2000 Chevy Silverado Vibration - II
As for the steel vs. alum. wheels, I've heard of more problems with the steel wheels than the alum. Personally, I had problems with the steel wheels (warped) that caused my vibration.
Good luck
Seems like anything 3/4 full in the cup splashes out when motoring down the road.
Any comments?
John
Ovalley: In your post 157, you asked if I intended to say "balanced off the truck", and the answer is yes. From a theoretical perspective, I assume that balancing on the truck takes into account hubs, rotors, etc. My experience with this is a mixed bag, and the more I know about wheel and tire balancing (which is not much), the more I am convenienced that the operator of whatever balancing equipment is used is the key. I mentioned in an earlier post that a local Firestone dealer went through 13 tires (including the OEM set) and 6 GM wheels, and the vibration problem was worse than when they started. Whether or not the Michelin dealer could have solved the problem (as they did with the Michelin tires) with the Firestone tires is problematical.
I've noticed the steering wheel picks up every bump or blemish in the road. The feel goes through out the truck thus causing a rough ride or vibration. If it is a steering sensitivity problem, would the vibration be in the passenger seat? It seems like it would be in the steering wheel only. On the other hand, if it's a frame problem, the vibration would be felt all over, right?
Since I bought this truck, I've test drove numerous other new trucks and all but one had a steering wheel jerk. What's the deal with the steering wheel sensitivity? Remember the guy who posted the information on the steering system (re-routing vacuum tubes, etc.), maybe he's right.
Just my observation......John
I've read on this board and others...that the driveline growl will not be corrected on all trucks with the PCM update. In fact, for some including myself...it actually got worse.
Randy
I don't think Chevrolet drove this truck on Hyw 99 and I-5. The kickback in the steering wheel reminded me of my Ford Pinto from my college days, and the constant motion from the rear end made the trip a very busy affair. Lowered air pressure to 32 front 30 rear. Seemed to help. Will be switching to 245/70HR16 Bridgestone HP soon.
Someone else suggested Bilsteins too, Obyone , ride is not quite as stiff over small bumps I'm told. I liked the KYB's on my old truck. I'll see if my long time mech, a dealership foreman, can get me shocks under warranty. I'm gonna pick his brain.
3 days 1100 miles. I hope I can get the vibration fixed fast.
I haven't had time to stop by the dealer yet. Need my oil changed in the next week or so, will probably have them look at rear leaf springs then, maybe I'll look at the drive shaft too. I have not noticed any drive shutter until I loaded about 1400 lbs in the truck. Later.
I'm picking up my truck today and will park side by side so service writer can see how easy the doors close compared to mine. I'll also double check drive shafts.
My 00 model was made 7/99 in Canada as well. I'll check the size of each piece (drive shaft) tomor.
Thanks.... John
He said none of the trucks that he has pick up since XMAS do not have the vibration problem. So GM must have figured out the problem and fixed it on the assembly line. I ask him to speak to a mechanic who just came back from a special school, and he was told that GM it aware of the problem and is working on a fix. The problem is due to the A-Frame and Suspension. Again if that is the problem that should have bee identified during testing and design analysis phase. Other than the vibration problem I love the truck. But that vibration problem is a substantial problem. My advise if you are planning to buy a 1500 series is make sure it was made after December 1999 and test drive it down a smooth interest or highway up to 75 mph for a few mile holding at constant speeds between 55 to 75.
mine was built jan 99 fort wayne and has the launch shutter problem.
I have none of the launch shutter that is mentioned here, nor any other of the weird noises.
Some of you will remember that I did a lot of research on the date codes of the G.Y. tires. Mine are 45th week of 1999. The ones they took off were 40th week.
Overall this is the best truck I've ever had and hope it continues.
For those of you with the problems ....keep at them...they'll sort it out. Call Chevy and the dealer every day!!
R
R
Not happy at this point. Wish we would have checked before buying.
Dealer still has my truck...been exactly one week and I'm starting to forget why it was in there in the first place...I'm starting to like the rental better that my own...except of course for the 4.8 and this awful meadow green metallic...
When purchashing a new or used vehicle, a odometer affidavit has to be signed by the buyer and seller. When you bought your truck the odometer affidavit should have had the current miles (new or used).
Another point: if you less than 200 miles on the truck, you made be able to return as well.
Something sounds very suspicious..
John
Truck now has 1200 miles on it.
I recently drove a 2000 Mitsubishi Mirage compact from Alamo Rental, and it had an amazingly good ride, far better than Tundra. The moral of the story...trucks are for hauling.
I LOVE MY SILVERADO,...have a nice day....
Roger.
I got the 4-door LS in early April. I am very sad to say that it has all the problems of the 3-door models and maybe more. With 1000 miles, the dealer says that 3 out of 4 of the Goodyear Wrangler ST tires on the 4-door model are out of round. Also, they suspect that the cruise control module is defective(knocking noise at low speeds). My truck spent last week in the shop and I'm sure it will be there next week, too. (Still waiting on them to come up with three new tires and to diagnose the rest of the problems.)
Warning: Heed what you read here. I read it all and thought "this won't happen to me".
The Silverado is very intoxicating. The best looking and best appointed truck on the road.
However, just read Consumer Reports. They tell it like it is. These trucks are totally unreliable and will give you nothing but heartache and headaches. They are at the absolute bottom of the ratings on reliability.
I convinced myself that the problems with the first vehicle were a statistical oddity and that there was no way it would happen again. Well, I'm now convinced that it definitely wasn't a statistical oddity. All the complaints on this site are very valid.
These are very bad vehicles and they turn what should be a happy experience into a nightmare.
Have a nice day,.....
Roger.
Hang in there, you will get it fixed or replaced.
Other than the bounce, Truck is a GEM. Mileage is now near 20 MPG, and ride is QUIET. Once the bounce is gone, I'm set. And I agree, it's the best looking Truck on the road today, bar none. I hope those with problems can get them fixed, and don't take "NO" for an answer. At the prices we are paying, we DESERVE to have the trucks right.
Remember, all truck manufacturers have some problems with their vehicles...it's inevitable. Those who get a "CHERRY" off the line are fortunate, but not an exception to the rule. Some vehicles can't be fixed I guess, but I bet 99.5% of the problem vehicles can. I'll keep trying if I'm not happy...If the 'bounce' is fixed with springs and coils, then I'll be happy. If not, then I'll keep trying.
I am disappointed that Chevy decided to put American General tires on my vehicle however.(255/75R16s).. I may look to see what kind of trade in upgrade I can get at some tire manufacturer...do they do that? Dealer won't change tires since they seemed to balance properly(?).
