Lincoln Town Car Maintenance & Repair
1356737
  • salu74salu74 Posts: 1
    hey, i m having a problem with my 89 lin, town car. ok there is a cooling line(hose) from motor to inside the car (somewhere behind solve compartment) and there is a censor in the middle of that line. 1st can anyone tell me wut it is called , ok now the censor or wut ever it is called is broken. and all the coolant was leaking from there. i cant find that part. so can i like just join both the ends with a coupling and make it direct?
  • beernutbeernut Posts: 329
    I'm guessing its the heater control valve. You can bypass it but the heat will be on all the time. Or you can plug both ends and have no heat at all. In my younger day, I did it all the time for emergency hose leaks, etc.
  • garsarnogarsarno Posts: 72
    Thanks for the detailed solution. My '99 leaked on the driver's side last year - now it is the passenger side leaking.
    My '99 Town Car has high piched squeaky brakes and now at 65 mph, when I brake, the car pulls strongly to the left. Had the front pads pulled, cleaned and a coating of anti squeal applied. Looking for help with this. Thanks...
    Two options:
    A) The left side pads are not releasing. Can we assume that, if the pads were removed and re-installed, that they have adequate life left? Depending on how the front pads were "pulled", the guides may or may not have been serviced and may not be sliding freely. There is also a chance that the left slave cylinder is binding and not fully releasing due to internal corrosion or gunk.
    B) The right side brake is not working. Limitless causes.
    Thanks. Taking your post with me to my service tech. Also was told to try the right side caliper sliding mechanism may have seized. The driver side rotor is darker than the right side. Heat....
    Worked on brakes today. Replaced front pads with ceramics, bled brakes, cleaned up the calipers, did not use as much grease on parts, did find air in system. Drives smooth / stops straight so far. Thanks to all for the help..
  • guessguess Posts: 3
    I need help,Please read message #33, The car won't start at times, extensive testing of fuel system, ignition system & etc. When car starts it runs great , will use car to go to local store,shut off car ,shop,then try to start car ,won't start. Dealers can't find problem,they look at me like i'm crazy. I called Lincoln's customer service and they haven't any service bulletins,recalls or etc. If any of you guys or gals have any information that may help,please let me know. THANK YOU!
  • tc94tc94 Posts: 3
    I am going thru the same thing with my 94 tc. No way
    is it the weather conditions. When i have my problem
    there is not starter engagement and really NOTHING when you try
    starting the car. Today it would not start then i tried again 5 minutes later
    and it started up NO problem after I put it in N and then back to P. I have gone months without any problems
    here are my theories.
    1. An electronic fuel pump issue. It seems it happens
    sometimes soon after fill ups. after one trip to the repair shop(no charge), it was his guess,but no
    problem at the time thus he found nothing.
    2. The electronic brain. This happen to a friend of mine and it was hard to catch by a
    ford dealer.
    3. Sometimes it helps to start if you jump the car. It is not a loose batttery/cables etc.
    Any other theories? Fuel filter is new.
  • Update to my earlier posts-Reviewed 1040, 1045, 1049, & 1052. Took the T/C to a dealer-diagnostics came up #24 on the climate control. Replaced the blend door motor and the blend door. Same problem- turn on A/C after a few seconds blows max hot air. Blend door just keeps going to max. checked diagnostics #24 again replaced the motor and climate control. Same problem- they called FORD- must be a ground. Tried 2 days of trouble shooting. No luck- tried the disconnecting everything. Next they said replace the entire wiring harness. I said stop there. Currently have the blend door unplugged and have A/C for the summer-Have to reconnect for heat in the winter. Ford tech support told dealer if you figure out the problem call them back and tell them what the problem was. Don't have anymore $$ for the wiring harness repair and don't know if that would fix it. Tired of shooting in the dark. Any suggestions?????????????? [email protected]
  • tc94tc94 Posts: 3
    1.EEC relay(on drivers side under hood in plastic box. Switch with ac/relay or horn relay to see if it helps.
    2.Corroded battery terminals and wires.
    3. Possible anti-thief replay that affects starter sole. switch
    tc94 says that "guess"'s no start condition is not due to the weather - "no way" is what I think he said. He also says he is going through the "same thing" as "guess" is with his own car.
    The only thing similar between "guess"'s problem and tc94's problem is that they miss appointments because their car won't go. Otherwise, tc94 is NOT going through the same thing as guess.
    I still believe there is a strong chance that guess has a weather, moisture or other ignition conductivity problem.
    tc94 is likely correct the HIS problem is not weather related.
  • nvbankernvbanker Posts: 7,285
    www.FlatRateTech.com - they are really good at diagnosing these types of problems for you guys.
    http://www.flatratetech.com/
  • hemsley1hemsley1 Posts: 21
    this may seem like a simple problem, but how the hell do you change the wiper blades on a 97 TC. there is not enough clearance to lift the wiper blades, they hit the hood. I'm sure it is something easy but i cant figure it out. thanx in advance
    It's a [non-permissible content removed], all right, and I wish I could tell you how, but I'd have to work on it for an hour myself each time I try to do it. For the love of Mike, I wish the engineers would simplify this process for owner service.
  • euphoniumeuphonium Great Northwest, West of the Cascades.Posts: 3,425
    They are easier to work on when out of their bull pen.
    Wet the windshield
    Turn on ignition key
    Turn on wiper switch and when the blades are just out of their resting place, stop them by turning off the ignition switch.
    that helps - then it only takes about half an hour to figure it out.
  • mytcmytc Posts: 7
    The headlights on my 99 TC are very dull and have condensation on the inside. I have tried drying them out, but with time the moisture comes back. This is getting to be an issue as the lights are no longer as bright at night, and they no longer have the same brilliant look. Any ideas?
    Drill some small holes in the bottom of the plastic asserbly to ventilate & drain them. It should help. Your only other alternative is to replace them.
  • tc94tc94 Posts: 3
    For the last two days it was no start first thing in the morning. I kept on hittting the unlock button on my remote and Slowly hit the ignition again a couple of times. This did the trick. Where
    can I locate the anti-thief relay switch?
  • b737mikeb737mike Posts: 1
    The remote radio volume, station select, am/fm, temp control and fan speed rocker switches that are located on the right side of the steering wheel are not working on my 1996 TownCar. The cruise control cluster on the left side is working fine. I believe they were working last week. Just had the car detailed and now they don't work. Is there a possibility a fluid got behind the switch cluster and needs to be either cleaned or dried out. Is this a part which can be easily changed out. Any way to test the cluster or do I just need to by a new one and go from there.
  • eventmaneventman Posts: 1
    Greetings:
    I find the same problem with a 98 Town Car. Has Ford Acknowledged this issue? Much thanks for your attention as I await your reply.
    Maurice Newsome
    My neighbor's Excursion did the same thing after an open-window rain storm. He waited for it to dry out and it worked just fine, BUT, it took almost two months.
    I would like to thank every body who tried to help me with this problem,I thankyou.The problem turned out to be at ignition switch cylinder, there is a small switch called a " starter interrupt switch" which triggers the interrupt relay (part of the anti-theft system) thus causing the engine not to start. Replacement is simple, Remove the lower cover behind steering wheel,press release pin(1/8th pin) and remove ignition switch cylinder, you'll have access to interrupt switch. I hope that this information helps any body who may have the same problem. Again, THANK YOU ALL!!!!
  • i have a similar problem, the difference that the a/c on my '01 LTC blows cold air about 70% of the time. I will be driving down the road and all of the sudden i can barely feel the air coming out of the vents. The fan is still blowing but barely any air coming out of vents, odd. Generally, I have to stop, turn off the vehicle, cross my fingers, and re-start the vehicle and hope the problem goes away. I have taken the vehicle to several mechanics and then the dealer for diagnostics, none can find anything wrong. 70% would not bother me, but this Arizona summer is difficult to deal with without the other 30%. Any suggestions.
  • adagioadagio Posts: 1
    I have a 1998 Lincoln Town Car which is maintained to the nines. The problem is the automatic climate control air conditioning system. Problem only occurs when ambient temperature is high (above 90). When the dash says 65, hot air blows out of the heater vents. Change dash to 60, cold air blows out of center vents. Change back to 65, hot air blows out heater, center, or defroster vents. Volume of air seems lower than normal. Entire blend door assembly, computer control head, and ambient temperature sensor have been replaced by the dealer. All pinpoint tests so far are normal. Now we are waiting for a Ford engineer to look at it. Everyone is trying, but living in Florida I'm getting worried. Any ideas?????
  • tonyk1tonyk1 Posts: 1
    I had a Prestige Remote Engine Starter installed on my 2003 Lincoln Town Car. Whenever I use the remote control to lock the car, the burglar alarm goes off in 5 to 20 minutes. I have already taken it back to the original installer, as well as to a local Chicago-area tech several times, and it keeps happening. Anyone else have this experience, or more importantly, know how to fix it? Thank you!
    i own a 97 towncar signature, and it has the landou roof or carriage top, or whatever you call it. anyways. above the windshield there is a strip of the carriage top that always works itself out, and when i'm on the highway air gets up under the carriage top and makes some noise, if i stop the car and push that weather strip above the windshield back in, then the noise stops. i guess i want some easy way to make sure that strip stays in and stops working itself out, if any of you have a carriage top and know what i'm talking about any input would be appreciated. thanks in advance!
  • jjuddjjudd Posts: 1
    I have a 1991 TC. There seems to be a problem with the ACC. It is stuck on 85 degrees all of the time. I changed the whole ACC system with a part from the local pull and save but still have the same problem. I had the system charged today for the AC but the problem still lies. Any ideas? ">
  • demandeman Posts: 1
    I have a 1990 Towncar, and the Message Center above & right of the steering wheel is showing the outside temperature to be -15 when it's about 75 degrees out.
    Any ideas??
