Visitor Agreement.
Thanks! RONN
I do not think the new Avalon would look nearly as good with side molding. True...we will all have to watch those dings, but be proud of its new design. I think it is awesome.
However, i still think you paid tooooo much. (As did I) -- That car should be selling no more than $1,000 over invoice this month -- And +$500 the following months.
We early birds paid tooooo much.
I saw one "happy" camper in the Gainsville dealership pay for the 'demo' $2,000 over MSRP.
Amazin'
I self-installed XM in my current car, and mounted the antenna on the back shelf. I have had no problems whatsoever with that location, and would intend to put the Avalon antenna there as well.
Anyone aware of whether there's a way to pass the antenna wire from the shelf back to the trunk?
Is there enough length on the antenna wire to mount the antenna on the back shelf? Is there a convenient place through which to route the antenna cable to the receiver?
I strongly recommend Greenfield Toyota for your extended warranties.
I received my paperwork after only four days!!
Have any others noticed the engine noise when idling? I've also read similar queries on the new 2006 GS300 forum. Might they be the same engine or from the same engine manufacturer? I believe that the Avalon engine is made in Japan for the 05 model.
Regards: Dan
See my response to Maceman re details of purchase. If you need more info, let me know,.
Using the remote engine starter: The engine starts fine, but when I open the door, the engine stops. Is that what is supposed to happen? I thought the idea was to have your car running when you enter.
The idea is not to have your car running when you enter, but to have it pre-warmed (or pre-cooled). The engine is supposed to shut off when you enter the car. That's a safety measure, and also a security measure, so someone else can't jump in your car and drive away with it. Once you're seated, you push the brake, re-start the car (since only you have the key fob for that car), and away you go.
Per the 2005 Avalon Introductory brochure, the remote start:
1) Works from 80-120 feet from the car.
2) Is intended to pre-heat or pre-cool the car for driver comfort.
3) HVAC resumes at prior settings when car is started.
4) To prevent unauthorized or unintended driving away, the engine will shut off when:
a) Any door or engine hood is unlocked or opened.
b) Key is inserted into the ignition lock cylinder.
c) UNLOCK command received from remote, or LOCK button held for 3 seconds.
d) Brake pedal is depressed.
e) Shift lever is moved out of PARK.
f) Alarm system is triggered.
g) 10 minutes have elapsed since starting.
h) Engine temperature exceeds a preset value.
"When ready to enter vehicle and drive, engine must be restarted."
As you can see, Toyota has engineered in quite a few overlapping backups to the remote start.
Regards: Dan
pricecutter
The difference may be that I used AAA (I'm a member) which has a special arrangment with certain dealers. However, as I said before, some of these dealers, not Thompson, wouldn't honor their commitment, e.g. one told AAA that they were charging members $500 over invoice. When I called this dealer, the contact said MSRP only for 2005 Toyotas. Also,AAA advises that dealers can still charge for advertising. Personally, I don't think confrontation at this point would be useful. Note also that my purchase occurred a full month after your quote. Each month and other factors make a difference.
Mackabee
