ONE YEAR AGO----1/03--- THE A/C WOULD NOT SHUT OFF, EVEN WITH THE KEY OUT OF THE IGNITION. OF COURSE IT RAN OUT THE BATTERY. WHEN TOWED TO BUICK DEALER IN PEMBROKE PINES, FL. I ASKED TO HAVE THE ELECTRICAL SYSTEM FULLY CHECKED TO FIX THE PROBLEM, SO IT WOULD NOT HAPPEN AGAIN. SERVICE MGR. SWORE IT WAS CHECKED AND COULD FIND NOTHING WRONG. JUST RECHARGED BATTERY. NOW 1 YEAR LATER SAME PROBLEM AND I NEED A NEW BATTERY. IF I GET ONE, I KNOW THIS A/C PROBLEM WILL HAPPEN AGAIN. DOES ANYONE ELSE HAVE THIS HAPPENING OR DOES BUICK HAVE A RECALL? OR SOLUTION? THANKS R. KLINGSBERG------IROK1953@AOL.COM---BUICK CENTURY 2000.
2000 century coustom 46000 mi keyless entry cruise cassettee ABS power W/L and driver seat 1 owner some crack on windshield from a used car dealer he is firm at $6100 KBB trade is $4900 Private party $6900 Edmunds Trade in $5600 private party $6800
What's you guys opinion about this? Is that a reasonale price? Which particular part should pay special attention when mechanical check? thanks much!
I wouldn't pay that much for a 2000 model. 2003 models are selling for under $10,000 in the Dallas area. 2002 models I have seen for $6995 advertised, with 50-60K miles on tham. With those miles and that year, IMO it's worth about $4000-$4500. Remember the windshield will cost $200-$400 to fix (used or new part is the price difference)
Bought new and are having a problem with "jerking" when proceeding from a stop. The dealership says they have never had a problem like this come into their shop. It does it every once in awhile so when taken out for test drives it behaves like normal. Has anyone ever had this occur and if so what was the solution?
What state do you live in? Here in Colorado, it is against the law for a dealer to sell an automobile with a cracked windshield because it poses a safety hazard.
I have a '98 Buick Century and occasionally the ABS warning light is on when the car is started. It might happen one time in ten. It never comes on except when the car is started and when it does come on, it does not go out while driving or flicker on & off. There is no noticeable effect on braking.
I've had previous cars where the engine service light occasionally came on and a mechanic could find no reason for it. Anybody else had an intermittent ABS warning light problem?
I have a 2004 Pontiac Grand Prix. It seemed as though I was putting more mileage on this car than on my other cars. Last week I checked the trip odometer against mileage markers on the Parkway. Sure enough my odometer was showing 2.1 miles at the 2 mileage markers (a 5% difference). Does anyone know how to get it corrected. There are federal regulations against messing around with odometers. My car is leased and this could put me over my mileage limit and at $.15 per mile this could cost me at the end of my lease.
I parked, took my keys out and my car kept beeping as if my keys were not extracted! I had to disconnect my battery to get my lights to go off! Not only my head lights were on after I took out keys but also my taillights When I pushed lock botton my lights would not go off ? Any clue????
My father has a 97 Century Custom and the headlights are turning milky on the top half. I tried to polish the outside with some plastic polish and it smoothed out the roughness, but it looks like the main problem is inside.
Any solutions? I'm contemplating going to a salvage yard to see if I can pick up a set that are not affected.
I have a 1998 buick custom century. I am having problems with the right side blinker light. The left side works like it is suppose to, however, the right side clicks really fast(not normal speed) and does not show up in the light indicator of the instrument panel. Outside front right side lights do not blink at all. Only the back right side is blinking but very fast. I have tried replacing the light bulbs for the front and back lights and replaced the fuse, but none of this seems to work. I would greatly appreciate any advise in fixing this problem. thanks, ralz
I have a 2000 Buick Century that has an electrical problem that is causing the low/high beam light not to work. I have taken the headlight out of this car and tested them on my 2002 Buick Century. The light worked good on my 2002 Buick. I also took the headlight switch out of my 2000 Buick and put it in my 2002 Buick and it worked correctly. I have checked the 20 amp fuse and the two 15 amp fuses and they were ok. If I hold the high beam switch on the high beam lights will come on. The parking light and daytime light work correctly. Does any body know where the Running control module is for this vehicle??? Also where is the Daytime running lamps ambient light senor?? Any suggestions to trouble shoot this problem would be appreciated.
My father has a '98 Century with about 40k miles. A few months ago, it mysteriously began not starting. Every few weeks, when you turn the key, nothing happens -- no cranking, nothing. However, an hour later it starts with no problems. Of course the mechanics can't find any trouble codes or anything else. The battery is new. Any thoughts would be appreciated. Thank you.
Hey Joel, I have the same exact problem on our 2000 Buick Century. I took it to the dealer and they charged us $150 to tell us that it is probably the light switch and it would cost $711 to replace it. I told the service manager he was out of his mind. I took the headlamp assemblies apart and swapped the high beams to the outside position. We now leave the high beam switch on for the time being, although the light is now diffused inside the assemblies. I just bought a new switch for $70 and I'd like to know how difficult it was to change it out. Thanks, John
Mine had that problem, best I can figure, it was the injectors sticking shut. I was a die hard fan of cheap speedway gas, never gave me a problem till this car. Now if I use it, every other tank I get an injector that sticks shut and engine runs like crap. Switched to Shell, no problems since.
Dealerships will tell you it's probably the switch arm ($400). Mine started doing that on the right, and then progressed to the right. After switch arm $400, main electronics $500, new bulbs $20 and many hours of labor, they got it fixed. Luckily it was under warranty so out of pocket was only $50 total
on my 03 buick century everything on my instrument panel goes dead and my check engine light comes on eventually they come back and engine light goes off ive checked all my fuses but nothings bad
Hi, Did you ever find out the problem with your Buick, Century? I am having a similar problem. When I accelerate and the car is trying to switch gears, it jerks. The only way to get this to stop is to turn the car off, remove the key (disengage the electric part) I believe it is an electrical problem, because the car will reset itself after the key has been removed, and one of the doors has been opened. I hope I have explained this. Thank-you
Well, I don't own a Buick, but all my Fords, and my Jeep had this problem. The problem was lowered resistance in the circuit allowing more current to reach that lamp, making it flash faster. The left and right circuits are parallel, and independent of each other, which is why the other side works fine and some other bulbs work in the same circuit. It's not the fuse, no lights would work if it were. If the car was ever hit, look for an open in the circuit where it was hit, using a test light, or an ohmeter. I think you are on the right track, you may have a blown bulb in the right side but from what you said, it sounds like its in the dash. Buy yourself a Chiltons or Haynes manual and check the circuit. Manuals are cheaper than mechanics. Good Luck. :shades:
Iignition switch in the column? Ask your dad if the switch feels a bit loose. This happens with a lot of GM cars. I doubt it would trigger a code either. Those things go when the keychain is extra heavy. My dad had a lot of keys.
It sounds like you have problems with the Pressure control solenoid valve (PCS Valve). My Century 2000 had the same problem, GM has a TSB on this, it affects the 4T65E Transmission. I had mine fixed, $615.00, but this car still has a lot of problems. Anyhow, I've got a serious problem of my own --
Last September, just after the car had the tranny work, it broke down. When it happened, I was turning, maybe going 10 mph. The car began grinding and shuddering -- this was coming from the engine area. It was loud. If you've ever heard a cell phone or electric shaver/trimmer in vibrate mode that was placed on a counter or table top -- that was the sound my car made -- only it was about twenty times as loud. Anyhow, the car began jerking badly. I hit the brake pedal but it kept pulling. The steering wheel felt like it was stuck in wet cement and I had to use both hands to turn it. The car kept puuling, then finally stopped and stalled. The car would restart, but when put into gear, stalled. The radio and headlights worked fine. Had it towed to the dealer. They could not find anything wrong; apparently the car started for them the next day. Whatever.
Fastforward to about two weeks ago. The grinding noise returned. The steering wheel was fine this time, but the car, once more, did not want to stop. I was going around 20-25 mph. The car stopped this time but did not stall. The noise grew louder. The light turned green. I took my foot off the brake and the car accelerated to 20 mph -- without my foot on the accelerator. I was on a flat road. Several seconds later the grinding stopped, and the car drove again. It did not return until This past Thursday, same thing.
Does anyone have any idea what this could be? The shop doesn't know, and neither does anyone else. Also, has anyone else had as many problems with their Century? This car only has 79,000 miles on it. Since September it has accumulated $2,500 in repairs, and it still has this problem.
Hey, I have a 1999 Buick Century with 98k miles on it and about 6 months ago the low coolant light came on so we inspected it and it looked like there was mud or clay inside the radiator cap. A couple people suggested that the dexcool coolant probably just mixed with some regular green coolant and that I should just get it flushed. I did get it flushed but never did check it afterwards and I noticed that it was running just a tiny bit hotter than it was before. Two days ago the light came on again and we checked the radiator cap again and same problem. Now it runs way too hot while it is idling but cools down to normal while driving. Think I got screwed the first time I had it flushed? Or is there a problem with the engine, perhaps, where the oil is getting mixed with the coolant to cause the brown muck? The engine and tranny are leaking some. Anyone else had any similar problems?
It sounds like Stop Leak to me. This substance has been used for years to stop leaks, and it works -- for a while. However, after this stuff has solidified and stopped the leak, the chemical make-up of it begins to change. It eventually turns to putty, breaks up, and floats around your entire cooling system. This putty-like material then clogs other areas -- areas never intended to be clogged. This can cause big problems! I bought my car used and it had this "stop leak" stuff in it. The problem is, when this stuff is first put in, it's literally undetectable. After a while, though, I noticed my reservoir tank and radiator cap had muddy stuff on it. This was the stop leak fluid after it had turned to putty. It clogged my intake plenum gasket. Cost to fix was over $1,000 as the engine had to be completely taken apart. Thank goodness I have that extended warranty!
If stop leak is the culprit, don't put anymore in, as it could get into other parts of the car outside the cooling system, i.e. engine. From your description that sounds like the culprit. However even when my car was losing coolant rapidly and had this leak, it did not run extra hot, so that part of the story has me scratching my head. Good luck with your car.
you are not alone my 2000 century does the same with a high pieced whining that sound like it is comming from the trans cannot pinpoint what is yet will let you know
I have a similar problem. just bought a Century 2000 a couple days ago and have the same problem. Sometimes I stop the car in traffic and the engine is still racing like the trottle stuck open or it still runs on high gear. Returning the gear to the parking position won't solve the problem. What made it even worse is that the car will abruptly accelerate when the gear switches from parking to other gears when this happens. I have this problem two times already among four days I own this vehicle. Anyone has any ideal what causes this and how much it may be to fix this?
The guy selling me the car is a fairly reasonable guy and we have some nice talk with him and his wife ... but just in case, I am in MA. Is there a lemon law covering severe mechinical problems. I have this car less than 6 days.
I have a 1998 Buick Century. It has had a vibration problem between the speeds of 45 to 55 ever since I bought it. The Buick Dealership said it was the tires. I bought four new tires and have had them rotated and balanced twice and still have the vibration. The people at Goodyear (where I got the tires) assured me it was not the tires when I brought the car back again to have the tires looked at because I was still having vibration. They said that there had to be something wrong with the car. I took it back to the Dealership and told them I had put on new tires and had had them balanced and rotated but my car was still having a vibration problem. When I called to check on my car they told me the tires needed to be rotated and balanced (for $180) :mad: . I told them I had just had that done (like two days prior) and that this was the second time I had brought in for the same problem. The Dealeship got amnesia and said it was the first time he had looked at my car and wanted me to bring it back for further investigation. That is what he was suppose to do the first time, not just make an assumption as to what was wrong. Oh well.
Has anybody out there experienced some of the same poblems and is there a cure?? :sick:
On three occasions now, my 2002 Buick Century would not start after I filled the gas tank. The engine would crank but would not start (almost like a vacuum lock). After waiting 10-15 minutes, the car starts and runs normally. The only thing the dealer could suggest was that there was a theft-deterrent device that would not allow the car to be started for 10-15 minutes. They made a new ignition key and reset the computer to solve the problem, but (of course) the same thing happened again yesterday when I filled the tank. Any suggestions?
This can be really serious. My wife had the throttle jam at 70 mph ofn the freeway, slammed on the brakes, exited the freeway at high speed, ran a stop sign and finally stopped it by throwing it is park and stalling the engine. This saved her and my kids but trashed the brakes and required over $800 in brake work. The brakes were so over heated that the hub caps melted. I talked to Buick customer assistance and they told me it was a used car so tough luck. I took it to the dealer and he says that the problem is the floor mat. It can get pulled down into the hole where the accelerator cable goes through the floor and jam it. The simple solution is remove the floor mat. I f you really want to keep the mat then you need to secure it by wiring it to the seat or something. You may want to train possible drivers about this and tell them yopu can put the car in neutral if this happens. My wife was afraid to do this because the though the power steering would fail and she would not be able to steer. I feel we need to notify NHTSA about this so would like to get your name and email so I can show this problem is more widespread than ust out occurrence.
Ok, First of all, YES I am a woman with limited knowledge on car maintenance and repair. I bought a 1995 Buick Century in March of this year. I love the car and it has plenty of space for my 3 year old son. Two weeks ago while i checked my oil and found it to be at the correct level, I noticed my coolant reservoir was a little dark. When I opened the top of it I was shocked to find oil in my coolant! :mad: I have taken my car to two places and called a few to diagnosis this problem. All 5 places I have contacted say it sounds like my intake manifold gasket is the culprit. Yesterday I took it in to have the intake manifold gasket replaced at 7:30 am. At 3 pm when my boyfriend called to see how the car was coming along, they told him that it would be done in the next 10 minutes, BUT there was a crack in my oil pan near the drainage bolt. They also stated that there was some tan epoxy type stuff that prevented them from taking the bolt off. They said they had to chisel it away to remove the bolt. Now when I bought the car, my dad inspected it over and under and did not see any epoxy or anything on the oil pan. Last week Monday I had an oil change done at Wal-Mart. The garage I took it to to get my gasket replaced is saying Wal-Mart did this. After I picked my car up I headed straight to Wal-Mart to have a discussion with them about this. They informed me that if the crack had been there, they would not have provided me with an oil change. They also stated that if there had been any type of epoxy on my oil pan they would have noted that. The tech that performed the oil change said he would have noticed the epoxy and then in turn notified his manager to that and stated it on the paper. They said the only stuff they use is torque seal. Upon Wal-Marts re inspection of my car, we found the oil drainage plug not to be tightened all the way and my car was leaking oil from the plug at a steady pace. He was kind enough to tighten it a little bit more only to have the oil start leaking even more. He said this was due to the crack near the bolt. I have a signed statement from Wal-Mart saying there was no crack in the oil pan and if there was they would have refused service on my car. I left Wal-Mart and headed home. By the way when I left the garage I noticed a knocking sound from the engine which got louder on my way home from Wal-Mart. By the time I got home( a 10 minute drive) I was leaking even more oil. To my dismay I noticed oil literally pouring out from where the oil plug was. So I called my boyfriend down to look at my car. The dipstick was not in all the way and there is grease all around my gaskets. Upon inspection of the coolant reservoir I got even more ticked off than I already was! It was still murky and looked as if they never replaced the coolant! :mad: Now the guy who worked on my car says he flushed the system. How is it possible he did this if I still have a ton of oil in there? I was told by a friend of my dad's that the garage most likely cracked the oil pan by not supporting it properly and is blaming it on someone else.... or they are trying to get more money out of me....I was also told by this same person, who by the way is a mechanic that it could be my oil cooler that is causing the oil in reservoir???So now I am sitting here afraid to drive my car with even more problems than when I took it in....And a hefty $537 bill that I feel I should not pay. This coming Monday I am taking my car to a Buick dealer to have it inspected.... Upon their inspection and me getting my car back, I will be filing charges against the garage for fraud with the DA's office.... Any comments you have with this matter are greatly appreciated.... I'm just trying to get some in site to what the root of my problem was to begin with.. oil in the coolant reservoir??? Thank you
There are several reasons you might have oil in the coolant. One of the reasons you mentioned. Another would be a lot worse. The engine block itself could be cracked. Depending on where the crack is (if that is the problem) it might not be that easy to spot. Mechanics are sort of like car doctor's, they look for the easiest and most common reason first and fix it. Then, if that doesn't work they look for something else. Taking it to a Buick dealership is your best bet for finding out what is wrong and how much it would take to fix it. Trying to sue the first garage may be just a waste of time and money. Even though you have a signed statement from Wal Mart that they did not see the epoxy or crack does not mean that it was not there. Don't forget that it is in Wal Mart's best interest to disavow all knowledge. That fact would not be missed by any juror or judge. I also have had bad service at Wal Mart upon occasion. Even a good mechanic will mess up now and then. But only the ones with a good character will admit their mistakes.
Get your car checked out by Buick and if the engine is cracked or the gasket not replaced, then you might could say that the first garage did not repair it or did a repair that you did not need (if the manifold gasket was not bad in the first place). Lots of Luck.
No one has answered my problem about vibration yet. I guess I am the only one with that problem.
well i had buick look at the car and they said that the garage that worked on my car did a crummy job replacing the gasket. there was dirt on it and they cross threaded one of the valve cover bolts! buick had to replace both upper and lower manifold gaskets, the lifters in my engine and the oil pan. they also stated that the crack in the oil pan was due to over tightening! and if wal mart would have cracked it i would have seen oil right away.but now instead of having a $500 bill i have an $1800 bill! so yes i am going to court cuz the first garage is still expecting me to pay the bill i have with them even tho the dealer had to redo the gasket.
Hi, Lately every time I try to start my buick the security light will stay lit for about 5 minutes. Its getting very frustrating because while its still lit, It wont start. We have to wait till the light starts blinking , then it will start. Can anyone explain why or have a solution to this? Thanks alot Dawn
Thank you JB! I have my car back and it is running beautiful! i file this coming Monday and I got a bill in the mail from the first garage. I opened it and laughed! I will keep you poted on what happens!
I am having a problem that it seems no one knows the answer to. Last week while driving my anti lock warning light came on and stayed on. When this happened, I lost the function of my power door locks, my headlights, brake lights and each time the car is started the clock reverts back to 12:00. I have checked all fuses and they are good. Has anyone else had a problem like this. I just cannot find a common link between the different problems.
I've had 4 fuel pumps put on my 99 century in the last 3 months. The first one lasted about a month... the 2nd one a few weeks... the 3rd about 5 miles and the 4th one a week .. Now can anyone tell this woman .. what the problem is ?? It turns over but it won't crank !!!!!! Its Driving me crazy :confuse: Any by the way thats the only thing I'm driving !!! So any of you Know what the problem might be ?????
Reference message #42. My 1995 Buick Century Electrical Problem is identical to your car problem. First it was the inoperative door locks and anti lock warning light. Two days later I lost the leadlights, brake lights and clock setting. All other systems appear to be operating efficiently. I bought the car new, now has 123,000 miles. No traumatic accidents, no flood damage, no lightning stikes, the vehicle has been reasonably maintained. Your insight into this phenomenon will be appreciated.
I have a 98 Buick Century. This year the air conditioning compressor konk'd out. It will cost at least $800 to replace. I figured not now, maybe later or maybe not at all as long as the windows work. Then, almost on cue my drivers door window goes on the fritz. Everytime I turn the car on it rolls all the way down. Then after a few seconds the up button will work and I can adjust the level, I just can't lower it as the down button doesn't work. I was afraid the motor was gone but the motor seems to move the window fine. I'm wondering if this is a minor chip or relay problem of some kind or am I looking at several hundreds of dollars to fix it. I'd like to know more about it before I take the car to a repair shop and have them tell me what's wrong, or tell me what will get them the biggest profit.
The abs warning light comes on when I start my 2000 buick century limited and it stays on. I had the brakes checked and the drums in the rear new installed. I had the electrical abs checked out. The warning light went out for a week. Now it is on again and stays on. Can anyone help me on what the problem is. Thank you for your comments. Rich
About a month ago, I had my fuel sensor replaced (fuel gauge was broken) at the Buick dealer to the tune of about $600. After that I have been gradually having problems filling my gas tank. I had the car back to the dealer (to replaced drivers-side auto window motor) and they checked the gas seal and said they couldn't find anything. Anyway, as soon as I start to fill up the nozzle clicks off. It has gone from bad to worse. Can get half a tank full then have to stop, and if I'm lucky can get it filled on the second try. Two days ago, however, I was just about on Empty and I went to fill up -- only got about 3 gallons in and the gas backed up and overflowed onto the pavement and my feet. The Buick service mgr is going to look at it this Tuesday and try to put gas in it himself. Just wondering if anyone else has had a problem like this and had a solution. Lately, it seems I'm putting more money into the car than its worth. Any feedback? Thanks.
I bought my Buick Century one year and four months ago. The first year was fine with 65,000 miles and two owners. After the second year, I have replaced the starter. Replace the compressor so the mechanic says twice, (meaning two separate mechanic completed the AC problem. Two weeks latter, the AC stopped working. It's the rings the said. Two weeks latter after making home with no problems. The next day the car will not excelerate over 10 mph. I had to turn the car off to get it to go 30 to 40 mph. Finally I park at at repair shop that stated the could not run a computerize scan, but felt that the transmission was gone along with the gears. Shocked I transferred the car back to the dealer that refuses to give a written estimate but says that it is the transmission and gears. When I asked for a written estimate they have refused. I totally feel that they are not being honest. They seem to be afraid to give a written estimate. :sick:
46000 mi
keyless entry
cruise
cassettee
ABS
1 owner
he is firm at $6100
thanks much!
Jeremy
Deke
Joel
than 6 days.
Lots of Luck.
jfb
Jbankston
Instrument panel lights would flicker and car would stall.
My check engine light did not come on.
Turned out to be a bad alternator.
The car would stall and would not restart for a few minutes.
AbeStreet
I am guessing that the electrical problems were due to the low battery.
