If I use my blinker is starts to actually wipe as if i pressed the button that sprays and wipes 5 or 6 times. I ended up just unbolting the arm and blade altogether to stop it. I might just disengage the motor but would like another solution.
Something has to be shorted out somewhere. Any help is appreciated.
Will
Also, the Navigation/Radio system has sporadically turned itself off and then back on while driving several times.
To me there is a bug in the electrical system somewhere, maybe a bad cable. Has anyone experienced something like this?? Please help, thanks in advance.
I would recommend taking the vehicle in the next time these lights come on. If you can leave the vehicle running so the dealer can see the warning lights on and check for codes. Please keep me updated on your situation. I look forward to hearing from you.
Christina
GM Customer Service
I apologize for your frustrations. Have you spoke with your dealer or Customer Assistance? If not, I would recommend doing so. Please keep me updated on what your dealer says.
Christina
GM Customer Service
Sorry to hear about the problems with your vehicle. Were you planning on taking the vehicle to a GM dealership? Please keep us posted.
Thank you,
Caron, GM Customer Service
145 AMP has part # 10464476
I really don't believe I bought a lemon, just trying to get an idea of the cost or is this alarm at this stage normal, etc. Looking for any feedback.
Good luck
Jacynda
When I am in drive, the truck makes a thud and gets into gear really fast, still rides smooth, just makes a loud noise when I first begin to drive.
Either way, if we can be of further assistance please don't hesitate to get in touch via email. I hope you have a very happy holiday season!
Sarah
GM Customer Service
Thank you for sharing your experiences with your post. Can you please email me your VIN, current mileage, and involved dealer? I look forward to your email. Happy Holidays!
Christina
GM Customer Service
I would recommend speaking with the dealer. They will be able to at least diagnosis the concern for you. Please keep us updated on your situation.
Christina
GM Customer Service
Happy New Year,
Sarah
GM Customer Service
Any Input would be appreciated
Melissa
The SDM (system and diagnostic module) detects the steering wheel module deployment loop resistance is greater than 4.8 ohms for 500 milliseconds .
The SDM detects the voltage at steering wheel module high control is less than 2.4 volts and steering wheel module deployment loop resistance is 6 ohms or greater for 500 milliseconds .
DTC B0084
CIRCUIT DESCRIPTION
The inflatable restraint seat position sensor (SPS) is used to determine the proximity of a front driver or passenger seat position with respect to the frontal air bag. The SPS interfaces with the sensing and diagnostic module (SDM). The state of the SPS allows the SDM to disable stage 2 of the frontal air bag for a front seat that is forward of a forward/rearward point in seat track travel. The SPS is a hall effect sensor that is mounted on the outboard seat track of both the driver and passenger seats. The seat track includes a metal bracket that shunts the SPS magnetic circuit creating 2 states of seat position. The shunted state represents a rearward seat position. The non-shunted state represents a forward position. The SPS provides 2 current ranges, one range for the shunted state and a second range for a non-shunted state. These 2 states are inputs to the SDM. State 1 (shunted) being the rearward threshold and state 2 (non-shunted) being the forward threshold. When the SDM receives input from a SPS that state 1 threshold is reached (seat is rearward) the SDM will not disable stage 2 deployment, if required by the deployment sensors. When state 2 threshold is reached (seat is forward) the SDM will disable stage 2 deployment on the side the seat is forward. The SDM monitors the SPS circuit and if a fault is detected the SDM will set codes B0083 or B0084 and defaults to disabling stage 2 frontal deployment. This will only default on the side of the vehicle the sensor has a fault. Its important to understand that the SPS is secondary to the passenger presence system (PPS) and the manual instrument panel (I/P) module disable switch. If either one of these devices are in the disable mode the passenger air bag will not deploy regardless of the SPS status.
DTC B0100
CIRCUIT DESCRIPTION
The inflatable restraint front end sensor utilizes a unidirectional 2-wire circuit. The front end sensor modulates current on the interface to send ID, State of Health, and deployment commands to the inflatable restraint sensing and diagnostic module (SDM). The SDM serves as a power source and a ground for the front end sensor. When the ignition is turned on and input power from the SDM is first detected, the front end sensor responds by performing internal diagnostics and sending an ID to the SDM. The SDM considers the ID to be valid if the response time is less than 5 seconds . The front end sensor continually communicates status messages to the SDM, which determines if a fault is present in the front end sensor circuit. When a fault is detected, the SDM resets the front end sensor twice by removing and reapplying power. If the fault is still present, the SDM will set a DTC.
CONDITIONS FOR SETTING THE DTC
DTC B0100 and B0103 will set when one of the following conditions occur:
A valid ID message is not received within 5 seconds of the front end sensor being powered up.
Status message is not received.
The SDM has failed twice to reset the front end sensor.
DTC B0102 and B0105 will set when one of the following conditions occur:
The SDM has received an ID message from the front end sensor which does not match the ID stored in the SDM memory.
When 2 front end sensor resets are attempted without the correct identification being detected by the SDM.
DTC B0101 and B0104 will set when the SDM has received 4 consecutive NOK (Not OK) messages from the front end sensor.
Sarah
GM Customer Service
I drive over 1000 miles a week and cannot afford to be put down on the road. Any suggestions?
Tahira
Sarah
GM Customer Service
This is my wife's car. I don't drive it to much.
Thanks again
