I decided on the Driftwood Pearl / Tan combination just because I felt it was a better color combination / coordination with no better or worse visibility of soil.
I was looking over the cleaning information that came with the car and it looks like the interiors are fairly easy to clean with a rapid (within 30 mins.) response to spills being key. It suggest simply water and/or lemon juice for most spills and stains.
Because everyone does not read every post, I'll be asking every few pages until I get responses or perceive that none will be forthcoming.
This problem is potentially life-threatening. I would like to collect more information from those who also have experienced the same problem.
Not with the 2004.
You are lumping the 2001-2003 models with the 2004, which is inappropriate since brake controller was changed.
There is a very noticable brake behavior difference between the classic & new model.
JOHN
As an example- can I do a voice command for temperature while on the map screen?
> the sudden shutdown of ICE and appearance of many warning
> lights on dash?
Yes, you are.
Not a single owner on any group, even the big one on Yahoo, has reported what you've experienced with a 2004.
The problem is very much isolated to just you own specific vehicle. That's why I asked for greater detail. You are the only one that can provide it to help with a diagnosis if it ever does happen to someone else.
JOHN
JOHN
The Prius is a compromise. I like the front and back end but the sides are like walls of sheet metal. Thank goodness they had created a crease at the lower waist line, otherwise, it would have been one massive side. I also like the "Zagato influenced" bubble roof lines. Don't care for the rooftop antenna. Seems like a lot of manufacturers are doing this. They could have put in a retractable antenna which, when not in use, create less drag. Even my old MR2 had a power antenna. I don't listen to the radio much so a retractable antenna would have been great.
Besides these minor complaints, I love the car and love driving it. I hope that Toyota will do a bit better design for the 3rd generation of the Prius. If they can make such dramatic design change from the 1st to the 2nd generation, I am really looking forward to the next iteration. I strongly believe that styling/design is as important as the engine/technology under the skin. Just my 2 cents...
First, the 2004 is the 3rd generation Prius.
Second, what does "better" mean?
JOHN
1. While playing with the controls (the car was in park,) I shifted it into "N" and then many things froze: break indicator was red regardless of parking break; shift won't work (can't shift out of "N"); even power button won't shut it off. Only after hitting "P" button got it out. I guess it was on IG_ON mode but power button should have worked.
2. Had instrument panel light control in minimum by mistake. The next time I started it, nothing was on display. This is probably an expected behavior but caused some panic never the less.
3. The Owner's manual is poorly written.
In general I am happy with it. By the way, I have AM package. Really wanted Homelink. Find out from maintainance manual it can be put on on as accessary together with autodimming rearview mirror, $240.
Currently 42 MPG after 250 miles mixed driving.
What do you need "N" for?
Toyota intentionally discourages its use, since it really doesn't serve any practical purpose in a full hybrid... hence the freezing you witnessed.
To shift out of "N", you have to step on the BRAKE pedal at the same time.
> should have worked.
If you intentionally want to override that safety setting, you have to continue to hold the button. After awhile, it will acknowledge your intentions and allow you to power off that way.
JOHN
Toyota intentionally discourages its use, since it really doesn't serve any practical purpose in a full hybrid... hence the freezing you witnessed. <
I could see needing N when the Prius is run through an automatic car wash (the ones where a car is pushed through on a guide rail). If you didn't have neutral, how could the car move through the car wash?
Also what about towing the Prius? Can you flat tow a Prius behind an RV? I would see a need for Neutral in that scenario.
Power antennas also freeze up (or down) in winter. Many times in my old Acura Integra I switched on the radio only to hear a whirring/clicking noise from an antenna that refused to go up.
They're OK when they work, but when they don't it's a major inconvenience.
Towing & Pushing are a given. That makes sense, one basic setting that never changes.
What doesn't in a full hybrid is how some people use neutral when coming to a stop, for added control on snow, or when gliding down a hill. Those uses are meaningless with this design.
JOHN
...better in a sense of even more aerodynamic. Body not as massive. Window sills not as high up and waist line lower. Even more of a eliptical look...more so than the triangular roof line. I would even like more of, for lack of a better work, an "Egg" shape...
Oh, OK. Quit being so vague. ;-)
There were simply too many cosmetic changes to call it a "model year" improvement to describe the difference between 2000 and 2001.
And since the hybrid system change significantly in 2001 too, "generation" is the appropriate label.
There is no in-between term. Coin one. We'll use it.
JOHN
A "generation" typically refers to a major change to not only powertrains, but also the interior and exterior design and often the chassis. An examples: for '04, Chevy put a new engine into the Cavalier and also changed its front and rear styling. I have not heard anyone refer to these changes as a new generation of the Cavalier. The last generational change for the Cavalier was in late '94, when the car got an all-new body, interior, chassis, and (I think) some new engine choices. Many people call the mid-generation changes "refreshes", although I'm not aware of an official term for them. Another example is the RAV4--it got a revised engine for '04 plus some styling tweaks, but it too was not considered a new generation. I asked my Prius salesman about the Prius generations a few weeks ago, noting that some people think there have been more than two generations, and he was quite emphatic about there being only two generations, although he added that there have been changes to the hybrid powerplant along the way. So that's not an official word, but does give another opinion on the subject.
How much can you change before it is no longer the same vehicle?
There are many examples of nameplate transfers, where there really isn't any relation to the previous vehicle. The terminology doesn't really fit that either. Realistically, it's called "branding". And by using that logic, everything is messed up. But then again, how much different you want your next generation to be, aka: your children?
JOHN
So, this is my suggestion for US Prius:
2001 - 2003 = Prius Mark I (MkI)
2004 - until new body design = Prius Mark II (MkII)
This will clarify which version of the Prius we are talking about. This has been done on other boards for "major" changes between both technical and body/cosmetic changes within the same model.
Backy...good points. I agree that minor cosmetic or mechanical changes do not constitute "generational" designation. As an example, lets say that for the 2005 model year, Toyota decides to re-shape the tail lamps and re-color it. This, in my opinion, does not constitute a generational change unless the whole body has also gone through major re-design.
I understand that under the skin there may be updates to the engine/hybrid system throughout the years. However, these tweaks, do not, (again, in my opinion) constitute and update to a Mark III status without also changing the whole look of the vehicle.
That's really a marketing question. Sometimes a name has worn out its welcome (e.g., Excel, Tercel, Bronco, Nova, soon Cavalier) for whatever reason. So the manufacturer decides to rename the vehicle when it is redesigned. Other cars have been redesigned many times over their lifetimes (e.g. Camry, Corolla, Civic, Accord, Impala, Mustang, Corvette) but retain their names because the manufacturers think there is positive brand equity in them. I expect that the Prius name will not live that long, maybe one more generation beyond the current one. Why? Because IMO the Prius is Toyota's showcase and testing ground for their latest hybrid technology, and once hybrid technology becomes mainstream and has spread across Toyota's entire lineup, there won't be a need for a single model that is a showcase for Toyota's hybrid technology.
Another idea to label the Prius generations is Prius Classic and Prius TNG, which is borrowed from an obvious source that John should recognize. ;-) Actually the Prius Classic label is already commonly used.
Prius (2004)
I doubt the Prius will stay as soon as the Camry, Highlander, Corolla and RAV4 get hybrids because the Prius, like backy said, is Toyota's showcase for new tecnology.
M2 started in 1999, there was no 1998 model in the US. VVT and turbos have been added, but it's still an M2.
Just my 2 cents'. But what do half a million sport car owners know. ;-)
-juice
Keeping the Prius alive and well will give Toyota a platform to try out new technology without affecting the other model lines. Being conservative with other future hybrid lines like Corrolla or Camry may be beneficial to Toyota. Just my $0.02...
http://lemonlaw.com/lemonlist.html
Prius is #2 on the lemon list? I suppose this is data from the classic Prius.
Neon ranks better than Civic or RAV4? I'll pass on that data...
-juice
The site is nothing but a promotional tool for a group of attorneys.
There is no real merit behind their claim. They simply took advantage of a unique situation to add a popular new vehicle to their list, one that would generate lots of attention to their website.
JOHN
Buick LeSabre is among the most reliable on that platform, yet the list implies the opposite.
At a minimum, they just don't have a large enough sample for it to have any meaning.
-juice
Note that the M5 connector is **inside** the transaxle and so is not immediately affected by rain. The moist air inside the transaxle condenses on the wire leading to the connector and runs down into it. The resulting "short" across connectors causes the symptom. Sitting (in broken-down condition) for several hours allows you to drive again, but you may break down again as I did after just 53 miles.
I'm still waiting for Toyota to respond.
Except you'll find after awhile that looking isn't needed anymore. The buttons are specially designed to be operated based on position & feel.
JOHN
To my understanding the previous generations did not have traction control on them. So I'm curious as to how your older model prius has it. Was traction control an option then?
One of the selling points of the 04 prius is the fact that it comes with traction control. And as I took my prius on for a slight alignment adjustment I talked to the service manager and he says the older model prius didn't have traction control.
The catch is that version of "traction control" was actually a "hybrid" of what fit the official definition/implementation. So Toyota wasn't allowed to actually call it that.
That was an obvious lost marketing opportunity. So they tweaked it in the 2004 design to meet the official qualification.
JOHN
I am looking to buy a '04 Prius in the twin cities. Any dealer recommendations? What kind of wait time can I expect. Looking for Option pkg #9.
It isn't Bush that is phasing out the incentive. Its how the incentive was written. Its been around since 1992 (for clean technology vehicles). Most of these laws are written with phase-outs or end dates to keep the total cost down. At $1500 in 2004, if there are 50,000 hybrids sold that is $75 million in tax deductions for the buyers. Its starting to become an expensive subsidy as it is...
That said, hybrid cars are now at the point where the government shouldn't have to pay someone to drive one. They are a good enough value proposition that the government doesn't need to spend lots of money promoting them.
