Mazda RX-8 Problems and Solutions
I think they (Mazda) are still trying to get the cat. to last the required mileage plus give the owners close to promised power. They are also working on the flooding problem. The A/C problems owners are reporting are rumored to be fixed by hardware changes in the next model. They may not be able to address it in the current cars, as I think it's a design change. The new ducting probably wouldn't fit into the current cars, or would require dash removal, which would be prohibitively expensive.
thanks for your help
As for a "rebuilt" renesis engine - I'm pretty sure Mazda hasn't got a rebuilder in NA yet. They are probably "freshening up" the ones returned to Japan that had problems. If that's the case they are "factory rebuilt" and will be as good as new (or better - most parts tested). My friend got a new "long block" replacement when his went last fall - including a new PCM.
Failures I've heard about so far on the "grapevine" are:
1. Coolant leaks - mostly caused by machining problems of the "O" ring grooves allowing the "O" ring to move.
2. Rotor or e-shaft bearing failures, most probably caused by lubrication failure (fuel in oil, low oil, etc.). As all engines have gone right back to Japan, this is all speculation.
The number of failures has been average for any kind of engine, so don't let this worry you.
The rotary engine is actually a very reliable design, as long as it gets enough oil and coolant. There are very few moving parts! In fact, I think you can count them on one hand!
2 - rotors (do we count the seals?)
1 - eccentric shaft
Do we count the electric intake routing valves?
I must be missing something else.
This happened after I was 25 or so miles away, by the way. Happened again a lot on Wednesday thru Friday. Always when I was braking. Didn't matter in which direction the road crowned, the pulling sometimes went with, sometimes against.
It feels like I have the ghost of Arnold Schwarzenegger sitting on my lap and he's driving. I really have to use my biceps and shoulders to keep the car in my lane to prevent it from sideswiping someone else or from crashing into the curb. And this is at low speeds!
Doesn't always happen, but I can feel it through the steering column when it's coming on. Wierd. A little difficult to explain. Very dangerous and I'm afraid to keep driving it. Needless to say, I'm not having any fun, yet.
Showed up at the dealership mad as hell when they opened on Saturday. Went for a ride with one of the techs. He felt it. When I brake at 30mph and let go of the wheel, it spins on its own,hard at least180 to 270! Said, "That's not right" Had to wait till Monday for certified Mazda tech to go over it.
Tech said that it's not right. Got a call today. Told me all they did was a front end alignment! Is that it? Could that have been causing such a drastic problem? Or am I getting snowed?
Will the L (or I guess now, "M" reflash help?
I used to own the beloved RX-7, and definitely whacked the fron end out a bunch of times, but never experienced ANYTHING like this!
Anyone else got similar prob/solution?
Not having any experience with your issue, I'd rely on the Mazda tech's advice.
In either event, it's an easy enough fix if the Mazda tech knows what he/she is doing.
Someone pulled out in front of me on my way to return the rental car, and I hit him. Luckily I had insurance coverage through the rental agency.
Thank goodness I wasn't driving my 8 at the time.
Needless to say I was overly cautious on my way home after picking up my car from the Mazda dealer.
Cheese-
So far I have not heard that peculiar clunking noise while putting the car in "park" since the new transmission....hmmm? But being the great skeptic that I am, I still spend a lot of time listening to the trans for any unusual sounds.
Nice to have her back!!
mkoll....I can't fathom being without my 8 for any period of time. What the heck is an AVEO? I've never heard of those. Wrecking a rental car always sends a shiver up the spine. It's only happened to me a couple of times (I travel a lot and average 45 rentals/year). The rental car companies scare you so badly in warning you about what they won't cover if you don't opt for their outrageously expensive "additional insurance". I've never taken the insurance and the couple of little accidents I've had were always covered by my credit card company. In one of the accidents, the rental car company tried to charge me for the time they couldn't rent the car while it was in the shop. The credit card company came to the rescue, though. They fought it and won by saying the car was still driveable and that it wasn't a certainty the car would be rented during the time it was being fixed. All-in-all, no out of pocket expense and no "extra insurance" was needed from the rental car company.
mkoll - I once almost drove a Toyota Corolla rental over a cliff in Hawaii. In Maui, there is this one road that you can take around the island that actually becomes a one lane road at one point. Talking about scary, there is no guard rail and you actually see crosses set up randomly for people who met their end. It was frustrating on the one lane road because I had to keep going back in reverse to let other vehicles get by who were going the other direction. Finally, I said no more! This mini-van driver wasn't yielding so I had to slowly go passed him without scraping the vehicle. Then, I felt the car sink and obviously noticed the front right wheel was over the cliff. Due to helpful residents, I was able to pull the car up and save it. The rental car company none the wiser. The funny thing was, the rental car company still overcharged me and it took me three months to get it straightened out with my credit card company. I think the rental car ratted me out.
Those little cars have never held any interest to me....thus, I don't follow the latest developments with them.
Did a proper "spring detail" on my RX8 on Saturday. Only problem was getting the dirt out from around the lug nuts on the wheels. Anyone try any of those "wheel cleaners" on the market? I've always been fearful of them because I wax my wheels and don't want any "harsh chemicals" ruining the wax or the wheels.
Does someone have any insight/experience with the spray on wheel cleaners?
beacon....refresh my memory....
oil pan was an oil level sensor replacement and baffles, correct? This was done because of getting false "low oil level" readings?
intake manifold was replaced because of the CEL? Did they also replace the EVAP? Which ECU flash did they do (letter)?
You drove it 35 miles, turned it off and the next day it wouldn't start? Do I understand this correctly? Did they put in the leading "hot plugs"?
I don't remember, but are you using the same dealer for all service? If so, change dealers. These guys don't sound like they are "with it". There is no way they should tell you your car flooded given the information you posted. Also, they should cover it under warranty. If they don't, give Mazda customer service a shout.
Again, from your description, your servicing dealer sounds a bit "shaky".
Let us know what Mazda customer service says....this shouldn't be happening.
I will report full on the problems leading up to the latest nonsense. Picked it up last night covered under warranty. The oil change because of contamination was covered cause I took the free service package instead of trading in the car when the whole Horsepower thing occurred. Option of Mazda buy-back, or 500 certificate and free maint.
Maybe I'm fortunate because I've got a stellar "tech" that works on my car (same guy all the time).
The reason I bought from the dealer I bought from was because of this "tech". He has a reputation in the rotary community as being the top guy in the city. I had a dealership closer to me (multi-line), but had dealings with them before when I owned BMWs. They were always looking for a way not to cover warranty related issues.
It really irritates me when I hear of any dealership trying to parlay either their lack of knowledge or their lack of responsibility back onto the owner.
The rotary is just now back on the market. The dealer techs should have had proper training to do diagnotics. I've even heard of some dealers not investing in the proper diagnostic equipment to work on the RENESIS. To me, that's just not good business.
The production date was April 03, bought it sept. 03.Was not told about the H/P thing, I have the window sticker still saying it is 250hp
So I left the car and called Mazda service rep. not much help, he said he had to believe if they found nothing wrong then there was nothing wrong, went back and to the service manager, he agreed to call Mazda tech support, they said never had the complaint before try to look at the cam programming, does anyone know when was the m flash released?Tried the brakepedal thing and nothing happened
I can't comment on your "shake" issue as my engine has always been as smooth as glass. As a matter of fact, when it gets warm, it's hard to tell the engine is idling in mine.
I didn't think there were any built for North America as long ago as 4/03. I thought they were built in July...maybe June of '03?
If your dealer has never done a reflash, there is no way you have the most recent upgrades to the ECU.
All they keep saying is "all systems passed no DTCS" even though you can see the shift lever vibrating.
I guess eventually whatever is causing it will completely fail and then maybe they can find it.
I've got mine in today for the two recalls and the oil sensor fix. I guess I need to ask them about the reflash as well.
You've had your car for 3/4 year (July '03)? Did you get the "free service + cash" offer from Mazda? If not, you should have and I would contact Mazda customer service about it.
If that's the case, then get back to your dealer as there are several things your dealer should be doing.
--oil level sensor upgrade (if applicable)
--CEL fix (if applicable)
--recall for minor airbag work and some minor sheilding
--latest reflash of the ECU
Are you changing your oil every 5K miles? If so, where do you get that done?
My gearshift shakes a little when idling, but I don't notice it that much. It's not really a "fault" with the car. If the car is shaking violently, then something's wrong.
I'm very pleased with the car. I haven't experinced any shaking with the gearshift. The only real problem is the gas mileage. I haven't done any better than 21 mpg and that was on a trip with all highway speeds. I understand that the reflash might help this some.
I find Memorex to be the brand my RX8 CD player likes best for burned CDs.
I don't have a problem with any commercially bought CDs. Really can't say why, however.
As for the difference between burned and commercial cd's, burned cd's are done with chemicals whose reflectivity is changed by the burning laser, whereas commercial cd's are stamped with a glass master. It's easier for the laser to track a physically stamped groove than a chemically imprinted one. It's interesting that any kind of cd's skip nowadays- I'd imagine that all car players have sufficient anti-shock buffers, which is apparently not the case if your cd's are skipping.
Liven up your evening and join your fellow enthusiasts every Tuesday from 6-7pm PT/9-10pm ET for our Mazda Mania Chat!
The chat room opens 15 minutes before the scheduled chat time, so come early and get a good seat! Hope to see YOU there on Tuesday!
Mazda Mania Chat Room
PF Flyer
Just make sure you're checking the oil regularly. Matter of fact, make sure your dealer filled your oil since they just changed it. I've seen it happen during an oil change... mechanic drains the oil, puts the new filter on, screws in the oil plug, and then forgets to refill with oil (happened to me at a Jiffy Lube a long time ago...it cost them a new engine).
If nothing's turning up on the dealer's computer, then maybe the reflash is causing the ECU to "relearn" and that's causing some of the sounds you're hearing...that's a "long shot" but would be the best explanation I have. If indeed that's the case, it will disappear over time. Mine accelerates as smooth as glass. My shifter vibrates just a "wee bit" during idle, but that's no big deal.
Rough idle - we've had some coilpacks go flakey. We ARE messing with the ignition system, so that could be the cause, but the front leading pack started to fire a bit around the time the rear one fired, and that messed up the idle on his car. It probably runs hotter than the rest, being at the front and closest to the radiator. I swapped the pack with the rear rotor trailing one and that solved the problem. The front leading is the pack at the front of the set (four of them on a bar, seen way down under the intake hose).
You can only see this problem with a scope, although it doesn't take a genius to tell it's idling roughly.
i recently bought the exhaust finisher and will attempt to install it on my own without taking off the bumper,will be more than happy to let any one interested know how that goes.
...what's Maurice's take on the recent ECU reflashes? Do they affect his ECU mod in any way?
...do the reports of rough idle have anything to do with the leading "hot plugs" being installed?
As a side note, I've got the "regular plugs" installed and I made a point of getting out of my car last night while it was idling and put my hand on the hood. Fact is, if I didn't know for a fact the car was indeed running, I couldn't have told it by putting my hand on it...it was running that smoothly. Even though my shifter shakes ever so slightly at first, once it gets to operating temps, it doesn't shake at all.
I don't see how hot plugs would affect the idle. It should actually idle better (plugs run cold at idle). In Maurice's case it was a flakey coil, because when I switched it, it idled fine. We've been fine-tuning the ECU mod. output to the coil packs, trying to get the pulses into the packs the same as the stock PCM. Just to make sure the coil pack flakeyness will not repeat because of what we do. I'm pretty sure it was not us. They are marginal to begin with. Not very well heatsunk. The coil pack is an ignition coil (a rather small one), with a transistor that grounds it (that is, when the transistor is turned on by the PCM - a 3V 5 mS pulse - current flows through the coil charging it up - and when the pulse ends the coil sparks).
I didn't think the "hot plugs" would make much of a difference. I was just curious on your take.
Just a guess, but I would think any reprogramming that Mazda does with the ECU would cause the "mod" piggyback board Maurice has would either close the gap between Maurice's mod vs the stock ECU or cause it to be totally ineffective.
Do you have to reprogram the mod every time there's a reflash from Mazda?
vtlc...without knowing more, it may be that there a "miss" causing your car shake as you describe. The Mazda tech should be able to be diagnose it easily by hooking your car up to the dealer's diagnostic computer and reading the codes.
I have to admit, hearing the number of times you have to go back to your dealer for "this & that" is extremely unusual. These cars are very robust in both build and design. I believe you said you've tried many different MAzda techs to service your car? Has your dealer seen it shake when you take it in? If so, is the only thing they say is wrong is it's missing? Have you ever done a very hard launch? If so, then you may have broken a motor mount. That would cause it to shake. It's highly unusual, but still possible. That said, I've launched mine by doing a clutch dump at 4K RPMs (takes off like a "jack rabbit") and have found the car to be stable and stout under those conditions. The trade rags have launched at 8K RPMs without any trauma, either. I have never heard of any of the cars shaking like yours.
As mentioned, they run as smooth as glass. I can barely tell when mine is idling. It's revs are nothing but a model of smoothness.
I drive very easy around 4 to 6k rpm. To me the car has pretty good power there already, only few times ever went above 6k.
No matter how many times I have to take my 8 back to the shop, Im enjoying every minute of driving it when its not being serviced.
