Visitor Agreement.
I’m trying to find a good way (online data?) to estimate the maintenance expenses of a 2003 Taurus ABOVE 75000 miles. Basically, I’m trying to decide if it is more cost effective to keep my current car and drive it till it drops or trade it in on a newer, low-mileage used car with some warranty left on it.
The difficulty I’m running into is most sites offer an average maintenance calculator based on the overall life of the car (I.e. $0.59 per mile average for the life of the vehicle) but I need to try and estimate how much my maintenance expenses will go UP now that the car is getting up there in mileage.
Now, the next step....how do I determine if it's the alternator or A/C pump(the only two things driven by that belt)? Like I said earlier, it sounds TERRIBLE when the A/C is turned on, but it cools good, and the battery charging system seems to be working fine. Any tips on determining that?
Thank you again for your help.
If a pulley bearing is bad, you should be able to feel it. It won't turn smoothly, can bind, or will be able to slide in and out on it's shaft. The a/c will be different, because unless the clutch is on you really aren't spinning the compressor.
I think I have to ask about your symptoms again. If there is NO noise with your engine running (and a/c off).....and then when you turn on the a/c the noise appears, then the a/c compressor is suspected to be bad.
If you have SOME noise with the engine running (and a/c off)....and then when you turn on the a/c the noise gets louder, then I would suspect some other pulley. When the a/c is turned on, it puts a lot of extra load on the belt. If there is a marginal pulley, it would be louder with extra pressure on it.
So with your belt back on, no a/c, do you get the noise?
Engine cold:
squeaking is there, and gets real bad when the AC is turned on
Engine warm(normal temp):
No noise, with or without the AC. it sounds pretty much normal
Drive belt removed:
No noise at all
There isn't a tensioner pully for that belt. The tension is adjusted with a bolt system connected to the alternator. Only the AC, alternator, and crank pully for that belt.
NO.......NOT THE MAIN PULLY! As I said, when it's warm, most, if not all of the sounds disapear.
Thanks again
There is one thing you should check is working correctly first, though. Make sure that the ac clutch is disengaging when the ac is off, and engaging when the ac is on. When the ac is on, it will most likely also cycle on and off (which is fine). I'm looking specifically for the clutch to be un-engaged when the ac is off.
Assuming that is correct, then follow this logic:
- With the ac off, what is spinning is the main crankshaft pulley, the alternator, and the clutch piece of the ac. The internals of the ac compressor shaft isn't spinning.
- With the ac on, what is spinning is the main crankshaft pulley, the alternator, and the internal ac compressor shaft. The clutch isn't spinning because it's locked up.
- Your crankshaft pulley isn't the problem, because it doesn't make noise without the belt on.
- Since you have a squeak whether the ac is on or off, then most likely it has to be the alternator. In one case the ac compressor shaft is spinning, in the other case the ac clutch is spinning. It's unlikely that you'd have both the clutch AND the compressor shaft go at the same time.
Assuming that the clutch is engaging and un-engaging correctly, then your noise symptoms occuring with ac on or off would point you to the alternator.
That's my story, and I'm sticking to it!
Early '90s suburban with the 5.7. Service Engine Soon light flickers on when idling and warmed up, then goes off when you hit the gas. Thoughts? This is different than a CEL, correct?
I have been having a problem with my car that has been on and off. The dealer seems to be dumb founded when it comes to fixing the problem. The problem is this. The cars ASR light and soon after check engine light come on after driving the car for about 5-10 minutes. The code reader says that the car is running lean. I have since replaced the MAF sensor, which seemed to fix the problem for a few (summer) months. Now the surrounding temperature is going down and the problem is back again. I do not want to bring the car back to the dealer because they can not fix the problem and they are not cheap for wrong answers. Please help. If i can not solve this problem, i will be trading this car that i like into the dealer.
Thank You,
A V-Dumb owner
The other question I have is; How do I determine if the AC clutch is, or is not engaged, when the AC is off, as you questioned earlier? Visually? How it sounds? How it spins? What is the best(or only for that matter) way to determine this?
Thanks again for all your help.
So what you are saying now, if I read your last post correctly, is.....
- When the AC is turned off completely, you hear no squeaking.
- When the AC is turned on, and the clutch is picked...you hear squeaking,
- When the AC is still turned on, but the clutch disengages....the squeaking stops.
If that is your scenario, your compressor is bad.
When the AC clutch is disengaged and just freewheel spinning, then the noise disappears. But when the clutch pic
Bad AC clutches often "chatter" when engaged, like a sharp "chirping" sound that is irregular. I've never heard an AC compressor make a steady high pitched whine, but I guess it is certainly possible.
I have a 2000 Chevrolet Venture LS van with 120k miles on it. It has recently started making a horrible popping noise under the front end (i call it firecrackers as this is what it sounds like).
I 1st noticed it while idle at stop sign 1 day. I had to look around for kids....thinking someone had lit a box of firecrackers and thrown them under my vehicle. It stopped, only to return lasting longer and louder.
Thanks in advance for your comments & suggestions!
Is it really loud, like an exhaust manifold/pipe problem?
In July I had my oil changed. I always have put 10W30 Quaker State oil in it since brand new every 3,000 miles per the dealership(I drive 98% city), however my car with the increased mileage has been burning oil (about a quart every 1500 miles). I asked the technican about it and he indicated that since it was summer and my car had high mileage that putting 10W40 in it might help the problem. He indicated that as the weather got colder I should switch back to the 10W30 (he went into a long explanation) So I agreed to the switch. With the 10W40 my oil burning decreased to a little less than a quart every 3000 miles, I got fantastic gas mileage (25mpg city, which is all I drive). My engine was really quiet and ran fantastic.
Now since my last oil change I switched back to the 10W30. I am once again burning a quart of oil every 1500 miles. My gas mileage has decreased as well. My engine has started to have a slight ping noise. The engine just runs rough.
Now at the same time our gas stations switched back to the 10% Ethanol mixture. While I can't attribute the oil burning to that, I am wondering if the cars newest ping/rough running and significant decrease in mileage (25mpg city down to 21mpg city) is due to the oil change, colder weather or the gas???? Can I run my car with the 10W40 to prevent oil burn during the colder months or is that a no no????
You may want to run a compression test and see what the internal condition of the engine is. You may be coming to the end of it's economical life. 165K is a lot of miles for a four banger, which has to work hard to keep up.
That wasn't what I wanted to hear, lol!!!!! I was just reading that the average passenger cars life is 9.2 years. I guess mine beat that average so I shouldn't complain. I'll just drive the stupid thing until it blows up, lol (but I think a compression test would be worth while).
Your car engine can burn oil for a long, long time as long as you keep adding it. Oil burning isn't the Death Sentence by any means, unless it gets really drastic. Once you start gobbling 1 quart in less than 1,000 miles, it's probably time to start shopping.
I'm kind of surprised your oil consumption changes so drastically just by changing viscosity of the oil. It's not like it changes to mud. This makes me suspect your valve guides or valve stem seals, because these relate to oil as it acts under gravity, as opposed to leaking past the piston rings entirely, where the oil is under pressure and less likely to respond to changing viscosities.
My driving recently to VERY short trips - it often doesn't get fully warmed up (I know, I know - that constitutes abuse.) But the mileage stayed the same for awhile and only recently took a major dip (from low 30's to low 20's). It's like there's a hole in the tank (there isn't).
My mechanic, who seems pretty sharp, can find no problems. Tires are fully inflated (and more).
I've been accused (by yourself actually) of under-revving it. I never lug it, but I usually use it pretty gently, in an effort (misguided perhaps?) to make it last. Then again, sometimers I need to acelerate, and I utilize almost all the revs, like to 6000, 6500. I've redlined it only a few times in all these years.
Did he check the fuel pressure? (Fuel pressure regulator may not be working properly)
Did he check exhaust flow? (A partially blocked catalytic converter can cause those symptoms)
Just some thoughts to throw out there.
The cat is fairly old. I'll look it up in the records. That sounds like an interesting line of inquiry. I'll ask him if he checked the fuel pressure regulator and fuel filter.
Or some other changeover to "winter gas?"
Could this be the culprit?
I appreciate everybody's help. It's a strange quirk.
I'm going to check with my guy and ask exactly what he is and isn't testing. Maybe let the local dealer conduct a diagnosis too.
I should probably also post my problem in a Civic-specific discussion in case there might be others who have experienced this.
No leaks and not a whisp of tailpipe smoke. This car has the spunky 3.8L
all it needs is some RPMs and it moves okay. Isn't coolant loss usually a very undesirable sign?
They can do a pressurized radiator test to see if you have a leak somewhere, can also do a cylinder pressure test to check for headgasket problems.
Hopefully you can get out of this with just hoses and clamps, flush, and refill....but I'd definitely be watching it closely to see if I can find the leak.
If this is the case you can't repair the radiator, it has to be replaced.
I believe you should find and fix the problem, as opposed to putting foreign leak fixers in it...but there are some situations where you might not have any other choice.
Check into a product called irontite Ceramic Motor seal.
http://www.irontite.com/adds.htm
It is fairly widely used in the diesel field.
Seems to work very well, at least in the applications I have used it in.
Mostly heavy truck and marine.
This car is a 1996 Volvo 850R sedan, automatic trans with 5 cylinder 2.4L turbo engine / + or - 96,000 miles.
Over the weekend it developed a very noticeable tapping sound that appears to be internal to the engine. I can't tell if it's coming from the top or bottom of the engine... The problem occurred while accelerating to enter the interstate while the turbo was producing about 15PSI. The tapping sound is consistent with increase and decrease in RPM's. Other than the tapping sound, the engine appears to be operating as normal - no misfiring , hesitation, knocking etc.
The car has been maintained very well. The current oil is Penzoil full synthetic 10W30.
Can anybody offer suggestion as to where to begin? Is this a known problem with this engine? Could it be just a valve adjustment or something broken? Any info will be greatly appreciated.
Thanks!!
