made by aftermarket manufacturers (for instance Penda make the liners). Not sure who makes the tonneaus.
I asked my dealer to quote me for a package of the following:
Aluminum brush guard
Aluminum Nerf bars
under lid bed liner
fiberglass tonneau
He came back with a total price of $4,500 Canadian including tax and installation. That was a special deal as I bought the truck at the same time!!!
I went to a local store and they will do it all for $3,000 Canadian and they will replace aluminum with stainless steel for brush guard and nerf bars.
Incidentally they are near to a Dodge dealer, guess where the dealer goes if they need parts in a hurry.
Anyway, don't know much about the folding tonneau, but I would definitely recommend the A.R.E. cover. Mine (LSII on Dakota 6 1/2 foot bed), cost around $950 Canadian installed and it looks great. They also have a combination gas strut and steel hinge opening that reduces stress on the truck bed.
I should point out that not every one agrees with me on the stress reduction - have a look at the fiberglass lid topic for more details - please nobody else take issue with me on this point again.
The rear bumper has some information embossed in it about towing capacity etc. and there's a depression with a hole in it that seems to invite putting in a hitch ball.
Can you use a ball in the bumper for some light towing (e.g. bringing home a trailer with a ditch-witch on it from the rental yard - about 5 miles)??
Though I distinctly recall my dealer telling me that any sold vehicle (i.e. a customer order) went to the head of the line ahead of any trucks that were just destined for dealer's lots. After all the official launch of the new model year is October 1st.
My 2000 Dakota was delivered about two weeks ago, 6 weeks to the day after I ordered it. I got a SLT+, Club Cab, V6, 5speed with a few minor extras. I guess I am feeling pretty lucky, given the turn- around you are facing. Oh, I live in upstate NY (Albany area) if that matters...
Andy, thanks for the ABS feedback a while back!
Bruce
I am now at 6 weeks without a definite date, last quote from the dealer - "Your vehicle even has a VIN now, course we don't know what it is yet....."
I have placed the order for my accessories so as to avoid delays after I get the truck, especially as the tonneau needs color matching which might take a while with the new color (Patriot Blue).
Felt pretty smart for thinking of that until the accessory supplier says "Mmm, we don't have much storage here, you might have to store some of the bits yourself and bring them back when the truck is in". He was thinking tonneau and brush guard. Showing amazing restraint (hey this is Canada what do you expect, eh), I pointed out that the tonneau was essentially a flat pack and that the nice stainless steel brush guard that I had ordered would look a lot nicer in his store than the black one he now has.
Being the nice guy that I am I didn't even ask how I was supposed to pick the "bits" up without a truck.
Anyway, I am planning on stopping by and seeing my dealer again tomorrow (harder to hide in person than on the phone) and persuade him (in a terribly nice way of course) that a delivery date would be appreciated.
Watch this space for more exciting installments of 'How hard can it be to spend C$37,700'.
Sorry, I was worried you all might think I was rubbing it in, but I really was not...:). If it is any consolation, such luck is unusual for me! I have no idea why mine got delivered so quickly (it is Patriot Blue, too, by the way. Very nice color that I have received many comments on), except perhaps my dealer does greater volume and gets special treatment?? Could be they are picking on our "neighbors to the North". Would not be the first time...
Hope you at least get a delivery date out of your dealer!
Bruce
I hope I don't get too many comments on the color - I got the V8, so hope to be going too fast for comments!!
I have a 97 4x4 sport that I just purchased used with 28000 miles on it. Nice. Anyway, the 'key in' warning bell is driving me nuts. The sound seems to come from behind the glove box. Can anyone who has yanked this bell out give me a hint on the best way to get at it? thanks very much
CAJUN17
If your engine has a distributor and not the multi-coil packs then you should be able to adjust the timing, which is all it sounds like you need. If you do have a distributor then look at it's base where it goes into the block. There should be a Y shaped piece of metal pressing down on the base of the distibutor with a bolt in it. Make sure you put a mark with paint or white out on the distributor and the metal piece so that you can put it back to where it was if you need to. Loosen the bolt and turn it ( if I remember correctly ) counter clockwise to advance or clock wise to retard the timing. I belive you need to advance the timing a bit. Do it in small increment and then test drive it until you get the knocking to go away.
At least you have a VIN !!! I just got off the line with Daimler and they still don't have any additional info for me. The dealer doesn't have a clue and neither does the manufacturer. This whole process is very discouraging and I'm close to just pulling my order. Even if I receive it, there are all these horror stories about the Dakota. I think if I had any mechanical problems with the truck, you'd see my picture on the 6 o'clock news and the [non-permissible content removed] end of my new Dakota hanging out of the showroom picture window...:(
7 weeks and counting - and I ain't got the VIN yet.
I have a date for my truck!!!
Not a delivery date you understand......
Not a definite date of course......
But a scheduled factory departure date!!!!!
As you can imagine my corner of rural Ontario hasn't seen excitement like this since the railroad was built.
Well anyway, as of now, my Dakota is leaving the factory on September 21st and should be at the dealer around the turn of the month.
Course I was also told my truck was being built last week - 2 weeks between build and shipping from factory?????
I order my 4.7L 4x4 in July get it October
telgenh2 orders his or her 4.7L 4x4 in August, gets it September.
Now I grant you I live further from Detroit (about 4 hours by road), but come on here.
Yet another example of the US behemoth picking on its less populous (and far superior) neighbour.
OK, go ahead, beat me up - after all I am deadly serious.
eh!
I wanted patriot blue with color matched grill and bumpers; can't be ordered; therefore went with the white sport plus in stock as I did not want SLT with the taller rims, or taller tires, the 255 X 15 on the truck with the lightest suspension gets me closest to car like and the Club Cab means space behind the seat for stuff that can be locked up and the seat can recline.
Little that I've driven it I find it to be a perfectly balanced vehicle and I mean balanced. The V8 auto combo is great. The OD is easy to switch in and out but the tranny makes really seamless shifts and the power is there.
Here's the numbers and stuff:
Base Price 16,750
Custom Pref Pkg 26B, grill
body color, etc 980
HD Sevice Grp, 750 amp bat,
HD cooling, tranny cooler etc 180
Sports Plus Grp, AC, Lts, Wheels
15 X 8 Aluminum, 255/65R15,
135 amp alt 1,465
Trailer tow grp 275
Delux convenience grp 390
Power convenience grp 570
Mats 30
4 spd auto trans 975
Anti spin limited slip diff 285
Rear Window slide 115
Pwr mirrors 160
Radio, tape CD 560
Leather wheel 50
Destination 520
_____________________________________
24,495
Sports Plus Grp discount -350
4 X 2 CC V8 Bonus -560
Customer pref discount -980
Total price 22,605
Dealer discount -924
________________________________________
"Bottom line" price, including
$249.00 MOPAR bedliner 21,930
_________________________________________
MSRP 22,605
Mopar Liner 249
__________________
22,854
But I'm getting it for 21,930
Now I am 99% certain they are square on this but it's late so I'll check vs the Edmunds invoice numbers in the morning. The object here was for a daily driver that was "car like" but with weekend truck ability and light tow ability, (inflatable boat); SLT and other things make the step in higher; step in is actually lower than a Ranger now and the price is within 3K and I got V8 and some hip room, wish they had Ford's Toredor red, otherwise I'm cool.
They just found this truck on the back lot tonight; been there a week, I was in the process of ordering and would have liked perhaps, pwr seat, ABS on all four wheels for damn sure, had thought about the 3.92 axle, but can't see it now that I've driven this truck. Also audio controls on the steering wheel (nicer than you'd think, option RD2) Alarm (AJB)
Calilfornia tough truck yada yada. JOHN
"trouble with the 4x4 transfer and tranny?" That doesn't sound encouraging. Does that mean as soon as Daimler can get the truck in first gear, then they'll start shipping ??? I'm getting cold feet over this whole Dakota deal. The automatic has problems, they can't deliver 5 speeds. I just sold my 87 Pathfinder after 12 years / 150K miles of trouble-free service, now I'm waiting for a new truck that has problems at the factory ??? It's a shame, I really like the Dakota but I'm going to have to start looking at other trucks in case this deal goes sour...only thing I would miss is the V8...Tundra is too much bread and no stick. When other manufacturers wake up and start dropping v8's in their compacts, you'll see a dramatic shift in the market...
