2000 Chevy Silverado Vibration - II
I picked up a '00 Silverado LS, 3 dr, Z71,short bed, 4.10, w/locker in late December. After a couple of careful test drives I decided on this one. The first thing I did was take off the stock Firestone Steeltex A/T 245 tires and put on a set of BF Goodrich A/T 265's. I've got over 5000 miles so far with no hint of vibration and/or launch shudder. Knock-on-wood!
B4 I bought the truck the I discussed these problems w/ the Dealer, and he unofficially stated that there may have been a couple of '99's that were affected.
I hope that everyone that has had these problems gets them resolved.
Any suggestions on what exactly I should tell them to look for
While I have had NO problems with my 2000 LS 2500 2wd Ext. Cab Shortbox 5.3, this is VERY useful info for those getting the run around.
Thanks for posting it.
Ray T.
Cheers, Al
Ford hell no, Toyota-not a chance. Dodge only if they would stay together longer.
Any help is appreciated.
One thing is for sure, a long test drive at all speeds should help. Did any of you guys notice vibration when you test drove them? Does GMC have they same problems?
Obyone: Thanks!
I really don't know what the best advice is here, but the sheer amount of 2K Silverado's and Sierra's I have seen lately let me think that the situation is not that wide spread. Plus, you can go into the dealer and use it as a negotiating tactic.
I have read this topic, and the similar ones before it, quite extensively and I really feel for those who are suffering through it.
Keith
My question is for anyone who has this problem, what should I be looking for???
rcoos.
In trying to fix it by replacing the tires and wheels myself (it still shook), I had the originals spin balanced one more time before putting them back on. (WOW)it took most of the vibration out!!! It still shakes just a little between 60-65 mph. Now, we can either make GM replace these bad designed trucks or just get a wheel man that is good with a spin balance machine.
Oh, and I'll give FORD a chance at my next business!
Hauled my John Deere riding lawn mower in the rear of my truck today and noticed a steering wheel shake/jerk. It felt like it was detecting every bump in the road...very sensitive. The steering wheel had a slight jerk/shake/shimmy.
Got a feeling this has something to do with the drive shaft and/or launch shutter problem I'm still having. Or maybe the springs......
00 ext. cab. 2wd...... any suggestions?
P.S. rides OK without load.
John
try adding air to the rear tires whenever you have weight in the back. also maybe it's time to balance and rotate your tires-- should be done every 15,000 miles anyway. and rotate should be every 7500 miles.
Still think I have an out of round tire though. Last time I took it in they indexed and rebalanced them. On one side they rotated front to back. Now the slight vibration is in the back and not front. I only know they switched because they had marked all four tires the last time I was in. Most of the problem I am facing now is the aftershock thing. On a smooth road it is fairly smooth, but on a wavy road it seems to exagerate the aftershock shaking. I really hope your fix works for me too.
Is it an out of round tire or a warped rim? When the dealer rebalanced the tires did they all balance to 0.0? Did any of them have excessive weights?
2. Get a copy of your state's Lemon Law (the whole copy).... follow its guidelines if BBB can't help.
3. Read all of the post on this topic, if you haven't already.
Good luck
John
rcoos
rcoos
and they said they would order new rear quarter
windows, apparently they new they had a problem with them to start with. They didn't really give me an answer what the problem was
1- Wind noise while driving at highway speeds
2- Defective latches that don't latch
Started in '99 and carried over into '00 models. Speaking of which my replacements were to have arrived this past Tuesday. Damn Chevy dealers you gotta keep calling them or you'll never get anything done. Next thing you'll know they will use my parts on someone else's truck "by mistake"
They had contracted this job out to a glass company. The frame and latches were just too weak to hold against any amount of wind. The glass and frame had to be replaced. Was stated that they all needed this.
Note: I ended up in a rental, because while the windows were setting, the truck could not undergo any body flex for some 6-8 hours.
Still in and out for:
Rough Idle (?), Launch Shudder(So far reflashed the PCM-mild help), Steering Clunk(ordered spring insulators), After Shocks(ordered front shocks),Wind Noise @ windshield and pass. door(still waiting) and an uneven brake squeel(Expecting a rotor resurface).
STILL A GREAT TRUCK!! at 18K miles ~ 4.8 motor
If you're looking for perfection, do a frame off restoration of a classic, for around the same price.
Ray T.
driveability & you can apply the law to this.-----------------------------
My daughter just tried to use the lemon law on her windstar (ford..shudder), in NY, and it was a $400 application fee, and the mileage buyout would make her take a licking. She traded it in instead, and made out better. Now someone else gets to own it.
Ray T.
I'm going to buy Bridgestone Dueler A/T's with Uni-T construction. This means the rim bead reinforcing cable is without a splice, and should help out roundness.
Of course, I was lucky enough to get 4 "perfect" oem tires, Firestone (owned by Bridgestone) Wilderness A/T's. With 25,000 miles, still going well. Rotated twice, never re-balanced. Run 30 psi front/back. Look like they can go 50,000.
Still got a slight vibration at 65. Not even sure where from but seems like might be the engine. Changed plugs and wires but still seems like vibration from engine like one cylinder not firing correctly. Oh well just gotta take the tech out again for a joyride when picking up truck tomorrow after rear quarter windows replaced.
jed1894
I had played a round of golf with two old friends who each owns a service station and used to race 7 sec pro stock type car. I asked them about pinion angle causing vibration. Both of them told me that the best way to set the pinion angle is to mark the angle with the truck loaded with max weight and with no weight and split the difference. Hmm...I guess I'll ask the dealer service manager about that one.
I believe I read somewhere that a guy had a s-10 with two piece driveshaft and he replaced it with a one piece unit to fix launch shutter.
I looked under my truck and it looks like it would work........ what you think?
John
Don't harp on these guys the problems are REAL! Be glad you don't have them.
Ray T.
rcoos
Just be glad you don't have the vibe problem...yet. Mine started at about 3000 miles. I have the Firestone 265's on my Denali though not WOL...these tires sure have an ugly profile. Michelin LTX M/S looks way better. Sometimes you have to wonder about GM placing Firestone's on a $45K SUV. Well I guess it's the same as General tires on a $30K truck.
Ray T.
BTW, on the steering clunk wasn't there a TSB or actually a recall to retorque the steering gear to frame bolts NHTSA item no. SB602764?
Quads answer makes sense 4wd as opposed to 2wd driveshaft length difference.
Ray T.
HOW you say it is another matter! Posts are scribbled for language - profanity, real or redactive (characters instead of letters); for being off topic, or for violating Edmunds requirement for civil discourse.
This is a family oriented site. While I recognize that children will hear worse language on the playground or in the hallways than they would here, I will still delete anything that I feel might trigger "Net Nanny," "Surf Watch," or similar programs.
In the final analysis, it is a judgement call, and this is NOT Burger King! I allow more leeway in Pickups than I would in SUV's or Aftermarket and Accessories , all three of which are mine to watch.
Front Porch Philosopher
You can say something is a pain to do but DON'T use the "a" word.
As I said prior to scribble working on the split driveshafts & changing carrier bearings/universal joints IS NOT FUN.................... hope this will sufice!
Ray T.
