Visitor Agreement.
Volts matter as regards electrical "force"....our bodies just aren't that good a conductor...
Anyway, here's what the car talk guys say about it---maybe you can get a little "tingle" out of a 12V battery after all!
http://seattlepi.nwsource.com/wheels/269701_talk12.html
the resistance your body presents to the battery is a function of many of the things i already mentioned before. if your skin is very dry, chances are the resistance will be orders different (more) than if you are perspiring (where it will go down). when dry, your skin presents fairly high resistance to a voltage source, and therefore not much current flows. But, if you perspire, the equation (values, not relationship) changes.
I = V / R is what it is - it's not a theoretical vs. real-world concept as the entertainers on the talk radio make it out to be. No offense intended; i'm sure they've probably forgotten more about vehicles than I'll ever learn about them.
I know, if R decreases with V fixed, the current flowing in a circuit increases. Get R (the resistance in ohms) in the correct range, and the I (the current in amps) can result in a shock.
When I'm disconnecting a car battery, I'll continue to remove the (-) first and when re-installing, connect the (-) last. Maybe I'm being overly cautious, but maybe I'm not. There's nothing to be ashamed about if you exercise caution.
I really hope we might dispell the notion though that it's the voltage that bites you. It's the current, and it's the current path through the body which influences the outcome of an event. Is there by chance a cardiologist who happens to be a car geek lurking here in edmunds land who would confirm this for us?
I like the point made by bolivar on the current the battery is capable of delivering into a small resistance and the risk of bodily burns / injury.
regards.
My wife has a 99 Malibu. It has a "noise" while driving that is hard to explain. ALmost like a roar. It is not too loud. To me it sounds like it is coming from the right front wheel. It is there even if while cruising you put the car in neutral. It seems to go up in pitch as you get faster and go down as you get slower. I rotated all the tires to see if that would help, (putting the front tires in the back and the back into the front). It did not seem to help very much. I also took the break pads off and cleaned then and the rotors. There was plenty of padding left on the brakes.
I did notice that while cruising at highway speed if I turn the wheel to the right I can make it a little louder while turing.
ANy idea what this would be and how to tell? My guess might be a cv joint? My Hayes manual says a symptom of that is clicking or grinding while turning but this does not sound exactly like that.
By the way I also with the car jacked up pulled on the wheel before taking it off and did not feel any play. (I thought that was the right way to tell if a wheel bearing was bad.)
I have never messed with a front wheel drive car very much so I am not sure how difficult it would be to replace if this was it. Autozone has a unit for 70 bucks. What is involved in replacing one? (If that is my problem).
Also, on this 96 Chevy truck I noticed I have a coolant leak that is difficult to find out where. Last year I had the radiator checked and plugged. But it does not seem to be coming from there. I feel "wetness" On the water pump outlet to the lower radiator hose. I think the hose is only 1 year old. "Replaced it when I took the radiator out."
Could it be leaking where the water pump bolts to the block? Every other water pump I have had go out it would leak out the weep hole. Maybe the water pump bolts have loosened causing it to leak where it meets the block?
Anyhow I appreciate your advice and Merry Christmas to you and your family!
Don
does ANY 4-year-old have braces? ;b
The question you should be asking is, "what else could it be?" As you said, a CV gives different symptoms. You've checked the brakes. So I'm not sure what else it could be.
Elsewhere I've read that if you jack up the car under the body with the regular jack and spring the wheel you can feel the bad bearing by putting your hand on the front bumper. I'm not sure you're going to feel looseness. It's the bearing surface that has a bad spot instead of wear along the ends of the bearings that would leave more looseness.
If it's a rough growl and you feel it in your feet and the steering wheel that would match my 93 when it had a bad bearing at about 80 something K miles.
I jacked it up and could not feel the tire "move" when pulling.
Any ideas guys? The car has 94,000 miles. Is it hard or expensive to change the bearings? I have changed wheel bearings before, but it has been awhile and was always in a rear wheel drive car.
I can make it worse for a second by turning the wheel quickly to the right at highway speeds. This is my wife's car.
By the way, to me the sound sounds similar to a truck with mud tires going down the road at highway speeds but no vibration.
In car repairs, guarantees are not always made. Sometimes, all you can do is take all of the symptoms into account, eliminate as many possibilities as possible, and make your best guess. Sometimes, the only way to know for sure is to make the repair. If it cures it, you know you were right.
Oh, and when doing the old "let's do this and see what happens" method, start with small stuff first. If you are doing it yourself, the part shouldn't be too expensive (just don't buy it from the dealer). So, worst case, it eliminates one of the possibilities and only cost you a couple hundred bucks at the most.
By the way, did you get to spin the wheel while jacked up in the air. Obviously, you want to make sure nothing is rubbing while turning. Brake shields, for instance, have been known to get out of whack and rub.
I took mine to the dealer and the mechanic who test drove it with me commented that it was a whole hub replacement on that model year and that I could do it myself lots cheaper. He almost implied he'd to it at home for me.
He did the diagnosis by swerving left and right.
I did have X-One tires on the car that had hardened the rubber with age ( all tires do ) and had developed a sound just like a front bearing--even with vibration from the front. I put them on the back and still heard the noise from the tread on one or both tires.
Mud tread tires on a work truck is a good description of my bearing on the 93 leSabre.
Was this a car similar to mine?
It is funny, we just bought new tires for this about 6 months ago.
What is involved replaing the hub?
Someone on a 2000 had to use a wheel puller to pull the hub off the axle--those are available for Autozone he thinks. You might price the job at a local, quality mechanic to see if it's worth all the trouble for yourself. One post said there was a cap or something over the 35/36 mm nut like a dust cap or something.
If you do a lot of your own work you might check into a factory service manual for the specific car. I'd suggest Helminc. They have a half price sale until December 31. malibu service manual
I've bought them with each new car (almost) through the years from 1977 Cutlass on. They're much better than Motor or the other one that's a cross general manual, in my opinion.
You might check websites loike Autozone and pepboys for their repair help sections. One might talk about wheel bearings.
For all the work I'd want to know that bearing was the one giving problems. I had seen mention of a transaxle bearing or gear making a noise on the Bonneville 60 and 65 model transmissions. That's why I suggest being able to feel the vibration or looseness before replacing. The one inside the transaxle housing also is repairable but more work.
Does anyone know if I have to "re-program" my remotes or whatever, for an old Clifford Alarm? I have this alarm on there, I don't know what it is, or who put it in (I got the car used at auction).
I tried using the spare key once when I couldn't find my other ones, and ever since then it sems like the remote ket doesn't work. But I've switched keys before and had no problems, and never had to re-program anything.
I am with you, I would like to find out exactly what it is before fixing it. I can try to jack it up again but I really can feel a vibration from inside the car, just a noise.
That was gonna be my question!
Heck, I have an expensive torque wrench borrowed temporarily from my father and that doesn't go nearly that high, either.
I do my own work, too, but I read up on changing the hub on the volvo and determined it was not worth it. I believe the part was nearly $200, so paying the shop $350 was not that tough of a decision for me.
A neighbor up the road does lots of mechanic work and he just sort of eyeballs it with a pipe on the end of a regular socket. If you use a total of 3 feet, then you would push down with 75 pounds of force. 75 X 3 = 285.
I'm with letting the quality guy who does it a couple times a week change it out. I had the dealer do mine because they give free loaners off the used car lot if you bought yours there and we needed the loaner since we both were working.
I don't see how that works ... how does the wrench know you put an extension on it? And, it it did, wouldn't the "click" point change based on where you are holding the wrench? Granted, I'm not an engineer, but I'm just not seeing this. Is there a reference I can read?
I understand what you are saying regarding force. But with a torque wrench that clicks based on the force at the head, I don't see how this can work. 100 lbs on a torque wrench should always click at 100 lbs.
I think a nut on my 94 Ranger front suspension was about that value. I just used a breaker bar with a pipe extension and pulled with all I could pull. That seemed like 284ft/lbs to me. Nothing came loose in the years after that.
another
ok ... here ya go:
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=3184&group_ID=362&- store=snapon-store&dir=catalog
I ended up having to rent a van for the remainder of my trip, so they could finish the repair. When I got my van back, it seemed to work. I went about 100 miles, then the same thing happened. I took it to another dealership, where they said the PCM was shot. They replaced that, and said that the Chrysler engineers told them to replace the RCM as well, which they did not have in stock. The van seems to work fine now.
What would cause this, and is it "normal" for this to give out in that fashion? I read somewhere that the PCM has a federally mandated warranty of 80,000 miles which would be good news for me, as my van has 49,000 miles on it, and is outside of the mfr warranty.
Thanks in advance!
Try Googling these to find out more.
http://www.helminc.com
'I posted this under another topic but I'll repeat it here. Assuming the battery and charging system are ok, they one thing in common with this is the BCM. Before you go running to dealer to have this exspensive part replaced, I know of one person (elsewhere) that fixed very similar troubles by cleaning all the connections to BCM with product called 'DeOxit' (electrical connection cleaner) and ensured connections were tight. This person also did the same with all the fuses/relays in nearby fuse box. When cleaning around relay #23, they found what was possible arcing (short) to nearby ground plate and after cleaning that, he put a small strip of electrical tape over that area. He has not reprted any troubles since that I know of.' Good luck
So in a nutshell, I replaced the clutch, and 1000 miles later, it started having the same problem.
What could cause a clutch to break? I'm thinking alignment, wheel bearings (I do get some front end vibration at high speeds), pilot bearings, bad CV joint... I don't know. Seems like something on the way to the wheel that's out of whack and stressing out the clutch. Does any of that sound plausible? Anyone else have any idea what could cause a clutch to go out, or do we think it was improperly installed?
What do you all think?
In my opinion, the clutch wasn't installed correctly, or the throw out bearing wasn't replaced or was replaced with an inferior part, or that wasn't the problem to start with.
i'd probably get a good strong flashlight and a big mirror and attempt to see if i can locate any wiring harness / connectors behind the assembly that look as though they are loose.
perhaps a pull-it place has a dash assembly you could look at to find the location of the connectors.
but, maybe by looking at one at a pull-it place, maybe the odometer is a module or a "daughter-board" or an LCD display which is connected to the main dashboard / motherboard with some sort of multi-conductor ribbon cable. if so, the problem could be one of the solder joints to the ribbon cable.
perhaps fiddling with the wires will be enough to remove mechanical stress that may be making the circuit intermittent.
shifty, i think you're right, they wouldn't want to make the ODO too easy to tamper with, but i suspect the display is on some standoffs or on the end of a ribbon cable, and the smarts and memory are on the main board. just a hunch.
I don't believe based on those symptoms that it is a fuel problem. I recently replaced the control module in the HEI thinking that might be the problem. I don't know what other components could fail that would cause an intermittant problem like I am having. Could it be a compression problem where when the car does fire up, oil goes into the cylinders and improves compression, thus making the car start for the rest of the day? Anybody have any ideas of what could make my car act this way? Thanks
I believe that could explain why the car runs poorly as the fuel sitting in the intake manifold is sucked in with the new fuel already rich for cold running from the choke...
It seems to me there was a problem with the plugs they put into the holes used to drill the main fuel passages. It seems to me they didn't quite seal and needed epoxied...
I may have my carburators mixed up from the 80s before fuel injection took over everything.
I assume you've checked the spark at a plug by laying it on the intake manifold and cranking cold. You also might have a float running low due to aging of the needle valve seal.
I'd do the cold check for fuel. If you don't want to take the bowl cover off (I don't recall the steps) you could let it sit a couple of days and then remove the air cleaner and push the throttle linkage to see if much gas sprays out into the throat of the carburetor. You should be able to drown the motor by repeatedly pushing the linkage. If it runs out of fuel after one or two pumps, that would tell you there's no fuel in the bowl to the proper depth.
Has anyone seen this happen? Any ideas would be appreciated. Thanks MPSLICK
Also I've read that the rocker arm trunnion should never rest in any area that was threaded.
