I can tell you any A/C system requires pressurization in order to:
A. cool your car
B. keep the oil circulating throughout the system and all its components, and
C. keep moisture and other contaminations/particulates from entering the A/C system
(Based upon the info you've provided, both B and C could be applicable). So, losing enough pressure can screw up your A/C system in a variety of ways, including premature wear. In fact, even not using your A/C for extended periods can contribute to overall wear and tear because the parts aren't being regularly lubricated. I lost my compressor and receiver/drier in my '85 Prelude back in high school because it sat for a month during summertime with a leaky line.
Hope that helps a little.
Tim G.
'05 OBXTL-5MT
I'll second that! The biggest disapointment in my otherwise excellent OBXT.
And Subaru doesn't seem to care. In fact, they insist that they get no complaints about the ACC. Buit judging by all the forums I hang out at, about 50% of owners with ACC are upset about their system.
One wierd fact is this: At times, when ACC is off - it will blow some air - click on the flow which has 2 options (one is circulating the inside air) & the other is bringing outside air in. once you click this, the problem solved. This is wiered but subaru had this problem even in previous gen OBs, so this is a carryover issue. SInce i come from prev gen, i know the solution.
those who are new Subaru are freaked out about this i guess.
i suggest you don't drop the car because of this.
versus the auto. :shades:
We live near Toronto, and are in the middle of a lengthy heat wave with very high humidity. Both cars get cooled down quickly with minimal fuss.
Doug
The air flow for the floor duct passes through the heater coil hence warmer air which mixes and negates the cool air in the cabin from the dash ducts.
-Dave
Again, the system works great for providing heating and cooling of the cabin. It just never seems to stay comfortable for extending drive times. We have also discussed the winter problem where 66F is not a cold enough setting for Subie winter driving zones.
Anyway... as I said in the last post... I love my Outback and would never consider giving it up because of this truly minor annoyance. It just seems strange when I reach for the ACC controls more frequently than the XM?
Craig
what he said. Rob M.
The new '06 Outbacks are now just arriving at dealers. I've seen several already.
Bob
The current issue tests SUVs and they're all over 10 seconds except for the V6 XTerra.
-juice
The Forester, on the other hand, is fun and sprightly with either transmission.
Craig
auto trans ... I haven't found any on the manual. Glad I came here and asked the experts. Has anyone found data on how fast the manual from 0-60? Thanks.
Bob
I've test driven an OBXT before, but that was over a year ago before I took ownership of my 05 LGT wagon. After a year of driving my LGT wagon, there were some things that I noticed -- nothing new or groundbreaking -- but clearly different from my daily experience.
Sitting in the OBXT, immediately I noticed the added ground clearance. It was strange to be just a little higher with all else being similar. The slight difference in perspective does make a difference in feeling a little more isolated from the traffic around you. Not quite as big of a difference as when driving an SUV, but just enough to relax me a bit. Made me miss my Forester a bit!
Driving through city streets, I also quickly noticed the higher profile tires and suspension do a much better job at smoothing out rough roads. The road leading to the dealership is covered with cracks, poorly applied patches and potholes. They clearly bothered me less on the drive out.
Steering -- subtle, but I did notice the difference in the steering ratios. The OBXT required a bit more turning of the wheel to make the same turns.
Power delivery -- not surprisingly the same. However, it's duty as a loaner had not allowed the 5EAT to optimize it's shift points. The 5EAT took more time to downshift so I found myself using manual mode more often. Something to keep in mind when test driving any 5EAT Subie.
I noticed the biggest contrast when driving highway 17 back to work. For those of you who don't know the area, highway 17 twists and turns it's way over the Santa Cruz mountains with some 45mph rated turns.
Given it's ground clearance and longer travel suspension, the OBXT naturally rolled through the turns more than my LGT. I found that I had to slow down more through some turns, but a part of that had to do with my not knowing the limits of this vehicle. Overall, I think the ride was much improved over it's predecessor and very commendable for a vehicle of a higher CG and longer suspension travel.
What surprised me the most was how much heavier the OBXT felt when changing direction. Weight-wise the OBXT and LGT wagon are very close, however the suspension differences make the OBXT feel less willing to rotate. I found myself noticing this even while turning street corners. I thought that this perception of weight could actually work in favor of an OBXT buyer who is looking for a more "rugged" application. At the same time, I also was impressed at how my LGT wagon, which weighs as much as an OBXT, could feel so much more responsive.
Again, nothing revolutionary here, but it's not every day that a LGT wagon owner gets to drive an OBXT for an extended time.
Ken
Do you think over time this would loosen things up in the car too much? I'm pretty OCD about squeaks/rattles etc.
Brett
I have an 05 OB XT (gold/black twin of what Ken got for a loaner), and I debated between that and the Legacy GT wagon almost all the way down to when I signed the papers. I was set on the Leg GT, but a couple things were nagging at me -- comfort on lousy roads (I have a 70 mile round trip commute to work over lousy concrete on I-64), ability to drive on rutted dirt roads where I kayak, and ability to handle deep snow (almost everytime I drive out to Snowshoe WV to ski, I hit a major snow dump). For all of those reasons, I am really glad I got the OB XT and I have realized that many times "in action".
As I was shopping last summer, I realized that the 05 XT handled so much better than my 02 Outback that the difference between the Leg GT and the OB XT was very small compared to either car compared to my 02 Outback. The XT handles really well, and corners a lot flatter and more quickly than my 02 ever did (I have to agree with Ken, it's pretty good for 8.7" of ground clearance and a lot of suspension travel). For that reason, the OB XT seemed like a great all around compromise -- a dose of what makes the Leg GT so great, same great engine/trans, and all the utility and capability I was used to in the Outback.
Craig
As Craig wrote and I noted earlier, the OBXT will be significantly more sporty compared to your 2000 OB despite the increased GC. However, the Legacy GT, IMO, is quite a bit more responsive on roads to the point that it makes you realize that despite sharing many components, is really targeted towards a different use application.
The GT is more firmly sprung than the OBXT but by no means is it a kidney-bashing sport car firm. In fact, I think the GT has quite a bit of a forgiving stock suspension set up for the amount of performance it can provide. It's been designed with US roads in mind and is in not a track setup.
Interestingly I came from a 98 Forester S that I also drove it close to it's limits on occasion (Craig used to own a WRX). Even with a stiffer rear sway bar and upgraded tires, the Forester S can not come close to the cornering I can achieve with the LGT.
I think you should try and see if your local dealer will let you take both models for an extended test drive. Check on the Subaru website -- some dealers are now participating in a 24 hour extended test drive program.
Some food for thought -- an equivalently equipped LGT wagon is about $1000 less than an OBXT. You could use that money to buy a new set of rims and tires with a slightly higher sidewall to provide a softer ride (ie. 205/55R16 vs. 205/45R17 stock). In fact, you probably could pick up an inexpensive base 2005 Legacy set of 16" wheels on eBay. That way you could have the best of both worlds if ground clearance wasn't a top priority.
Ken
-Barry
Tirerack confirmed to me last year that 16" will not fit the GT.
I think for most people the OB is well suited, because roads are not perfect and how often do we really get to drive at 10/10ths?
The GT is the insider's choice.
-juice
CR tests without advanced techniques, and their numbers are remarkably similar to Car and Driver's Street Start, which is the performance that most people will be able to extract in everyday driving- simply stomping on the gas and holding it to a given speed.
If you look at those two sources closely, as well as the passing information (more important, I feel) one can assemble a clear picture of a vehicles acceleration.
IMO, I'm not all that surprised by CR's time of 11.9 to 60 for the heaviest and least powerful of any Legacy/OB model.
~alpha
Ken
Mark
Craig, I live in Richmond, CA, close phonetically, not geographically. My OB only sees snow during ski trips but I really appreciate it then.
I've test driven both and didn't see too much difference except in the ride height Ken mentioned, but I think the 24 hour test drive will provide a more detailed analysis. There are enough dealers in the area I can probably swing 2 extended drives.
Thanks again for everyone's input,
Brett
Craig
I see that you live in the Bay Area as well! I used to live in El Cerrito so I know how some of those East Bay roads can be.
I also recall seeing a few dealers in our area participating in the 24 hour test drive. My favorite dealer, Santa Cruz Subaru is doing it. I'm not sure if Albany Subaru is participating, but I got bad vibes from their sales group when I was shopping back for my 98 Forester.
To echo Craig's point, both really are great vehicles. If I could afford it, I would have both in my fleet. Over the last two days of the OBXT loaner, I do wish I could switch between the two based on my needs. :-)
However, being the shameless Legacy GT fan I am, I'll make one last pitch to sway you over to my side. When I owned my 98 Forester S, I was enamored by the extra ground clearance and the thought of light offroading. Well, as it turned out, I drove one or two fire roads during the five years of ownership and the rest wishing that it handled more like the then Impreza 2.5 RS. The extra ground clearance was nice but not a necessity for my trips up to Tahoe. Nothing looks more sexy than an OB or Forester in the Sierras, but I was too OCD to go through roads, paved or otherwise.
To answer a question you posted several messages ago, my LGT has just one small rattle coming from the sunroof shade moving in the guides. The OBXT I'm renting now has it too and I think it can be fixed with some application of weatherstripping. Otherwise, it's been very rattle free -- far better than my 98 Forester.
Ken
http://www.cars101.com/subaru/subaru_discounts.html
Normally, employee pricing is lower than invoice -- usually invoice minus holdback. At least that is the case for my mother in law, who gets Ford employee pricing (she works for Hertz). We used that when buying a Mazda 626 many years ago.
Craig
Craig
Craig- I use the Chase Subaru card as well. The Subaru bucks have been used for some parts, and some work done so it has paid for itself. Still have some, which hopefully I will use on a new Subaru in the not to distant future.
Mark
Mind you, JnJ didnt offer SUBARU Employee pricing, but it is the VIP Program, and there was no time limitation (ie... 6 months participation with IMBA, for example).
Joe
I prepaid everything & have them mounted around Dec 1, at which time I will have approx 30k on the vehicle. I figure by then they may be worthless.
Tire Rack had them for $102 each, but when you add $40 for shipping, $80 for mounting & balancing (they list several dealers that would perform the service) extended warranty, etc., I come out much higher than the %25 (which included RI sales tax 7%)
So, any comments from owners out there about their experiences with the 92's or the Triple Treads would be greatly appreciated.
Also, note that most RE-92 negative comments pertain to the previous generation of RE-92 with a lower wear rating (~240). I had those on a couple Hondas and my WRX, and they were not great in rain or snow. However, Outbacks have always used a *different* version of RE-92 -- my 02 had RE-92 tires with a wear rating of 320, and the tires were going strong at 60K miles -- no complaints at all. The 05 models actually have the RE-92A -- an alltogether new tire (not sure what the wear rating is on your 2.5i, might be worth checking). So the moral of the story -- most of the negative RE-92 comments don't apply to the Outback tire, and for 05, it's a totally new tire and the jury is still out.
Now, let me put on my economist hat and scold you for giving your money to the tire dealer 4-5 months before getting the tires!! Got any more money I can take off your hands for a few months?
Craig
Legacy GT RE92s have UTOQ 160 (215/45R17).
I bet Bridgestone is using RE92 as a general "premium/high performance all season" tire label that they tweak to any manufacturer requirements.
Krzys
Serge
Switched to Bridgestone Turanza LS-H tires....much smoother ride, great in the rain and handled snow just fine. The Outback is a totally different car with the new rubber.
Doug
-juice
Bob
You can go aftermarket for less (decent wheels start at around $120) but choose wisely. Many low-cost aftermarket wheels are heavy and/or not as strong as OEM wheels.
If you can get an 06 at invoice (check www.fitzmall.com) then go for that -- it will likely be the cheapest overall way to get an Outback with 17" wheels (within 1-2 months of the 05 models hitting the street, I was able to get my OB XT at invoice at fitzmall). I guess you will miss possible additional incentives on the 05 that would drop the price below invoice, but it would probably be a wash when adding wheels to the 05.
Craig
I have aftermarket wheels on my allroad now and they've been fine, but I know there are a lot of heavy, easily bent rims on the market. Looking to keep my OB stock.
Brian
Basically you won't end up saving any money with an '05.
-juice
