Looking forward to get answers from you. Thanks again.
thousand miles,I would bring it back to the dealer and have them check everything.Good luck.
don't use it you won't get the performance or gas mileage
the manufactor says it will.
I hope the MPG will improve with time and miles.
The car is just awesome. I smile every time I drive it.
A little less stress with the 300C to start but I do have a bit of a leadfoot and am looking forward to seeing how this car runs/handles at 100+.
return to your dealer for repairs a TSB came out on the 20th of last month for a fix.
I can tell you it works. GOOD LUCK TO ALL.
Ummm, something is wrong with the specs as you've written them. Either you're looking at a 300C STR8 with the 6.1 liter Hemi with factory 20" wheels or you're looking at a 300C with the 5.7 liter Hemi with the MDS and factory 18" wheels. If it is the SRT8 then yes, the price is fair, if not, then the price they're asking is an absolute total rip-off.
My gut guess is that since every component of the car you described was a plain 300C (except the engine size), that you should take a pass on this car. That having been said, if you can get them to drop the price to a more reasonable $29,000, then it might could well be worth a look.
Best Regards,
Shipo
When it started to warm up this spring, the a/c did not seem to get "Cold." I bought a temperature probe and logged some vent outlet temperature. Would never get below 50F with full cold, blower high, recirculate.
Took it in to dealer. They said refrigerant was 0.5 lbs low. Helped marginally.
Got hot in Kansas again and took car back into dealer. I had gathered a ton of data about vent temperature against various settings. The most curious thing was that by moving my manual temp control only one detent off of full cold (the manual temp selector has 20 detents) it raised the vent temperature 10F. Second decent raised temperature another 6 degrees. By the time I got to the middle of the Cold position (about 9:30 o'clock) temperature was 90F. At neutral (12 o'clock) temperature is 110F.
Dealer now says it is the controller. While all this is going on, the vent temperature coming out of the rear console is about 20F hotter under full Cold settings.
On Monday, controller will be replaced. We shall see if this fixes problem.
I have been driving their loaners during this time, and both the PT Cruiser and Caravan set significantly colder.
I am wondering if there is a damper door that has been misadjusted somewhere, allowing some hot air to get into the system even when controller is set to full Cold.
I sure like the car, and have put 10K miles on it. I have been very careful about recording mileage. In town and mixed driving, I get about 21-23 MPG. Up until last fill up (driving 70), I never saw more than 24-25 MPG. My last fill up of strict highway driving, I saw 27.9, so perhaps the engine is getting broken in.
I drive new cars, and jumped ship from the Nissan line to buy a black Chrysler. If they don't get the A/C problem fixed very soon, I will be trading it off for a Toyota Camry or Nissan Maxima.
Sure love the looks and ride of the new 300. The base engine is adequate for my needs, and I bought it based on value and desire for good highway MPG.
Its says the a/c won't cool down in hot and humid condition.The bulletin # is 2401405.I hope this helps I hate to see you jump ship to the japanese cars.
idle,idle sag,cruise control fail to engage.I don't know how a dealer could mess this up with 2 bulletins for rough idle.I hope this helps and get a fix.I have a 06 3.5 with no problem so far.Good luck.
I have another question. Should I change oil and filter after the first 1000 miles or is it better to do a first oil/filter change at 3000 miles? I will be very thankfull for your advice.
The oil filter they use are factory which is alot better then the ones used at the quick oil change places.Most people don't know this,but you can buy in advance oil changes from Chrysler,its called Essential care.Just talk to your service adviser and look at the options.You can pick how many years you want to pay for.I bought the 4 year plan,and it comes out to 8.44 for a oil change at the dealer.They send you a coupon book,when you go in for service they take the coupon,thats it.
on the MPGs.If that doesn't help,have the dealer check it out.Good luck.
I really appreciate your help, guys. Thank you again.
My car came with Continental ContiTact Touring tires. Anyone else have another tire with substantial performance increases?
The dealer has been great in trying to fix the problem, however this 300 limited was an aniversity gift to my wife. I have a 3500 cummings, and a 68 roadrunner so I been mopar fan for a long time. These problems have been driving me insane.
I also worked on Mopar police cars for 23 years.Thats what
made me a Mopar man.
Will send you picture.
I have had mine the shop 5 times and nothing seems to work.
I think if enough of us get together on this Chrysler has to fix the problem.
I am a loyal fan of MOPAR have been since the 60's, love my 300 ltd. and want to keep her running for a long time.
The car is a classic. My dealer has been great but it is time for Diamler/Chrysler to step up to the plate.
happened to me with a 2001 Chrysler Sebring.My dealer tried everything they could to fix my car.I told them I wanted a buy back.The service manager told me to take it to another dealer.When I did that I got a call back from my service manager telling me Chrysler will buy back my car.I liked the car but it couldn't be fixed.Good Luck I
hate it when they can't fix something.
a picture on the forum.There aren't to many '68 Runners out there.
I love the 300 when it is running right, I just got a bad apple,
O, by the way, the frontend alighment was off.
Pic 1
and the Base, Touring and Limited have fog lights that are set within the blacked out opening like this:
Pic 2
I saw a 2005 300 on CarMax that said it was a Limited (has the heated power seats, dimming mirror, Nav System and walnut trim on the wheel/shifter).....but it has the front end that I always associate with a 300C. Can someone explain if I have it right above or if the Limited comes with the front end shown in Pic 1 rather than Pic 2. Is it a model year difference?
I also had one Conti tire replaced because the self seal bladder came loose and ended up as a big blob of goo rolling around the inside of the tire. It was replaced by Conti. I understand these Conti tires have caused lots of headaches for owners. If you are buying from a dealer then you might want to negotiate a change of tires to another brand. This is the nicest car I have ever owned, but not saying something else will come along in the future like the Challenger!!! I am a Mopar fan. Good luck!
1. To try and fix the left rear window which will not go down on a hot day (though interestingly enough, when it is cool--and does go down--if I just tap the switch so it comes off the hard "closed" position, the window works fine all the time).
2. To address the non-functioning easy exit seat function (the steering wheel, though, does move up and out of the way). The truth is, though, that I really only need the steering wheel movement.
I've also lost the driver's window express up feature a couple of times, but that you can reprogram easily yourself. Philosophically, I guess you have to expect electrical glitches from time to time the more complicated these vehicles get. Or maybe I'm just saying that because I love the car....
I Chrysler stand behind the product it would be a great car and people would purchase more of them that Toyota's
think you did well.Good luck.
The '06 has a few more bells and gadgets in it and it is the same color. My wife is happy and I am happy)
Good Luck.
