Visitor Agreement.
The next day, I noticed about six technicians staring at the engine as it was receiving it's used car inspection.
Curious, I walked over to see what was so interesting.
They had pulled the valve cover and the entire valve cover and valve train were coated in thick black sludge! It honestly looked like the car had never had an oil change.
It looked like someone had shoveled roofing tar into the engine. Surprisingly, it still ran like a typical Honda.
Just made everyone sick to see such abuse.
We sold it yesterday to a wholesaler.
Their warranty claim was denied. Go figure.
If memory serves, the owner's manual states to wait for the light or do an oil change once a year, whichever hits first.
My idea is to have a place for you to change your own oil. We would have it set up just like a jiffy lube, but you actually do your own oil change. I'm thinking the charge would be about $5.
We would supply the bay and also have tools and a mechanic on hand in case you had trouble. We would also have oil filters and oil for sale or you could bring your own.
The advantages are you don't have to worry about dumping your oil somewhere, raisng your car, having the right tools and you make sure you do it right.
Disadvantages: Have to pay to do your own work, have to drive somewhere else.
We could also offer antifreeze and transmission flushes that you do yourself.
Right now I'm thinking it would not be a bad idea, but probably not good enough to justify the costs. What do you guys think.
Hey, good idea though...you will probably have to come up with some concrete cost figures for building, equipment and insurance to see if a business plan will work. One thing to remember is that there are a whole lot more do-it-yourselfers that would use this on the weekends...might be kind of slow M-F.
One other long term liability of a site like this would be possible ground contamination from oil and other fluids. IF the fluids leaked in the ground, possible expensive cleanup...might want to check that angle.
miles or a reading of 40% oil life left on the indicator.
I have always tried to keep my cars in top shape and they generally sell almost as soon as they hit dealers lot when
traded in. My only concern is not putting extra wear on the engine by changing less often.
Thanks for any and all help with this!
The Sandman :confuse:
If you want to be dead sure and you want to go on extended oil changes, have the oil analyzed periodically.
" That SAE tech paper documents it. It may have something to do with tiny carbon particles suspended in the oil which prevent metal-to-metal rubbing. This means we should leave the oil in for at least 6,000 to 8,000 miles or so. Quote is from http://neptune.spacebears.com/cars/stories/mobil1.html .
Haven't worn out an engine yet by changing oil too frequently......
How much oil breaks down and what level (and type!) of contamination is what an oil anaylsis does. An analysis might very well justify leaving your oil in for 8K miles...sure...but there's no guesswork about it.
Besides, if you find say a lot of bearing material in your oil you can perhaps intervene and prevent a catastophe.
Friend just bought a car with 150K mi on it. He feels it's good to 300K before needing work. A 4-cyl. He took a mechanically knowledgeable person in that brand of car with him to inspect the car to see if it really had been dealer maintained regularly. It's a 1992.
OTOH my last leSabre I traded had 150K and the motor and trannie ran fine. I've been tempted to look up the VIN to see if it's still running around. I'll have to have my wife look in our records for the VIN number.
I generally change my oil about every 3500 miles or three and one half months, whichever comes first. I also benefit in that dealers are eager to take my cars in trade as they sell quickly and help build a good reputation for the selling dealer.
Oil dilation, if in excess, can be fatal to an engine...but it has to be a considerable quantity---enough to push the dip stick reading higher than normal.
Sometimes if you do lots of quick trips in cold weather, you'll get some oil dilation but the fuel burns off when you hit the highway and get the engine warmed up.
REALLY excessive oil dilation by gasoline can even cause an explosion, but we are talking radical amounts of fuel in the oil here.
Most often, you will only see increased engine wear from the fuel diluting the oil. And the best way to avoid the problem is to take the vehicle out for a nice long drive when it has been used for short hops. Once the engine is up to normal temps, the fuel will vent off and the oil will be in better shape.
By the way... thanks for the help, everyone. I feel better knowing that this is somewhat normal.
