I have a 2008 Denali, we have replaced the battery once in May. The new battery has been dead on five occasions since May. Dealer running tests and giving it back to me each time saying no problems found. Any Ideas short of just suing GM??
This clunk you are talking about, is it the same im experiencing ? @ a stop I slowly accelerate, release the gas pedal and quickly step on the gas pedal to accelerate then I hear a clunk as if a gear slip or something out of tract and slip back into tract. Any help? 02 Yukon Denali
Interesting timing on your message as we have the exact same problem and have had it for about two years (we have an 07 Yukon XL). Every time we have taken it to the dealership they hook it up to their computer and say that they can't find anything wrong with it and can't replicate the problem during test drives. We're just about to hit the end of our 36k warranty and have noticed the problem getting worse to the point it seems to shift hard, or slip, multiple times while accelerating (especially on hills).
My wife finally insisted that the service technician ride with her and they quickly replicated the issue. He said it was a problem with the drivetrain. Well, she just got back from the dealership and is furious with them. Basically, they told her that the problem is that we drive it in "Auto" all the time and that we should always drive in the 2WD setting unless it's winter. We couldn't find anywhere in the Owner's Manual where GMC gives that direction. Anyway, they told her that there's nothing that they could do to fix the problem and that we'll just experience that 'slip' whenever we drive in Auto. I'm going to call GMC when I get home from work. Ugh!
You can actually feel it more than what you can hear it. After I drive for a while when I turn in slow motion (like when parking) then the truck feels like if I have a flat tire and it is going over bumps in the road. We took it to the shop and they charged $1800 to replace the front rod but that did not solve the problem. When we took it back they tried several things but they were not able to figure out the problem. The mechanic at the shop took it to the mechanics at the dealership and they also did not know how to solve the problem. Does any one have an idea, help please!!! I love my Yukon but I am afraid I am going to lose a wheel one of these days.
Yeaah i dont think that has any thing to do with it. You should be able to drive awd or 2 wheel drive. I find it hard to replicate mine, it does it when it wants to. I wonder if its the u joint in the front.
I have the same problem with my 2004 Denali. Chipping paint on the Navigation and radio buttons. Anyone know if GMC responded to this issue or another solution.
I would really question them on the battery. Our 2007 Denali has gone dead at least four times. It will be starting/running fine, you stop to run in the store and try to start back up and it is dead. Leave it sitting and come back several hours later and it starts up just fine. OnStar tells us the battery is dead but if you disconnect it and test it, it tests fine. The last time it happened, I had it towed in to a local GMC dealer. By the time they got around to checking it, it started fine again. You can guess that we got the same answer you got, "could not reproduce the problem, no problems found". In my opinion, there is a major problem with the on board computer but I can't get the GM dealer to admit that or replace it. Maybe we should just sue!
In an interesting turn we now have charged the battery and replaced the negative cable. I have been checking the battery with a multi meter on a daily basis for over a week morning and night and the battery is reading 12 + volts each time. I am amazed but it would at least appear that this has fixed the problem. They said that the alternator charges the battery through the negative cable and a bad cable would prevent the battery from charging . Mine never would come back with out a charge or jump start, once it was dead it stayed dead.
Man ! I had a similiar problem a long time ago. The main power cable from the positive side in the fuse box with huge fuse. You will see connection tie together by nuts or some sort. sometime you have connection or you dont. I got this vehicle straight from the dealer brand stanking new. This may not pertain to your vehicle but i share your illness. good luck !!!
You have to insist on 800 CCA if they give you anything lower. Mine had a 700 CCA and I was having the same problem until I changed it for the bigger CCA battery.
My fuel gauge on my 2000 Yukon Denali, has started to vibrate in position after the vehicle has been running about 10 or 15 minutes. The vibration is so fast that the needle looks twice as wide as it is. When driving the dampening of the needle is not always there anymore. If you turn the vehicle off then back to the on position the gauge swings clockwise past the full mark to a hard stop point for about 5 or 10 seconds. It does seem to be reading about right. When you first start the vehicle cold, everthing seems fine for awhile. Any help would be appreciated. Thanks.
I have a 04 Denali XL. There's no popping in the steering column but I had to have the steering gear replaced because of vibration and a grinding sometimes squealing noise when making sharp left turns at a slow speed. The problem has re surfaced and only does this when the engine gets up to normal operating temp, I'm from the southeast so the problem is more noticeable during the hot summer months. Someone suggested that I need a front end alignment so I'm taking it to the shop for service and a all around lube job to see if that helps. Will let you know the results. Thanks for the info on the A/C because mine blows hot air from the driver's vents but the front passenger and rear continues to blow cool/cold air. I'll check the belt tensioner and will probably change the serpentine belt. Will let you know.
I'm having problems with a power surge that started about 15 months ago. Had to replace year old battery 12 months ago. All lights (interior and exterior) "strobe" during operation. Took to GM dealer and was told that factory recommends re-routing wiring. Alternator was checked but is putting out proper amps. But meter does show surge. Can someone help me b/c I don't want to play the "let's try this to see if it works" game that the dealer wants to play.
I am having problems with the battery running down also, with only the radio playing. Now the battery seems to be bad or not getting charged. I had not heard of the recalls that were mention pertaining to ID#07007 and etc. Besides the battery, I recently had the air conditioner blowing cold air on the passenger side and hot air on the driver's side of this vehicle. I tried the controls but did not fix. When I turn the vehicle off then back on, the air started flowing correctly. I hope the repairs that were mentioned will correct these problems. I will look at getting a new battery or a second battery. Any other suggestion will be appreciated.
Our dealer replaced our negative battery cable (which I thought was crazy) and it seems to have fixed our battery problem. They said GM was not sure what was wrong with these cables but they have replaced several on the Denali and it is fixing some electrical issues. Who knows, but so far three weeks have gone by with out any problems.
2003 Yukon Denali with approx 110,000 miles. The dome lights(frt to cargo area) are engaged and will not switch off. The switch dimmer is working but will not shut lights off completely. Is there a way to isolate the problem to a faulty switch?
I have a 04 Denali XL. There is a humming noise and a slight vibration in the steering wheel when making left turns at a stop or slow speeds. Turning to the right is as smooth as ever. The noise is similar to what a vehicle makes when the power steering fluid is low, I have checked and double checked the fluid and it is where the manual says it should be. Had this problem before when the vehicle was still under warranty, the steering gear was replaced and I didn't have any problems again until recently. Had a front and rear wheel alignment, vehicle rides well but still has the problem. I'm worried that it could turn into a major repair if I don't find the problem soon. Any suggestions or ideas out there
i notice there is space for a second battery. is it possible to install a deep cell battery for accessory use using an A/B switch without harming the electronics on vehicle or voiding the warranty? i have used this system on boats but dont know if it translates to autos.
also, my owners manual was stolen (looks like a purse) dealer wants $85.00 for new one..is it downloadable?? on the web?.. thanks rvanr
First answer yes you can get a second battery for that spot. Dealer install is about $500 they may not know what you are talking about tell them its the police package. If you want to do it yourself I have the part numbers: 25825642 Cable 15888242 F Cable 14005061 Retainer 11509853 Screw
Second answer, go to gmc.com and get an account. You can download the owners manual from that site.
We had the same air conditioning problem on our 2005 Denali. The dealer stated they had to replace the "actuators" that direct the air to the driver side. Fortunately, these were covered by our extended warranty.
the denali uses alot electrical components which is almost as bad as having a sound system.i've decided that i will upgrade my alternator to higher amps not voltage.having higher amps allows more power usage.i'm trying to allow the battery to charge without having too much drain. my 2005 denali dies if i dont turn it on for three days.as im driving i can actually see the voltage drop every so often.alternator is working perfect battery is good but like i said maybe the denali requires more amps.i will post and update.
My 2005 Yukon Denali drives well except when cruising at constant speed. The vehicle occasionally bucks/shudders repeatedly until I either press down the pedal to accelerate or let off the gas. This happens at low speed as well as on the highway. Not sure if this is a fuel injection or tranny issue. It does not happen all of the time but enough to cause concern.
Any help to troubleshoot this problem would be appreciated.
I bought fuel injector cleaner today. Also found out the fuel filter is on the fuel pump in the gas tank. At 80k miles, I may have to bring it in to get checked out. Any other input?
Up until Last week my girl has been great! I have the every now and then turning off and on again by themselves issues But nothing that has kept the vehicle immobile. I always use my remote start and keyfob to enter and lock the car, so I go to get in my car after leaving a store and turn the key and No turn over. No clicking, the radio was still on but the check engine light was on. I call onstar and they send out someone to jump battery, No charge with the jump so its towed to the dealership. Dealership says battery is completely draining and I need it replaced. They also tell me that when they put the new battery in that the care wouldnt turn over and they had to bang on the starter with a hammer and turn the ignition at the same time to get it to start. OK WTF ! Then he tells me Im probably going to need a new Starter soon at $700 + . So today Im out shopping again and the exact thing happens, NO START. A nice nice was in the parking lot and I asked him to please bang on the starter to see if we could get it going. That doesnt work and the battery is FULLY charged. I called the dealership and they say have it towed to them and they will look at it. IM NOT HAPPY and IM not taking it back to them. I remembered a service guy telling me once that the security autostart can shut down the entire car and if it happens it needs to be reset. Manually lock the car, wait ten minutes and open the car with the key not the keyfob. SHE STARTED !!!!! But now Im very confused on what the problem is.... Do I really need a new starter??? Is there a problem with the autostart or security system that killing the car????? The dealership says they cant help me unless the car is having the problem while its there so they can see the code. Well how the heck am I going to accomplish that, I dont know when the car is going to decide to DIE. This is bullcrap and I know the dealership has seen these problems before, Im not the only owner that this has happened to. So frustrating to pay 65K for a vehicle and this BS happens !!!!
There is a TSB and a recall for this issue. It is a programming flaw in the computer. If you never had the software fixed it is covered under the recall. Tell your dealer to review recalls on this vehicle. The fix is free under the recall!! A reputable dealer service manager would have checked this first! You can use another GM dealer if you are not happy with your dealership. Chevy dealers can deal with the issue since it is cross platform to the Silverado as well and they have access to the fix. Good luck.
My yukon is sitting much lower in the front than what it should be. I switched the front shocks out with top of the line shocks and it raised it very little and the ride in the front is still rough. Should I be looking at the coil springs next?
Also, I have always had a squeaking in my front breaks. I have changed the front pads with top of the line ceramic brakes from NAPA and I also put new rotors on the front as well. I still have the squeaking, but I was abe to get rid of the shimmy from the old rotors being warped. I was told that I may want to get shims that fit between the pad and the caliper? Any suggestions?
Well after twice last week of the truck not starting again, It was towed to the dealership and the starter was replaced. I asked them about the TSB and any recall and I was told ( with an attitude ) that NO TSB or recall existed for my truck and I didn't know what I was talking about. So my 2007 with 48K so far has had the battery and starter replaced. Im really starting to think my truck is possessed and I hope this isnt the begining of problem after problem.
I am also having problems with the battery in my 07 Yukon Denali. If you leave the key in the ignition with the radio running even for only 5 min the car won't start and needs to be jumped. Is this a common problem? This has happened at least 3 times recently.
I had a similar problem and after the third battery in about 2-1/2 yrs, I came across a service bulletin that was mainly issued for the truck, but applied to the Yukons as well (I also have an '07). Since I took my vehicle to the dealership and asked them to perform this SB, it's been okay (yes, I had to find this and tell them to do it. I think they only look at recalls and that's it) This site lists the mutliple SBs for the '07's. http://www.4door.com/tsb.htm. Good Luck!
There is a recall for the computer programming and 2 TSBs! One for pinched wire in the headliner and a second for wire faults in the right rear passenger door. These are for 2007 Yukon Denalis. Your dealer needs to learn that GM is having problems and customers expect a little respect before they are talked down to. My battery was damaged by the wires shorting out and was able to demonstrate 2 bad cells in a 2 year old battery myself. I have personally bought mt last GM product despite owning over 14 GM vehicles in my life. My problems are more related to how consumer issues are handled by GM customer service when the local dealer has no power to resolve the issue locally despite their best efforts.
Dealer in Morehead City NC said I could not have a second battery installed without voiding the MFR warranty and said they could not do the job since it is not OEM to my vehicle. Any thoughts or insights?
I posted earlier that replacing the negative battery cable seemed to have cured my dead battery issues in a 2008 Denali. After 2 months of trouble free driving the problem is back again. So the negative cable was /is not the answer. It is back in the shop and I am again trying to talk to the folks at GM customer service for a permanent resolution to the problem. I currently own four GM products, and have purchased three of them new in the last 15 months from the same dealer. I am not sure anyone cares about customer support anymore. I may start riding a Schwinn.
There is a computer program recall,as well as TSB's #1741191 Battery electrical drain, for 2007 Denali's and #2074806 for 1996-2008 GM's using Class 2 Communications. I agree that service is GM's greatest failure.
Message #733 Re: Battery Dead [kchawk1] by fiaga123 Aug 01, 2009 (6:01 am) You have to insist on 800 CCA if they give you anything lower. Mine had a 700 CCA and I was having ...
Message #695 Re: battery keeps dying [circlew] by fiaga123 Jan 25, 2009 (6:32 pm) I figured it out this week. Firestone replaced my previous (dead) battery with a 700 CCA battery. ...
THE SPEEDOMETER IS READING 60MPH WHEN I AND IN PARK. WHEN I START TO PRESS THE GAS IT GOES OVER MORE AND STICKS FUTHER UNTIL IT'S AT 120+ . I HAVE NO IDEAL HOW FAST I AM GOING. I CAN BUMP THE SWITCH ON AND OFF AND IT RETURNS TO ZERO BUT IT HAPPENS AGAIN.ANYONE OUT THERE KNOWS WHATS UP?
Happened to me after I changed a dead battery. I solved it myself since I noticed every time I shut off the ingnition completely and started it back up, the speedometer would inch back around 5 mph at each on/oof cycle. It wasn't enough to turn the key on/off without starting. I needed to start it each time and then turn it off and repeat.
I think i did it around 30 or 40 times but it did reset and has been normal for about 10 months now.
Most likely your problem is not resolved. As you may or may not know, there is a recall on the instrument cluster for faulty servos. GM will warranty usually up to 70,000 miles, after that, your on your own. Replacement of the cluster through GM will run you in the neighborhood of $650. Their are repair facilities that advertise on EBAY that will repair your cluster for around $200, but you have to send it to them. Thats what I elected to do and have been pleased with no more problems. The cluster is rather easily removed, the bezel snaps onto the dash, remove I believe four screws and the cluster comes out. Be sure to disconnect the battery before unplugging the harness from the back of the cluster. Good luck
Absolutely! Check the U-joints first, most of the time its just a matter of grease the U-joints; but, if your OEM U-joints do not come with grease fitting, then just drive until one of them goes bad, at that point (a side from the Clunk your hear/feel as you accelerate from stop) you should feel a slight vibration from the rear of your vehicle at speed around ~45mph... Good Luck!
Unless you use Coil-over or Air shocks, those gas charged shocks will not do much at all to raise/restore your vehicle to its original height. Being its in the front, upon replaced the coil spring (or perhaps instead of coil springs, they may be torsion bars), you will need to have the front wheels re-aligned.
As far as minimize the brake squeak/squeal, having shims installed (correctly) between brake pads and caliper will most definitely help. Before you shop for shims for your particular vehicle, you may want to check with your Ceramic pad manufacturer for the proper shims (and adhesive), since not all shims are made of quality steel... URL below as FYI.
I check around for pricing and come up to be around $200 to replace 2 u-joints in the front, having already replace the 2 in the rear, I hope this work. Another question you may know is about my rear shock, can we buy aftermarket brand because dealers are $600 for both. well, thank you for the advice. and I will let you know.
If you have the OEM Auto-leveling System, then you 1st would probably have a hard time finding those after market air-shocks (i.e. from Monroe and etc.) for the application. Although, I have seen some past post about Bilstein may have something that's close, but your on- board computer will display some sort of "Ride Control" message all the time, which can be a pain... I would suggest to checkout the place called Arnott, their price is much more reasonable than of a GM Dealership... Hope that helps. Good Luck! http://www.arnottindustries.com/part_GMC_Air_Suspension_Parts_yid15_pid95.html
OW
rvanr
25825642 Cable
15888242 F Cable
14005061 Retainer
11509853 Screw
OW
Where is the Fuel Filter located in a 2005 GMC Yukon
OW
Thanks in advance, Joe
OW
http://auto.howstuffworks.com/auto-parts/brakes/brake-parts/brake-shims.htm/prin- - table
