Visitor Agreement.
Our 93 Camry Le 2.2 4cyl with 286,000 miles it driving us nuts. The problem is that whenever the car is placed in drive or reverse and you aren't moving, it vibrates bad, unless you increase the rpm's a little, but even if you rev the engine, it vibrates more than it used to. This is my dad's car and he is an ex mechanic and know pretty much aljl things about cars. He thinks that it might be the balance shafts in the engine, but this car has so many miles, i dont think it's worth it. The engine has never been replaced or had major work done. We know that it isn't misfiring or running rough.
Here is all of the repairs we have done to try to fix the problem : motor and tranny mounts, plug replacement, all fluids replaced(not for the prob. but just maintenence), and we put a bottle of gum out fuel system cleaner in, all to no avail.
This car is amazing. In its 13 year and 300,00 mile history, the only repairs we have done, all recent, were drive axles, water pump, radiator, a couple of batteries, front exhaust pipe, and battery cable clamps.
So what do you guys think??? THis is my car in 5 months and i dont want to give it up.
Brad
A leaky manifold doesn't always mean coolant is in the oil, but it can.
Since you have already had is looked at, and it was very low on coolant (1 gallon is a lot to be low) then it's probably been diagnosed correctly and the only real repair is to have the manifold repaired.
If the coolant is very low then the heat can be as you described. The coolant level is below the level needed to effectively keep the coolant from circulating through the core.
Is it a 3.4 Liter engine?
I saw on several internet sites that it is not normal to have problems with the manifold until around 90 to 100K miles? Is that true? We have just over 37K. Warranty just ran out about 2 months ago.
Goiing by that wording..., it sounds like a leak where coolant is going to the outside of the motor since the mechanic said "looked like."
If that's the case, the coolant level will just get lower and lower. The heater is probably the highest point in the water system and that's where the air accumulates so no heat.
Where you had water spots on the pavement, was that an orange brown color? It would leave a color on the concrete for a while. If there wasn't a color, it was air conditioning drip. That would show up afteer the car had been driven with the air conditiioner on and then parked.
Do not add any sealers. That's especially true if you might have the system worked on. All those will do is clog up the heater's tiny passages. GM has a sealant that's organic in pellets that are added when the system is refilled. They're available at GM parts counters. I add two every time I change my antifreeze at home-every two years.
I would look for a second opinion.
Code 25 means that there is a lean fuel mixture, so i'm almost positive your fuel pump is bad.
I know how to replace the pump on your model, so if you decide to replace it your self, i'll give you some steps. It's actually easy.
Then, some kind of relay got stuck, whenever the outside temp dropped to around freezing, and the electronic locks would go on/off all night until the battery went dead.
Solved that by pulling the negative terminal each night before bed. Next day she'd start fine.
No problems (even with the neg terminal connected) all this past summer.
We got home after a short trip last week (1st day of cold weather). No mechanical problems.
But, got up the next day and it wouldn't start. Not a click, not a sound. Thought it was the battery, so I replaced it with a brand new one, but to no avail.
In fact nothing much works now but the H&L beam headlights.
I've checked every fuse I can find, under the hood, and in the dash. Only a couple of them have "fire"...
Inside: Only the Rear Defog (all others = no signal)
Under Hood (on Driver-side/right of batt): Anti-skid; Grill Trail; and H Lamps (all others = no signal)
I'm at a total loss. Don't even know what else to check, since I'm not much of an auto electrician.
Is there a "main fuse / relay" that would allow for some of these points to get batt power, and not others in the same bank of fuses?
If so, where/what is it?; how do I check it?; how do I replace it?
I'm desperate...thanks in advance!
Thanks Tony
tonymacchiaroli@yahoo.com
Good luck
I found this set of steps that should apply to your supercharger on the net.
Supercharger Oil Flush/Change
This procedure is for Series I (92-95), and the procedure is the same for the 96-03 M90, other than the location of the plug.
Go to the Pontiac dealer and buy 2 bottles of Supercharger Oil P/N 10953513. If you're not going to flush the cone, one bottle will be more than enough.
Pull the smaller of the two covers off the blower, on the pulley end of the supercharger (passenger side of the engine compartment). You'll see a small plug (1/4" NPT if you know your plumbing sizes) out of the nose cone assembly (you'll need an allen wrench). You don't want it hot, but make sure it's warm. Wipe any debris or dirt off the nose cone in and around the plug before removal.
Put a Jack under the Front A-arm or sub-frame on the driver's side and raise it. This will force the oil towards the pulley end of the nose cone and make it easier to suck out.
Get 2 large syringes from your local drug dealer or farm/feed supply, and some 1/4" tubing from the auto parts store. A foot will do for each syringe. Press the tubing onto the end of each syringe, and use one to
suction the oil out through the fill hole.
Refill it with a clean syringe and tubing, not a funnel, cuz you have to see when the oil reaches the bottom edge of the threads.
Re-install the 1/4" NPT plug in the nose cone assembly. If you're flushing (reccommended), start the car and let it run for a minute or two, and repeat step 4, always using one syringe to empty, and the other to fill. The last time you fill it, let it off the jack (level car) before
filling it.
Re-install the wire harness cover.
TKS
Should I add fluid, or take the van to a dealer?
Dennis
Usually there are 2 lines on a brake fluid resevoir, so just make sure you are looking at the correct one.
It must be sensing a significant speed difference between the wheels.
I pulled the fuse to the pump it was so annoying.
The cables going to the wheel sensors look ok.
Any ideas?
96 Dodge Intrepid.
Don
Mike
1) Are there different types of fittings and could my grease gun have the wrong one?
2) If I haven't been greasing it what damage could this do & what symptoms might it cause?
3) How much grease should you give it on a regular basis and if I haven't been getting any grease in how much should I give it now.
4) Is it typical for grease in a grease gun to seperate and a yellow liquid to leak out of the grease gun? Thanks...
Probably this fitting is for the driveshaft to slide on a spline. Hard to say what, if any damage might occur, but if you could get a small deep socket and remove that fitting and install a new one, that would probably solve your problem.
These are called "zerk" fittings I believe.
Here's where you can buy a zerk fitting cleaning tool:
Zerk Cleaning Tool
Here's a place where you can download pix and specs for all common zerks:
http://www.gen-aircraft-hardware.com/template.asp?pagename=grftg
The ABS light does not come on.
