Mechanical issues:
1. Lockouts changed at 70K
2. Motor to shift to 4w changed at 75k
3. Blown spark plug out of cyl. head at 85K
4. Constant issues w/electrical
a. Fuel gauge shows empty when full sometimes
b. Passenger door powerlock doesn't always work
c. Overhead console display shows empty tank when full;
d. Shows 200+ miles left when tank low
Overall, I've spent more money on this truck than all the Toyotas I've had combined. That includes 1 that went 225k, 1 215k, 1 98k (current), 1 150k
PF Flyer
We called Ford manufacture also. They are not going to do any thing. We are checking other options to see what we can do about this situation.
Does your truck have over 24,000 miles on it?
Your not alone...
The F-250's that you're seeing on Ebay are the larger F-250's that shared the bodystyle with the F-350's and the '92 thru '96(or was it '95?) F-150's. The 250's and 350's changed their bodystyles with an early '99 model, which was really in '98.
I coasted off the road and when I came to a stop with my foot on the brake the engine died. I waited a minute and started it up and took off again about 3 miles later the same thing happened. Took off again stopped at a couple of stores with my brother following me. We switched trucks and he said he lost power but it did not cut off. Also I started feeling dizzy and sick after driving and noticed a fume smell coming in through the dash vents with the climate control on. Will take back to the dealer tomorrow. Has anyone experienced anything like this? I know they had a lot of problems and claims with the engine but thought they were all resolved now.
A dealer up there found a bad EGR valve he said. Since replacement it has been fine. Mine does it so infrequently now that it doesn't even bother me, I never noticed any dramatic power loss on the road though.
I've heard people describe these engines as rubber burning power-houses? (I must have got the sister engine).
Anyone using a chip? I'm trying to find something to give it a little more grunt on take-off.
I can state from experience that Ford is not very responsive on power problems. They refer to them as 'driveability' issues. They fight tooth and nail to keep from paying for engine repairs - at least that is my experience. Partly as a result of this deal, I got a new Dodge Cummins 2 months ago. Good luck.
Coloradod, Mine is an 04 w/6.0L automatic. Jim, I see what you are saying about the RPMs. It does come to life at that point; I was just investigating something less expensive than the intake/exhaust solutions you mentioned. What I wondered is whether or not a chip could get the turbo up any sooner? I thought I saw something about how the pitch of the turbo vanes was adjusted by the computer? Or are we solely depending upon the exhaust flow here?
The electronic variable response turbocharger (EVRT) on the Power Stroke uses a set of pivoting vanes that surround the turbine to optimize and control an almost infinitely adjustable airflow to the turbo compressor. When traveling at high speeds, climbing steep grades or at altitude the vanes close together to route more airflow through the turbine. At low speeds the vanes open to provide better engine response.
There is a great cross-section photo of it at http://palmettotruck.com/6ldiesel.htm if you're interested.
Where I am, they change over to a winter- blend diesel that resists gelling up to a point. But this past weekend we had -10 degrees, and the wind was gusting to 50+ mph.
All it takes is someone to screw up somewhere along the diesel fuel distribution system for the station to get a poorly blended/treated batch. If their tanks are in the ground, they will not know there is a problem until you put the fuel in your tank and let it cool. Diesel fuel should be treated for the region of the country that it is sold but, it is apparent by these posts about fuel gelling every winter that the proper treatment sometimes does not happen. Treat your fuel yourself or take your chances!
Diesel Fuel Additives go by names of Power Service, Stanadyne and several others. You can find them a big-truck stops, and even Autozone, PepBoys & Walmart sell their own brands of diesel fuel treatment that's also an anti-gel. (Read the label of the store brands, avoid them if they contain alchohol) These will additives will prevent gelling from starting. However, if you've been stopped because of gelling, there's a product called Power Service "911" that will dissolve the wax and get you running again. Comes in a bright red bottle. Pricey, but worth it if you start to gel. Of course a 1/2 a bottle of regular Power Serve at each and every fill-up helps. If you're using good quality blended fuel, conditioner, and filling up at about 3/8 of a tank, your doing all you can. Buy your fuel where the big rigs go, at least you know that they have a high turn over of their product and the pro truckers will let 'em know real fast if they got a bum load of fuel.
Hint: Dead give away that you may be in trouble for gelling is if you see ice crystals in the filler neck after removing cap...moisture is present, and you need to address this or pay the price. Hope all is well with your rig. Winter is tough on equipment.
The I.A.C. - Idle Air Control valve is probably the culprit - it seems to be the weak link in all the modular engines. It gets clogged up with carbon, etc. then motor won't idle worth a darn.
Is check engine light on? When valve gets bad enough, the engine will usually start reporting error codes.
Repair is relatively easy, and part isn't that expensive.
If it itsn't the IAC, check for dirty air filter, and leaks in one of the vaccuum lines.
The name of the business is Diesel Injection Services and they are out of Texas. I have never received anything less than excellent service from them and their prices beat anything I can find locally.
Where are you getting your fuel? I would try another supplier. You need to buy your fuel from a truck stop that turns over a LOT of fuel on a daily basis. C-stores and "mom and pop" stations are notorious for having water in their fuel. I get my fuel from a truck stop that sells over 10k gallons a day. Not only has my light never come on since I switched to this truck stop, I have pulled my tank and found no water there either.
Thanks again, Eric
Put a bottle or two of Diesel Fuel treatment into tank to suck up any water in there. May have to change the fuel filter again afterwards as well.
Try to buy your fuel at busy stations where big rigs go. Small convenience store stations can cause you trouble because they don't turn their fuel over fast enough.
