I thought it was a miss print on Edmunds.com site, then I went to the Toyota.com
they has 268hp listed :confuse:
and about the horsepower its the same ! but its the new SAE rules ! so when u use better fuel 93 u get 280 and 89- the 268hp !
I had mine installed for $600 (I live about 30 minutes within the Boston, MA area) . This is for full coverage including the side mirrors, headlights, and fog lamps (My installer also put some on DLC lens).
As for yellowing...
According to my installer, this tendency is symptomatic of films from Avery-Dennison. I heard that 3M film does not this problem. (Of course, he was a 3M installer, but I'm banking on the warranty to cover me in case this happens).
I found my installer from the 3M website:
http://solutions.3m.com/wps/portal/!ut/p/kcxml/04_Sj9SPykssy0xPLMnMz0vM0Q9KzYsPDdaP0I8yize- - INzL20y_IcFQEAN50etQ!
Hope this helps.
You can check out this link for some F.A.Q.s about this film
Tom H.
After about 12000 miles my observations are that the octane does have some effect on the horsepower - if you really need the 6+ second 0-60 etc. then stick with premium - if are willing to sacrifice a second or so 87+ does fine. Unlike the old days I think the engine computer systems sense available octane in the fuel and adjust what needs to be adjusted to prevent detonation (pinging). Have not noted any significant differences in fuel economy, however.
Although I understand that that there is a new engine rating standard I don't think there is any difference in the 2005 engines vs. the 2006. And, if Toyota simply rerated the horsepower to reflect running regular gas they have an easier sell in these times of high gas prices. That said, seems likes there's more than 12 hp difference in my 2005 with the lesser grades - maybe more like 20 or 25!
Some of you are in self-denial about the horsepower rating change. It has nothing to do with regular or premium. Toyota overstated the HP rating. Period.
Your car runs its best with higher octane, but that is giving you the full monty.
Lower octanes only degrades the HP rating.
You can be sure that every manufacturer gives the highest possible horsepower rating because it SELLS CARS. They use the best fuel in a factory-babied car to calculate both HP and mileage.
SAE changed the methodology of calculating horsepower. The calculation is the same, but the "latitude" permitted car manufacturers was restricted. This was due to mainly Japanese manufactures overstating actual horsepower. Toyota took the biggest fall (Camry models including Avalons). Honda Acura also took a big hit.
You can goggle this subject to your heart's content.
And try this link a well
http://www.detnews.com/2005/autosinsider/0508/17/A01-283759.htm
Note the comments from the Kelly Blue Book guy.
Does that lessen the perceived value of any car? That answer only lies with the owner.
zekeman1
Stop the presses! Detroit News finds fault with Japanese vehicle manufacturers...
It appears that we are yet to learn about changes affecting most Detroit models...
"While Toyota and Honda are retesting their entire vehicle lineups, other automakers generally are retesting only cars and trucks with updated powertrains."
Not to give you guys a dig, but the car seats in my 300M are the best I have ever sat in
Regards
Jack
Regards
Jack
zekeman1
Then you say, "Your car runs best with higher octane....lower octanes only degrades the HP rating."
Setting aside what "self denial" has to do with it, I'm pretty sure that actual evidence backing your contention that "Toyota overstated the HP rating...period," would be more convincing than assertions nestled up against each other in the same post that are clearly at odds with each other.
Thanks for all input.
You should re-read the article found at the link you provided. It specifically mentioned that under the new hp rating requirements, "whether or not premium fuel was used" was one of the parameters addressed. So, 280hp still stands for Premium and 268 for 87 as far as Avalon is concerned - unless you have another link you wish to provide indicating otherwise.
Deanie
P.S. By your name I take it that you live in Baltimore or have some association with that city. Please use you turn signals when driving - most people in that area seem to drive with doing such - regardless of what hp their engines produce.
I called the Tire Rack asking about putting 225's on the existing 17" rims, which theoretically could accept that width of tire. Don't do it. They told me "Don't do it", adding wider rims/tires causes a risk for the wider wheel/tire to contact the struts in certain turning situations under certain loads. If you want to improve the car's handling, there are several tires in the factory 215/55 R17 size, a few of which have "W" rated rubber (Avon makes one). Also, you could just go lower profile - plenty of 215/45 r or z 17" tires for better handling. But if you want big wheels because that's what's popular or..... To each his own.
Deanie
The Remote Engine Starter will shut down automatically under the following conditions:
If any door is manually unlocked via Smartkey
If any door is opened
If the shift lever is moved from "Park"
If the hood is opened
If the key is inserted in the key cylinder
If the SmartKey button is pressed
If the brake pedal is applied
I have only used mine once or twice so far, and it is kind of a (little) pain to have to restart the engine upon entering the vehicle, but I think I can understand the safety and security concerns of this. I can live with it for the convenience of cold-winter morning startups when it has sat outside all night!
Mike
On the 268hp they tested it with the Power Steering pump ON the Engine.
http://www.autotoys.com/x/cust/product.php?productid=5017&cat=0&page=1
A picture of its installation is here -
http://photobucket.com/albums/y294/gbinplano/
Hope this helps,
Greg
p.s.-Great looking ride. I'm drooling for mine now.
Tom H.
Greg
Contentions that octane has nothing to do with HP is ludricrous - showing a basic misunderstanding of what octane rating is (a value for energy available per unit volume) and the way that many current engines are designed to make some use of this energy as revs increase and valve timings change. The Japanese (Honda) actually pioneered some of this this technology back in the late 70's with it's 'CVCC' engines and were followed closely by the Germans who took it steps further with variable valve timing, the American mfgrs. are now just starting to get with the program.
The Av is a pretty darn quick car at 3600 lbs. - if it will run 0-60 in something less than 7s and do a quarter in something over 90 - why does it matter whether the window sticker says 280 or 268?
The reason Toyota's HP numbers went down is because the SAE changed the way ALL HP numbers are figured. There will prolly be changes to every vehicle sold in the US.
The guidance map lacks many roads--even major roads like a chunk of 288 near Richmond, VA--if they are less than five years old, so I asked my dealership parts department. They told me the 2006 update will be out in October.....of 2006! For $250 a pop it seems as though they could do just a little better than that, but that's what he says. Does anybody have some better news about this? Mackabee----HELP! Is Toyota our only source?
My new Limited has the DVD-based navigation system. Have to admit to being kind of preoccupied with trying to learn the vehicle's many other features, so I put off really delving in to the Nav thing. But your post has got me to thinking: am assuming that the map database is on the DVD and your dealer has quoted you a price of $250.00 for the new disc?? After paying $1900.00 (retail) they want $250.00 for the map update each year? PLEASE tell me this ain't so?!...
And if it is so, then tell me that we are talking about a standard DVD-type media that can be duplicated... somebody pays the $250.00 up front, dupes the discs and then everybody kicks in ten bucks a piece for a disc, thereby getting the cost down to where it should be... :>)
Sorry, mstem, but it IS so. (Try not to think about what you paid for the nifty map system; it is sunk cost at this point). What surprises me is that it isn't even annual. I got my system in April, loaded with version 4.1, and they tell me the next update won't be available for a year and a half--October of 2006. The $250 I will gladly pay if I can get more complete maps. It already amazes me that it can tell if I'm on an exit ramp and knows which way I should turn at complex intersections. And then I suddenly plunge out into the GPS map version of "open fields" where the system is totally ignorant about four lanes of concrete. The FAA updates aviation databases every 28 days, and the annual subscription isn't much more than this rarely-updated road system diskette. And I'll be the user base is nearly as many installations--maybe even more.
BillT
Also where can I find the device to use to take off the oil filter housing besides going to the dealer?
I've been noticing slight pinging when my car is in idle? I have about 1,600 miles on my XL. Any ideas ??
I think I may try to fill up my car with premium gas and see if that gets rid of the pinging noise at idle.
For your reference, aftermarket companies such as Alpine and Pioneer charge $300 for their DVD updates. The reason for the high cost is the licensing fees charged by NAVTEQ and TeleAtlas. It cost serious dollars to collect, compile and verify the map information. Undertaking the creation of a software that will safely route you to a destination is no trivial matter.
Toyota sells printed repair manuals, but they are very expensive. You can order from dealers. A much better value, in my opinion, is their http://techinfo.toyota.com/ serviice information web site. For $10 per day, or $50 per month, you can download the entire contents of every repair manual, TSB, tech training manual, wiring diagrams, etc., in PDF form, for all/any late model Toyota and Lexus vehicle. including the '06 Avalon. If you have a broadband connection, and are willing to forego a night of sleep, you could download every bit of data relative to just your Avalon easily in one long (4-6 hour) session, for $10 charged to your credit card online. See details on the home page. The identical information in printed form would cost more than $200.
