Ford Super duty - Continued III
Gtvrdik... b4 you can determine which truck you want you need to determine primary usage, your driving style, preferences, etc. you can read my past posts on this for some ideas. as trucks are same price (for this deal) you may want to consider the psd from a fuel economy standpoint (but that isn't the entire issue as maintenance is significantly higher on it). also... is not a "new" truck. don't wait too long though, as these are all "hot" trucks (you may wind up having to order one).
Had LASIK surgery today.....monitor is kinda blurry and I don't know if I am spelling everything correctly......so I'll see ya (hopefully better)....tomorrow!!!!!
http://www.colorplus.com
RE: "Ordering"
checked five local dealerships, all wanted $500 above invoice; found small town dealership 60 miles away;bought for 1% over invoice.
Y2K F250 Crew Cab, Lariat, 4x4, PSD, auto,ESO,island blue, ETC.,
Ordered 9/7/99
No DORA from dealer,(no allotment as I have learned on this site, however dealer said 12 weeks, after 7 weeks had VIN with build date of 11/8/99, called VOPC build date 11/1/99, called on 11/1/99 said that it was released from the plant
ETA week of 11/21/99
CAN'T WAIT my son is driving me crazy
and he is typing this
Blue on 9/18 and it came in yesterday-11/4.
My salesman originally told me 6 weeks and after
reading some of these post, thought he was pulling
my leg. Went to dealer today to check it out and
salesman told me he was about to all me.
Having the sprayed-in bedliner put on.
That was changed about two weeks a go to Build date Nov 8, delivery date Nov 29.So far that still stands, will find out this week .I am getting A F350 PSD
You mentioned higher maint for the PSD whats this about? I heard the the PSD was low maint
Thanks for any info.
John
Any Pro's and Con's???
I live in Washington State and don't get a lot of snow in my area. DOT uses very little salt in there clean up work here --- mostly sand.
The truck is toooooooo big to fit in my little garage ( Crewcab Longbed) so it will have left outside in the weather (RAIN) until I can build a carport to cover it and my trailer ( a couple of years away ).
Suggestions would be helpful. Thanks in advance.
Just my humble opinion.
I'm a toy freak and have been wanting a power washer for some time.
Showed you post to the wife and she asked if I was'nt the author.
Thanks for your opinion!!! I also noticed that I'll have to proof read my posts a little closer!! My mind is faster than my fingers!! ("so it will have left outside in the weather")Sheeesh.
The PSD requires oil changes every 3k/4k miles just like the gasser's. However, you'll use a case of oil (12qts) for every oil change as the crankcase holds 15qts. The oil filter is also about $10 as well. So each oil change with the PSD will run ya over $40 if you use Shell Rotella-T oil as the real die hard PSD folks do. The fuel filter needs to be changed every 6mo's or so. The antifreeze mixture should be monitored/checked with test strips every 6k miles or so.
So, the PSD does need to be maintained just like a gasser.. However, the PSD will outpull any gasser, and probably give you 250k miles or more before you have to do any serious work, whereas the average gas engine would need some work before that time.
Porky:
IMHO, I think your better off with the power washer option.. The undercoating doesn't help the truck when its sitting in your driveway (or garage). Also, now you have space in the garage to keep the other toys like powerwashers, welders, air compressors etc, since the truck won't be using that spot..
For the undercoating thing, I did have mine undercoated/soundproofed at my local ZIEBART store. The only difference between undercoat and soundproofing, is that the soundproofing is put on thicker to help minimize road noise. As stated above, I live in centrall ILL., and the road crews love to use SALT, and LOTS of it. That is one reason why if you ever drive through ILL. the roads suck. I think they have some unwritten rule that unless it snows more than 2-3 inches, SALT is the method of choice for clearing roads. Plus, it helps darken the underside of the truck and makes it look nice. Oh-well, that is my .49-cents on the issue.
I've not heard of the $500 Ford compensation, this sounds like the dealer trying to keep a sale.
You're valuable to the dealer, because if he cant sell certain types of trucks, his allotments for those will continue to be low..
Some general questions, (he may or may not answer)
How many SD's is he allotted this month.
What % of those can be V10
What % of those can be V8 (5.4)
What % of those can be SuperCab, (although I didn't know this was an allotment category, I know CrewCab is an allotment category).
If you switch to the 5.4L, what is the expected turn around time.. Also, did you get a DORA from the previous order?
If there are other ford dealers in the general area, you might want to check them out..
Tom18: Good luck with your dealer hunting. From what others describe, I think you can find a faster dealer.. Others have waited for 5months to get their trucks, and said it was definately worth the wait. What was the form on this 'letter' that the dealer showed you? Was it the allotments page or something different?
Anyone have any experiences with the AMERAGUARD spray in liner? I'm interested in it because it can be exactly color keyed with the truck color. Also looks to be fairly gouge-resistant.
The important thing is that your happy with your beast, you wont be if you always have to cuss your truck because it doesnt have the power you need. Believe me I know the feeling.
John
When I called my dealer, he said, nope, we don't have it yet and claims he was just at the drop off to pick up 12 trucks, but mine wasn't one of them. I asked him to recheck his computers for the current status and get back to me..
I think bucket seats have a different permanent center console (which is deeper?) and there is a small foldable armrest built on to each seat.
gta... we ordered the buckets because we also ordered the crew cab & have no need to transport > 5 souls. our primary reason for ordering them is that you get a "permanent" console & some additional comfort that comes with that seat design.
Thank you everyone I value your input,
Scott
I think your MPG expectations are reasonable..
You've found a rare bird, (unsold SD w/V10 on a dealers lot)
I have received the dora from my original order.My priority statis was 10.
jraske,I am going to be towing a fifth wheel,but I really cant make that investment for the psd.I am at my limit already.like I was telling tom18 I am going to stay with the V-10 so I have to start searching for another dealer with allotment for what I want in my area.Just one thing I cant believe is that the dealer left me hanging when he basicly knew what his allotment was.I will keep you guys up to date.Thanks,Wayne
My eta remains at 11/13. Its like waiting for x-mas when your 12..
