Visitor Agreement.
Has anyone seen any larger diameter nerf bars for the Tundra without the plastic steps?
Thanks ,Tim
GO K-STATE!
I have to say, the truck is nicely proportioned. The size is signifigantly bigger then the Tacoma, but still not as BIG as the Big 3 trucks, a plus in my book. I like the lines of the truck, it is smooth without being round like the F150, yet square without being as brick-like as the Chevy. I noticed that all the trucks are about the same length. The Reg. Cab has a longer bed and the Access Cab a shorter one. Also, 2WD and 4WD seemed to have nearly the same ground clearence and ride height. Another plus for those who don't want or need 4WD, but stil desire a tall ride with good clearence. The trucks I was looking at were Silver, Maroon and Green, the paint seemed quite good with no orange peel or waves. Every truck on the lot was a V8 SR5, no Limiteds, no V6's and a mix of 2WD and 4WD.
Overall, from a design standpoint, this truck is great, with only the flashy chrome grill detracting from an otherwise clean design. I liked it very much, and IMO, the best looking "full-size" truck on the road.
Just my opinion, purely subjective.
I took delivery of my Limited on July 13, 1999
and the dealer said it was one of the first Limited's offered to the public. It would be interesting to know what number it was.
Tuck.
Also, is there a fix for the steering wheel vibration problem that I have read about even more frequently than the seat situation. I thought I remember someone mentioning a heavier steering wheel, but that just seems like a band aid for the problem.
Do you think Toyota will have a technical service bulletin covering one or both of these problems??
Would sure like a response.
$300,000.00 on Liability.
$1000.00 on Medical Payments.
$300,000.00 for Uninsured motorists.
$250.00 deduct on comprehensive
$500.00 deduct on collision.
This is together with my homeowners policy.
The company is Heritage Insurance.
I don't believe this is too bad?
Tuck.
on the same road, with the same speed. Tires have been balanced by Toyota dealer. Balance had helped, it used to vibrate at 58-62mph all the time. My captain chair also vibrates if no one is seating in. I love my truck, and hope Toyota would have a cure for these problems. People that I talked to thought the Dunlop tires were the cause. I'll appreciate your response.
Im curious....do you have 2wd or 4wd???
606
Thanks a million for all your helpful responses! Seems like you have become our resident factory man. Some time ago you posted that the 2001 Tundra would have a redesigned rear seat. "Much more comfortable" I believe you said. Any information as to details of the redesign, when available, and if the new seat could be retro fitted to a 2000 model? I will be purchasing a Tundra, but this might make the 2001 worth the wait.
Thanks for you response in advance.
Glad I drove the Silverado and Tundra the same day. It took about 3 seconds to realize they are not in the same league. Sorry if my previous posts regarding looks, etc., were harsh. I should have driven first - what an experience.
By the way, what opinions does anybody have on the driving feel of the 4x2 vs. the 4x4? My wife, is concerned about driving the rear wheel drive in our harsh winters after spending the last 10 years driving a front wheel drive.
I don't want the 4x4 unless it drives much like the 4x2.
About oil: A drain with the filter uses about 7 quarts. My guess is that at least a quart or more is in the oil cooler. Thus this engine has a large oil resevoir in relation to its displacement. Consequently, drain intervals can be extended to the manufactures recommended intervals.
BTW, I have been using synthetic oil since the late 70's and have changed oil at 7500mile intervals without incident in engines that have had known problems with top end lubrication. I always break the engines in for 3K miles with the factory oil and I don't baby them.
I can't sort out just what the rear bumper wiring harness is, as compared to the mutually exclusive tow hitch. Does the hitch option include the rear bumper wiring? Both are port installed accessories.
What are the pros and cons of getting one option or the other at time of delivery versus adding this capability later when I need it.
Note my previous towing has been to get the lawn tractor in for repair on a borrowed trailer about once a year. Does Toyota make tractors?
If you elect to install this stuff yourself, note that this truck and most other Toyotas require a converter/adapter (black box w/wires) since Toyotas use independent rear brake and turn signal lights. The cost for the trailer wiring converter is about $40 at Auto Zone.
The ride is incredible (note: I do have the extended cab). Double wishbone suspension, rack & pinion steering (I think the only 4x4 with R&P). I haven't hit the dirt yet...maybe this weekend. Plus, it's made in the USA so when the UAW start complaining, let them know the Tundra plant employs 2300 workers in Indiana!!! As far as towing capacity, I helped a friend move and we packed the bed with a lot of weight. The handling was still quite good and no problems jumping onto the highways...
Only good things to say about the Tundra....it cost a bit more, but, I will probably be trouble-free and that is peace of mind....Good luck in your decision
"stop-sell" on the alarm system while they re-design it. He said it will be 30-60 days. Has anyone else heard of this?????
Got any insurance nightmares for me?
I don't know what the problem is. I was just going to have it installed at the dealer in my new Tundra and they said that they were redesigning the "dashboard sensor". He said it would be available again in 30-60 days. It may have nothing to do with the system, but with how it applies to the new Tundra. I have sent an email to Toyota and asked for an explanation. If I hear anything, I will post it.
When I got home tonight I had a message from my
dealer saying that they had my alarm and I could
call to arrange installation. I never did get a
response from Toyota Web Page, so now I don't
know what was going on.
Kent
I'm now looking for a tow hitch to pull a 4,200 pound boat. Anyone has any ideas? I am also shopping around for a cab hi topper. I really like the EXPO model from SNUGTop, but I don't think they make it for the Tundra. I plan to installed Line-X ASAP and buy the LUND Model 18083 Bug Shield that some one recommended in an earlier post.
Buzzman2
Overall, a great truck, but has anyone else developed an annoying rattle or plastic scrape sound from the center of the dash where it meets the windshield. I'd rather not have the service dept. take it apart to try and find it, but it's starting to make me nuts. Any remedies?
Anyone else getting lousy MPG? I have a limited 4x4 access cab and got 13.3 first tank, 13.84, second tank, mixed city and hwy.
Have experiences the front end vibration periodically. That sure is a mystery. Have the TRD Off Road pkg with BF Goodrich tires. What was the concensus on the front end vibration? Has anyone had that checked?
