Visitor Agreement.
Where can I find that piece of information? I have heard that 99 escorts don't have timing belts but timing chains. Is that true? Thanks
How can I check wether Gates is correct or not?
Thanks in advance and Happy Holidays!
Does the atmospheric sensor sound like BS? I've never heard of it before. Also, we asked that they leave us the old parts, but they conveniently "forgot".
Any other ideas what may be causing this problem?
Power is pulled from the battery by starting the car, and the alternator pushes power back into it by raising the voltage to the battery.
When it regains its full charge, the alternator stops charging, and the voltage read is the battery voltage, which would be about the 12.9volts you mentioned.
Everything looks good here to me.
filled the #3cylinder with coolant.I assume the head gasket blew or the head cracked.The engine smoked bad out the exhaust.After shutting down the engine for a few minutes,I could not turn over the engine until I removed the spark plug.Overall,the vehicle is in excellent shape.Due to its age I am wondering if it's worth repairing and what kind of problems can I expect inside the engine.I would appreciate ant comments.
I appreciate all your help,
The Greasemonkey, more commonly know as Dave..
The example of the controls that are noticeably lighter are Maintenance Required, Left and Right blinkers, open door indicators for both Left and Right doors but not the Rear doors. I am curious if his odometer has been tampered with or this is a typical Honda problem? If somebody somehow messed with the milage, will the onboard computer show it? We do not want to take it to a dealer unless we know for sure that they can actually tell.
Any input is greatly appreciated
On the other hand, there are "hundreds" of engine reman/rebuild companies that say nothing about that, and will sell you a remanufactured engine.
With 200,000 miles on my Rodeo, I would like to start thinking about a new heart for her.
So, any ideas or knowledge about this? Rebuild the engine I have, a used engine or a remanufactured engine? Thanks...
You might be able to buy an entire, very decent lower mileage 97 Rodeo for close the price of an expertly built engine. Figure a used engine, by the time you've done everything necessary "while we're in there", is a $2,500 proposition at least.
Even if it has a mechanical odometer, it is unlikely that it would affect the rest of the dash.
I understand what you are saying about a new engine and the rest of the vehicle still being old. I am looking at options right now to see which direction to go. I believe that should I keep the vehicle, I will go with a used engine rather than a reman. I have this rolling restoration thing spinning in my head!
Thanks for helping me with that part of my decision. pjs
Now if you are going to follow this plan of attack keep in mind that you should look at the other major parts as well, it's best not to wait until they fail, but to go at them as you can afford them. The entire steering system, gearbox, ball joints, tie rod ends, center/drag link, idler arms, all will need to be gone through and replaced, along with your bearing plates if it's a 4WD. Then there's the rear end, nothing lasts forever, the axle bearings an seals should be done along with a good check of the ring and pinion gears they are probably ready to be replaced. Now for the springs, after a 200K mile beating they have to be sagging and bobbing around. Even after changing all the major components are replaced you still have a truck with 200k on the dash, and now you can plan on the electrical system getting some gremlins in there.
My realistic estimate on the whole deal broken down:
Engine/Trans rebuilt $3000
Engine/Trans used $1800
Steering $ 600
Rear Diff $ 500
Front Diff (4WD) $ 400
Transfer Case (4WD) $ 450
Springs $ 750
Paint Job (average) $1000
So really to do it the right way to are looking at around $3700 on top of the engine & tranny replacement, add that in and you get $6700 w/new or $5500 w/used. For that kind of cash I'm sure you can find a much nicer ride with a whole lot less miles, and not have to deal with the hassle of being w/o the truck wile it's in the shop for each stage of the make over. Maybe a call to "Pimp My Ride" would be in order if you are really that attached to the old rodeo.
I just had one installed in our Pilot last week. I can tell you that I'm not very happy with it. Due to the factory alarm, the only way to operate it is to unlock the doors with the remote before starting the car. So I strongly suggest going with a whole new alarm/remote start that will eliminate the factory alarm altogether.
You would never guess she has that many miles because she does look that good inside and out. Still shines up like a diamond. I think thats what the problem is. (besides bad credit, thanks ex!)
She has done me so well for so long, I can't imagine not trying (having) to keep her on the road.
I printed off what you guys explained that would need to be done. Obviously, I need to think about it more and my options. Haven't you ever had a set of wheels you smile at and glance back at when you park and say thanks for the ride sweetie!? Thats the relationship I got going.
Hope this isn't a closet thing or something.
Thanks again for the input!! pjs
The owner's manual should describe maintenance intervals and should be correct.
periodically. When it occurs, the rpms will slowly drop and I will be unable to accelerate.
Upon forst experiencing this I changes the fuel filter and added a supposedly good fuel injector cleaner.
My wife is in transit as I write aftewr traveling some 600+ miles and she experiencing
extreme hesitation.
Any suggestions? I read something about cleaning
the throttle body. Is that just a matter of removing the air intake and spraying ether into
the carburator?
Need help ASAP!!!
Chris
I have a 99 nissan sentra gxe that i recently bought. i changed the oil when i got it and filled it up with chevron 10w-30. When i first start the car after sitting for awhile, the oil light flashes - probably from .5 - 1 second. I know that the oil light flashing is normal, but it just seems slightly longer than on other cars i've had. Do you think the .5-1 second is a problem? Should i use 5w-30 or a better brand of oil?
the other thing was that when i hit a bump in the road, something will squeal - at first i thought i was my horn going off, but i think it is something in my suspension. what could it be?
thanks,
N
I'd tend to think that most severe ignition problems tend to stop the vehicle or make it run so badly as to be undrivable, so I'm going to lean toward a fuel related issue, component or sensor.
thanks for the reply..
What is a mechanical oil pressure gauge?
What is the "old sender" and how do i swap it out and "clean the wire connector."
thanks for the tips
"Idiot lights" are merely simple electrical circuits which light up when the sender or sensor in the engine is "tickled" by oil pressure and grounds itself to the block, thereby completing the circuit and light the light on the dashboard.
Soooooo.....if you pull the wire off the sending unit or sensor that's screwed into the engine, and you ground that disconnected wire, the dash light would light.
So an "idiot light" basically tells you only "pressure or no pressure" but not HOW MUCH presssure.
Any help?
What kind of paint does my car have? I didn't know there were so many types of paint. What are the positives and negatives of each? How much is a reasonable price for a paint job that is in the same quality neighborhood as it came from the factory?
I have had quotes from $200 on up and I don't have a clue as to the options i have.
Don
You can get a "decent" temporary paint job that might look good for 3 years for less, or you can ruin your car by spending under $1,500.
Would you also tell me the types of paint? Household terms would be 'latex' or 'enamel'. The paint shops were offering multi types of paint and I have no clue as to what is what.
Don
Shifty your Host
http://members.tripod.com/~bobstory/faq.html#Automotive%20Paint0
