Visitor Agreement.
sdman, who said I used a book?
They have higher gear ratios available etc, and even a differnt tranny available as well I think.
The only 'gotcha' is that from the factory, you can't order one with any type of bed.. So you have to go to an upfitter to put the bed of your choice on, (flatbed, pickup style, dumptruck, utility etc.)
This is what you saw..
What many folks who have big RV's are looking for is bascially a factory orderable F450 that has a bed on it already..
I figure mid-September is the longest any of us allocationless people are going to have to wait for a 2000 SD.
Has anyone heard what in store for the 2001 SD?
Ordered 12/10/99 F250 SD, SC, 2WD, SWB, V10
On a good note, I found an underground website on FORD News........www.blueovalnews take a look at it.
There are several companies that cater to the RV crowd and customize F-450s and F-550s, primarily for towing 5th wheels. One such company is Fontaine which has a shop in Kentucky very close to the Superduty factory. No coincidence there. I'm pretty sure you order the truck from Fontaine, rather than a dealer, and then they get the truck from Ford, put all the goodies on it and call you when it's ready.
It's not inexpensive to add the goodies. The Fontaine package I saw include a low profile bed, fiberglass moldings all around, running boards, fifth wheel hitch, and auxilliary fuel tank. The cost was about $7,000. Add leather and other interior goodies for about another $2,500. Add air-glide suspension for about another $4,000. You can find less expensive customizations, but most of the ones I've seen raise the price of the truck up into the $55,000 range.
I have to believe Ford can do it cheaper at the factory and I have to believe the demand from the RV crowd is there, but you never know. Maybe it's not. I can see them justifying not offering options that are on the F-350, but I do believe they will start making F-450 Lariats in the not-too-distant future that have all the options the F-350 has, including a standard size bed. If someone doesn't want a bed, they can opt for the bed-delete.
As Bess mentioned, another thing I'm hoping they offer is a taller axle ratio like the 4.30 (for the V-10)or 4.10 (for the PSD) rather than the 4.56. The taller ratio will reduce the tow rating for the F-450, but the tow rating should still be greater than the F-350. For someone like me, an increase in tow rating is not why I would be considering the F-450. I would want it for the increase in GVWR for carrying a heavy slide-in truck camper. The axle ratio won't impact that and, by offering the taller ratio, I won't have to sacrifice mpg for towing capacity I won't need. For those who need the increased towing capacity, they can opt for the lower axle ratio (higher number).
One of the reasons the F-450 probably looked bigger is because they come with 19.5 inch tires I believe instead of 16 inchers.
Ordered 1/20/00...200? F250SD, SB, V-10, auto, Lariat, 4.3LS...gotta stop. My tears are dripping on the key board...
btw, i don't know the mossey ford ph# off hand, but it is in the 619 area code. if you are interested, give them a call. regardless, sympathies and good luck to you.
So, what are your options:
- wait.. although your dealership must be outside of their allotments so the wait will be very extended.. You should ask for your $1000 back in any case.. (There's no requirement from FoMoCo for a deposit, my dealer never even asked for one).
- Check out other dealerships.. (even online ones). Most can 'drop ship' them to your local dealership.. Some folks even take trips a few hundred miles to pick up their truck..
How immediate are your needs? Do you currently have something to pull your trailer/horses, how long will that vehicle last you?
Heck, send me/us the list of all your order option codes, I'll be at my dealership tomorrow or the next day (having my truck looked at now), I can stop by and see what my dealer says about order times and availablity.
As for 2001 trucks being built in June, I don't think so... I seem remember reading both here (I think) and www.ford-diesel.com (I'm pretty sure, title is '2000 Super Duty balance out' by Louder) that the last day that 2000s will be built is July 28. 2001s won't start up for a few weeks after that. Sounds like potential non-builds are 4x4, crew cabs with auto trannys and 7.3L, 6.8L, 5.4L engines (yeah, that doesn't make sense but...
This came from a Ford dealer in Texas so some of the above may be a southwest regional commodity issue and not apply nationally.
Check your E mail, was too long to post here. Bottom line, I just talked to Brian at Courtesy, and he is sure he can get your truck for you and have it drop shipped. He said V-10 no problem, may be a hold up on the automatic.
Bob
Mainecowgirl: Extremely sorry to hear about your problem. I think the V10 is the culprit.
You folks know the difference between a Fairy tale and a Tall tale? A fairy tale begins "once upon a time..." and the tall tale starts, "You ain't gonna believe this s**t."
Well, you ain't gonna believe this s**t... (but it's true-that's the other disclaimer) I was cruising down I-75 yesterday, going 60-65 with no cruise or a/c on in the beast-baby. I started to wonder about whether the gauge was wrong, so I stopped to fill up. 15.22 MPG-amazing. I was dropping altitude slowly all the time from 800 down to about 200' over 259 miles.
I ran through another tank yesterday afternoon and this morning going UP I-75. 13.3 MPG @ 70 on cruise. If you average the 13.3 and the 15.22 you still get 14.25 or so. I'll take it.
Not too shabby for a V10 CC, 3.73 LS, 265s, 4X4
Now since I suppose I am one, I can say this: Know why they don't put "black boxes" on redneck 4x4 owner's trucks? Because after every crash, all you'd ever hear would be "Watch this!"
bowhuntwi: I think maybe your truck got shipped by the same crew that shipped lewac's truck. Sounds like it's going back to KTP.
Gosh: too much to catch up on.
Question: Do Husky mats form-fit the floorboards in front? If so, where do I get them? An ho3w much are they? The Ford mats are puny.
1. When was the SD ordered
2. My order is taking too long
3. MPG
4. How good my SD looks
5. How strong it is
6. Should I go with v10 or deisel
My god! Can't we talk about any other thing about our SD's than these bland topics?
I know I will get flamed for this, but oh well...
The owners manual says to use 5w30, that seems to be a little light for our S. Texas summers.also, 14.3 mpg on last fill-up.
sunscreen.... Just do what I suggest to folks that don't like certain TV programs ..... change the channel .... the program won't miss you a bit and you will be a lot happier.
Open to suggestions sunscreen. None were forthcoming in your post. You eliminated mpg, power, gas vs diesel, and how to get one, which limits the remaining topics. My leather seats are pretty, even after an Alaskan summer of fishing and camping.......
sunscreen- what would be worth more, a 5 pound box of $10 bills or a 10 pound box of $5 bills.
And thanks for the email....will reply...so sunscreen doesn't have to pour over another topic that is boring....although I think I might have the record for most topics not related to the SD's......
And sunscreen...have you ever posted in here before....If you have...it must have been sooooo interesting that I just forgot about it.....
It is so nice to have my bumper aligned....no big cracking noise when hitting potholes and speed bumps.......
All-When I wrote last night that I had to stop because my tears were falling on the keyboard I was saying that for a little comic relief in light of this TRAGIC situation, but tonight you all did me in. I had to go and get a Kleenex!! I have never felt so cared for in all my life. I came on board here right around the time that lewac was having his troubles, and I was amazed and so heartened at the outpouring for him, and now I'm feeling it coming my way. You are all just the best. Thank you.
I received two very helpful e-mails today with leads on trucks in Denver and Connecticut, which I will be following up on. Bear with me here and I'll post my exact configuration: Y2K F250SD, SC, SB, 4X4, auto, V-10, 4.3LS, Lariat, captain's chairs, ESOF, sliding rear window(no privacy glass), cass./cd, trailer tow pkg(no hitch), power tele. trailer mirrors, 235bsw tires, dk. torreador red. Was given invoice price of $28959, but since I have since decided against the accent color it would now be $28767. There you have it.
I do have a '93 F150 that's pulls my trailer very nicely on the short hauls so I am in no screaming hurry to get this new truck. And you know what they say...good things do come to those who wait. Again thank you one and all for your words and good deeds. Sorry for the length!
Service manager called fairly soon after.
He said that the computer chip supports multiple octane fuels, and mine was set wrong..
So he set it to the proper octane..
The work order says quote:
'Correction: Road test vehicle BO codes ran oasis called hotline instructed to set fuel octane retard timing let customer have truck'
My result: No change, (It actually feels like I might have a little less power, arg, but this might be while the computer re-learns how to work).
The ping is the exact same as it was before.. Obviously they didn't drive the truck after the fix.
Also, my cig lighter is now missing.. I don't smoke anyway, but don't want the hole there either.
I left a message for the service manager specifying no change in symptom, the missing lighter and I'll call back to re-schedule for another look, and I'll need a loaner this time..
This sounds like a 'nit' problem and many folks wouldn't think twice about this sound. But I've heard that pinging can cause engine damage..
Also,as they say they test drove the vehicle and called the ford service hotline, I assume that they heard the same sound I did, and determined that its not normal for the engine to do this. So I'm confident they'll figure it out..
Still waiting to hear from my dealer that my 00 F350 CC is in their building and that we can pick it up, instead of it traveling the countryside with out me, built 2/18?
Also I was wondering if anyone had any suggestions on weather we should get an extended warranty with the 7.3 PSD?
I also bought the Husky Liners for my F250 Lariat. Like crazyelvis, I was not, well, crazy about the tan ones (I have the Lariat interior). Bought the gray ones instead. They look OK, not great, but OK. If I ever want to show off the truck, I'll probably pull them out first :-)
I agree that the stock Ford mats are really cheezy looking.
Paid $108 for the two fronts and rear at a local OffRoad shop (did not buy the third one to cover the hump).
They do a *great* job of keeping bad stuff off your carpet.
I will watch the site for further info on bedliners, cab steps, etc. while I wait. Thanks again to everyone for the info and suggestions, I am happy with my choice!
250SD SC 5.4 5spd 4.10ls etc
mainecowgirl-glad to hear that you are handling your setback well. What kind of trailer do you pull. My wife has a 2300 lb. Belgian horse and would like to know what type of trailer you would suggest.
Catch ya later.....Have a Great Day....
Mainecowgirl....hope your search at alternate dealers goes well....I know there is a truck lost somewhere in Illinois right now....maybe you can re-direct it towards Maine.....sorry bowhunt....
Where is lewac....missing his "boring" posts...ha ha......
$82,000 for 5 years @8% is $1662.00/mo. Pocket change for the "king." :-)
The best price I have seen for the mats is from Bass Pro Shops. Front liners are $50 for the pair, $40 for the hump, and $50 for the back seat liner. It will cost you shipping but no tax if you live outside Missouri so that is a break even. I wouldn't pay for express shipping since my orders have arrived in just a few days using regular shipping. These are listed in the 2000 Master Catalog and I believe that they are also available on the net at www.basspro.com.
Mainecowgirl: My sympathies!! I agree that I would get my $1,000 back regardless of your decision. You have already demonstrated good faith and that is what the money is for. I'm curious, if you leave your order in place, will it automatically roll over to 2001. If so maybe you will get one of the first 01s off the line and then all of us "haves" will be jealous!
'00, 250 sd, cc, 4X4, swb, white/gold, v10, auto,
1650 miles mostly in town @ 11.6 mph.
idahoan, extended warranties. Check out www.ford-diesel.com , there have been many discussions on the wisdom of extended warranties as well as pricing and third party extended warranties.
all on the floor mats. I agree, couldn't believe how cheezy the factory floor mats are on a vehicle that costs that much. I got the Catch-All mats since the Husky all-plastic look didn't catch my eye. Color was a good match and cover most of the carpet (unlike those factory floor mat imitations
Has anyone had the same experience or do you think something is wrong?
