Use caution when playing with electrical items and be sure there are no gas fumes or battery fumes around.
Actually you don't WANT to start this engine just yet until you investigate it internally a bit more.
First off, we need to check for an injector pulse using a noid light.
Okay, you got a pulse, so the injectors are getting the message to squirt.
No, do you have fuel pressure in the fuel rail? Is it ENOUGH pressure?
Okay, you have fuel pressure and you have injectors.
Now then, do you have SPARK at the end of the plug wires?
Okay you have a fat spark....now it gets ugly
Do you have compression?
Okay you have compression. Has the timing belt slipped or broken? (does the rotor spin around when you crank the engine?)
so step by step like this and you should at least nail the general area of the problem.
You're missing something here---you can 't really have all things okay and not have it start, so it's missing fuel, or spark, or compression, or the timing is whacko.
What kind of "soot"? Is it oily, or just gas fouled, or???
freon was just added in february, but only blows out hot air. also, air does not blow out of 2 center air vent off dashboard as well??
Have you checked your dipstick. Is the level extra high?
Thank
We checked the spark plug wires and are not getting any spark. Fuel pressure seems to be fine when they check it.
So far we have replaced the ecm, ignition control module, crankshaft sensor, coils, and fuel filter. Any other suggestions would be great. We are at a loss.
But sometimes when we squirt starting fluid in the breather, it starts. This is why we are so confused.
Any more suggestions.
Earlier in the week the only thing out of the ordinary was the ABS indicator light came on and wouldn't go off for the longest time. Also, the last two mornings the car wouldn't start right away. I left it for awhile and tried again, then it'd start. Same thing when driving downtown but I thought maybe it was overheated. I do have a full tank of gas and all the fluids levels are proper etc.
Even if I could have some suggestions for some trouble-shooting that'd be helpful. I will most likely have to take it into the local garage but would rather have some information ahead of time, if possible.
Car repairs are maxxing out my learning curve. Thank you in advance
If all that's okay, and they get the car started, I'd check for fuel pressure, which I suspect is your problem. If the car doesn't start, I'd put a noid light on the injectors to see if they are getting a pulse. If they are, I'd check spark, and then I'd check fuel pressure in the injection rail.
So you work from basics, from the simple to the more complex. Given that the car just stops while driving, this isn't very subtle, so I would think the failure should be obvious when diagnosed.
It happened again this morning, but I managed to get it into a nearby shop. The mechanics did a diagnostic test on it and let it run for a long while.
The alternator is fine, the battery is good.. the only thing they could come up with was a "crank sensor error". Their computer showed that the car has had similar problems twice before, I guess. Not too clear on how that all works. The only frustrating part is that if I say "Yes, go ahead and do the $270 worth of repairs" there is still no guarantee that it'll fix the problem, not even for a day (according to the mechancic)... Gee, I don't know.. Not sure which direction to go now.
One question, please. Is a crank sensor something that you would consider buying from one of those Auto Parts (used), or not? We have several of those in town but I wouldn't want to go that route if it wasn't too logical.
Thank you again.. ~~ Liberty
I'd never buy an electronic part used, no, but if you want to shop around for a new one, and get a book that might tell you how to install one, that might be okay.
Messages Page 18 of 18 Go To Msg # Search This Discussion
1 ... 12 13 14 15 16 17 18 Recent Msgs
#329 of 333 smoking dashboard???? by lpratt Jun 10, 2005 (9:21 am)
Bookmark | Reply | E-mail Msg
Hi...I just recently went and bought an 1989 Ford Taurus car. I had to things that I thought were wrong....both E-brake cables and a bottom radiator hose...well just recently I was driving it and all of a sudden it started making this weird clicking sound. Then a very loud knocking sound followed...well water pump was shot...fixed that and replaced belts and it was then taken on a test drive and it sounded normal again. Well in return, the car was parked and shut off. Well when it was time to restart it...first it had absolutly no power to anything, no turn over....nothing. then the dash started to smoke a very thick smoke and also out of the steering wheel area....I have no idea what happend....would this be an ignition problem or electrical??? Nobody knows what is wrong with it....any advise
I appreciate your assistance. Have a fun weekend.
~~ Liberty
I have a 1994 Honda accord with about 150K miles on it. It cracks fine but stops within a few seconds. Yesterday it did the same thing but started after a few tries and ran fine. Today I have not able to get the car running. Every time I turn on the ignition it cranks fine but the engine stops after a few seconds. I had the starter replaced last year and the fuel injection service was done about two years ago. I will appreciate any advise.
