Chrysler 300: Problems & Solutions
Was taking it to the dealer (less than 1 mile from home) with no fuel warning light on...and vehicle just died. Thought I had damaged the oil pan by bottoming out in my driveway. (Oil light came on and read Zero). I'd also had a "OBD" light on from the day of purchase.
Dealership towed it and told me that I had run out of gasoline.
Later in the week, I was driving the vehicle on the highway, with 1/4 tank showing. The vehicle again ran out of gas.
I was informed that the 300C has a "saddlebag" design for its fuel tank. It pumps fuel from one side to the other and then to the engine. Thus the sensors in the tank could read fuel, but the fuel might not get to the engine.
They replaced both fuel pumps and sensors. Needless to say, I am leery about getting down to a quarter tank or less.
Might this be part of the problem people have with the vehicle "cutting out"? Perhaps the fuel pump is not doing a good job?
I haven't had any other problems or idling issues.
I also hope that running out of gas in the 300C hasn't caused other damage to the engine? I had a fuel injected VW Sciracco that my wife ran out of gas, and it never ran the same again.
Has anyone had the dealer replace pitted wheels with brand new ones?
To get ODBII Codes, go to:
http://autorepair.about.com/cs/troubleshooting/l/bl_obd_14.htm
Last week they said it was maping sensor was full of oil , they cleaned that I guess .car still shakes ,acts like wants to stall, gas guage jumps,rear end shakes now ,still a pain in the butt.
I'm filing the lemon law , got the card sent out today :lemon: :lemon: :lemon: :lemon:
anyone else having the same problems still?????
after the sixth time to the dealer and the car was only 4 months old, we told them this is not exceptable to us, we spoke with a Chrysler rep as well.. he told us that the shaking or wanting to stall at an idle is due the emissions settings, and this is regulated by the goverment( he told us that all car manufactures have to comply with this law) however he did admit that ALL car manufactures have their own quirks, and this is Chryslers) .. If this had done it on the test drive, we would NOT be driving a Chrysler today...
we are resolved to drive it while we still have a warranty and we WONT be buying anymore Chrysler products.. and this was our first and last purchase..
Different rim problem here.. I bought a 300 Touring Sig Series on Saturday and had the dealer put 20"rims on it. After leaving, I realized I was getting the tire pressure light. Took it back to them and they said that the rims that THEY put on do not have the sensors on them that the computer is searching for and thus aren't sure what to do about the problem. Don't they think these things out?
Tom
Please post your results with the lemon law people. I have a 2005 Chrysler 300 Touring model that is having the same issues that you and others are reporting with the shaking, shutterng, loss of power, etc. I have had mine in the dealer 3 times so far and they are not able to figure it out at all. They have turned the valves and cleaned te engine and things of that nature but nothing has fixed the problem.
I look forward to finding out your success incase I have to follow the same path down the road.
Chrysler has determined it is a software problem and that they are working to resolve the issue, not sure how long it will take. I knwo how you feel.
but I will say this much, the dealership where we bought the car bent over back wards to try and fix it.. they are just in the dark about this as well..
so my conclusion is this, Chrysler Corporation has a defective ongoing problem with the fluttering and shaking.. this shouldn't happen in a new car.. they dont know how to resolve it completely.. and so once our warranty is done( 5 Yrs) or if we can no longer put up with this, we will not be driving any more chryslers for this family...
this is to bad, cause the 300 looks beautiful!
Well the Chrysler dealer called this morning with an update on my 2005 Chrysler 300 Touring Edition. This is the third time in the shop for this vehicle which is having all of the same symptoms as everyone else on here.
The first time it was in the shop they basically just ran some cleaner through the engine and that was it.
The second time it was in the shop they took the engine apart and cleaned it out again and turned all of the valves, etc.
The third time (today) they are going to be taking the engine apart again and cleaning it but they will also be replacing the cylinder heads and valves in the engine. So they are basically taking it one step further each time. They advised me that this is the order that the Chrysler service people told them that they must take until the issue is solved.
I will keep everyone posted as what comes next because after seeing what everyone else has been through I am not to confident that this is going to solve the problem.
Well I got the trusty 300 back from the shop on Saturday. They put in a new cylinder, valves and all the parts that go along wtih that. So far the car is running smooth but when they fixed it before it ran fine for about two weeks prior to giving me issues again.
The dealer told me that they are following the chain of command for that issue and repairing it as they are told. The did however acknowledge that they are having a problem with the Chrysler 300's and that shaking problem. However, they said that right now all they have is theories on what is wrong and not a final solution from DCX.
I'll let you know if it has to go back for a 4th time.
It has a new problem now when I go to stop or am slowing down I get this feeling at my feet of some sort of something knocking or hitting just under my feet, It had never done this before now I'm getting concerned is my bottom going to fall apart now? sometimes it's a hard knock like I hit something in the road and it poped up and hit my undercarriage but i've hit nothing when this happens. and the it feels like it drags when going, I will be going a speed and feels like breaks are being applied kinda feeling it just brief slow down motion . This is really weird . I'll be so glad to get this car outa my driveway , I'm gona get a :lemon: sticker to put on my back window of this car to let others know , and if they ask I'll gladly tell .
This dealership in Winter Haven has also given another lady problems by not standing by their product , she had transmission problems in a Magnum 2005 she fussed with them a year still no luck she lost money when she traded it in with another company . her's would pop out of gear when she was driving it , she only had 500 some miles on it.
I'm looking at Toyota and others . I'd like to stay american but heck if the americans can't take pride in something that carries our loved ones around ,why should I buy? If anyone out thier knows of a good american car please tell me.
looking at the 300. Am leery about having problems.
Had 2002 Toyota Camry, :lemon: THE BRAKES WENT OUT (1100 miles)& TOYOTA WOULD DO NOTHING!! Have a file 2 inches thick of correspondence. Needed car for interstate driving & ended up "eating" $$$$$$$ thousands for Concorde. At least Chrysler isn't ignoring you
Had a 2000 Intrepid R/T - great for about 3 years, and then it started to fall apart. I swore off Chrysler after that point - stylish vehicles, but they don't last. (Before someoen tells me about their 300,000 mile Chrysler, I've had siblings with similar experiences who both swore off Chrysler as well, so I'm happy for you, but it won't change my mind.)
My thought is to contact Chrysler to let them know but I thought I would put it here for the vast amount of knowledge that is here for someone explain why they may not have "worked".
Off to report to NHSTA.
What did you do to kick off your "lemon-law" process?
Thanks for the help in advance.
Teesh
Ps: when we started talking lemon with the service manager, he told me that we HAVE to give them an opportunity to fix the problem since the car has a warranty... I asked him , okay, what are you going to do different that the last 5 visits weren't able to resolve? he knew then I had HIM in the corner and I wasn't going round 6 with them or the car... the Chrysler rep finally came to meet with us, he offered us a new car as well, however, since we had miles on the car, they take a depreciation for every thousand miles and only give you piddleys for the car you payed top dollar for.. I find when you sqwack the loudest, they either want to get rid of you, or try and resolve your issues.. GOOD LUCK
However, this noise is a humming sound and it occurs when the car is off. It seems to be coming from the area of the radio and temperature controls.
Does anyone have any idea about what is causing this? Thanks!
Just Kiddin.....Evil - From BOSTON!
it is a 2006 300C.
Well still in the 10 week process of the Magnuss and Moss law........got like 3-4 more weeks to go to find out if chrysler is gona buy it back or if I can get the pleasure of sticking a piece of dyniamite up the tail pipe ! :mad:
I see people on the road at a stop lite ahead of me with the same car and hey their shaking , I can see it ! I stop to talk to everyone that I see that ownes one of these lemons they all are not happy at all , it is really something that they haven't recalled this car after all the problems that this is causing.
They changed my maping sensor said it was reading like it was in the mountians and it didn't need as much rich gas mixture in thiner air so causing it to stall , ha ha ha thier was a oil build up on the sensor um hello? any one in thier? dosen't this mean a possiable oil leak somewhere? this is the 2nd time they changed it within 2 months for same problem , car still is shaking at stops and seems like it wants to stall out , they fixed the problem for mabye 2 hours ? anyway really sucks totaly disiapointed , such a nice car , with so many stupid problems. I know before I do any car shopping again i'm gona check this site for any gripes about a car or truck before I'm stuck in an agreement. ........ha ha hey did ya'll see on tv that add that chrysler has out now ???? try it for 30 days and if you don't like it return it? i'm really thinking on bring back my car and telling them hey i've complained about this before 30 days after having this lemon , it should still apply? i'm gona try anyway .........wish me luck , they probley wont honer it like every thing else.
I will not recomend or buy again from Winter Haven Dodge of Florida in polk county !!! :lemon: :lemon: :lemon:
I'm going toyota next.
to everyone out thier that has problems with thier lemon the best of luck to ya ! and ask about the Magnoss and Moss ! from your lawyer ! it's quicker then the lemon law. and less hastle.
I am sadly disappointed in the car... even thought the car looks great,and has many luxury features, the issues i have are not acceptable in a new car..
Honestly, I will not buy another Mopar product... hope this helps in your decision process..
I own a 300 Limited. I have never had any problems with the car except for discolored chrome rims which Chrysler took care of. The car drives excellent and for the size the fuel consumption is great. This is also my 3rd Chrysler product. I have owned 7 General Motors products and have too many problems to mention with all of them.
Blackbrute
