I live in an area that gets maybe 3 inches of snow a year and I can't drive the car in these conditions, the fender liner of my car will snap off and snow will get impacted behind it or I will hit the brakes and the Traction Control makes the brakes go nuts. Both situations makes the car un-drivable.
As for the service, they SUCK and so does the customer advocate line they will agree with the service department in all cases. So they are worthless.
Above all this, the resale value of a VW is non existent. I went to look at trading up to a Touareg and the car is worthless literally! Now the thought of another VW is out of my head for good.
Don't do it! Go with a different brand, sounds like Mazda is the way to go!
Krzys
1975 VW Scirocco (primary car, 85% highway driven) - 6 years, 250K (and this was the most unreliable of the bunch until I replaced the Zenith Carburetor with a Weber downdraft and converted the ignition from points to electronic). Even drove this car cross-country three times and was never stranded.
1987 Golf GT (primary car, 85% highway driven) - 16 years, 624K - The only time this car left me stranded was when the fuel pump failed - at 375K. Extremely reliable. I performed most of the maintenance myself. Replaced the following major (normal wear and tear) items:
90K - Replaced the timing belt (first two timing belts I replaced myself at 90 & 180K - mechanic replaced the belts at 270K and beyond).
145K - Performed the first of many suspension changes (shocks, springs, struts) (myself)
160K - Performed complete brake job - front disks and rear drums (myself)
175K - Replaced the original water pump (myself)
199K - Replaced the original clutch (mechanic)
200K - Replaced the original starter (myself)
235K - Replaced the original alternator (myself)
375K - Replaced the original fuel pump (myself)
429K - Replaced the original engine and transmission. (mechanic)
2003 Wolfsburg Jetta (weekend car, 75% highway driven)- 45K miles so far, absolutely NO problems (repeat: NO problems).
1997 Jetta Trek (work car, 95% highway driven) - Just turned 125K. Purchased car last year at 80K - original owner didn't trash the car, but didn't actually maintain it either - probably traded the car in with an intermittent check engine light problem. After a quick scan of the engine compartment, I noticed a crack in the ignition coil. After replacing it myself ($156 for the coil), the problem was solved. Changed the timing belt at 90K (like I have been doing with the 1975 and 1987 VW), and had the clutch replaced (since I had no idea how good the original owner was with the original clutch). Driven for 30K after that with no problems.
If you drive a VW, keep the following things in mind:
If you are going to do a lot of stop-and-go city driving, get a Honda, Toyota, Nissan, etc. These cars were developed in a country (Japan) with narrow roads, and massive rush hour traffic (I've been there), so the cars are properly designed for stop and go city-oriented driving, and tend to be much more reliable in those situations. VWs (as well as most other german cars) were not designed for stop and go driving. They were designed for long-distance high-speed driving on the autobahn. As long as they are driven on long highway commutes, they will last a long time. If you drive these cars every day in the stop and go, hustle and bustle of the city, you will tend to have MORE problems.
Many car owners tend not to take into consideration whether they will do mostly city or mostly highway driving when purchasing a vehicle.
Remember, folks (and I cannot stress this enough):
If your driving mostly consists of city or suburban stop and go driving for short distances, I wouldn't recommend a German car (in fact you would be wasting your money big time IHMO). Get a Japanese, Korean, or American car.
If you do a lot of highway driving, however, I would highly recommend a German car, because highway (autobahn) driving is their stong suit. The Germans specifically engineer the steering for "road feel", just for this style of driving.
And as long as you keep the car properly maintained, it will prove to be quite reliable.
And one more thing, folks - Never, EVER, buy any car in its first couple of model design years - whether German, Japanese, Korean, American, whatever - to do so is asking to be a beta tester to help the manufacturer work out the bugs.
So if you need to regularly TURN or STOP, or RESTART your car after stopping, get something reliable?
Have a nice day...
What really amuses/saddens me about VW is how long they have been producing junk.
I had a new 1975 Rabbit and then a new 1979. The '75 refused to start about 3 months after I bought it, when the weather turned slightly colder. It had to be towed for replacement of needle jets in the carburetor. That was just the start of many problems with this car, including premature clutch wear, a broken sunvisor, catalytic converter innards coming loose, cracks (!) in the floor under the seats, muffler rusting/leaks, and the beginning of excessive oil consumption. I traded it for a '79 before it hit 40K miles.
The '79 was better, but the alternator quit when the car was 2 years old with only about 15K miles on it, stranding us on the road. The blower motor failed also, before 30K miles: I thought some leaves had gotten in the blower motor, making a clicking sound that drove me up the wall. Then one day, I caught a whiff of a burning smell.... Also it was recalled by the EPA for excessive oil burning due to premature valve stem seal wear. Mine hadn't yet begun to use oil excessively, but I remember the sticker VW sent to affix to the fuel filler opening reminding me to check the oil at each fillup. I sold the car at 33K miles. That was my last VW.
Amazing how some things haven't changed!
I'd seriously look at an R32 once there's more power. I can't see owning anything else, since reliability is a major deal for me.
I've done several hundred VW lemon law cases, they're third in number to Kia and Hyundai in my personal stats. A real bummer, because I think back to thefun I had in the Beetles I've owned when I was overseas, and the GTIs I raced autocross with.
And speaking of causing trouble, I'm sure your comments here were meant to improve someone's self-esteem:
#999 of 999 rsharp by bjbird2 Jan 30, 2005 (12:32 am)
Bookmark | Reply
As I said Randy, watch your Ford. It may catch on fire while you're not looking. At least the Pacificas are not going down in flames.I'd rather have a clunking noise (and I don't) than a truck prone to spontaneous combustion.
Perhaps you should clean up your own back yard before criticizing mine.
has treated me well since my next 3 VWs lasted a long time:
1987 Golf GT - 16 years, 624K miles (totalled by a deer) - 3rd model year of the Mk2 series and last VW year built in Westmoreland County, PA (east of Pittsburgh).
2003 VW Wolfsburg Jetta (currently own) - 45K and absolutely NO problems. 5th model year of the Mk4 series.
1997 VW Jetta Trek (currently own) - 125K and still going strong. Final model year of the Mk3 series. I have the 2.0 liter engine and it does not burn any oil (Makes me wonder what boneheaded design change VW made with the 2.0 liter engines for 1999 through 2002 that created their oil consumption problems)...
The 1979 through 1982 VWs kind of lost their identity when VW tried to "Americanize" their vehicles. Big mistake. I avoided these cars like the plague.
The 1988 and later VWs through 1995 I definitely avoided like the plague, especially since VW just moved their production facility to Mexico for the 1988 model year.
The 1999 through 2002 models I also avoided like the plague. More problems:
Window regulator - some genious decided to use plastic clips to hold up the glass instead of metal ones, which they eventually started replacing the plastic ones with during their recall)
Ignition coils - Problems with their supplier delivering a bad batch - reminds me of the 1987 recall for heater core failures due to a bad batch received from their French supplier.
The reason I have had better luck with VWs than other owners is because I carefully do my research and usually buy cars in their final model years. The probability of the bugs being worked out is much higher by then. I do not wish to become a beta tester for any new model car, and I also do not have a desire to be the first on the block with the latest and greatest gizmo that comes out on the market. I prefer to let others make that move and learn from their misfortunes.
My, aren't we getting defensive with the personal attacks... Thanks for providing me with a good laugh, but my self-esteem and I are getting along just fine, thank you...:-)
Besides it takes someone with a hell of a lot of self-esteem to be a long term owner of the most "unreliable" automobile on the planet - 4 times as a matter of fact...:-) Bottom line - I drive VWs because I enjoy driving them, warts and all...
I congratulate you on your ownership of 12 VWs. I guess you're doing it for purposes of "research" in order to strengthen your litigation cases. I suppose I can't blame you for wanting to keep the revenue stream flowing by any means necessary. In fact, I would probably do the same thing if I were in your shoes...
"I guess you're doing it for purposes of "research" in order to strengthen your litigation cases"
Completely uncalled for - I have no bearing on the strength of any cases, I'm not a lawyer. I'm a technical expert - huge difference. And, no, I've been an expert witness for 4 years, and hadn't owned a VW since 1998.
My revenue stream has nothing to do with the vehicles I own or the research I do - I simply report on the cases I'm given.
...and for the record, I tend to avoid caffeine and the other vices of a (sad to say) pill popping, alcohol and drug-consuming society...
But thanks for your concern...
Are you a non-profit organization? Pardon my skepticism, but nothing
gets accomplished nowadays without a financial motive lurking somewhere behind the scenes...
With this, I see a broad spectrum of manufacturers represented in the 5,779 cases I've worked on in 4 years.
I get paid the same whether I'm writing on a Chevy Cavalier, a VW Golf, or a Mazda Miata. Win or lose, I get paid the same, and there's a never-ending supply of cases - I don't have to advertise or drum up business - I pick up the new files and give back the completed files - period.
Personally, I could care less where they come from (manufacturer) - I'm paid for an opinion. With the large number of cases I've had, though, it's easy to notice strong trends, and I post those trends here on Edmunds at times.
Kind of our own Ralph Nader.
Can't see old Ralph doing any of that stuff. I also know the automotive industry and I'm interested in vehicles as an enthusiast, something he can't say - I doubt I'll ever see old Ralph doing Solo II with me at Cal Ripken Park in Maryland...
And I'm not older than dirt, either....
Just curious, why do you drive a Saturn and a Dodge? They seem like rather mundane cars for an adventurer like you.
Let's skip the personal stuff from here on out, OK?
PF Flyer
An aside: I have been reading the posts of Driftracer for awhile now and think his experience provides great insight and his posts are seemingly accurate and enjoyable to read!!!!
Again, thats the great thing about these boards, we get to read the opinions of many poeple!!!!
The Passat has truly been a wonderful car, but like a lot of german autos has needed stuff repaired (All under warranty). AM radio quit (Corroded antenna connections), Battery will discharge if leave car sit for week or two unlocked. If you lock it the computer goes to sleep and doesn't discharge the battery! Finally at 70K miles it was leaking oil from the cam tensioner seals. All work done under warranty. Car has been a blast to drive and own, but I am looking to replace it. In MN AWD is really a good thing to have. Am now looking at the Infinity g35X. Love the horsepower and rear wheel drive bias on the Infinity Vs the Passat FWD bias even W/ AWD also, the passat is basically unchanged from 2000 and I am not going to buy the first year of the B6 version.
Overall, have had great service from two Volkswagens in two different decades, and found the dealer support to be very good both times around.
After having owned 5 japanese cars over the past 14 years, nothing had ever gone wrong until I bought this Passat.
Homelink went out after 1 month, 5 different lightbulbs burned out, being towed twice for faulty ignition coils, 3 times attemtet to repair trunk hinges, 5 times the check engine light came on, fuel ignition and another ignition coil replaced. Finally, before 60,000 miles I called in another check engine light. I could not get an immediate appointment, I reported to them the mileage and they said the car was driveable. When I got the Passat into repair I was told that the No. 4 cylinder head needs to be replaced, but since I drove it past 60,000 miles the dealer told me I was out of luck and the Drive train warranty of 60,000 miles had expired, although I reported the problem prior to that.
Rather than go to court I sold the car.
Normally I share a pickup from a rental company and I hear all these familiar horror stories from the other owners.
VW keeps Enterprise Car Rental single handed in business. This is my second experience with VW, one in 1982 and the next in 2002, both the same nightmare, never again.
There seems to be a love/hate relationship for many VW owners. I loved the look, the feel, the handling, but the overall ownership experience was bad..too many electrical problems(melting fuse panels, elect. smoke etc) poor dealer service(my last trip I left screaming at the service mgr), and VW has what I belive was, and apparently still is, a poorly designed engine. After about 70K, the dealer told me that my head were warped..and one of best friends had his 1980 Scirroco engine, when it was about 4 years old, seize on him. I have no doubt that someone can get a good reliable VW, but the odds are that you won't. Sorry, I'll stick with the [non-permissible content removed].
I recently owned a 2002 Passat. It regularly had small electrical issues and other bothersome things. I never really worried too much about it breaking down, but it seemed like I was always running to the dealer for little things. But, I really liked that car. Once again, it handled better than the competition and it had better styling in and out, too.
Both times I replaced it with a Japanese car. The more things change...
I did a lot of research and looked for several months this past fall for a brand new or newer used (2001-2003) Golf. But in the end the overwhelmingly negative on and offline comments about recent VWs ultimately steered me away. I love how VWs drive and handle, but just didn't want to deal with the reliability issues. So I bought a 2004 Mazda 6S 5-door (hatchback). It doesn't handle or drive just like a VW, but for me it's a good compromise. And better yet, the Mazda doesn't have a recent model VW's electrical system. I'm hoping VW reliability improves. If so, I'll seriously consider a clean-burning TDI Golf or Jetta if/when the U.S. finally has low sulfur, clean-burning diesel fuel widely available. We all have to make our own decisions, and that was my decision-making route. Good luck.
I'm now driving a 2003 Wolfsburg Jetta (45K, no problems so far), and a 1997 Jetta Trek (125K, doesn't even burn oil)...
But here's the problem, I replaced the starter at a vw dealership with an auotlite starter and the problem still persists. What is going on? has anyone ever had this issue? Please help me. Please email me directly, at fedisir@gmail.com thank you very much.
j
This sure sounds like a KEYSWITCH or RELAY problem to me. (The starter only cranks when it is getting power....it can not continue to crank "on its own" )
hugh
At close to 50 K miles I had them change my rotors without any charge as I had mentioned this problem of steering wheel shaking when coming to a stop from hight speeds when I was in for 40 K service. WesGreenway VW@Alexandria, VA. They are very good. Russell VW in Baltimore lead in their suckitude!
I commute 100 miles daily and I have to fill an extra Qt of oil around 4K miles. VW did a oil consumption test and says they consumption is within limits. The 2.0 L engine is quite old technology. The 1.8 T is better. I love my Golf, but I hate the high engine noise in the car. I love this car that I will drive it till it dies but dont know if I'll buy one again because of the noise. VW design, styling is seond to none IMO. You get more for your money with many standard features. Japanese cars will cose 2-3 K more for similar accessories. How else gives you 4 air bags for each front passenger for a sub 16K car? I think driving a VW is an experience and I love it very much. If they make the car less noisy I'm sure I will be back in line!
I bought my car from Quirk VW in Quincy, MA before I moved to VA. They were alright.
People who are buying a car look into http://cars.msn.com and edmunds.com for reviews. Most people in this forum are people with bad experience hence the scathing remarks. I'm not saying htey are lying, but the saying "you'll hear from them only when things are wrong" is true for any product and any consumer. And for the record, my car has never refused to start, stall etc. I would say it is reliable. Here I see everything negative (or mostly) if you go to carpoint website, you would notice that vw golf has an 8.3/10 with many people giving positive reviews!
Talking about dealers, most dealers are bastids. Ideally they would like to sell a car(junk or not) and not have to worry about customer service/repairs/parts etc.. So you start hating a product if the dealership sucks. Luckily for me the dealers I've dealt with have been pretty good.
i like vws but i'm not a fanatic. i'd buy another one if it fit my needs as well as the two i already own
It's an old post, but one wonders how he knows that "most dealers are bastids" if the dealers he's dealt with have been pretty good......
It's a good thing it came with a free Trek bike, because I did need it!
Bob
And now the new GTI will come out around the time I'm finally getting a new car, but I'll be too scared to buy one. I honestly know zero people who have had unproblematic modern VWs (my parents had a couple before I was old enough to really remember them). On the other hand I only know about half a dozen people who've had problematic VWs, but I haven't gone to sleep yet so I'm tired enough to not remember everything. Still, 0 for 6 scares me.
Making their cars more expensive doesn't make me trust them more.
(And more importantly, I think that pricing the Jetta with the likes of the Volvo S40 and other near-near-lux cars will yield VW the same tiny market share that those cars get. It's not a very popular niche, but it's not a new one either... and it sounds like they're counting on this "premium small car" segment blowing up.)
I wouldn't want the size of those large cars anyway, but I do think the '05.5 Jetta is overpriced by a couple of thou. OTOH, there is a rumor that Nissan plans to do this (move it up to "premium compact" status) with the next Sentra, possibly arriving for the '07 model year. I would be more sold on the New Jetta if they had done better with the fuel economy.
The only person I ever knew with a VW was my best friend, who had a '95 Jetta GL. Worst nightmare car she ever had. Traded it at about 70K miles, the auto trans was just giving up the ghost, and many of the electrical components inside had long since failed at that point (including the odometer, which read 36K, and I noticed when the dealer resold it they advertised it with "low miles! 36K" even though she had informed them of it. Crooks).
She moved on to larger cars in 1997, with first a Camry and now an Accord after she got bored with the Camry. Not a single problem with either, and she is sold on Japanese for the time being.
The single worst rated car by CR for reliability is the five year old Jetta and Golf V-6. OTOH, they now put the base Jetta and Golf 2.0 on the list of reliable used cars.
