Dodge Dakota - III
This topic is a continuation of Topic 861....
Dodge Dakota - II. Please continue these
discussions here.
Front Porch Philosopher
discussions here.
On the opposite side of the spectrum we have very SKINNY tires. Anyone who has driven in snow will tell you that SKINNY is the best tire to choose for maximum traction. The idea here is to let the tires 'cut' through the snow to get at the road surface for maximum traction. Floating on the snow is the LAST thing one wants to do.
(In fact when some people first saw my Dak. The very first comment was "gosh those are big tires... arnt you afraid of poor traction in the snow?")
What are my qualifications on driving in the snow?
I learned to drive in a 4x4 and have at least one 4WD in the driveway at all times since then. Driving in the snow is a way of life here in Vermont.
:'-P
I've done a bit or research on the topic and have come up with these ideas (not specific to the Dak)
Spray-in
Pros:
Seals out water, dirt, etc.
Does not "take up" cargo space
Becomes part of the bed, no shake rattle and roll while you are driving (this is both a noise thing and a scratch the paint thing)
Cons:
They are part of the bed so if you drop something heavy it can dent your bed instead of cracking the liner
May chip or fade (most are warrantied but...)
Drop-in:
Pros:
If you drop a heavy object it cracks the liner not your truck (and they are usually warrantied)
Usually have some kind of cargo space dividing slots for 2x4s so your bed has "compartments"
Cons:
Can scratch the paint while moving around or everyday if installed incorrectly.
May cause noise while moving around.
Dirt and water can be trapped underneath and cause erosion and eventually rust.
Takes up a little of the cargo spacing.
Also, if you are a drop-in person, do you have a perference on brand or over-rail/under-rail?
Thanks alot for your help!
--TI
Visited dealer and got info etc.
2/8 Went back with intent to buy. Could not find one with options I wanted. Salesman checked into ordering, informed me it was on restriction, (I neglected to get details), but could order anyway without time of delivery estimate. Decided to think it over.
2/10 Decided to order. Went in, he put it in the system and it came back with no restrictions.
2/24 Called dealer, got order number. Called DC, 4x4s on restriction. Customer Rep had no details, suggested call back next week.
2/28 Called DC. No restrictions, order through Edit (whatever that means).
Does anyone have a 4x4 Quad on order? Is it delayed? Whats the order/build process through DC?
BTW, my order was for:
4.7 engine with auto transmission
quad cab
part time 4x4
limited slip
3.55 ratio
other options which shouldn't affect delivery
Bookitty
I'll be driving in central Pennsylvania with some snow and mud, what is your advice? Should I go with Tire and Handling Package (I want the sway bar and wheel flares) and sell off the 15x8 wheels and the 31x10.5R15 tires replacing them with a narrower wheels and tires? Or should I stick with the 15x8's and after the Goodyears wear out, replace them with a narrower tire that still fits the Dodge 8" rims?
Talked to Ernie today and I still have time to make changes through the dealer.
You might consider them seperatly. There are very nice Anti-sway bars available for the Dakota. I have read somwhere in these forums about somone buying Dodge Wheel-flares and installing themselves. It sounded like a pretty easy intall.
(All holes exist for plastic screws)
Another consideration with the 31x10.5R15's is that replacing them with like tires will be more expensive than the other options.
Think very seriously about opting-out of the "handling package" you get a lot for the money. (But MOST of it is for LOOKS... wheels, tires, flares.)
I guess I am just trying to cover all of your options as you make your decesion.
BTW...Who is "Ernie"?? I have seen his name here before but still do not know who he is.
Bookitty
I don't have a problem with the Do-It-Yourself sway bar and flares. In the "old days" when I had more time, I (had to do) did 5 clutches on Volvo wagons and for fun installed beefer f/r sway bars, 2" shorter springs, urethane bushings around, and gas shocks/struts. Volvos kept me broke during the years Detroit was producing "rust buckets" like the Vega and Pinto.
Ernie noted that there weren't any restrictions holding things up but its a dealer/district allocation issue at the moment. snowedin is right about being "locked" when you go D-1 status.
I believe Ernie likes his job and likes helping people. You can sense that and he comes across as sincere and in turn is a real asset to DC. But like the rest of us, give him a million bucks and he might be doing something else for the rest of his life. No fault in that.
I have driven through around 4-5" on snow and probably up to around 13-14" off road. I have a stick shift 4.7 4x4 with the 3.92 rear end and limited slip.
I have not experiences any problems on road in the truck whatsoever - the vehicle has felt stable and I have been able to turn and brake confidently. That said I know that I have not pushed the truck to its limits. I suspect that with the 3.55 rear end it may be a little sluggish on starting if it is going through fresh, heavy wet snow. Haven't had much 'dry' snow this year.
Off road the truck has been a little more hard work, but then the snow was deep. I suspect that I made matters worse for myself by not putting any extra weight over the rear axle. There was a tendency to turn sluggishlyand follow the slope, i.e. the rear end would slide down hills a little. I always felt that I was in control - even if the truck was not responding immediately - hell it was a foot of snow. I never stopped until I got through because I wasn't sure at the time how deep it was.
In my case I feel that the larger tires advantages outweighed the disadvantages - indeed that is why I bought them in the first place.
I know what your thinking, why am I getting 2wd. Well I've driven 2wd in snow for more years than I will admit, and I've never needed 4wd for the ROAD. I don't drive off road like Andy, so what do I need 4wd for. Don't say re-sale value, because there won't be anything left of this truck when I'm done with it. You should see what I'm driving now.
I go by word of mouth, and most people I know who have a Dak love it.
As far as consumer reports goes, take their findings with a grain of salt. I've had two cars that they rated as "less than average." Didn't have ANY trouble with either car.
They seems to always rate foreign cars and trucks higher than American ones too. The Tundra is brand new and its reliabilty prediction is good...
The way I look at it is this: dollar for dollar the Dakota is a helluva truck, its even got more leg room than the "full-size" Tundra if memory serves. It rides nice and looks great. Plus you can get a stick with a V8 which is getting rare in the market these days. Life's too short to sweat the small stuff, if you like it, buy it!
Stepping off the soap box...
--TI
I picked up a brochure on their LT Tires and found that there are some options. Although I've never gotten what I call good tread life out of any Goodyear, their little brochure has about 13 sizes that fit the Tire and Handling package 15x8 rims and are in the 1900+ pound load range. All 13 have tread widths of 7" +/- and are in a 1.5" range.
My concern of limited traction in bad weather with 31x10.5R15's can be remedied by eventually changing the tread design and the moderate operation of the gas pedal. It doesn't seem that the 1.5" difference between a P235/75R15 and a 31x10.5R15 can be as big an impact as I once thought.
If the Goodyears hold true to form, they'll be close to done at 20,000 miles. At that point I'll start looking at Yokohoma Geolander AT's or anything in the On/Off Highway category. Any suggestions?
The downside is the noise. The aggressive tread really sings, especially on the freeway. My wife refused to put them on her Suburban, so on hers we went with another great tire - the Michelin LTX M/S. Highway friendly (less noise), and a much more subdued, dare I say refined, look. The snow traction and tread life are also excellent.
Stay away from BFG Long Trails. Lousy traction, poor tread life - your typical OEM type tire.
Tirerack.com has a great site for researching tires. Customer survey ratings, complete specs. Great site.
Both of my friends are 6' and 6'3 and were quite impressed with rear seat room of the Quad Cab.
it tows my bike trailer like its not even there.
One of them is now seriously considering a Quad Cab for himself! I have a 4x2 Sport 4.7L automatic
and am very satisfied so far.
Some responses here have prompted me to think that there is a way to change the order before it gets to a certain coding, others have implied that you are locked in as soon as you walk out the door. Any comments are welcome. Thanks.
--TI
I would like to thank all of you on this board for your thoughts. It made ordering my Quad so much easier. Now, I have to figure out how to squirrel away the extra bucks from the bride to get my bedliner, fender flares, etc..! I ordered on 2/11 and checked today, it's in D1 status and is SUSPOSED to roll off the line 3/9.
Jim Buckingham
I hooked up the green/black wire to the two pin, kit supplied connector that goes on the headlight switch. I also spliced in the blue/black wire to the 14 pin headlight switch on pin #7 just as the instructions said to. All the other lights on the truck work, but not the fog lights or the fog light indicator on the headlight switch.
Any ideas.......hey Bookity......are you out there with an answer to this problem???
'Nough of that, can't wait for quad to arrive. Should be end of the month. :=)
KnK
Bookitty
Any other solutions out there?
Order for Dakota Club Cab 4x4 w/ 4.7L V8, auto placed on December 23. On restriction until February 7. Built and finished (KZ status) by the end of February. Now its sitting at a railyard while Chrysler conducts "quality checks" on it. Ernie at DC tells me there are other vehicles there in the same situation, so this might be holding other orders up as well. He said it will ship no later than 20th of March, which puts it here in Connecticut on the 28th hopefully. There's no way I would have custom-ordered a truck if I knew it was going to take over three months to arrive. So much for "6-8 weeks". I better get a free bedliner out of this...
As Bootkitty asked... please drive carefully around all carriers with Quads on them.
My order was placed on 2/3 shipping on 3/6 (2wd).
Good Luck everyone.
Again, I will check the ground and voltage on the other side of the relay. If the relay is normally closed as it states in the instructions, then I should have power somewhere on the other side of that relay. If not, the relay is stuck open and the lights are never going to work!
Just a note to those wishing to add fog lights.....get Dodge's kit. It cost me $115. If I hadn't had the problem with the ground, my lights wouldv'e been installed in less than 1.5 hours. You get lights, wiring harness, relay, fuse holder, and an original switch to go in the dash.
A word of wisdom for those taking this path...you will be supplied with a 2 wire connector that goes on the back of the switch. Don't use it. Instead, use the old 2 wire connector, remove the green/black wire from it and insert the new green/black wire that runs from your new fog lights. You will be assured that you have a good ground to start with. (This connector would have gone to factory installed fog lights). The instructions tell you how to remove the wires. Good Luck!
