Chevy Silverado - IV
-scott
I don't know what GM puts in at the factory, but I know that Mobil-1 meets the Corvette specs. In fact, if you go to the GM Goodwrench website, you will see that they advertise Mobil-1 as their syncthetic.
Sorry for not responding to post #185 sooner. The picture that I sent to you of the 2000 Silverado LT, ext. cab, Z-71, indigo with black wheel flares does have 265 Firestone Wilderness AT tires.
David H.
- Paul
Synthetic oil's shine isn't only in its capabilities to protect the engine parts better by reducing friction, but also in its ability to eliminate carbon/sludge buildup which will destroy an engine by depriving it of lubrication. If you plan on turning your vehicle over every 3 or so years, synthetic oil probably isn't necessary. But if you plan on keeping it past 5 years and/or you put a lot of miles on it, I would seriouly consider synthetic.
BTW, I started with Mobil 1 5w/30 but it finds a leak like nobody's business.
I did my first oil change at 1000 miles. Castrol Syntech 5w-30. The service manager said they would not even look at the motor if there was a problem if I used Syntech and a Fram filter. So after hearing that, reading the posts here, and reading articles elswhere about oils, I promptly changed the oil again. This time Delco filter and Mobil-1 5w-30 synthetic. Now the dealer can't say much about not using the right filter!
kyle
Well, one new guy did change the oil accidentally, but that was at 68,000 miles. The car was then driven another 100,000 miles with no changes. Regular oil was used, not synthetic.
At 168,000 miles, the car still had no oil-related problems. The engine was disassembled to check for wear, and it was all in tolerance: very little wear, fairly clean passages. The engine is still around, working as a test engine in the San Pedro High School auto shop.
Why do I mention this? Only to state that, unless you drive short trips that don't allow the oil to warm up and burn off moisture, changes at 3000 miles are excessive and do nothing but use up resources and (unless you have your oil filters crushed at a recycling center to remove the oil trapped inside) polluting the environment.
I changed my S-10 oil every 5000 miles. At 129,000 miles it used no oil, still ran fine and was squeeky clean under the valve covers. My '67 Camaro goes 5000-6000 miles with similar results. I live in Southern California where the climate is mild and allows this, and I will soon be switching to synthetic for the added protection it provides, but if you don't use a Fram filter, anything even approaching 3000 miles is excessive in my opinion.
Richard
Before somebody pipes in and gets defensive on behalf of the oil guys, I'm not knocking them. They've gotta make a buck, too. All I'm saying is, be a smart consumer and use good, common sense judgement. It's your money...
Bryan
I reset mine at 9000. The oil change reset light will come on if you wait 30s or so for the battery light to go off after you do the 3 quick wacks on the pedal.
Thank you Kanton for your info: now, I don't have to ask the Service dept.
QUAD>>
Saw Jupiter and Saturn last night (with binocs) - was tricky trying to steady it but I could see the 3 moons of Jupiter and Saturn was a bit of a blurr. How amazing, now tonight is suppose to be the brightest yet, so buddy is bringing over his telescope tonight. Thanks.
If you lilke, you can go to
http://community-1.webtv.net/dp2000/TRUCKFORCEACTION/page3.html
to see a picture of my truck with the LSII on it. Mine is the 12th picture down from the top.
Jon
I used to use them also..
- Tim
1. Lower filtering area than most others
2. Bad anti-drainback valve design (not a problem with our trucks since they face down)
3. Bad bypass valve, which when combined with the lower filtering area means you have stopped filtering the oil after a relatively short period of time.
4. (according to my auto shop teacher) Thinner metal canister than others.
Around here, Fram costs the same as or more than AC-Delco.
Fram is kind of like Microsoft ... they're the biggest so everyone buys them, even though they're crap. Combine Fram with Pennzoil ... I don't even want to think about it.
My problem lately has been finding AC-Delco. The chains don't have them any more, and the chains have put the smaller shops out of business.
Richard
Richard
Pennzoil isn't good stuff? That is what i always use when i am changing my oil on my GMC Jimmy. I have a Silverado coming in Dec. and I want to make sure i am using the best stuff on it so it will last me a while. What is a good motor oil to go with?
Tea
http://minimopar.simplenet.com/oilfilterstudy.html
I'm not sure about the suspension option. We tow a 5,000 lb open race car trailer. A test drive in a Z85 hd suspension (2wd) was too harsh when empty. Has anyone experienced the ZX3 suspension?
Are the blackwall 255/70's all General brand? Would the raised letter 255/70's get me Firestone?
Also, we will probably not order the fourth door to just avoid the wait hassle. Any thoughts?
Any other comments about what plan to order? We are just south of Milwaukee, WI....$100 over invoice (no advertising added in).
1) They say to not put a child seat in the front middle position in either cab style (40/20/40 seat). It doesn't explain why, it just says it won't restrain properly. Why?? That position has a manual seat belt which is probably better anyway.
2) The maintenance schedule recommends checking the front & rear differential fluid levels every 7500 miles, for ever! What gives, I've never heard of such a thing. Most cars never have this checked for the life of the vehicle. If there are no visible leaks then the level must be okay. This seems like a stupid recommendation to me but they must have a reason to put it in. Why??
http://www.gmpowertrain.com./trck60TC.htm
I would not NOT use it, but there are other brands I like better. I other words, it's not BAD, but others are better.
As for filters - always used Delco.
I got the Crutchfield catalog recently, but was wondering if anyone knows just how much power (watts per channel) the factory radio puts out? Since this is my first full-size truck, I did not have any brand loyalty issues to deal with. Two things got me to buy the Chev - GMO and Autotrac.
As for oil. In petroleum based - Valvoline is the best and is used more by auto racing teams than any other brand. For synthetic - Amsoil or redline is the best rated, but costs about $6-$7 per qt. For the best synthetic used for daily drivers with regular maintenance intervals, Mobile1 is the best for the money.
This is based on several different studies. It is not my own formulated opinion. I am just repeating what was determined.
My choice is Wix filters and Mobile1 10-30. I them both for my 99 Silverado and my 96 GrandAm.
No I do not work for Pennzoil, yes I am an engineer that can interpret the numbers, and yes I have personally run many vehicles with Pennzoil for many years with no problems. Their labs and process are state of the art.
Bottom line is use what you like as long as it has the "start burst" emblem. For something simple to look at, read the consumer reports test with NY taxis. All modern oil is good, synthetic are usually recommended for Turbos, Towing, and retentive owners.
I will definitely stay away from FRAM. No one had anything good to say about that.
It also makes sense about all the shops use Pennzoil, though. Eadeneris, are you sure? You definitely did the study? Thats interesting.
Let us know how you fair if you ever put any real miles on your vehicles. Its a proven fact that synthetics greatly increase engine longevity over petroleum based oils. If you only keep your vehicle a couple years as I do, it may be overkill. However, if you keep your vehicle past 100k miles, you will greatly see the advantage of a synthetic over a petroleum based oil, especially if you ever rebuild the engine.
On top of its better protection properties, synthetic oil is better on the ecosystem and natural resource management. I don't think anyone has to be an brain surgeon or even an "engineer" (which I happen to be also) to know that synthetics are better than petroleum based oils.
Where synthetic has it over conventional oil is if you overheat your engine. Which is why most of the Winston Cup and NHRA teams use synthetic oil in there engines. Most people never require the added benefits of synthetic.
I have always used Castrol GTX and have never had a problem. I started using it in motorcycles years ago and like the advertisements say "it does not breakdown and foam". My last car has 140,000 miles on it. My neighbors kid runs it now. The valve covers were leaking, when we pulled them off (at a 130,000 miles) the top of the heads still looked brand new. The engine has never been overheated and doesn't burn oil. It is 91 Daytona with a Mitsu 3.0L V6. An engine that is known for dropping valve guides and burning oil. This car was well maintained and still is.
If you feel you need to spend lots of money for synthetic oil by all means spend it. All I can say is I have never had a problem with a good quality conventional oil.
Randy
Well I finally got motivated and ordered the Putco stuff from Autozone.
S.S. Locker Rails - $189.99
S.S. Skins with Holes for stake pockets - $182.99
Plus 6% for the state - $395.36 Total
Should have them wednesday and on by Thursday. I leave for Deer waiting Friday....so they will be just in time. I'll post pics Thursday.
Pipeline Boards are out of stock right now..
Oh well..
Whos says it doesn't pay to procrastinate??..DOHHHHH!!
- Tim
After seeing the difference in engines running synthetic and engines running cheap oil, I won't even risk it on a 30k truck. Daytona's were use once and then throw away cars from the get go, so I highly doubt I would have ever invested any money in one of those cars, but a 30k Silverado that can last 20 years and still keep going....I'll give it the best possible treatment.
If you ever run synthetic in the extreme heat while towing a bass boat, you will see the difference. If you ever start a truck using synthetic in sub-zero weather, you will see the difference. It's your money. You will either pay it in the beginning or if you plan to keep it a long time, you will pay for it in the long run.
I only keep my trucks 2-3 years, but running synthetic is cheap insurance against friction heat, and oil breakdown in my opinion.
I would never buy a used vehicle from someone like you.
Thats why GM now installs oil life monitors in it vehicles so people don't over use there motor oil.
Why don't we go back to talking about what we all came here for which is Silverado's not oil, or start another topic on oil.
Oh well.
They be on the way
- Tim
