I would imagine that if I had some big repair they might use this to avoid covering it . . .
FV
If you really want to go to a 10,000 mile OCI, simply keep using your OEM filters and use a good synthetic oil in the proper weight class. Once at 10,000 miles I then suggest that you have the oil analyzed as I suspect that it will show that the oil is still in good shape with plenty of reserves. You may then decide to go even higher on your OCI schedule. ;-)
Best Regards,
Shipo
Best Regards,
Shipo
BTW, I'd never rely on the manufacturer's claims only.
But it's generally accepted that the 3000-mile, 3-month oil change is now overkill (except for the usual caveats, like driving on dusty roads, the hot desert, towing, congested city traffic in high temps, etc.)
It could be something relatively simple, or it could be a major problem like an engine replacement if you ran the engine dry after oil indicator came on. You could have just cracked the oil pan or a fitting, causing a leak......or you could have smashed the whole bottom of the engine damaging the lower part of the engine.
How does one have, and what do you mean by an "under car accident" ? Ran over a speed bump too fast, and bottomed out the car?
Gee – I guess when the salesman talked me into buying the oil change coupons so I would get the owners manual’s recommended service, he was full of .
As for future oil changes, buy your own oil, take it to a good independent shop and have them put it in. That or go to a Mobil station that uses Mobil 1 and use either 5W-20 or better yet, 0W-20 oil.
If you do get the UOA, please share with us what you discover.
Best Regards,
Shipo
Could you explain a little further what the reasons would be for doing this (other than suspecting that you were given bad oil)?
Where would you go to have this done and what would be the approximate cost?
Other things that come out of UOAs are indicators of how well your current oil is doing its assigned task and how much longer it can do its job before an oil change is required. Case in point, a UOA last year showed trace amounts of coolant in one of our cars. That was kind of a "Heads-Up" for me to keep an eye on things. All of the sudden this winter the coolant usage started becoming noticeable. Fortunately when I first read the UOA I switched to Propylene Glycol coolant which isn't anywhere near as toxic to the engine bearings as is Ethylene Glycol based coolants. That said, now that the leak has gotten worse, I'm assuming that it is a head gasket (the engine has 140,000 miles on it after all), so probably the second weekend in June I'll be diving in and replacing both head gaskets (and drinking a few beers along the way).
As for how to get it done and the cost, I usually pay $30 for the actual UOA and occasionally I pop for the extra $10 TBN (Total Base Number, a measurement that indicates how much life your oil has left in it) analysis. I've used Blackstone Labs and have been very pleased with their service. There are others out there, and a quick check will easily find them. ;-)
http://www.blackstone-labs.com/
Best Regards,
Shipo
Thanks again!
Heck no, it's a ubiquitous dark green 1998 Dodge Grand Caravan. That said, for the last two years and 60,000 miles it's been my sole transportation to and from work.
There are a couple of things in the works that may change that in the next few weeks, and even if they do, I still need to keep it running well so that either my son (who'll be driving in a couple of years) can use it when the time comes, or so that I can sell it this summer with a clear concious.
Best Regards,
Shipo
Best Regards,
Shipo
That said, it looks fairly certain that we're moving to Hong Kong in six weeks or so. The first six months are on a trial basis for both us and the company, and if the arrangement proves satisfactory to everyone concerned, then I'll be leaving Mrs. Shipo and the kiddos in HK come January, flying back here, emptying out the house and either putting it up for rent or sale (depending upon the market). That also means that I'll be peddeling both vans and freeing my son from the threat of having to drive one. ;-)
Assuming the above happens, then while I'm back here in January, I may also be buying a car to have shipped over to HK (current leading candidates are Mini Cooper, Honda Civic, Honda Fit, Toyota Yaris). I've been comparing prices there versus here, and it actually seems cost beneficial to buy one here, ship it over and then sell it there when we're done with the three year stint.
Best Regards,
Shipo
What's interesting is that a Civic EX here in the states has cloth interior, a 5-Speed (although an automatic can be opted for :P ), and manual HVAC controls. A Civic in HK has turn indicators on the outside mirrors, alloy wheels, leather and automatic transmission standard, and the pricier version also includes Automatic Climate Control. If I was to take a 5-Speed U.S. Spec Civic to HK, it would certainly be a bit of an odd-ball over there. Can't decide if that would be a good thing or not. ;-)
The good news is that we won't have to make the decision until next January when the six-month trial is over. By then, I should have had the time to talk to some of the outfits that specialize in Ex-Pat cars over there.
Best Regards,
Shipo
Best Regards,
Shipo
If I decide to get a car, and I must emphasize IF I decide, I have a few advantages here. I've driven in England and New Zealand in RHD cars, sticks even, so been there, done that, got the Tee-Shirt. :P As for a normal parking space, the good news here is that the company will pay for that, so we're good to go there too. I also do most of my own maintenance, and I always use Synthetic Oil, so the whole two month thing on oil changes will be more like six months to a year, and relatively inexpensive when I do it.
With the above in mind, the discussion of getting a car is still very much a mental exercise as there is a very good likeliehood that I won't need one at all, hence the fact that I'm not even going to bother with making the decision for at least six months.
Best Regards,
Shipo
One of the main reasons they reccommend a lighter weight oil is because there may be a small increase in fuel economy.
The car was completed in late 2005 and has been unsold until I bought it this month. Manufacturer says to change oil per the oil minder or at least once a year. My dilemma is that I am unable to determine when the oil was put in or if it was changed at least once. Assume I should get an oil
change unless the dealership can document that the oil was changed at least once since it was off the production line in late 2005. Any input and or advice appreciated.
If you wind up finding out later that the dealership changed the oil, no harm done, if they didn't then you're ahead of the game. Also, remember that many dealerships (most?) simply buy bulk oil (Quaker State 10W-30 or whatever), oil that may or may not be optimal for your car. If you want your oil changes done correctly, do them yourself or, at the very least, buy your own oil and filter and take the car to the dealership (or a garage you trust) and watch them use the parts you supplied.
Best Regards,
Shipo
I have never changed my own oil but with all the stuff that happens I should strongly consider it. Will post a follow up after my appointment.
applies very much to the car business, "To trust is good, not to trust is better". I will probably have the oil changed again at about 3000 miles or when the oil monitor hits about 40% oil life remaining.
Best Regards,
Shipo
While I don't know for a fact, I believe that's the case. I've driven three cars with OLMs, two specified synthetic oil from the factory, one that didn't. The two synthetic cars were operating toward a nominal 15,000 mile oil change, the one that came with conventional oil in the crank case operated on a nominal 6,000 mile OCI. Conclusive? Nope. Interesting? I think so. ;-)
Best Regards,
Shipo
Mine is an 03 and seems to run cleaner than my 98 motor did at the same age, i.e., oil discolors less quickly. That, as you say, may mean nothing.
Hmmm, to the best of my knowledge, no OLM (yet) is capable of actual on the fly oil analysis. They get around this by keeping track of other metrics like fuel consumption, engine temperatures, RPMs, load, cold starts, and probably a few other measurement points. As such, the OLM must be predisposed to one oil type over another, and can only give the proper readings for that type. So, if your OLM is calibrated for conventional oil, using synthetic will not make it go down slower.
Assuming the above is true, is that a reason NOT to use synthetic? Nope, not in my book. For the warranty period of your new car I'd absolutely adhere to the recommendations of the OLM regarding when to change your oil AND at the same time, I'd use synthetic oil. If you get beyond the warranty period, then you may want to consider adding 50% to your oil change interval (assuming synthetic of course), and maybe even 100% more miles if you have your oil analyzed and said analysis indicates the oil is still good to go.
Best Regards,
Shipo
Best Regards,
Shipo
Sort of in validation of the above statements, when I picked up my 530i in Germany I drove it around Europe for a couple of weeks, often spending hours on end at speeds well north of 100 mph. The OLM on that car called for the first oil change at about the 13,000 mile mark. For the next several months following the first oil change, I found myself commuting between our home in southern New Hampshire and clients in Long Island and the Philadelphia area. As I made it a point to commute during the wee hours of the morning, I was able to set the CC at a nice leisurely seventy something, resulting in MPG readings in excess of 30. The OLM called for the next oil change at 19,000 miles!
Here's a link that shows how the BMW OLMs work:
http://www.savagebmw.com/Service/content_service_IntervalsLED.htm
Best Regards,
Shipo
Deville, weight is less than 50 pounds more on the 2006 and the horsepower, is the same on both models, the 2006 is rated at 8 pounds less torque than the 2004 Deville. My guess is that the combination of wider tires and more tire tread in the new car could account for this. Are there other factors I should be considering?
