Visitor Agreement.
I know each car is different, and that there are many variables, meaning some belts may last less than 105,000 and some more, perhaps considerably more. Deferring replacement of the belt may mean that I may only have to replace it once instead of twice before the car wears out. I'm willing to take some risk, say, a 10% risk that the belt will snap between 105,000 and 125,000 miles (20,000 additional miles is 19%, so I would assume that Honda engineered at least that much margin into its schedule), but if the chances are greater than 10%, rather than less, that the belt would fail, I'd opt to change the belt at 105,000.
I know this is not an exact science, and there are no guarantees, but I would be interested in hearing from anyone with knowledge or experience on this matter.
As for the case of the disappearing oil, it can't just disappear, of course. It had to have gone somewhere. To leak out in that time, it would have to be a major leak and I'm sure noticeable. To lose that much through a blown head gasket would have resulted in the car running VERY poorly ... again, because of the speed at which it dissapated. SO to me, that only leaves burning it off. I still think you should have had some running problems, though. I mean, to have THAT much blowby would mean, I believe, extremely low compression in 1 or more cylinders.
Your mechanic still can check the compression, by the way. the car does not have to run, it just needs to turn over with the starter. That would be my first place to look.
Incidentally, in what may seem like an inconsistency, I follow the recommended maintenance schedule for my car, but am just questioning this item.
It wasn't running up to par, but I thought all it needed was a tune up. It still would haul b_____, just not like it did.
I appreciate the suggestions and am calling him momentarily to tell him your thinking. If it were you, would you continue with the car (rebuilt engine) or let it go? I'm looking at $2500 for the rebuilt.
Thanks so much for your help!
If it were me, yeah, I'd probably NOT rebuild it and put that $2500 towards something else ... but i'm a chronic car buyer, so you shouldn't listen to me.
Wow. Never heard of anything like this.
I hope someone replys that knows what you are talking about!
I've had 67 & 68 Camaros and don't recall anything like that on them.
did you recently replace the battery? possibly the engine has some idle re-learn procedure you must go through.
was in the car. I got in the car and pushed on the brake pedal and there was no change.
Remained on. I unhooked the battery cable. Could the switch fail in the on mode ? Easy to replace ?
Get under the dash and look for where the switch is, and determine yourself whether it is within your technical capabilities. All depends on what you are comfortable doing.
Sure would like to see a picture of it though.
The only thing I can think of is that it is some kind of accumulator. Does it have any hoses going to it?
Can you get a pic of it? I sure would like to see it.
Is there any markings, like a name or numbers on it?
It is a fairly easy job. I don't remember all of the details, though.
I guess if you are the one driving it and it's all local, then a reasonable risk. If it broke on my daughter and then overheated the engine.....not a risk worth taking.
It would take you what, 10 minutes to replace?
When to replace belt
james
According to the link the superfical rib cracks are normal. I believe the cracking is consistent throughout the entire belt though. The link stated if cracks are within an 1/8 inch all the way around belt may need replacing. So, I'll take another look at it. I still have the old belt from when it was replaced 3 years ago in my trunk, so not really concerned with break downs... mostly local driving. Still you would think you would get more than 3 years out of a serpintene belt.
4 cyclinder
standard
130k
Trying to install clutch cable- need directions can't figure out how to hook up :confuse:
So you could have blown a fuse, air pump could be bad, computer control bad, a solenoid could be bad, an air tube could have broken or come loose, the suspension position sensor could have gone bad or become loose, or the shock could have gone bad.
I'm not a DIY'er on belts, so they're really not that cheap to replace.
Thanks Again
Thought it was a squeaking belt, but got worse when the A/C was turned on(especially when engine is cool). Overall performance of the car is fine, and the A/C works fine, also. Can you change just the pulley on the compressor, or do you have to replace the whole thing? What is the difference between one with, or without a clutch? When I looked up the part on AutoZone, Kragen, etc., they offered both. Which one is better, and will they both work?
Thanks in advance.
Let's say you hit a curb and bent your wheel. You can buy a new wheel and mount your old tire on it. Or you can just buy a new wheel/tire unit and just replace the whole thing.
Thanks again.
I went back and read your original post. If the problem is a noise, then you need to figure out what it is that is causing the noise. It could be the compressor, but it could just as likely be any of the other accessories or pulleys. The easiest way I've found to do that, is to take off the serpentine belt, and start the engine just to make sure that the noise is gone. You do that by finding the tensioner, taking the pressure off the belt, and then sliding the belt off. If the noise is still there, then it is something internal to your engine and you need to get it to a shop.
Assuming however that the noise is gone, then turn off your engine. Slowly turn each of the accessories one by one, to feel if it turns smoothly and there is not any play in the bearing (either side to side, or in and out). You can usually find the problem device fairly easy this way. Look closely at the tensioner and tensioner pulley, which is the device that puts the pressure on the belt.
If the problem is indeed the AC compressor, unless you've done freon systems before I'd recommend taking it to an AC shop. They'll have to evacuate the system before replacing the compressor, and then fill with the correct amount of freon pressure.
By "freon", do you mean the old R-12 refrigerant, or are you using the word freon as a generic term from "refrigerant?" The reason I ask is that I'm virtually certain the '94 Lexus ES used the R-34, which is the new refrigerant used in all A/C equipped cars today. R-12, or freon, was the term for the old refrigerant.
So now all I have to do is get him to run a new air line.Feels good to be off the ground.
