But just imagine how clean it would have looked with 3K dino changes...
I'm not that sold on synthetics. Better? Probably, but in the life of a normal car, I don't think there would be enough of a benefit to bother.
How about the Turbocharged Acura RDX? If there was no benefit to synthetic oil, why would Honda specify it for that engine?
Best Regards,
Shipo
The reason I took the valve cover off was to replace the valve cover gasket kit. My spark plug wells were filling with oil and leaking down the rear side of the engine. The last time I had the valves adjusted, the dealer didn't install the gaskets correctly around the plugs. I also have a leak at the lower engine of the engine at the balance shaft seal. I have to have that looked at, although I had it done once probably 70,000 miles ago.
Even so, it only goes down about 1/2 a quart in 5,000 miles. I'm expecting that to decrease with the new gasket kit in. I do keep a close eye on it due to the leak situation.
I usually change my oil around the 4500-5000 mark and after 100,000 miles my engines are clean inside too.
I think I would rather do that then stretch out my oil changes. I don't drive that much and I usually don't hang on to my cars more than a few years anyway.
I'm thinking of sueing for a new engine. What do you guys think?
1) No harm will come to your engine, especially in the few miles that you've driven it.
2) If you are really concerned, have them change it again and watch them pour in the oil.
Best Regards,
Shipo
No pressure at all to upsell me anything, they didn't even ask... which was surprising. Suggested services recommended on full circle inspection print-out were: the fuel system (which I heard was useless) and an air filter, which I'll need to look at as it was replaced 1 1/2 years ago on a two year schedule.
It'd probably take all of ten seconds. ;-)
Personally I believe that they are buying 5W-30 in bulk and that is what they use in all of their cars, regardless of what the Owner's Manual states. This by the way is a fairly common short coming of dealership oil changes, in fact, there have been a number of class action suits against the dealership infrastructure over this very issue (although usually it was over using conventional oil when the manufacturer specified synthetic for their engines).
BTW, skip the fuel system service, totally unnecessary.
Best Regards,
Shipo
I took my other car, a Buick regal, to Valvoline Instant Oil Change the same day I had the oil in my Mazda changed. The service tech asked if I ever had the fuel system serviced. I said I put in some Chevron Techron fuel additive about 6 months ago. He said that when they service the fuel system they guarantee that I will be able to notice an improvement in performance or my money back. Sounded like a bunch of b.s. to me. He just said, "something to think about" and let it go.
My Mazda dealer on last oil change recommended throttle body being cleaned. Is that necessary?
With them buying 5w-30 in bulk, I guess that would be to save money. This dealership just opened a couple years ago, and most of their maintence services are a lot less expensive than the one other Mazda dealership in our area. Whenever I've gone in they don't seem to have much business going on in either sales or service.
roadburner: What is CAFE strategy?
There is a big difference between the Fuel injection service that these places do and cleaning the throttle body.
Cleaning the throttle body is something that needs to be done occaisionally. But, you can do that yourself.
Stop by your GM Dealer and pickup a can of GM Top Engine Cleaner spray. It is spendy, about $15 a can.
Follow the directions to the letter and you will be good to go.
Also, if you are worried about cleaning the injectors, for the price these quick change places charge you, you can buy the set up to do it yourself. Like this one.
From Hyundai's own factory service information for a 2005 Sante Fe
THROTTLE BODY CLEANING
NOTE: Disconnect the in take air hose from the throttle body and check the throttle valve surface for dirt. Spray cleaning solvent on the face valve to remove dirt.
Warm up the engine, then stop it.
Remove the intake air hose from the throttle body.
Plug the bypass passage inlet of the throttle body.
Spray cleaning solvent into the valve through the throttle body intake port and let it soak for about 5 minutes . After 5 minutes open the valve and wipe it clean with a soft rag. CAUTION : Keep the throttle valve closed while spraying to avoid charging the intake path with solvent.
Start the engine, race it several times and allow the engine to run near idle for 1 minute .
Repeat Steps 4 and 5.
Unplug the bypass passage inlet.
Attach the intake air hose.
Disconnect the battery ground cable for more than 10 seconds .
From Hyundai's own factory service information for the 2005 Sonata
NOTE: Disconnect the intake air hose from the throttle body and check the throttle valve surface for carbon deposits. Spray cleaning solvent on the valve to remove carbon deposits.
Plug the bypass passage inlet of the throttle body. NOTE: Make sure the solvent does not enter the by-pass passage.
Spray cleaning solvent onto the valve through the throttle body intake port and let it soak for about 5 minutes .
Start the engine, race it several times and allow the engine to idle for 1 minute .
Adjust the SAS (Speed Adjusting Screw).
CAFE: Corporate Average Fuel Economy Using a lower viscosity(thinner) oil can often improve fuel economy by a few tenths of a MPG.
I like Hyundai vehicles, but saying the throttle body doesn't need cleaning is like saying the timing belt never needs replaced.
And I have never once had a problem.
Beyond that, I've never cleaned a throttle body, and never used a fuel additive, oil additive, or Super Prest-a-Gonzo highly refined Snake Oil either. ;-)
Best Regards,
Shipo
My Elantra has 52K on it, and the throttle body is clean as a whistle.
Did they do any other work? Replace air filters? Do an "inspection"?
Not necessarily. While I'm not familiar with the care and feeding of the supercharged engine that Chevy is using in the Cobalt, it might well could be that it requires Synthetic oil. If that's the case, then anything much under a hundred dollars is a fair deal.
Best Regards,
Shipo
The "performance difference" in many forced induction engines is not that syntheitc oil will make it run "smoother" or "faster", but that they are able to better endure the added stress/heat of a blown engine. I'm driving a turbocharged VW, and it's synthetic every 5,000 miles (or less) meeting VW's stringent 503.1 standard.
Best Regards,
Shipo
$250.00 :surprise:
A lot of variables will cause build up in the throttle body. Among the top of the list that I have seen is varnish build up, oil build up from certain reusable air cleaners and contamination from leaks on the air intake (air filter broken or cracked intake tube).
That is phrased so politically correct............
I just paid my Mazda dealer $42 for the 5000 mile service(which includes an oil change). I provided six quarts of Mobil 1 5W-30 so the total cost was around $78, which I thought was a pretty good deal. I'm going to stick with a 5000 mile OCI until my UOAs indicate otherwise; I'm concerned about the oil deterioration issues that owners of other direct injection engines are encountering.
Best Regards,
Shipo
Does a suction device draw up as much of the sludgy sediment on the bottom of the oil pan as opening the drain plug and letting it drain for an hour does? Does it leave a quantity behind? Ever tried suctioning and then putting a drain pan under it to see how much comes out?
I almost had a gusher of my own. :P
Best Regards,
Shipo
With engines and oils being what they are today I suspect that any sediment is a thing of the past. If your using shorter intervals, which this method makes easy, I think you have even less to worry about.
I have been happy with it on different vehicles and all the home lawn and garden equipment too.
Just my two-cents...
JR
Best Regards,
Shipo
Have not been under my car for an oil change in some time and often change between intervals because it's just so easy.
What does it cost? I would trust it, I was going to get one for several of my trucks that I have had, but just didn't do it. BUT I hear they are very reliable,as long as they are brass and have a gasket to make a VERY tight fit. Please tell me where you found it and how much,if you don't mind.
Best Regards,
Shipo
