Oil change/fiascos
1121315171826
    You probably damaged your engine.
    In a small claims court you would have a very good chance of winning, but if the number of miles come up, you might win very little. Any judge worth his salt would temper any judgement accordingly. With that many miles, that truck was nearing the end of it's life.
    That truck has probably had 50 oil changes in that many miles, who knows how many filters may have been overtightened?
    If I were the judge, I might ask the Quickie Lube to pick up 10% of the cost of a new engine.
    But, then, I'm not a judge.
  • wtd44wtd44 Member Posts: 1,208
    It's episodes like this that keep me changing my own oil and filter.
    I don't think that's really a fair judgment if the lube place was determined to probably be at fault. If anything, the cost of a used engine installed seems more fair to me. Maybe it had 10% life left statistically, but in reality the engine was performing as an engine should...it didn't have 10% of the horsepower left in other words.
    Like I said, I'm not a judge.
    My gut feeling is that the lube shop probably WAS at fault.
    It's also possible the filter housing was cracked or weakened from repeated oil filters being screwed on and off.
    I've spent a LOT of time in courtrooms and I've seen and heard a lot of judgements.
    If this went before a jury I think the chances of getting a bigger settlement would be much higher than with a judge.
    The lawyers for the lube shop would make a HUGE deal over the number of miles that car had.
    I really don't know what the outcome would be here.
    Oh, it's not a case for a real trial. It should be settled in Small Claims Court without attorneys or jury.
    My sister sent this today. It's an oldie, but still worth posting:
    Oil Change Instructions For Women
    1. Pull up to Jiffy Lube when the mileage reaches 3,000 miles since the last oil change.
    2. Drink a cup of coffee.
    3. 15 minutes later write a check and leave with a properly maintained vehicle.
    Money Spent
    Oil Change $20.00
    Coffee $1.00
    Total $21.00
    Oil Change Instructions For Men
    1. Wait until Saturday, drive to auto parts store and buy a case of oil, filter, kitty litter, hand cleaner and a scented tree, write a check for $50.00.
    2. Stop by 7 - 11 and buy a case of beer, write a check for $20.00, drive home.
    3. Open a beer and drink it.
    4. Jack car up. Spend 30 minutes looking for jack stands.
    5. Find jack stands under kid's pedal car.
    6. In frustration, open another beer and drink it.
    7. Place drain pan under engine.
    8. Look for 9/16 box end wrench.
    9. Give up and use crescent wrench.
    10. Unscrew drain plug.
    11 . Drop drain plug in pan of hot oil: splash hot oil on you in process. Cuss.
    12. Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil.
    13. Have another beer while watching oil drain.
    14. Spend 30 minutes looking for oil filter wrench.
    15. Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
    16. Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties. Drink a beer.
    17. Buddy shows up; finish case of beer with him. Decide to finish oil change tomorrow so you can go see his new garage door opener.
    18. Sunday: Skip church because, "I gotta finish the oil change." Drag pan full of old oil out from underneath car. Cleverly dump oil in hole in back yard instead of taking it back to O'Reilly to recycle.
    19. Throw kitty litter on oil spilled during step 18.
    20. Beer? No, drank it all yesterday.
    21. Walk to 7-11; buy beer.
    22. Install new oil filter making sure to apply a thin coat of oil to gasket surface.
    23. Dump first quart of fresh oil into engine.
    24. Remember drain plug from step 11.
    25. Hurry to find drain plug in drain pan.
    26. Remember that the used oil is buried in a hole in the back yard, along with drain plug.
    27. Drink beer.
    28. Shovel out hole and sift oily mud for drain plug. Re-shovel oily dirt into hole. Steal sand from kids sandbox to cleverly cover oily patch of ground and avoid environmental penalties. Wash drain plug in lawnmower gas.
    29. Discover that first quart of fresh oil is now on the floor. Throw kitty litter on oil spill.
    30. Drink beer.
    31. Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame.
    32. Bang head on floorboards in reaction to step 31.
    33. Begin cussing fit.
    34. Throw stupid crescent wrench.
    35. Cuss for additional 10 minutes because wrench hit Miss December (1992) in the left boob.
    36. Beer.
    37. Clean up hands and forehead and bandage as required to stop blood flow.
    38. Beer.
    39. Beer.
    40. Dump in five fresh quarts of oil.
    41. Beer.
    42. Lower car from jack stands.
    43. Accidentally crush remaining case of new motor oil.
    44. Move car back to apply more kitty litter to fresh oil spilled during steps 23 - 43.
    45. Beer.
    46. Test drive car.
    47. Get pulled over: arrested for driving under the influence.
    48. Car gets impounded.
    49. Call loving wife, make bail.
    50. 12 hours later, get car from impound yard.
    Money Spent
    Parts $50.00
    DUI $2500.00
    Impound fee $75.00
    Bail $1500.00
    Beer $40.00
    Total $4165.00 -- But you know the job was done right!
    That one has been around before but it's worth reading again!
    It also totally outlines exactly why I will no longer cahnge my own oil.
    I love it! :)
  • gonogogonogo Member Posts: 879
    My oil change.
    5 qts $6
    Filter $2.08
    25 minutes time.
    Get exercise, good for physical health, being busy good for mental health.
    Take waste oil to local shop that burns it for heat, glad to see me come. :)
  • badgerfanbadgerfan Member Posts: 1,565
    My oil change is even cheaper
    6 quarts at $.59/quart (those monthly Checker rebates and coupons are great-Chevron brand usually)
    Oil filter about $3.50 at most (and this is the Motorcraft OEM filter)
    Total cost a bit over $7 after I pay the state their sales tax.
    I use ramps and an oil change combined pan/container I have had for about 25 years, so those are well amortized.
    I recycle my oil at our city recycling facility, so no environmental damage done.
    More convenient for me than any oil change place as I do it when I want and the elapsed time per change is about 1/2 hour.
    At those costs, I can afford to never stretch an oil change. I change at about 3K miles just for general peace of mind, though I know I could likely go longer with little negative results on engine life.
    Also, I don't have to listen to the song and dance sales pitch for add on services I don't need.
    No more...too much of a PITA for me!
  • imidazol97imidazol97 Member Posts: 27,745
    I do it myself too. I know the condition of the oil coming out so I can judge if there's an engine problem or change with age. I also control the filter going on.
    Now that cars require no ball joints greased, it's evey easier to do changes myself. Otherwise I'd jack up each wheel and grease it every 2nd oil change or so.
    Isell you work AT a Dealership. Obviously, you can get your oil changed any day you are at work, no hassle, no waiting.
    The rest of us have to make a special trip to either a dealer or independent oil change shop, so for many of us it is less of a PITA to do it ourselves!
    Yeah, that's true. I still quit doing it a couple of years before I took this job.
    I guess I just figured I had done enough of these. I had spilled enough oil, dropped enough drain plugs into the drain pan, etc.
    I've just taken a break to warm up while I'm hanging the outside Christmas lights. Another huge PITA!
  • 210delray210delray Member Posts: 4,721
    About Christmas lights... stopped doing those outside years ago, since we live in a cul-de-sac where only a few neighbors and visitors will ever see them. And we don't get along with a couple of the neighbors, so what's the point?
    And a couple of times recently, we didn't even bother with a tree. Just put out a few decorations...easy!
    I still change my own oil though. I'm lucky in that my employer has lifts and we're allowed to do it after hours. Plus, the old oil goes into a big container that gets taken away by a recycling service.
  • bremertongbremertong Member Posts: 436
    I have a recent model GM sedan that I bought from a highly regarded pre-owned car dealer in my area. Recently oil started leaking after the most recent change. On taking it back to the pre-owned dealer they referred me to the local GM
    dealer who diagnosed the problem as a loose oil filter, as a precaution he changed the filter. Problem solved. Because this has happened I plan to use either the GM dealer or a Chrysler dealer that I have purchased cars from in the past. MY QUESTION IS: The oil changes at the GM dealer are done by a separate department of lower level of car training staff. While at the Chrysler dealer the oil changes are done by the highly trained mechanics
    who I have known for many years in that they worked on my
    Chrysler cars. The cost will be slightly more at the Chrysler dealer but it's my inclination to go with them in that they also do other routine checks and I have never had anything like this happen to me when they did the oil changes. A recent model car is of course an investment of several thousands of dollars and having highly trained mechanics look the car over when changing the oil just makes good sense to me especially after the recent fiasco.
    I would appreciate any advice and input to help make this decision.
  • rowlandjrowlandj Member Posts: 254
    Is the GM still under any kind of warranty? If it is I would use the GM dealer as they can also check for TSB's and other items that a Chysler dealer would not have access to.
    JR
    Be sure that you ask the dealer to check for TSBs applicable to your car. Don't assume they would just do it because the car went through.
    Why take your GM vehicle to a Chrysler dealership to get the oil changed esp. if it wil cost more? I can change your oil for you and I have no automobile training. Changing oil is not like diagnosing a trouble code. It's pretty straight forward and easy as long as you have the right tools.
    Where did you get the oil changed when it leaked? What type of car do you have? A number of folks online can probably teach you how to change your own oil. then you know it is done right.
  • highrollerhighroller Member Posts: 351
    It is highly recommended that you should learn how to change the oil yourself. It is EXTREMELY easy to do. Most people who have owned cars for years or just got into the world of owning a car dont really know how EASY it is to change the oil/filter. All you need is some common knowledge of what the oil filter and the location of the oil drain plug looks like and a owner's manual, you're all set to go. And unless, you dont have the time or tools (good time to invest in some good tools), then take it to a trusty dealer.
    It's a PITA for a number of reasons. Trying to get under the car, spilling the oil, disposing of the old oil etc.
    So, someone goofed up and didn't tighten the fiter? Stuff happens to the best and most experienced people who work on cars. Probably never happen again.
    "Stuff happens to the best and most experienced people who work on cars." "Probably will never happen again."
    Sorry, but i have to override and disagree.. your statement doesn't seem very attentive and it is very
    unpredictable.
    I believe if they are the "best" or the "most experienced", they would know how to do things carefully and do it with patience. SOME dealers/shops i go to, the mechanics are in such a rush to try to cut down the work load that they are not doing it carefully. To them, time is money. That's why there are horror stories out there about loose/warped drain plugs, loose/overtightened oil filters, etc.
    isellhondas,
    I hope i didnt get you the wrong way, but from your statement, there's just too many if's or but's.. and just too many possibilities without one's own control.
    -highroller
  • richardsonrichardson Member Posts: 92
    Even though I am now in my sixties and have money I still change my own oil. I've been changing my own oil since 1961 when I bought my first car at seventeen. I never had a problem with a drain plug or filter if I installed it.
    I agree with isellhondas, and would add that if you learn to do the job yourself, you will be able to control all outcomes.
    Thanks very much for the responses to my posts, they address many of the issues that are presently of concern to me. In the past I have (5 years) and two cars I have had oil changed at the pre-owned dealer who has an employee who does oil changes and tire rotations. During my most recent visit he said I was the only customer they were currently rotating tires for, I replied saying that he owner had said they would do this for me. he proceeded to do the oil change and tire rotation
    after which I needed to have the tires re spun and balanced due to a vibration that occurred in the steering wheel, also
    the oil leak occurred after the same oil change. When I shared these problems with the owner he said they would do my next oil change free and apologized for the behavior of the employee. My thought is, if the employee doesn't want to do this work he should be dismissed (this is not the first time he has been rude). About two years ago the owner said he was thinking of replacing the employee due to
    his personality problems. Bottom line is that the employee was in a temper fit when he worked on the car and the poor work was affected by his attitude. No need to risk that again.
    Change the oil myself? I don't think so in that I am a generally healthy senior but getting under the car is not something I would easily do and there is no lift in my garage. Reason for picking the Chrysler dealership is that
    I have known the highly trained technicians there for over ten years and their attitude is both courteous and friendly. The GM dealer has an oil change section that does this work but I suspect the training level of the workers is not nearly as good as at Chrysler where they have no oil change section just the senior technicians to do this. Also the the GM dealer oil change section did some damage to a bumper the one time I had them change the oil some years ago.
    I am on GM's mailing list for TSB's so they know where to reach me, I will also be checking with the GM dealer for TSB's from time to time.
    Summary: At present I will plan to do routine oil changes at Chrysler given the fiasco at the last oil change appointment. I have both owned Chrysler products in the past and may be replacing my GM sedan with a Chrysler 300C
    in a year or two. I made them aware of this on a recent visit to ask about there doing the oil change work so there is every incentive for them to do quality work.
    If I have failed to use a logical approach in dealing with this issue I would welcome further comments. Many thanks for all the helpful comments that have been made so far.
    wtd44, you mean to say you agree with me right? :P i believe isellhondas would rather prefer to go to the dealership to get an oil/filter change where i would argue and say one should learn how to do it on one's own will and power.
    And I still have the equipment and a toolbox filled with tools. For me, it's just too much trouble especially disposing of the oil oil afterwards.
    The places I really would avoid are the drive through quickie lube stores. They goof up a lot and constantly push "flushes" and other things!
    oil changes are still one of the few things, along with cleaning my sewer pipes and trimming off the tops of trees, that I would gladly pay somebody else to do. It's a bargain these days. Do I check their work? YEAH! :P
    If you own a newer car would you or have you used Walmart or Jiffy Lube for oil changes? My concern is that some of the personnel at either one would not be that highly trained or highly paid increasing the chances of a fiasco such as I described in recent posts at this forum. I try to keep an open mind on all issues so would be very appreciative getting feedback from members who have used or considered using either of these companies for oil changes. My impressions about both these companies are not carved in stone or based on direct experience so would like to know opinions and experiences of other car owners.
    If i had a new car i would take it to the dealership, but since you only brought up two places, i'd have to go with.... (hard decision)... wal-mart = may be a little cheaper there.
    Just something else i would like to share and tell...
    My previous vehicle was a small car, my new vehicle is a 1/2 ton pickup truck. The difference between these two? The car needed jack stands and needed to be jacked up for oil changes (can be dangerous and very inconvenient for some), where as, my truck doesnt need any jack ups... one of the advantages of having a truck and doing oil changes on it :P
    Ramps work real good and are safe. :)
    I should have been more specific! I was agreeing with isellhondas about the fact that "stuff happens." Mistakes are made in very routine procedures, and often because they ARE so routine. People sometimes are on "autopilot" when doing these things.
  • nwngnwng Member Posts: 663
    nobody here mentions the time you saved on a diy oil change. If I bring it to a dealer, the drive itself is about 15 minutes, then the wait, then the drive back.
    If I do a diy, 5 minutes to lay out the ramp, tools...etc. Take a 5 minute drive to warm up the car, get up the ramp and start working on it. Another 15 minutes tops to get the car back on the road again. And I can pick my own time to do all this.
  • wlbrown9wlbrown9 Member Posts: 867
    I can pull into VIOC place with a coupon on Sunday on the way back from the golf course. 15 minutes later I'm on my way. I used to change my own oil, but it is too much trouble to do anymore and worry about disposing of the old oil. Just have to make sure they get it right. A couple of years ago, one of these left the filter loose. Took it back and got a song and dance from the manager that it was the washer on the drain plug needing changing every time. He was basically lying to cover up since I had seen where the oil was coming out. Still not enough to get me to change my own at home even though I have ramps, jackstands, drain pan to transport to recycling station, etc.
  • altair4altair4 Member Posts: 1,469
    Well, there is a bit more to it than nwng's 25 minute change. You do, after all, need to buy the oil and filter as well as properly dispose of the used oil afterward.
    Even as I type this, I probably have 4 gallons of used motor oil in my basement in 1 gallon jugs, waiting to go back to Advance Auto for recycling.
    And it's not impossible to screw up the job yourself. A friend couldn't get the old oil filter off - turns out he was turning it the wrong way. I thought we'd never get that thing off. That filter looked real bad when it finally came free.
    When I was a kid, a buddy had the old filter gasket stick to the engine block while removing the filter. He didn't notice and had oil go everywhere shortly after the first start-up.
    My own personal "best" happened when I was kid - I don't think I was even allowed to drive yet. I drained the oil, pulled off the filter and forgot to replace the drain plug before adding the fresh oil. You only forget that once... ;) :surprise:
    Our city maintains a tank for used oil. Just pull in and dump your oil in, throw the container into the dumpster and you're on your way.
    That's a nice system...where are you?
    In my area in SW Pennsylvania, it seems that every auto parts store has a tank for recycled oil. You just walk in back and dump your oil. The problem is they don't want the oily containers. I just reuse the same 1 gallon jugs.
    In Western Ohio. The 500 gallon tank? serves the city garage as well as the residents. It's next to a fire station and their practice fire tower so there are people around (I often walk over for exercise at night). If some enterprising teen or something tries to set fire to it, the firemen could call it 'practice.' Hasn't happened yet. Probably because the police roll in and out for gasoline at the pumps within 150 feet of it.
    I bought those 5 qt size motor oil, have about 6 of them in the garage, as well as oil filters and washers. So I don't have to go to walmart everytime I change oil.
    There is a gas station near my house where they have drums that you can dispose your oil, drive by it everyday on my way to/from work.
    OTOH, I wouldn't have done it this way if disposing the used oil is a hassle.
  • jlflemmonsjlflemmons Member Posts: 2,242
    Many, many years ago we had a chinese tallow tree come up in a fence line. We cut it down, dug up all we could, stump poison, you name it. Every spring, back it came, pushing the fence over.
    One spring, we cut it back, drilled holes in the stump, added root poison, and soaked it with about two gallons of used crankcase oil. All summer I watched that stump for any signs of life. Nothing. Thought we had finally ridded ourselves of the problem.
    The next spring the tree came back faster, bigger, and straighter than ever. We gave up. The folks now have a large healthy Tallow tree growing with a fence fully embedded in the trunk.
    Let's see now, where did that oil originally come from???
    Let the flames begin!
    I have a combination oil change pan/container that holds two oil changes. Lay it on its side and one surface is sloped towards a removable plastic plug. Oil goes in, runs into the container, then I put the plug back and close the tethered vent plug on the edge of the container, wipe off the side surface stand it upright and I have the container ready to take to our city recycling yard where I dump the waste oil. I have had this combination drainpan/conveyor for probably 25 years now. Much easier than trying to drain your oil into an old milk jug or similar.
    I also can schedule my DIY oil changes when I want to do them with no waiting, and since I watch the sales and rebates on oil and filters, I usually only have about $7-$8 out of pocket cost per oil change.
    Heck,
    We used to dump the old oil in any nearby vacant lot. Just poured it on the weeds! Sometimes we would light it on fire to get rid of the weeds.
    We poured antifreeze into the gutter drains and the Pacific Ocean was mere blocks away! We didn't know.
    We cooled down choke housings with R12 freon.
    And, we didn't wear bicycle helmets...horrors!
    My car has an oil life indicator which is showing 70% oil life left. The oil was last changed the third week of October 2005. I have driven 3000 miles since the last oil change. About 60% highway and 40% local city. I almost never drive on dirt roads. My owners manual says change at least every six months or 7500 miles unless driving under extreme conditions (heat, cold, start-stop). I have heard varied opinions on this issue, I would like to have a few more. Given the fiasco at the last oil change my
    inclination is to give more credence to the oil life gauge in the car and as an insurance do the changes when the oil life indicator is down to around 40% or 5000 miles or five months which ever comes first. In the past I have changed
    oil evry four months or 4000 miles whichever came first.
    and dumped ATF down the carb until smoke boiled out the tailpipe. Let it sit for a while and it would break up the carbon domes that formed in the heads. Common problem in the early 70's V8 engines.
    Yeah, I forgot about the ATF trick. The really brave guys would just a spray bottle of WATER! You had to be real careful doing that but MAN, the crap that would come out the tailpipe!
    Had a carbon dome drop out of the top of the head and start banging around in the cylinder. Sounded like dropping a fork in the garbage disposal. Ugly, but no harm done.
    I had a piece of carbon break looose in a 350 Chevy engine and I thought it was a bad rod! I let it idle for awhile and it finally spit it out.
    Oil Change instructions for Women:
    1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since the last oil change.
    2) Drink a cup of coffee.
    3) 15 minutes later, write a check and leave with a properly maintained vehicle.
    Money spent:
    Oil Change $20.00
    Coffee $1.00
    Total $21.00
    Oil Change instructions for Men:
    1) Wait until Saturday, drive to auto parts store and buy a case of oil, filter, kitty litter, hand cleaner and a scented tree, write a check for $50.00.
    2) Stop by 7 - 11 and buy a case of beer, write a check for $20, drive home.
    3) Open a beer and drink it.
    4) Jack car up. Spend 30 minutes looking for jack stands.
    5) Find jack stands under kid's pedal car.
    6) In frustration, open another beer and drink it.
    7) Place drain pan under engine.
    8) Look for 9/16 box end wrench.
    9) Give up and use crescent wrench.
    10) Unscrew drain plug.
    11) Drop drain plug in pan of hot oil: splash hot oil on you in process. Cuss.
    12) Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil
    13) Have another beer while watching oil drain.
    14) Spend 30 minutes looking for oil filter wrench.
    15) Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
    16) Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties.
    17) Drink a beer.
    18) Buddy shows up; finish case of beer with him.
    19) Decide to finish oil change tomorrow so you can go see his new garage door opener.
    20) Sunday: Skip church because "I gotta finish the oil change."
    21) Drag pan full of old oil out from underneath car
    22) Cleverly dump oil in hole in back yard instead of taking it back to store to recycle.
    23) Throw kitty litter on oil spilled during step 22.
    24) Beer? No, drank it all yesterday.
    25) Walk to 7-11; buy beer
    26) Install new oil filter making sure to apply a thin coat of oil to gasket surface.
    27) Dump first quart of fresh oil into engine.
    28) Remember drain plug from step 11.
    29) Hurry to find drain plug in drain pan.
    30) Remember that the used oil is buried in a hole in the back yard, along with drain plug.
    31) Drink beer.
    32) Shovel out hole and sift oily mud for drain plug.
    33) Re-shovel oily dirt into hole. Steal sand from kids sandbox to cleverly cover oily patch of ground and avoid environmental penalties.
    34) Wash drain plug in lawnmower gas.
    35) Discover that first quart of fresh oil is now on the floor.
    36) Throw kitty litter on oil spill.
    37) Drink beer.
    38) Crawl under car getting kitty litter into eyes.
    39) Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame.
    40) Bang head on floorboards in reaction to step 39.
    41) Begin cussing fit.
    42) Throw stupid crescent wrench.
    43) Cuss for additional 10 minutes because wrench hit bowling trophy or beer.
    44) Clean up hands and forehead and bandage as required to stop bloodflow.
    45) Dump in five fresh quarts of oil.
    46) Lower car from jack stands.
    47) Accidentally crush remaining case of new motor oil.
    48) Move car back to apply more kitty litter to fresh oil spilled during step 47.
    49) Beer.
    50) Test drive car.
    51) Get pulled over: arrested for driving under the influence.
    52) Car gets impounded.
    53) Call loving wife, make bail.
    54) 12 hours later, get car from impound yard.
    Money spent:
    Parts $50.00
    DUI $2500.00
    Impound fee $75.00
    Bail $1500.00
    Beer $40.00
    Total - - $4,165.00
    At the dealer. Oil(Castrol GTX), filter, top off all fluids, tire pressure.
    $19.90 out the door.
    And they provide coffee and breakfast snacks while waiting.
  • mitzijmitzij Member Posts: 613
    There are as many opinions on this as there are craters on the Moon. I'd go at least every 6 months, in case an issue with warranty comes up. (you can say you were going by the manual) Usually, I change oil in my car about every 4 months (about 1000 miles).
    The oil life monitor does not measure your oil. It calculates how much strain your oil has been under, by measuring things like engine temperature, number of start-ups, etc. It's not an exact science, it's guesstimating your oil's condition.
    Generally, I tell customers: do what you feel comfortable with. I have many customers who do the 3/3000 interval.
