Visitor Agreement.
While I am driving suddenly the car will jerk and the volt light will display on the dash. The car will come to a complete stop. Sometimes it will start right back up and then some times I may have to sit for 30 minutes before it starts again.
If I am going to have him rebuild it , how do you go about flushing torque converter, cooling sytem plus external cooler I have installed (HAYDEN).
If I am going to spend all this money I would at least hope to get (OR THE PERSON I SELL IT TO) more than 15k miles out of it.GRRR
Before proceeding, I'd be interested in any advice anyone has regarding this procedure. It seems a bit hazardous to unhitch 2 engine mounts, and try to raise the engine appox 4 inches in order to access the pulley on the water pump. I will not be replacing the timing chain as this was done recently.
Any advice would be appreciated.
Paul
88 Corolla LE 4 DR sedan 290000
https://www.automedicsupply.com/index.php?
There should not be that big a difference in price for comparable sensors. Make sure you are comparing the same ones aside from the connectors. :mad:
Then turn the key to crank, the test light should light up.
If it doesn't, then you have a problem from the ignition switch.
Let us know what you find.
The security light should light up for about 5 seconds and then go out, does it?
Paul
You need to watch silicone on any surface that shares with an oil galley or path. One fat chunk of silicone sucked into a small engine oil galley and your engine could suffer.
I prefer a thin coating of grease on the gasket and that's it.
Make sure that you scrape the silicone completly off both surfaces and inspect for nicks etc after cleaning.
I've replaced dozens of pumps using this method and never had a leak that wasn't due to my carelessness
Thanks. :confuse:
Especially at that cost?
-ss4
Is this true of some make of cars more than others, does anyone know?
I HAD to replace the brake fluid in my volvo every 30k miles or the pedal would get very soft.
If that fails, I would suspect the master cylinder...unless...unless...the rotors were cut rather than replaced and the cut was too much...that will stress the brake calipers.
Any help appreciated.
email me at: smartstart@townisp.com
Thanks for your help.
Thanks for your imput!
I assume you are planning on just putting snow tires on the front. But, ya know, rear tires can lose traction just like the fronts can. Go around an icy bend and that rearend can come right around on ya.
Don't get me wrong. If you are anywhere south of North Dakota, I am of the opinion that, with FWD, you don't need snow tires at all. A real good set of all-seasons will do ya just fine. But if you need to get snow tires, you really should get them all around. Nothing like uneven traction to cause problems.
I think you'd be surprised what could happen. The best traction control and ABS systems in the world can't help gain traction when there is no traction to be had.
I'm just saying, I think its a mistake to have better tires up front than in the rear. I'm no physicist, but it seems to me this could actually cause MORE unstable conditions. In other words, I hit a patch of ice and my trusty snow tires keep the front planted but ... uh oh ... there goes that back end.
to answer your question ... i also used to be able to buy steel wheels from the junkyard for cheap. Problem is, junkyards have become scarce (all turned into high-priced housing these days) and more and more cars come with alloys instead of steelies.
i think you had it right the first time looking on Ebay, personally.
