Mazda RX-8 Problems and Solutions
13468928
    Just curious about the details of the e-mails from Mazda if you could shed some light...
    First, I've never used anything but Premium in my 8. However, the manual does state that Regular is fine, but you will only give up some performance in its use....nothing more than that.
    Are there other reasons the MAzda e-mails state regarding their fanaticism regarding the use of Premium only?
  • darrshedarrshe Member Posts: 4
    I have had my RX8 since July, now have 5700 miles on it. Gas mileage has improved from 16 mpg to 22 mpg, with auto trans, as mileage has increase on car. Car did stall once. Turns out car can not be started and then turned off, while still cold, or flooding will occur. Need to warm engine before turning off. Also, battery needs to have a good charge, as engine needs to achieve 100 rpm on starter motor to start. On the A/C issue, mine does cycle. It has been recharged, still the same. Waiting for fix from Mazda. I have heard a rattling noise from right firewall/under the passenger floor at 3/4 throttle while accelerating from a toll booth. Seems to be some form of pinging. Will need to get that investigated if it returns. I always use premium fuel.
  • flatpickflatpick Member Posts: 43
    Loving mine...had oil light come on during a trip from Charlotte to Atlanta....waiting for oil pan parts to come in for fix...MPG getting better...have added about a quart of oil since driving off lot in late Oct to keep dead center of hi-lo marks....DSC kicked in a few times in rain, mainly because I was trying to get it a little squirrly and see how it reacted....I have 3 nicks from gragvel or ??? on my hood...not too big...part of owning such a low slung sports car.
  • eatonjameatonjam Member Posts: 7
    Please be sure and not flood the rotary engine. I flooded mine by starting it on a cold morning, moving it down the driveway, and turned the ignition off without letting it warm up. Raw gasoline is stuck inside the engine and I had to call roadside assistance to come tow my car to the dealer. The dealer said to make sure and let a cold engine properly warm up before shutting down and to never put your foot on the accelerator pedal when it won't start. The dealer said that they will have to remove the spark plugs and clean or replace them because they are fouled from the raw gas. Live and Learn I suppose. Where is the information on the oil pan technical bulletin?? Thanks!!!
  • audia8qaudia8q Member Posts: 3,138
    the big scare is potential 'pinging'....pinging is the kiss of death to apex seals on a rotary engine. The higher octane eliminates this problem. According to the service rep, one ping is all it takes.
    Glad I only use permium, then.
  • danwooddanwood Member Posts: 1
    I have had my rx8 about 4 months now. I have the gt package with 18in wheels and now have around 7000 miles on the car. I love the car but within the first 6 wks I began noticing a strong pull to the right sometimes when I would brake. It happened about 7 or so times in the first 3000 miles. I have since had it into the Mazda dealer 3 times for this problem. It has gotten worse and now pulls more frequently in either direction randomly when braking. Perhaps 1 out of every 15 times I brake. They have turned the rotors(I don't know why they didn't replace them) bled the brakes changed the pads checked the calipers etc. They have an open ticket with Mazda Tech Line. No luck and they said they are stumped. They tell me they are desperately trying to get Mazda corporate to help them. I am getting very frustrated!
  • cheezeboycheezeboy Member Posts: 218
    UPDATE: Showed the dealer my seamed cracked visor. No problem, but they will have to order one. Said it should take about a week. Will update further when I get the part!
    Also, 5K service cost me $22.
  • r0g5r0g5 Member Posts: 1
    When you all bought your rx-8, did the dealership warn you to warm the car up for at least 5 minutes before you drive it, and to rev the rpm's to 3000 before you shut it down? One of the dealerships I went to was absolutely adamant that I follow this, or else the engine would destroy itself within a few thousand miles. None of the other dealerships even mentioned this, and I can't find it anywhere on the web. Does anyone know anything about this?
  • wh9wh9 Member Posts: 32
    interesting that it only takes one ping to destroy the apex seals. I'd like to hear more about that.
    Not meaning to be contrary here, but woudln't the ECU intervene to keep "pre-detonation" or pinging occuring?
    YES! If you don't rev that puppy up to 3k each time you start it, it will self destruct! And watch out, cause when it blows, winged monkeys fly out and eat your face! Seriously! It happened to my uncle's sister-in-law's aunt!
  • pathstar1pathstar1 Member Posts: 1,015
    It's not necessary to fully warm up the engine before driving off. It's good practise in any car to not heavily load the engine until it is fully warmed up. I drive my 3rd gen off (gently) after 20-30 sec. (to close the garage doors). You shouldn't shut the engine off until it is warming up (temp gauge starts moving). This is to ensure you don't flood it next time. It shuts off "choke mode" and cleans out excess fuel needed for cold running.
    Pinging isn't going to hurt the apex seals, but detonation will. Pinging is a warning that detonation can't be too far in the future. Yes, just one detonation event -can- destroy an apex seal but it doesn't always. The shock wave has almost uncluttered access to the apex seals, whereas on a "boinger" (piston engine) the rings are down a bit from the top of the piston, so shock waves get attenuated before hitting them.
    The 3rd gen RX-7 community (and to some extent turbo 2nd gen as well), thought the fix was to go back to 3 mm seals, or even the expensive ceramic seals. Turns out they also break and appear to do so just as easily. Mazda went to 2 mm seals to try to stop them from "fluttering" (bouncing) when passing over the exhaust port on the rotor housing - less mass means better control. The conclusion most have reached is the only fix to avoid breaking apex seals is to run a proper fuel mixture.
    After saying all this, I doubt you could damage an RX-8 engine, even with 87 octane fuel, as long as you don't modifiy it.
  • golfbuddygolfbuddy Member Posts: 1
    I am experiencing the same flooding problem. However, I was on the interstate going approximately 100 miles per hour and the engine lost all power because of the excess gas flooding the spark plugs. Once the spark plugs are flooded, they no longer work properly. My dealership said Mazda is working on a computer program to fix this excess gas injection problem. Until then, they told me the same thing. Let the car warm up and do not cut the engine off until it has reached normal operating tempature and even then rev the engine until it reaches 3000 rpm and then cut off engine.
    For this caliber of sports car, what a pain in the butt.
    Thanks...as always, your wealth of knowledge clears up a lot of FUD.
    golfbuddy...that's the first I have heard about plugs fouling while you're driving. My dealership, which I have a lot of faith in, has said that, like any car, not to turn off the RX8 if it's in "cold/choke" mode. I've done this more than once with no flooding problems. I've also heard that "blipping" the throttle immediately before shutdown should be done. My techs don't see how that helps and it's somethign I've never practiced, but if if works for you, have at it.
  • doodle8doodle8 Member Posts: 3
    This is my first post to the RX-8 site!
    I've experienced several of the popular recurring problems posted at this site. In October, I experienced the dreaded fouled spark plugs when I moved my RX-8 from my driveway into the garage. Couldn't start it the next day and had to have it towed. Dealer gave me the same story on my '94 RX-7 (make sure car's warm before shutting it off), but NEVER had the problem with the RX-7. It seems to me that it would be worth mentioning in the Owner's manual that moving your car 30 feet might render it undriveable.
    I also had the "oil light problem" when I would drive on I95 at 80 MPH or so for more than 20 minutes. Dealer replaced the pan/sensor (same time as the sparkplugs!) and this problem has not re-occurred, but admittedly, I've done less highway driving lately.
    Now today the LATEST PROBLEM: When I started the car after work today, my tire pressure warning light came on. It went off when I was halfway home. I'm attributing this to the fact that it was about 15 degrees, and the pressure didn't reach a "threshold" until the tires warmed up. Does this make sense?
    I just love the way the car looks. It's awesome. But these nuisance problems are quite annoying. I also had EXTREME difficulty obtaining my "overstated horsepower" deal from Mazda, but I finally got the $500 giftcard in mid-December. Hopefully I won't have any more problems - I want to love this car, but it's testing me.
    but if a fixed oil light, low tire pressure, and having to properly warm up your car (which, personally, I feel should be required BY LAW on ANY car) "test" you, then you don't have enough real challenges in your life.
    i apologize for my abruptness, but driving to work in the snow today and watching all the idiots spin their cars right off the road has got me a bit short on patience.
    I have to concur with qbrozen here (maybe not as abuptly, however).
    The way I see it, your oil sensor was replaced (mine was done about two months ago) under warranty. No more problems.
    Your tire pressure light operated exactly as it was supposed to. You really can't fault the car. It told you that one (or more) of your tires dropped below or went above the "pre-set" pressure while you were driving. That's what it's supposed to do. Mine has done the same thing. At my next fill-up, I check all the tires and sure enough, one of my tires needs air. I adjust them accordingly.
    My 8 warms up quickly. Although, I've started and stopped mine cold, I've never had an issue. That said, I live in a remote 'burb. Anytime I drive my RX8 to go somewhere, it is going to be driven for more than a couple of miles.
    As qbrozen said, it's a good idea to get any car to operating temps before shutting down.
    As a general rule of thumb, I start and drive my RX8 without any elaborate "warm-up" procedure....just start and drive. I also don't shut it down unless the tach has settled into the 750 RPM range (no rich mode).
    Quite frankly, I'm hearing an awful lot about flooding/stalling recently on many brands that's leading me to believe this is a "fuel issue"...maybe a change in winter fuel formulations? A difference in refinery process? Emmissions standards are ever changing. Perhaps the attempts to succomb to the different stardards is causing some of this?
    My neighbor had his '03 Accord flat bedded to the dealership for flooding and no start a couple of weeks ago. I'm thinking of adding a Scion xB to the graphicguy stable come spring for Lowes duty. I've been following that thread and, again, talk of flooding/stalling seems to be an issue there, too.
  • rxnrlzrxnrlz Member Posts: 1
    Hey folks, as a 2nd generation owner for 14 years (same car, 164,000 miles), get used to the warm-up routine to avoid flooding - it just comes with the territory. You'll know you've come into the rotary culture when you find yourself sitting in a piston powered car waiting for it to warm up.
    Interesting message strings - I'm considering an RX8 to replace the good old RX7. Some of it's familiar and some of it is due to "advances" in technology. We all know the car is unique - that's part of the fun and the frustration.
    Death to the Z cars !
    that's a coincidence. i've been thinking an xA or xB would be a good runabout, too.
    There is a huge tire thread on Edmonds. I strongly suggest everyone read it. It will take you several hours to get through it all, but it's worth reading! There are several very knowledgeable people who have posted there (you will soon get used to their names if you read it).
    Bottom line, you should be checking/adjusting your tire pressures regularly, when cold (before driving). Tire pressures dropping when it gets cold is due to both loss of air (due to leaking because the materials get cold and don't seal as well along the bead) and just shrinkage of air when cold.
    rxnrlz....LOL! It's kind of a unique club in here. We get some who don't "get it" and slam our rides and then there are those of us who know exactly what the car is about and just have fun with our wheels and don't worry about the nitpicking.
    pathstar...although I haven't been to tire threads here for a while, you're right...it's filled with some good information.
    q....what are your thoughts about the Scion xB? I've only seen one in person and it belongs to a local tire store. It doesn't matter much to me what it looks like. I just want something to haul 2X4s and gardening supplies with (so I don't dirty up the RX8). Pricing and equipment look pretty darn good on the Scion, considering it would probably cost about the same as a new "stripper" pick-up truck. Of course, they won't be available in the OH valley till sometime this spring/summer.
    for fear of retribution, we should keep that on the xB board. But I don't know much other than what I read cause its not here on the east coast yet, either. Next month, I think. I might be inclined towards the xA, though, since the wife's Honda Pilot can haul much more than the xB.
    ummmmm.... on topic... um.... what is with the letter "x" in car names?? i find it rather annoying. At least the RX has been around since way before the "x" craze. :)
    doodle - In past posts, I mentioned the same tire pressure issue in the cold. GGuy, Pathstar, and a few others, clearly explained the issue and what to do about it - ie: buy a good gauge and put air in them!! I was concerned because it happened soon after my purchase, but they assured me all was well.
    Yes, a good tire pressure guage is a "must" for anyone who owns a car.
    While the "tire pressue indicator" in the RX8 is a bit more sensitive than those in other cars, I've never found it to be wrong.
    UPDATE - got the call yesterday that the replacement visor was in. Went in this morning. All better! No problems, No complaints!
  • johncaliforniajohncalifornia Member Posts: 28
    Thanks in part to the excellent information provided by this board, I'm about to become an RX-8 owner.
    I'll be choosing a base 6-speed, Titanium/black cloth, with only the cargo net as an option. My only performance modification will be eventually to install a chip that restores the car's original power.
    Rather than add exterior ornaments (strakes, etc.), I'll be removing all the badging so the car looks as clean as possible.
    I plan to keep this car for many years and want my RX-8 as light and simple as it can be. The base car's standard equipment already is more than adequate for my needs, and none of the factory options makes the car go a bit faster or perform a bit better, so why buy them? : )
    I'm a rotary-head, no question about it. My first rotary was the almost unheard of 1970 Mazda R100 (http://www.mazdarotary.net/mazda_r100.htm). It was tiny, beautiful, and its engine blew up regularly. But it addicted me to rotaries. It also taught me that if you don't drive a rotary the way you should, you will encounter the problems that have been cropping up on this board.
    While most contributors to this board understand and appreciate their RX-8s, I'm surprised by the utter cluelessness of some people who've complained about lack of toque and flooding issues, and seem disappointed that the RX-8 doesn't drive like a conventional car.
    In my humble opinion, all these folks should have bought G35s. Everybody would be happier: Mazda, Nissan, the owners, and especially us, who have to read their endless whining.
    Which reminds me: No more requests for turbo- or supercharging PLEASE! If you want a turbo on this car you're completely missing the point! (Which is that the RX-8's power, when restored to 250, will be more than adequate for its mission. A turbo severely compromises a car's driveability.)
    My main point, though, is that the RX-8 is an exotic, as sophisticated as any Italian supercar. Its rotary engine cannot be driven like a Camry V6. Just as with a Ferrari, if you try to drive an RX-8 like a Camry, bad things will happen. Count on it!
    Like a highly-tuned piston engine, the rotary makes demands on its owner that other engines don't. If those demands are not complied with, the owner will have problems, GUARANTEED. What some people here don't understand that problems like flooding are due to the owner's lack of understanding rather than the car's shortcomings.
    As an example, the best way to destroy a rotary is to lug it. But non rotary-heads who are used to high-torgue piston engines will lug their RX-8 by default. I blame the dealers for not adequately qualifying/informing their RX-8 customers. Those dealers' service departments will end up suffering as a result. And so will Mazda's reputation when the RX-8 is branded as a lemon by unhappy and uninformed ex-owners.
    Being a happy rotary owner is NOT a hard thing to do. Just follow a few simple precepts: change the oil frequently (5000 miles max); use premium gas; warm the car up thoroughly (don't trust the temp gauge, give it at least 10 mins); and keep the revs up (never below 4000, normally 5000 - 8000). That's about it!
    Follow these simple rules and you'll avoid flooding/low torque issues, and your rotary engine will last indefinitely. As will the rest of the car. Mazdas are legendary for their longevity. All my Mazdas (except the R100) have been virtually problem-free, even with high miles. Hard driving helps keep them young. And me too!
    If everybody understood how to drive their rotaries, we could use this board to discuss the real issues, like upcoming CPU replacement options from different tuners, and the minor problems that really are the factory's fault, like the oil pan design causing the warning light to come on. An informed customer is good for the dealer and the manufacturer, and a board like this is invaluable to owners who love their cars.
    I hope to become a regular contributor, so now you know where I'm coming from! Thanks again for all the info, especially graphicguy!
    Why thank you.....! Glad to be of help.
    Obviously, I'm in agreement with you. Rotaries are special.
    Neither better nor worse than their piston counterparts, just different.
    If one doesn't understand the uniqueness of the RX8, then, by all means, they should buy something else that's more mundane.
    However, those that do understand what they've got will be rewarded with a car with outstanding performance characteristics.
    While I do not warm mine up before drive off, I do drive it more than just a 1/2 a mile before shut down. I just jump in and drive....no thought given to flooding. Plus, I live in w wintery climate.
    If you're just now taking delivery, the oil level sensor and pan baffles are probably already installed.
    I'm more than satisfied with the performance of my 8. When the warranty is up, I may look into the "stage 1" mod. Until then, I'll be "zooming" along. I know of several first gen RXs with more than 250K miles without having anything done to the seals. With proper care, the RENESIS should be no different.
    Funny story...last Saturday, I had parked my 8 in front of a local eatery. A group of women were across the street from where I parked and shouted to me as I was entering...."hey, is that a Ferrari you've got?"....my answer, "It's an RX8". Ladies..."WOW, I'm going to have to remember that Ferrari has a new RX8 model on the market....."
    oh my......I mean I saw the new Ferrari in Autoweek and I hate to tell ya....there is no "R", no "X", and no "8" in 612 Scaglietti........and don't try to tell me you 'tried' to correct those ladies....no way, you LET them believe you had the new 'Scagleazda RX8"....ROFL!!......
    question: do you normally have an abundance of Ferrari's hanging out at your local eatery? :-)
    JohnCali: GGuy is our forum hero! Glad to hear you are getting an RX8 for yourself!
    Don't know about the hero part...I know some on these boards that would disagree. Thanks, though!
    Funny thing about the Ferraris, the closest dealership is easily 100 miles away. I can't think of maybe one or two that I've ever scene on the road around here. I've scene some at Concours events, but those are mostly trailer queens. I've seen plenty of them on the road in Vegas and the San Fran Bay area.
    Ohio just isn't a hot bed for esoteric cars like Lambos and Ferraris. Mostly, the most exotic thing scene on the roads around here are Corvettes, and of course, RXs. Biggest status symbols are Lincoln and Caddy SUVs....even with a Rolls dealer within 20 minutes of my home. The only Rolls that I've seen around here is owned by a local "magnate" who owns (or used to own) Chiquita (as in bananas). It's a nice one, too...a convertible.
    Considering that the ladies who mistakenly saw my car as something it wasn't were parking a very nice previous gen BMW 7 series, I would doubt they would have known what a Ferrari looked like. Maybe if they ever did see one on the road, they'd mistake it for an RX8?
  • carlikercarliker Member Posts: 285
    Graphic, I think those women were just using the RX-8/Ferrari thing in order to start up a conversation with you. Don't let the car take away any of your spotlight!
    For some odd reason, your comments and your politeness when posting them (even when you disagree with someone about the RX-8) remind me of Ned Flanders on the Simpsons. You wouldn't be him, would you?
    You're killing me....Ned Flanders?
    LOL!
    Actually, that's pretty funny.
    If I thought, even remotely, that my car would make me more appealing to the fairer sex, I would have bought it without driving it and site unseen while paying well over sticker.
    In all honesty, I've never thought about cars having any sort of "sex appeal", but if that is indeed the case, I'll start driving the RX8 more. I'm certainly not getting any 2nd looks driving my Civic. I've just attributed it to the fact that females don't get the full bennefit of my "sparkling personality" when they see me in the Civic;-)
  • canuettecanuette Member Posts: 10
    Where can I find service bulletins for my new RX8?
    Chas.C.
  • clementunesclementunes Member Posts: 6
    I've had my 6MT for a few short weeks now, still less than 1,000 miles on it. 'Been noticing a quiet but perceptible scraping/grinding-type sound when the shifter is in neutral. It's most noticable when the car is first started up and cold, then seems to lessen as the car warms up. The sound will disappear if I push in the clutch. I've noticed something similiar in my other manual shift cars but not quite to this degree.
    Is this normal? Anyone else notice anything like this in neutral with your 6MT? Thanks.
  • redrpmredrpm Member Posts: 16
    Canuette,
    Two sources I know of, 1st is free, 2nd one costs:
    www.finishlineperformance.com/rx8/docs/index.html
    and
    www.alldata.com
    Hope this helps.
  • yosarianyosarian Member Posts: 5
    Johnny C,
    For someone who has concluded that spelling and grammar are no longer a part of the English language, especially on the Internet, I was delighted to see both of those lost arts applied so adeptly in you posting. Thanks.
    BTW -- do you have anymore info. on the chip to which you referred? 12 ponies isn't much, but if it's not too expensive, and won't void the warranty, I'd like to check it out.
    What exactly did you mean by warm the car up thoroughly? Sit in the car for ten minutes, or keep the rpm's down for that length of time?
    The only observation I can make that isn't in your favor is your choice of color -- red, there is no substitute.
  • aaa_edgar_poeaaa_edgar_poe Member Posts: 24
    This 8 has me very intrigued.
    A few questions:
    I line in Southern California (Riverside city to be exact). Do I need to warm the 8 up (I am not an owner but in the market to buy)? It can be 38 to 42 degrees F in the morning from December to March. What outside air temperature would be good for not needing warming up?
    If you don’t know it, Southern California has traffic problems. One poster here (namely, johncalifornia) talks about not lugging around your car but keep revs above 4000. Well, in S. Cal, it can take three light changes to make it through an intersection, then often on the hi-way it is stop and go.
    Talk of this car reminds me of the movie “A New Leaf” Starring: Walter Matthau, Elaine May; Synopsis: Light romantic comedy about destitute rogue romancing wealthy young woman. Critics felt this '70s farce was a near-miss of a great film, but appealing for fans of era's comedies.
    In this movie Walter Matthau’s Ferrari is always breaking down since he can not drive in New York like a Ferrari should. If that’s the case with the 8, then I guess I need to look for something different.
    Q: anyone ever built a diesel oil Wankel type engine?
    I'm really not sure if its a problem, but, like you, I have heard this in other cars and have this now in one of my current vehicles. I believe it has to do with the spinning of the throwout bearing. I would think the noise is not a good thing as noise means friction which means wearing of parts. Maybe mention it when you bring it in for service and see what they say. I'd be curious to know because I've never had the luxury of having a vehicle under warranty that did this. ;)
    ...clutch out, shifter in neutral does sound different. It's not a bad "throwout bearing", just the engine spinning while the driveshaft is stopped (which happens to run right through the console tunnel next to your right leg). Not a problem.
    I don't remember anyone mentioning having their cars flood during warm or mild weather, which is what I would imagine Riverside, CA having. even with temps in the teens in the OH valley, I just jump into my car start it and drive it away after the RPMs settle down (maybe a minute?) and let it warm up while driving. That's true of both warm and cold driving temps.
    "Lugging" the car, in my estimation, means trying to drive in a gear that causes the engine RPMs to drop to somewhere around 2.5K RPM while in 5th or 6th.
    I wind mine out to about 3.5k RPM until the engine warms up (not difficult to do). That keeps you within the speed limit, whithout lugging it while still cold. After warm-up, I'll bounce it off the rev limiter at least once/day.
    This car warms up quickly. If you're stuck in stop and go traffic, it will warm up even quicker as you'll have a lot of "idling" time.
    No need to be worried about this car. Just take some easy to do precautions (like not starting and shutting down before warm-up) and you'll be very happy.
    I've never even heard of anyone trying to build a diesel version of the rotary, throughout its history.
    redrpm, glad to see you're back....how's your car since you've received it back from service?
    so what exactly, in your estimation, is making the slight grinding noise?
    To give a bit more info on this, you don't even need to step on the clutch completely to get it to go away. You can just gently touch the pedal and that will, I guess, take up the slack and stop the noise. I know I asked a true mechanic about this once but don't remember if I got a satisfactory answer. And since my years as a mechanic were limited, its not something I ever ran into as a problem.
    I'd have to get under the car and look/listen to what's happening with the clutch engaged and the clutch disengaged to tell you exactly what's going on (not the safest thing in the world).
    I'm making an "educated guess" that the sound isn't necessarily "grinding" per se, but actually more a "whirling" sound coming from the clutch housing....engine is spinning without load added to the gears, clutch and driveline.
    Like you, I've heard the same thing in other manual tranny cars. The RX8's sound is different and probably a bit more pronounced, but not one I would consider detrimental.
    Heater fan noise -- anyone else picked up, and no this isn't whining or nit-picking, on the high decibels put out by the air going through the floor vents? I've never heard so much noise. To make matters worse, if you select the dash/floor flow selection, you couldn't put out a match with the amount of air that goes through the dash vents.
    Ironically, in other vehicles the dash vents tend to receive the lion share of air flow when you split it between the dash and floor vents. Comments welcomed.
    I noticed something recently while adding a quart that someone else had posted about. It was a light brown condensation on my dipstick (no jokes please). It appears to be just water condensation.
    The dealership, which responded to my inquiry about the mysterious material sight unseen, made the suggestion above. I tend to agree. And the fricking cold temperatures here make the condensation even more likely.
    I'm in the market for a set of snow tires. It will most likely be a combination of tires and wheels. Anyone have any recommendations?
    C'mon springtime.
    Consumer Reports the 60-0 stopping distance is 117 ft. This is the best there is (tied with a couple of others lke Porsch and for the 8's weight, about 3000 lbs, the best for it weight). Since the 8 has an option of a bigger break, does any one know if the 117 ft distance is due to the standard for optional breaks?
    Blower for the HVAC is indeed noisy when on the higher settings. I would call that one of my "nit-picks". On the other hand, if they put more noise insulation in the car, that would add weight.
    Just in case anyone thinks I'm too "pro RX8", I've got some other "nit picks".....
    --location of the remote trunk release (if anyone knows a better way to find it by "feel", I'm listening).
    --needs some sort of gas cap holder somewhere on the car...yes, I've seen some home made solutions, but with such a well engineered car, someone at Mazda overlooked this.
    --can't fit more than 3 CDs in the center console
    --NAV system is slow to initialize upon start-up. Please, someone find a way to disable that infernal "start-up" screen.
    Condensation on the dipstick is something I've heard about with a couple of posters. I don't know that there's much that can be done about it with the winter weather short of adding some sort of "gromlet" to the top of the dipstick for a better seal at the top of the dipstick tube.
    I know the brakes on the RX8 are outstanding. I haven't read the CR article to know which package they tested with their RX8.
    Tnks.REDRPM,just what I wanted,took poss. of my rx8, in Aug. ordered it on thru the net, love it.Had it over 100 on 77th birthday. Chas.
  • joanmkjoanmk Member Posts: 9
    Hello, My son received a ticket, while parked at the airport, for no front licence plate. Aside from the fact that it would spoil the car, he really doesn't want to put one on but has to to cancel the ticket. Has anyone else had this problem and how did you get around it? Is this just a California problem? Thanks for any help. Joan
    Possible Solutions: Get a front license plate to cancel the ticket, then take it off a few weeks later. Don't park at the airport. If you decide that parking at the airport is a must, take the newly purchased front license plate that was thrown back into the trunk after cancelling a ticket back on for a temporary basis. Problem solved!!!
    Thanks for the advise but how to put the plate on the front without damaging the vehicle by putting holes of some kind in it. There is really no place to put it without ruining the front of the car. Joan
    Chas.....you're my hero. Congrats on treating yourself with an RX8 on birthday number 77 (and ripping it to 100). Let us know when you hit 100 years old and take the RX8 to 100 on the same day.
    Joan...there's a special holder that the dealer should have installed to hold the front plate since your state requires it. IF it's not there, then take the car back to have them put it on.
    Airports are now the most dilligient in enforcing the "Front Plate" rule due to the security measures currently in place. While unfortunate, it's probably better to detract a smidge from the looks of the front by putting the plate and holder on your 8, than to risk a ticket or worse, a tow.
